RetroArch system bios help
Where do you put a System bios in RetroArch 1.2.2 it says "System" directory, No matter where I put my bios file I just keep getting the same generic message about this system needing the bios, the error message is coming from Hyperspin I have the bio working outside of Hyperspin.
There is a folder in retroarch called "system" place all the bios there... Second: important as well... Config file (cfg) for that specific system u are trying to setup need to have its name as the hyperspin spells it... Exemple Sega CD.cfg - should be placed in retroarch/config folder :)
No need for bios for that.. Check retroarch module notes.. And u can see for which core u need their bios... I would suggest that u check out Austin's youtube video for retroarch and download his package in the desceiption. :)
I'm still getting the no bios found from Hyperspin got my Bios in "system" done and cfg labeled correctly any other ideas thanks for the help
Check this... Retroarch/config ... Open the core.cfg exempel sega cd.cfg and check if the path to the retroarch/system is there...
