ScummVM Problem
awaawaawa
Hi,
I have configured the ScummVM the official DB 1.3 (I found a thread of 1.7 but I did not found the file).
If I extract a game and I configure it in the ScummVM (with the single game selection) all works fine.
But I have the file in 7z and when I try to run the emulator with RL a windows open and close immediatly.
What I wrong??
Thanks in advance
Hi,
The paths need to be set in ScummVM.  With the files zipped, RL unzips them to the temp folder and then tries to run them from there.  Which is a different path than what you have setup in ScummVM.
I have a post somewhere with the DB and ini file posted.  Along with instructions on how to make it work zipped.  ;)
I'll see if I can dig them up.
Thanks,
Ron
  On 7/24/2015 at 2:46 PM, awaawaawa said:
Hi,
What I wrong??
Thanks in advance
Woot!  Here it is:
Instructions - http://www.hyperspin-fe.com/topic/5930-scummvm-17/?p=130798
And the ini is here (don't use the module in the  post): http://www.rlauncher.com/forum/showthread.php?504-ScummVM-changes-to-sleep&highlight=scummvm&p=5521#post5521
Thanks,
Ron
Hi,
What I wrong??
Thanks in advance
It still no working... :(
Here is the log:
21:31:04:153 | RL |     INFO  | +N/A   | Main - RocketLauncher v1.0.1.2 (www.rlauncher.com)
21:31:04:156 | RL |  WARNING  | +0     | Main - You have "Logging_Log_Command_Window" enabled. This is only for logging errors being dumped to the command window from an executable. This may cause issues with running some executables and needs to be turned off when you are done.
21:31:04:310 | RL |     INFO  | +156   | Main - System Specs:
RocketLauncher Dir: O:\RocketLauncher
RocketLauncher is: 32-bit
OS: Microsoft Windows 7 Ultimate
SKU: Ultimate
Total Memory: 8122.67 MB
Free Memory: 2333.59 MB
Used Memory: 5789.082 MB
SystemType: 64-bit
Physical Processors: 1
Logical Processors: 8
GPU 1 Name: NVIDIA GeForce GT 330M
GPU 1 RAM: 1024.00 MB
GPU 1 Driver Version: 9.18.13.4144
Sound 1 Device: NVIDIA High Definition Audio
Sound 1 Status: Enabled
Sound 2 Device: NVIDIA High Definition Audio
Sound 2 Status: Enabled
Sound 3 Device: NVIDIA Virtual Audio Device (Wave Extensible) (WDM)
Sound 3 Status: Enabled
Sound 4 Device: NVIDIA High Definition Audio
Sound 4 Status: Enabled
Sound 5 Device: Realtek High Definition Audio
Sound 5 Status: Enabled
Sound 6 Device: NVIDIA High Definition Audio
Sound 6 Status: Enabled
OS Language: Italian_Standard
OS Admin Status: Yes
Monitor #1 (\\.\DISPLAY1): 1366x768 (1366x728 work) [Landscape] (Primary)
Current AHK Desktop Width: 1366
Current AHK Desktop Height: 768
AutoHotkey Path:
AHK Version: 1.1.09.04
Unicode: No
21:31:04:314 | RL |     INFO  | +16    | CheckFile - Checking if O:\RocketLauncher\RocketLauncher.exe exists
21:31:04:316 | RL |     INFO  | +0     | CheckFile - Checking if O:\RocketLauncher\Module Extensions\BinHexRW.ahk exists
21:31:04:328 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
21:31:04:330 | RL |     INFO  | +15    | CheckFile - Checking if O:\RocketLauncher\Module Extensions\BlockInput.exe exists
21:31:04:332 | RL |     INFO  | +0     | CheckFile - Checking if O:\RocketLauncher\Module Extensions\CLR.ahk exists
21:31:04:339 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Extension.
21:31:04:341 | RL |     INFO  | +0     | CheckFile - Checking if O:\RocketLauncher\Module Extensions\COM.ahk exists
21:31:04:347 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Extension.
21:31:04:350 | RL |     INFO  | +0     | CheckFile - Checking if O:\RocketLauncher\Module Extensions\Control_AniGif.ahk exists
21:31:04:355 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Extension.
21:31:04:357 | RL |     INFO  | +0     | CheckFile - Checking if O:\RocketLauncher\Module Extensions\gdip.ahk exists
21:31:04:366 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Extension.
21:31:04:367 | RL |     INFO  | +0     | CheckFile - Checking if O:\RocketLauncher\Module Extensions\gdip_alt.ahk exists
21:31:04:373 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
21:31:04:376 | RL |   DEBUG1  | +15    | gdip_alt.ahk Version: 1.0.2
21:31:04:377 | RL |     INFO  | +0     | CheckFile - Checking if O:\RocketLauncher\Module Extensions\gsdll32.dll exists
21:31:04:380 | RL |     INFO  | +0     | CheckFile - Checking if O:\RocketLauncher\Module Extensions\itextsharp.dll exists
21:31:04:382 | RL |     INFO  | +0     | CheckFile - Checking if O:\RocketLauncher\Module Extensions\Java.ahk exists
21:31:04:390 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
21:31:04:393 | RL |   DEBUG1  | +16    | Java.ahk Version: 1.0.0
21:31:04:396 | RL |     INFO  | +0     | CheckFile - Checking if O:\RocketLauncher\Module Extensions\JSON.ahk exists
21:31:04:403 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Extension.
21:31:04:405 | RL |     INFO  | +0     | CheckFile - Checking if O:\RocketLauncher\Module Extensions\Origin.ahk exists
21:31:04:413 | RL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Library.
21:31:04:416 | RL |   DEBUG1  | +0     | Origin.ahk Version: 1.0.2
21:31:04:418 | RL |     INFO  | +0     | CheckFile - Checking if O:\RocketLauncher\Module Extensions\RegRW64.ahk exists
21:31:04:424 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Extension.
21:31:04:427 | RL |     INFO  | +0     | CheckFile - Checking if O:\RocketLauncher\Module Extensions\RIni.ahk exists
21:31:04:436 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Extension.
21:31:04:438 | RL |     INFO  | +16    | CheckFile - Checking if O:\RocketLauncher\Module Extensions\SevenZipSharp.dll exists
21:31:04:441 | RL |     INFO  | +0     | CheckFile - Checking if O:\RocketLauncher\Module Extensions\Steam.ahk exists
21:31:04:447 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
21:31:04:450 | RL |   DEBUG1  | +0     | Steam.ahk Version: 1.0.2
21:31:04:452 | RL |     INFO  | +0     | CheckFile - Checking if O:\RocketLauncher\Module Extensions\VA.ahk exists
21:31:04:459 | RL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Extension.
21:31:04:461 | RL |     INFO  | +0     | CheckFile - Checking if O:\RocketLauncher\Module Extensions\VA_Extension.ahk exists
21:31:04:468 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
21:31:04:472 | RL |   DEBUG1  | +16    | VA_Extension.ahk Version: 1.0.1
21:31:04:475 | RL |     INFO  | +0     | CheckFile - Checking if O:\RocketLauncher\Lib\7z.ahk exists
21:31:04:482 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
21:31:04:486 | RL |   DEBUG1  | +15    | 7z.ahk Version: 1.0.0
21:31:04:488 | RL |     INFO  | +0     | CheckFile - Checking if O:\RocketLauncher\Lib\Bezel.ahk exists
21:31:04:496 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
21:31:04:500 | RL |   DEBUG1  | +16    | Bezel.ahk Version: 1.1.2
21:31:04:502 | RL |     INFO  | +0     | CheckFile - Checking if O:\RocketLauncher\Lib\Fade.ahk exists
21:31:04:508 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
21:31:04:512 | RL |   DEBUG1  | +0     | Fade.ahk Version: 1.1.0
21:31:04:514 | RL |     INFO  | +0     | CheckFile - Checking if O:\RocketLauncher\Lib\Fade Init.ahk exists
21:31:04:520 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
21:31:04:523 | RL |   DEBUG1  | +0     | Fade Init.ahk Version: 1.0.1
21:31:04:526 | RL |     INFO  | +0     | CheckFile - Checking if O:\RocketLauncher\Lib\Fade Animations.ahk exists
21:31:04:534 | RL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Library.
21:31:04:536 | RL |   DEBUG1  | +0     | Fade Animations.ahk Version: 1.1.6
21:31:04:539 | RL |     INFO  | +0     | CheckFile - Checking if O:\RocketLauncher\Lib\Pause.ahk exists
21:31:04:558 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
21:31:04:562 | RL |   DEBUG1  | +0     | Pause.ahk Version: 1.1.3
21:31:04:564 | RL |     INFO  | +15    | CheckFile - Checking if O:\RocketLauncher\Lib\Pause Init.ahk exists
21:31:04:570 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
21:31:04:574 | RL |   DEBUG1  | +0     | Pause Init.ahk Version: 1.0.2
21:31:04:577 | RL |     INFO  | +0     | CheckFile - Checking if O:\RocketLauncher\Lib\Keymapper.ahk exists
21:31:04:584 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
21:31:04:587 | RL |   DEBUG1  | +0     | Keymapper.ahk Version: 1.1.2
21:31:04:589 | RL |     INFO  | +0     | CheckFile - Checking if O:\RocketLauncher\Lib\Keymapper Init.ahk exists
21:31:04:596 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
21:31:04:600 | RL |   DEBUG1  | +0     | Keymapper Init.ahk Version: 1.0.4
21:31:04:602 | RL |     INFO  | +0     | CheckFile - Checking if O:\RocketLauncher\Lib\MultiGame.ahk exists
21:31:04:609 | RL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Library.
21:31:04:613 | RL |   DEBUG1  | +0     | MultiGame.ahk Version: 1.0.7
21:31:04:615 | RL |     INFO  | +0     | CheckFile - Checking if O:\RocketLauncher\Lib\MultiGame Init.ahk exists
21:31:04:621 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
21:31:04:624 | RL |   DEBUG1  | +0     | MultiGame Init.ahk Version: 1.0.0
21:31:04:627 | RL |     INFO  | +16    | CheckFile - Checking if O:\RocketLauncher\Lib\MultiPlayer.ahk exists
21:31:04:635 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
21:31:04:639 | RL |   DEBUG1  | +0     | MultiPlayer.ahk Version: 1.0.6
21:31:04:642 | RL |     INFO  | +15    | CheckFile - Checking if O:\RocketLauncher\Lib\Password.ahk exists
21:31:04:649 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
21:31:04:652 | RL |   DEBUG1  | +0     | Password.ahk Version: 1.0.1
21:31:04:654 | RL |     INFO  | +0     | CheckFile - Checking if O:\RocketLauncher\Lib\Rom Mapping Launch Menu.ahk exists
21:31:04:661 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
21:31:04:664 | RL |   DEBUG1  | +0     | Rom Mapping Launch Menu.ahk Version: 1.0.5
21:31:04:666 | RL |     INFO  | +0     | CheckFile - Checking if O:\RocketLauncher\Lib\Shared.ahk exists
21:31:04:679 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
21:31:04:681 | RL |   DEBUG1  | +0     | Shared.ahk Version: 1.3.1
21:31:04:685 | RL |     INFO  | +0     | CheckFile - Checking if O:\RocketLauncher\Lib\Statistics.ahk exists
21:31:04:691 | RL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Library.
21:31:04:694 | RL |   DEBUG1  | +0     | Statistics.ahk Version: 1.0.3
21:31:04:697 | RL |     INFO  | +0     | CheckFile - Checking if O:\RocketLauncher\Lib\Statistics Init.ahk exists
21:31:04:703 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
21:31:04:707 | RL |   DEBUG1  | +0     | Statistics Init.ahk Version: 1.0.1
21:31:04:708 | RL |     INFO  | +0     | CheckFile - Checking if O:\RocketLauncher\Lib\Virtual Drive.ahk exists
21:31:04:715 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
21:31:04:719 | RL |   DEBUG1  | +15    | Virtual Drive.ahk Version: 1.0.0
21:31:04:722 | RL |     INFO  | +0     | CheckFile - Checking if O:\RocketLauncher\Lib\XHotkey.ahk exists
21:31:04:729 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
21:31:04:732 | RL |   DEBUG1  | +0     | XHotkey.ahk Version: 1.0.3
21:31:04:735 | RL |     INFO  | +16    | CheckFile - Checking if O:\RocketLauncher\Lib\XHotkey Init.ahk exists
21:31:04:741 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
21:31:04:744 | RL |   DEBUG1  | +0     | XHotkey Init.ahk Version: 1.0.0
21:31:04:747 | RL |   DEBUG1  | +0     | Main - Raw CLI received: "-s ScummVM -r zak-v2 -e ScummVM 1.7.0 -f O:\Hyperspin\HyperSpin.exe -p HyperSpin -c 1"
21:31:04:749 | RL |   DEBUG1  | +0     | Main - Received this dbName with no path via CLI: "zak-v2"
21:31:04:752 | RL |   DEBUG1  | +16    | Main - dbName: zak-v2
21:31:04:756 | RL |     INFO  | +0     | Main - zak-v2 is being forced via CLI to use the emulator: ScummVM 1.7.0
21:31:04:758 | RL |     INFO  | +0     | CheckFile - Checking if O:\RocketLauncher\Plugins\HyperSpin.plugin exists
21:31:04:761 | RL |     INFO  | +0     | Main - Loading Front End Plugin: "HyperSpin"
21:31:04:763 | RL |     INFO  | +0     | Main - RocketLauncher received "ScummVM" and "zak-v2"
21:31:04:774 | RL |     INFO  | +15    | Main - Did not find a "O:\RocketLauncher\Settings\ScummVM\Game Options.ini" file, skipping any game-specific options.
21:31:04:777 | RL |     INFO  | +0     | Main - Checking for a [scummVM 1.7.0] section in O:\RocketLauncher\Settings\ScummVM\Emulators.ini
21:31:04:781 | RL |     INFO  | +16    | Main - Found [scummVM 1.7.0] in O:\RocketLauncher\Settings\ScummVM\Emulators.ini
21:31:04:784 | RL |     INFO  | +0     | CheckFile - Checking if O:\RocketLauncher\Modules\ScummVM\ScummVM.ahk exists
21:31:04:790 | RL |     INFO  | +0     | Main - CRC Check - CRC matches, this is an official unedited module.
21:31:04:793 | RL |     INFO  | +0     | Main - zak-v2 will use module: O:\RocketLauncher\Modules\ScummVM\ScummVM.ahk
21:31:04:820 | RL |     INFO  | +31    | Main - Using SkipChecks method "Rom Only".
21:31:04:824 | RL |     INFO  | +0     | CheckFile - Checking if O:\_Emulators\ScummVM\scummvm.exe exists
21:31:04:828 | RL |     INFO  | +16    | Main - INI Keys read
21:31:04:830 | RL |     INFO  | +0     | CheckFile - Checking if O:\RocketLauncher\Module Extensions\7z.exe exists
21:31:04:833 | RL |     INFO  | +0     | CheckFile - Checking if O:\RocketLauncher\Module Extensions\7z.dll exists
21:31:04:841 | RL |     INFO  | +0     | Main - "zak-v2" does not qualify for MultiGame. Only roms with any of these strings in their name are acceptable: (Disc,(Disk,(Cart,(Tape,(Cassette,(Part,(Side
21:31:04:843 | RL |  WARNING  | +15    | Main - SkipChecks is enabled and set to: Rom Only
21:31:04:846 | RL |     INFO  | +0     | CheckPaths - Started
21:31:04:849 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom: O:\_Roms\ScummVM\zak-v2.7z
21:31:04:852 | RL |     INFO  | +0     | CheckPaths - Found rom: O:\_Roms\ScummVM\zak-v2.7z
21:31:04:854 | RL |   DEBUG1  | +0     | CheckPaths - Current romName: zak-v2
21:31:04:857 | RL |   DEBUG1  | +0     | CheckPaths - Current romPath: O:\_Roms\ScummVM
21:31:04:860 | RL |   DEBUG1  | +16    | CheckPaths - Current romExtension: .7z
21:31:04:862 | RL |     INFO  | +0     | CheckPaths - Ended
21:31:04:865 | RL |     INFO  | +0     | BuildScript - User Variables:
; INJECTED VARIABLES
#NoTrayIcon
#InstallKeybdHook
DetectHiddenWindows, ON
SetTitleMatchMode, 2
SendMode, Event
0 = 12
pluginPath = O:\RocketLauncher\Plugins
pluginName = HyperSpin
pluginExt = .plugin
contextOnExit = 1
rlMode =
rlTitle = RocketLauncher
rlVersion = 1.0.1.2
rlAuthor = djvj
rlURL = www.rlauncher.com
langFile = O:\RocketLauncher\Data\Language\Localization.ini
primMonitor = 1
frontendPID =
frontendPath = O:\Hyperspin
frontendExe = HyperSpin.exe
frontendExt = exe
frontendName = HyperSpin
frontendDrive = O:
exitEmulatorKey = ~Esc
exitEmulatorKeyWait = 0
forceHoldKey = ~Esc
restoreFE = false
exitScriptKey = ~q & ~s
toggleCursorKey = ~e & ~t
emuFullPath = O:\_Emulators\ScummVM\scummvm.exe
emuPath = O:\_Emulators\ScummVM
emuName = ScummVM 1.7.0
emuExt = exe
romPath = O:\_Roms\ScummVM
romPathFromIni = O:\_Roms\ScummVM
romExtension = .7z
romExtensionOrig = .7z
romExtensions = 7z
executable = scummvm.exe
systemDbName = ScummVM
systemName = ScummVM
dbPath =
dbName = zak-v2
dbExt =
romName = zak-v2
romMapPath =
romMappingEnabled = false
romMappingMenuWidth = 400
romMappingMenuMargin = 65
romMappingTextMargin = 15
romMappingMenuFlagWidth = 55
altArchiveNameOnly =
altRomNameOnly =
altArchiveAndRomName =
altArchiveAndManyRomNames =
altRomNamesOnly =
romMapScenario =
skipchecks = Rom Only
romMatchExt = false
blockInputTime = 0
blockInputFile = O:\RocketLauncher\Module Extensions\BlockInput.exe
errorLevelReporting = false
lockLaunch = false
lockLaunchGame =
screenRotationAngle = 0
screenRotationAngleGame =
logFile = O:\RocketLauncher\RocketLauncher.log
logLabel := ["    INFO"," WARNING","   ERROR","  DEBUG1","  DEBUG2"]
logLevel = 10
logShowDebugConsole = false
logIncludeModule = true
logIncludeFileProperties = false
logShowCommandWindow = false
logCommandWindow = true
rlDebugConsoleStdout =
sysLang = Italian_Standard
sysType = 64-bit
broadcastWindowTitle =
navUpKey = Up
navDownKey = Down
navLeftKey = Left
navRightKey = Right
navSelectKey = Enter
navP2UpKey = Numpad8
navP2DownKey = Numpad2
navP2LeftKey = Numpad4
navP2RightKey = Numpad6
navP2SelectKey = NumpadEnter
originalWidth = 1366
originalHeight = 768
vdEnabled = false
vdFullPath =
vdUseSCSI = true
vdDriveLetter =
vdAddDrive = true
servoStikEnabled = false
ledblinkyEnabled = false
ledblinkyFullPath =
ledblinkyProfilePath = O:\RocketLauncher\Profiles\LEDBlinky
ledblinkyRLProfile = O:\RocketLauncher\Profiles\LEDBlinky\RocketLauncher
emuIdleShutdown = 0
hideCursor = false
hideEmu = false
hideFE = false
fadeIn = false
fadeInDuration = 500
fadeInDelay = 0
fadeInExitDelay = 0
fadeOutExitDelay = 0
fadeOut = false
fadeOutExtraScreen = false
fadeOutDuration = 500
fadeOutDelay = 0
fadeLyrInterpolation = 0
fadeMuteEmulator = false
fadeUseBackgrounds = false
fadeWidthBaseRes = 1920
fadeHeightBaseRes = 1080
fadeLyr1Color = FF000000
fadeLyr2X = 0
fadeLyr2Y = 0
fadeLyr2W =
fadeLyr2H =
fadeLyr2Adjust = 1
fadeLyr2PicPad = 0
fadeLyr3Pos = Center
fadeLyr3X = 450
fadeLyr3Y = 450
fadeLyr3W =
fadeLyr3H =
fadeLyr3Adjust = 1
fadeLyr3PicPad = 0
fadeLyr3Speed = 750
fadeLyr3Type = imageandbar
fadeLyr3Repeat = 1
fadeLyr3StaticX = 0
fadeLyr3StaticY = 870|1575
fadeLyr3StaticW =
fadeLyr3StaticH =
fadeLyr3StaticAdjust = 1
fadeLyr3StaticPicPad = 0
fadeLyr4Adjust = 1
fadeLyr4X = 1792|952
fadeLyr4Y = 891|1596
fadeLyr4W = 128
fadeLyr4H =
fadeLyr4Pos = No Alignment
fadeLyr4FPS = 50
fadeLyr4PicPad = 0
fadeTranspGifColor = FFFFFF
fadeBarWindow = Image
fadeBarWindowX =
fadeBarWindowY =
fadeBarWindowW = 900
fadeBarWindowH =
fadeBarWindowR = 30
fadeBarWindowM = 30
fadeBarWindowHatchStyle = 8
fadeBar = 7zOnly
fadeBarNon7zProgressTime = 0
fadeBarBack = true
fadeBarBackColor = FF555555
fadeBarH = 30
fadeBarR = 10
fadeBarColor = DD00BFFF
fadeBarHatchStyle = 8
fadeBarPercentageText = true
fadeBarInfoText = true
fadeBarXOffset = 0
fadeBarYOffset = 150
fadeRomInfoSystemName = image
fadeRomInfoManufacturer = text with label
fadeRomInfoGenre = disabled
fadeRomInfoRating = image
fadeRomInfoTextMargin = 7
fadeStatsInfoTextMargin = 7
fadeText1X = 0
fadeText1Y = 0
fadeText1 = Loading Game
fadeText2X = 0
fadeText2Y = 0
fadeText3 = Loading Game
fadeText4 = Loading Complete
fadeFont = Bebas Neue
fadeExtractionTime = disabled
fadeExtractionTimeTextX = 0
fadeExtractionTimeTextY = 0
fadeInterruptKey =
detectFadeErrorEnabled = true
fadeImgPath = O:\RocketLauncher\Media\Fade
RLDataPath = O:\RocketLauncher\Data
RLMediaPath = O:\RocketLauncher\Media
RLErrSoundPath = O:\RocketLauncher\Media\Sounds\Error
modulesPath = O:\RocketLauncher\Modules
moduleFullName = O:\RocketLauncher\Modules\ScummVM\ScummVM.ahk
moduleName = ScummVM
modulePath = O:\RocketLauncher\Modules\ScummVM
moduleExtension = ahk
moduleExtensionsPath = O:\RocketLauncher\Module Extensions
libPath = O:\RocketLauncher\Lib
7zEnabled = true
7zPath = O:\RocketLauncher\Module Extensions\7z.exe
7zDllPath = O:\RocketLauncher\Module Extensions\7z.dll
7zExtractPath = C:\Users\ste\AppData\Local\Temp\HS
7zExtractPathOrig =
7zAttachSystemName = false
7zDelTemp = false
7zSounds = true
mgEnabled = false
mgKey = ~NumpadSub
mgBackgroundColor = FF000000
mgSidePadding = 0.2
mgWidthBaseRes = 1920
mgHeightBaseRes = 1080
mgYOffset = 500|800
mgFont = Arial
mgText2Offset = 100
mgUseSound = true
mgSoundfreq = 300
mgExitEffect = none
mgSelectedEffect = rotate
mgUseGameArt = false
mgCandidate =
mgOnLaunch = false
pauseEnabled = false
pauseKey = ~NumpadAdd
pauseBackToMenuBarKey = X
pauseZoomInKey = C
pauseZoomOutKey = V
pauseHiToTextPath = O:\RocketLauncher\Module Extensions\HiToText.exe
pauseSaveStateKeyCodes =
pauseLoadStateKeyCodes =
keymapperEnabled = false
keymapperAHKMethod = false
keymapper = joytokey
xpadderFullPath = O:\Utilities\Xpadder\xpadder.exe
joyToKeyFullPath = O:\RocketLauncher\Utility\JoyToKey\JoyToKey.exe
keymapperProfilePath = O:\RocketLauncher\Profiles\joytokey
keymapperFrontEndProfileName = RocketLauncherUI
keymapperFrontEndProfile = joytokey
joyIDsEnabled = false
joyIDsPreferredControllersGlobal =
joyIDsPreferredControllersSystem = use_global
joyIDsPreferredControllersOnExit =
CustomJoyNamesEnabled = false
CustomJoyNames =
rotateMethod = false
FEProfile = O:\RocketLauncher\Profiles\joytokey\RocketLauncherUI
defaultProfile = O:\RocketLauncher\Profiles\joytokey\_Default
systemProfile = O:\RocketLauncher\Profiles\joytokey\ScummVM
xPadderSystemProfile = O:\RocketLauncher\Profiles\joytokey\ScummVM\_Default
emuProfile = O:\RocketLauncher\Profiles\joytokey\ScummVM\ScummVM 1.7.0
romProfile = O:\RocketLauncher\Profiles\joytokey\ScummVM\zak-v2
RocketLauncherProfile = O:\RocketLauncher\Profiles\joytokey\RocketLauncher
blankProfile = O:\RocketLauncher\Profiles\joytokey\blank
ahkFEProfile = O:\RocketLauncher\Profiles\AHK\RocketLauncherUI
ahkDefaultProfile = O:\RocketLauncher\Profiles\AHK\_Default
ahkSystemProfile = O:\RocketLauncher\Profiles\AHK\ScummVM
ahkEmuProfile = O:\RocketLauncher\Profiles\AHK\ScummVM\ScummVM 1.7.0
ahkRomProfile = O:\RocketLauncher\Profiles\AHK\ScummVM\zak-v2
ahkRocketLauncherProfile = O:\RocketLauncher\Profiles\AHK\RocketLauncher
bezelEnabled = false
bezelICEnabled = false
statisticsEnabled = true
pressDuration = -1
emuVolume = 1
dxwndIni = O:\RocketLauncher\Module Extensions\dxwnd\dxwnd.ini
dxwndFullPath = O:\RocketLauncher\Module Extensions\dxwnd\dxwnd.exe
mon1O =
pacDrivedllFile = O:\RocketLauncher\Module Extensions\PacDrive32.dll
userFadeAnimIniFile = O:\RocketLauncher\Lib\User Fade Animations.ini
21:31:04:871 | RL |     INFO  | +0     | BuildScript - Loaded XHotkey Init.ahk scripts
21:31:04:875 | RL |     INFO  | +15    | BuildScript - Loaded Statistics Init.ahk scripts
21:31:04:878 | RL |  WARNING  | +0     | BuildScript - "O:\RocketLauncher\Lib\User Functions Init.ahk" not found
21:31:04:880 | RL |   DEBUG1  | +0     | BuildScript - Module starts on line: 2
21:31:04:882 | RL |     INFO  | +0     | BuildScript - Validating module
21:31:04:886 | RL |     INFO  | +0     | BuildScript - Validation complete
21:31:04:889 | RL |     INFO  | +0     | BuildScript - Module:
MEmu = ScummVM
MEmuV = v1.7.0
MAuthor = djvj,brolly
MVersion = 2.0.9
MCRC = 8DE09DA4
iCRC = C211523C
MID = 635038268922749586
MSystem = "ScummVM","Microsoft MS-DOS"
; Notes:
; If your games are compressed archives, set your Rom_Path to the folder with all your games and Rom_Extension to just the archive type.
; Set Skipchecks to "Rom Extension" for this system If your roms are compressed archives and also turn on 7z support.
; If your games are already uncompressed into their own folders, set Skipchecks to "Rom Only" so RocketLauncher knows not to look for rom files.
; You can set your Save/Load/Menu hotkeys below to access them in game.
; The hotkeys will be processed by xHotkey, so they can be defined just like you would your Exit_Emulator_Key (like with delays or multiple sets of keys)
; If you prefer a portable ScummVM, place your scummvm.ini somewhere Else, like in the emulator's folder and set CustomConfig's path to this file. It will work with the ini from there instead of your appdata folder.
; You can manually map your database rom names to archive files If you keep your games compressed and have the files named differently from your database by putting a file named ZipMapping.ini in the modules folder (or ZipMapping - SystemName.ini), this file contents should be as follows:
; [mapping]
; romName=zipFileName
; Launch Method 1 - Rom_Path has archived games inside a zip, 7z, rar, etc
; Set Skipchecks to Rom Extension and enable 7z
; Launch Method 2 - Rom_Path has each game inside its own folder and uncompressed
; Set Skipchecks to Rom Only and disable 7z
; Launch Method 3 - Rom_Path has archived games inside a zip, 7z, rar, etc, all named from the scummvm torrent that does not match the names on your xml
; Set Skipchecks to Rom Extension, enable 7z, enable Rom Mapping. Make sure a proper mapping ini exists in the appropriate settings Rom Mapping folder and it contains all the correct mapping info.
StartModule()
BezelGUI()
FadeInStart()
settingsFile := modulePath . "\" . (If FileExist(modulePath . "\" . systemName . ".ini") ? systemName : moduleName) . ".ini" ; use a custom systemName ini If it exists
scummDefaultConfigFile := A_AppData . "\ScummVM\scummvm.ini" ; ScummVM's default ini file it creates on first launch
customConfigFile := IniReadCheck(settingsFile, "Settings", "CustomConfig","",,1) ; Set the path to a custom config file and the module will use this instead of the ScummVM's default one
customConfigFile := GetFullName(customConfigFile) ; convert relative path to absolute
configFile := CheckFile(If customConfigFile ? customConfigFile : scummDefaultConfigFile) ; checks If either the default config file or the custom one exists
LaunchMode := IniReadCheck(settingsFile, "Settings|" . romName, "LaunchMode", "Auto",,1)
TargetName := IniReadCheck(settingsFile, romName, "TargetName", romName,,1)
ForceExtractionToRomPath := IniReadCheck(settingsFile, "Settings" . "|" . romName, "ForceExtractionToRomPath", "false",,1)
BezelDelay := IniReadCheck(settingsFile, "Settings|" . romName, "BezelDelay", "0",,1)
SaveKey := IniReadCheck(settingsFile, "Settings", "SaveKey","1",,1) ; hotkey to save state
LoadKey := IniReadCheck(settingsFile, "Settings", "LoadKey","2",,1) ; hotkey to load state
MenuKey := IniReadCheck(settingsFile, "Settings", "MenuKey","p",,1) ; hotkey to access the ScummVM menu
BezelStart()
If 7zEnabled != true
If romExtension in %7zFormats%
ScriptError("Your rom """ . romName . """ is a compressed archive`, but you have 7z support disabled. ScummVM does not support launching compressed roms directly. Enable 7z or extract your rom.",8)
;Find the zip filename by looking it up in the ZipMapping.ini file or ZipMapping - SystemName.ini If one exists
IfExist, % modulePath . "\ZipMapping - " . systemName ".ini"
ZipMappingFile := modulePath . "\ZipMapping - " . systemName ".ini"
Else
ZipMappingFile := modulePath . "\ZipMapping.ini"
ZipName := IniReadCheck(ZipMappingFile, "mapping", romname, romname . (If romExtension ? romExtension : ".zip"),,1)
If (LaunchMode = "eXoDOS") {
;Find and set the romPath in case we have several
romPathFound := "false"
If (7zEnabled = "true")
Loop, Parse, romPath, |
currentPath := A_LoopField
Log("Module - Searching for rom " . ZipName . " in " . currentPath,4)
If FileExist(currentPath . "\" . ZipName)
romPath := currentPath
romPathFound := "true"
If (romPathFound != "true")
ScriptError("Couldn't find rom " . ZipName . " in any of the defined rom paths")
} Else {
Log("Module - Searching for rom " . romname . " in " . currentPath,4)
If InStr(FileExist(currentPath . "\" . romname), "D")
ScriptError("Couldn't find rom " . romname . " in any of the defined rom paths")
If (ForceExtractionToRomPath = "true") {
Log("Module - ForceExtractionToRomPath is set to true, setting 7zExtractPath to " . romPath . ". Careful when using this setting!",4)
7zExtractPath := romPath
;Lets split filename and extension
SplitPath, ZipName,,,zipExtension,zipFileName
hideEmuObj := Object("ahk_class SDL_app",1) ; Hide_Emu will hide these windows. 0 = will never unhide, 1 = will unhide later
;7z(romPath, romName, romExtension, 7zExtractPath)
7z(romPath,zipFileName,"." . zipExtension,7zExtractPath,,If LaunchMode = "eXoDOS" ? "false" : "true")
; Send ScummVM hotkeys through xHotkey so they are linked to the labels below
SaveKey := xHotKeyVarEdit(SaveKey,"SaveKey","~","Add")
LoadKey := xHotKeyVarEdit(LoadKey,"LoadKey","~","Add")
MenuKey := xHotKeyVarEdit(MenuKey,"MenuKey","~","Add")
xHotKeywrapper(SaveKey,"ScummvmSave")
xHotKeywrapper(LoadKey,"ScummvmLoad")
xHotKeywrapper(MenuKey,"ScummvmMenu")
If (LaunchMode = "ParseIni")
{ Log("Module - Launch mode: ParseIni")
;Try parsing the scummvm config ini file for the path
StringReplace, romNameChanged, TargetName, %A_Space%, _, All ; replace all spaces in the name we lookup in ScummVM's ini because ScummVM does not support spaces in the section name
romNameChanged := RegExReplace(romNameChanged, "\(|\)", "_") ; replaces all parenthesis with underscores
If (TargetName != romNameChanged)
Log("Module - Removed all unsupported characters from """ . TargetName . """ and using this to search for a section in ScummVM's ini: """ . romNameChanged . """")
scummRomPath := IniReadCheck(configFile, romNameChanged, "path",,,1) ; Grab the path in ScummVM's config
; msgbox % scummRomPath
If (SubStr(scummRomPath, 0, 1) = "\") ; scummvm doesn't like sending it paths with a \ as the last character. If it exists, remove it.
StringTrimRight, scummRomPath, scummRomPath, 1
If !scummRomPath {
Log("Module - Could not locate a path in ScummVM's ini for section """ . romNameChanged . """. Checking If a path exists for the dbName instead: """ . dbName . """",2)
scummRomPath := IniReadCheck(configFile, dbName, "path",,,1) ; If the romName, after removing all unsupporting characters to meet ScummVM's section name requirements, could not be found, try looking up the dbName instead
If !FileExist(scummRomPath) ; If user does not have a path set to this game in the ScummVM ini or the path does not exist that is set, attempt to send a proper one in CLI
{ Log("Module - " . (If !scummRomPath ? "No path defined in ScummVM's ini" : ("The path defined in ScummVM's ini does not exist : " . scummRomPath)) . ". Attempting to find a correct path to your rom and sending that to ScummVM.",2)
If (InStr(romPath, romName) && FileExist(romPath)) { ; If the romName is already in the path of the romPath and that path exists, attempt to set that as the path we send to ScummVM
scummRomPath := romPath
Log("Module - Changing " . romName . " path to: " . scummRomPath,2)
} Else If (FileExist(romPath . "\" . romName)) { ; If the romPath doesn't have the romName in the path, let's add it to check If that exists and send that.
scummRomPath := romPath . "\" . romName
} Else
ScriptError("The path to """ . romName . """ was not found. Please set it correctly by manually launching ScummVM and editing this rom's path to where it can be found.")
} Else If (LaunchMode = "eXoDOS") {
Log("Module - Launch mode: eXoDOS")
;On eXoDOS sets game MUST be at this folder
scummRomPath := CheckFile(romPath . "\" . romName)
romNameChanged := TargetName
} Else {
Log("Module - Launch mode: Standard")
;Auto mode, scummRomPath will be empty here as everything will be read from the scummvm config ini file
options := " --no-console"
configFile := If customConfigFile ? " -c""" . configFile . """" : "" ; If user set a path to a custom config file
fullscreen := If Fullscreen = "true" ? " -f" : " -F"
scummRomPath := If scummRomPath ? " -p""" . scummRomPath . """" : ""
HideEmuStart()
Run(executable . options . fullscreen . configFile . scummRomPath . " " . romNameChanged, emuPath)
WinWait("ahk_class SDL_app")
WinWaitActive("ahk_class SDL_app")
Sleep, 700 ; Necessary otherwise the HyperSpin window flashes back into view
If bezelPath
Sleep, % bezelDelay
BezelDraw()
HideEmuEnd()
FadeInExit()
7zCleanUp(If LaunchMode = "eXoDOS" ? 7zExtractPath . "\" . romName : "")
BezelExit()
FadeOutExit()
ExitModule()
ScummvmSave:
Send, !1
Return
ScummvmLoad:
Send, ^1
Return
ScummvmMenu:
Send, ^{F5}
Return
CloseProcess:
FadeOutStart()
WinClose("ahk_class SDL_app")
Return
21:31:04:909 | RL |     INFO  | +32    | BuildScript - Loaded Multi-Player scripts
21:31:04:914 | RL |     INFO  | +0     | BuildScript - Loaded Statistics.ahk script
21:31:04:916 | RL |  WARNING  | +0     | BuildScript - "O:\RocketLauncher\Lib\User Functions.ahk" not found
21:31:04:919 | RL |     INFO  | +0     | BuildScript - Finished injecting functions into module
21:31:04:924 | RL |     INFO  | +15    | Main - Module is built
21:31:04:925 | RL |     INFO  | +0     | CheckFile - Checking if O:\RocketLauncher\AutoHotkey.dll exists
21:31:04:930 | RL |     INFO  | +0     | Main - Running module
21:31:04:931 | RL |     INFO  | +0     | Main - Starting timer to watch if Front End gets displaced and restore it if it does.
21:31:05:101 | MD |     INFO  | +N/A   | Module initialized
21:31:05:106 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~Esc" to call label: "CloseProcess"
21:31:05:138 | MD |     INFO  | +31    | StartModule - Started
21:31:05:155 | MD |     INFO  | +31    | StartModule - MEmu: ScummVM
MEmuV: v1.7.0
MAuthor: djvj,brolly
MVersion: 2.0.9
MCRC: 8DE09DA4
iCRC: C211523C
MID:
MSystem: "ScummVM","Microsoft MS-DOS"
21:31:05:158 | MD |     INFO  | +0     | StartModule - You have a supported System Name for this module: "ScummVM"
21:31:05:167 | MD |     INFO  | +0     | PluginInit - Started
21:31:05:170 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Started - Building Table for: Name|Cloneof|Manufacturer|Year|Genre|Rating
21:31:05:193 | MD |     INFO  | +31    | CheckFile - Checking if O:\Hyperspin\Databases\ScummVM\ScummVM.xml exists
21:31:05:199 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Searching for a "Game Name" in the database
21:31:05:223 | MD |   DEBUG1  | +32    | BuildDatabaseTable - Found "Game Name" in the database!
21:31:05:226 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Searching database for: Name
21:31:05:230 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Found "Name" with a value: "Zak McKracken and the Alien Mindbenders (Floppy DOS v2)"
21:31:05:232 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Searching database for: Cloneof
21:31:05:255 | MD |   DEBUG1  | +31    | BuildDatabaseTable - Could not find: Cloneof
21:31:05:258 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Searching database for: Manufacturer
21:31:05:261 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Found "Manufacturer" with a value: "Lucasfilm Games"
21:31:05:263 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Searching database for: Year
21:31:05:285 | MD |   DEBUG1  | +31    | BuildDatabaseTable - Found "Year" with a value: "1988"
21:31:05:288 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Searching database for: Genre
21:31:05:289 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Found "Genre" with a value: "Adventure"
21:31:05:292 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Searching database for: Rating
21:31:05:294 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Found "Rating" with a value: "ESRB - E (Everyone)"
21:31:05:315 | MD |   DEBUG2  | +31    | PluginInit - GameInfo:
GameInfo Label: Genre | GameInfo Value:
GameInfo Label: Manufacturer | GameInfo Value:
GameInfo Label: Name | GameInfo Value:
GameInfo Label: Rating | GameInfo Value:
GameInfo Label: Year | GameInfo Value:
21:31:05:318 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Ended
21:31:05:321 | MD |   DEBUG1  | +0     | BuildAssetsTable - Started - Building Table for: Game Logo|System Logo
21:31:05:325 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a Game Logo: O:\Hyperspin\Media\ScummVM\Images\Wheel\zak-v2.png
21:31:05:347 | MD |   DEBUG1  | +31    | BuildAssetsTable - Searching for a System Logo: O:\Hyperspin\Media\Main Menu\Images\Wheel\ScummVM.png
21:31:05:351 | MD |   DEBUG2  | +0     | BuildAssetsTable - Media assets found:
Asset Label: System Logo | Asset Path1:  O:\Hyperspin\Media\Main Menu\Images\Wheel\ScummVM.png | Asset Extension1:  png | Asset Type1:  system
21:31:05:353 | MD |   DEBUG1  | +0     | BuildAssetsTable - Ended
21:31:05:356 | MD |   DEBUG1  | +0     | BuildAssetsTable - Started - Building Table for: Artwork1|Box Art|Cartridge|Flyers|Letters|Other
21:31:05:378 | MD |   DEBUG1  | +32    | BuildAssetsTable - Searching for a Artwork1: O:\Hyperspin\Media\ScummVM\Images\Artwork1\zak-v2.png
21:31:05:380 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a Box Art: O:\Hyperspin\Media\ScummVM\Images\Artwork2\zak-v2.png
21:31:05:384 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a Cartridge: O:\Hyperspin\Media\ScummVM\Images\Artwork3\zak-v2.png
21:31:05:386 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a Flyers: O:\Hyperspin\Media\ScummVM\Images\Artwork4\zak-v2.png
21:31:05:409 | MD |   DEBUG1  | +31    | BuildAssetsTable - Searching for a Letters: O:\Hyperspin\Media\ScummVM\Images\Letters
21:31:05:534 | MD |   DEBUG1  | +125   | BuildAssetsTable - Searching for a Other: O:\Hyperspin\Media\ScummVM\Images\Other
21:31:05:540 | MD |   DEBUG2  | +0     | BuildAssetsTable - Media assets found:
Asset Label: Letters | Asset Path1:  O:\Hyperspin\Media\ScummVM\Images\Letters\!.png | Asset Extension1:  png | Asset Type1:  system
Asset Label: Letters | Asset Path2:  O:\Hyperspin\Media\ScummVM\Images\Letters\'.png | Asset Extension2:  png | Asset Type2:  system
Asset Label: Letters | Asset Path3:  O:\Hyperspin\Media\ScummVM\Images\Letters\(.png | Asset Extension3:  png | Asset Type3:  system
Asset Label: Letters | Asset Path4:  O:\Hyperspin\Media\ScummVM\Images\Letters\0.png | Asset Extension4:  png | Asset Type4:  system
Asset Label: Letters | Asset Path5:  O:\Hyperspin\Media\ScummVM\Images\Letters\1.png | Asset Extension5:  png | Asset Type5:  system
Asset Label: Letters | Asset Path6:  O:\Hyperspin\Media\ScummVM\Images\Letters\2.png | Asset Extension6:  png | Asset Type6:  system
Asset Label: Letters | Asset Path7:  O:\Hyperspin\Media\ScummVM\Images\Letters\3.png | Asset Extension7:  png | Asset Type7:  system
Asset Label: Letters | Asset Path8:  O:\Hyperspin\Media\ScummVM\Images\Letters\4.png | Asset Extension8:  png | Asset Type8:  system
Asset Label: Letters | Asset Path9:  O:\Hyperspin\Media\ScummVM\Images\Letters\5.png | Asset Extension9:  png | Asset Type9:  system
Asset Label: Letters | Asset Path10:  O:\Hyperspin\Media\ScummVM\Images\Letters\6.png | Asset Extension10:  png | Asset Type10:  system
Asset Label: Letters | Asset Path11:  O:\Hyperspin\Media\ScummVM\Images\Letters\7.png | Asset Extension11:  png | Asset Type11:  system
Asset Label: Letters | Asset Path12:  O:\Hyperspin\Media\ScummVM\Images\Letters\8.png | Asset Extension12:  png | Asset Type12:  system
Asset Label: Letters | Asset Path13:  O:\Hyperspin\Media\ScummVM\Images\Letters\9.png | Asset Extension13:  png | Asset Type13:  system
Asset Label: Letters | Asset Path14:  O:\Hyperspin\Media\ScummVM\Images\Letters\a.png | Asset Extension14:  png | Asset Type14:  system
Asset Label: Letters | Asset Path15:  O:\Hyperspin\Media\ScummVM\Images\Letters\b.png | Asset Extension15:  png | Asset Type15:  system
Asset Label: Letters | Asset Path16:  O:\Hyperspin\Media\ScummVM\Images\Letters\c.png | Asset Extension16:  png | Asset Type16:  system
Asset Label: Letters | Asset Path17:  O:\Hyperspin\Media\ScummVM\Images\Letters\d.png | Asset Extension17:  png | Asset Type17:  system
Asset Label: Letters | Asset Path18:  O:\Hyperspin\Media\ScummVM\Images\Letters\e.png | Asset Extension18:  png | Asset Type18:  system
Asset Label: Letters | Asset Path19:  O:\Hyperspin\Media\ScummVM\Images\Letters\f.png | Asset Extension19:  png | Asset Type19:  system
Asset Label: Letters | Asset Path20:  O:\Hyperspin\Media\ScummVM\Images\Letters\g.png | Asset Extension20:  png | Asset Type20:  system
Asset Label: Letters | Asset Path21:  O:\Hyperspin\Media\ScummVM\Images\Letters\h.png | Asset Extension21:  png | Asset Type21:  system
Asset Label: Letters | Asset Path22:  O:\Hyperspin\Media\ScummVM\Images\Letters\i.png | Asset Extension22:  png | Asset Type22:  system
Asset Label: Letters | Asset Path23:  O:\Hyperspin\Media\ScummVM\Images\Letters\j.png | Asset Extension23:  png | Asset Type23:  system
Asset Label: Letters | Asset Path24:  O:\Hyperspin\Media\ScummVM\Images\Letters\k.png | Asset Extension24:  png | Asset Type24:  system
Asset Label: Letters | Asset Path25:  O:\Hyperspin\Media\ScummVM\Images\Letters\l.png | Asset Extension25:  png | Asset Type25:  system
Asset Label: Letters | Asset Path26:  O:\Hyperspin\Media\ScummVM\Images\Letters\m.png | Asset Extension26:  png | Asset Type26:  system
Asset Label: Letters | Asset Path27:  O:\Hyperspin\Media\ScummVM\Images\Letters\n.png | Asset Extension27:  png | Asset Type27:  system
Asset Label: Letters | Asset Path28:  O:\Hyperspin\Media\ScummVM\Images\Letters\o.png | Asset Extension28:  png | Asset Type28:  system
Asset Label: Letters | Asset Path29:  O:\Hyperspin\Media\ScummVM\Images\Letters\p.png | Asset Extension29:  png | Asset Type29:  system
Asset Label: Letters | Asset Path30:  O:\Hyperspin\Media\ScummVM\Images\Letters\q.png | Asset Extension30:  png | Asset Type30:  system
Asset Label: Letters | Asset Path31:  O:\Hyperspin\Media\ScummVM\Images\Letters\r.png | Asset Extension31:  png | Asset Type31:  system
Asset Label: Letters | Asset Path32:  O:\Hyperspin\Media\ScummVM\Images\Letters\s.png | Asset Extension32:  png | Asset Type32:  system
Asset Label: Letters | Asset Path33:  O:\Hyperspin\Media\ScummVM\Images\Letters\t.png | Asset Extension33:  png | Asset Type33:  system
Asset Label: Letters | Asset Path34:  O:\Hyperspin\Media\ScummVM\Images\Letters\u.png | Asset Extension34:  png | Asset Type34:  system
Asset Label: Letters | Asset Path35:  O:\Hyperspin\Media\ScummVM\Images\Letters\v.png | Asset Extension35:  png | Asset Type35:  system
Asset Label: Letters | Asset Path36:  O:\Hyperspin\Media\ScummVM\Images\Letters\w.png | Asset Extension36:  png | Asset Type36:  system
Asset Label: Letters | Asset Path37:  O:\Hyperspin\Media\ScummVM\Images\Letters\x.png | Asset Extension37:  png | Asset Type37:  system
Asset Label: Letters | Asset Path38:  O:\Hyperspin\Media\ScummVM\Images\Letters\y.png | Asset Extension38:  png | Asset Type38:  system
Asset Label: Letters | Asset Path39:  O:\Hyperspin\Media\ScummVM\Images\Letters\z.png | Asset Extension39:  png | Asset Type39:  system
Asset Label: Other | Asset Path1:  O:\Hyperspin\Media\ScummVM\Images\Other\Pointer.png | Asset Extension1:  png | Asset Type1:  system
21:31:05:562 | MD |   DEBUG1  | +31    | BuildAssetsTable - Ended
21:31:05:564 | MD |   DEBUG1  | +0     | BuildAssetsTable - Started - Building Table for: Game Video|System Video
21:31:05:566 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a Game Video: O:\Hyperspin\Media\ScummVM\Video\zak-v2.*
21:31:05:568 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a System Video: O:\Hyperspin\Media\Main Menu\Video\ScummVM.*
21:31:05:570 | MD |   DEBUG2  | +0     | BuildAssetsTable - Media assets found:
Asset Label: Game Video | Asset Path1:  O:\Hyperspin\Media\ScummVM\Video\zak-v2.mp4 | Asset Extension1:  mp4 | Asset Type1:  game
Asset Label: System Video | Asset Path1:  O:\Hyperspin\Media\Main Menu\Video\ScummVM.mp4 | Asset Extension1:  mp4 | Asset Type1:  system
21:31:05:572 | MD |   DEBUG1  | +0     | BuildAssetsTable - Ended
21:31:05:574 | MD |     INFO  | +0     | PluginInit - Ended
21:31:05:597 | MD |   DEBUG1  | +31    | StartModule - Setting romName to the dbName sent to RocketLauncher: zak-v2
21:31:05:599 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~e & ~t" to call label: "ToggleCursor"
21:31:05:605 | MD |     INFO  | +0     | StartModule - Ended
21:31:05:629 | MD |     INFO  | +31    | Module Setting - [settings] - CustomConfig:
21:31:05:633 | MD |     INFO  | +0     | CheckFile - Checking if C:\Users\ste\AppData\Roaming\ScummVM\scummvm.ini exists
21:31:05:637 | MD |     INFO  | +0     | Module Setting - [settings] - Fullscreen: true
21:31:05:661 | MD |     INFO  | +31    | Module Setting - [settings] - LaunchMode: Auto
21:31:05:665 | MD |     INFO  | +0     | Module Setting - [zak-v2] - LaunchMode: Auto
21:31:05:690 | MD |     INFO  | +32    | Module Setting - [zak-v2] - TargetName: zak-v2
21:31:05:694 | MD |     INFO  | +0     | Module Setting - [settings] - ForceExtractionToRomPath: false
21:31:05:697 | MD |     INFO  | +0     | Module Setting - [zak-v2] - ForceExtractionToRomPath: false
21:31:05:721 | MD |     INFO  | +31    | Module Setting - [settings] - BezelDelay: 0
21:31:05:724 | MD |     INFO  | +0     | Module Setting - [zak-v2] - BezelDelay: 0
21:31:05:727 | MD |     INFO  | +0     | Module Setting - [settings] - SaveKey: 1
21:31:05:730 | MD |     INFO  | +0     | Module Setting - [settings] - LoadKey: 2
21:31:05:755 | MD |     INFO  | +31    | Module Setting - [settings] - MenuKey: p
21:31:05:757 | MD |     INFO  | +0     | Module Setting - [mapping] - zak-v2: zak-v2.7z
21:31:05:760 | MD |     INFO  | +0     | 7z - Started, received O:\_Roms\ScummVM\zak-v2.7z. If rom is an archive, it will extract to C:\Users\ste\AppData\Local\Temp\HS
21:31:05:762 | MD |   DEBUG1  | +0     | 7z - Using Standard method to extract this rom
21:31:05:763 | MD |   DEBUG1  | +0     | 7z - ".7z" found in .zip,.rar,.7z,.lzh,.gzip,.tar
21:31:06:107 | MD |     INFO  | +359   | CheckFile - Checking if O:\_Roms\ScummVM\zak-v2.7z exists
21:31:06:482 | MD |   DEBUG1  | +374   | 7z - Invoked COM Object, ROM extracted size: 913840 bytes
21:31:06:485 | MD |  WARNING  | +0     | 7z - Following paths in log entries may not be accurate because SkipChecks is enabled! Do not be alarmed if you see invalid looking paths when Skip Checks is required for this system.
21:31:06:487 | MD |   DEBUG1  | +0     | 7z - Checking if this archive has already been extracted in C:\Users\ste\AppData\Local\Temp\HS\zak-v2
21:31:06:491 | MD |   DEBUG1  | +0     | 7z - File already exists in C:\Users\ste\AppData\Local\Temp\HS\zak-v2 with a size of: 913840 bytes
21:31:06:494 | MD |   DEBUG1  | +0     | 7z - Breaking out of 7z to load existing file
21:31:06:496 | MD |   DEBUG1  | +0     | 7z - romPath changed from "O:\_Roms\ScummVM" to "C:\Users\ste\AppData\Local\Temp\HS\zak-v2"
21:31:06:515 | MD |   DEBUG1  | +31    | 7z - romName changed from "zak-v2" to "zak-v2"
21:31:06:517 | MD |   DEBUG1  | +0     | 7z - romExtension changed from ".7z" to "."
21:31:06:520 | MD |     INFO  | +0     | 7z - Ended
21:31:06:523 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~1" to call label: "ScummvmSave"
21:31:06:526 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~2" to call label: "ScummvmLoad"
21:31:06:545 | MD |   DEBUG2  | +32    | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~p" to call label: "ScummvmMenu"
21:31:06:549 | MD |     INFO  | +0     | Module - Launch mode: Standard
21:31:06:552 | MD |     INFO  | +0     | Run - Running: O:\_Emulators\ScummVM\scummvm.exe --no-console -f zak-v2
21:31:06:736 | MD |   DEBUG1  | +187   | Run - "scummvm.exe --no-console -f zak-v2" Process ID: 1924
21:31:06:738 | MD |   DEBUG1  | +0     | GetActiveWindowStatus - Title: RocketLauncherUI v1.0.0.3 [ FE = Hyperspin | Plugin = HyperSpin ] | Class: HwndWrapper[RocketLauncherUI.exe;;e930eb83-be12-4dbb-8aef-2519ca09ece9] | State: 1 | X: -8 | Y: -8 | Width: 1382 | Height: 744 | Window HWND: 0x550b52 | Process ID: 7236 | Process Path: O:\RocketLauncher\RocketLauncherUI\RocketLauncherUI.exe
21:31:06:739 | MD |     INFO  | +0     | WinWait - Waiting for "ahk_class SDL_app"
21:31:06:892 | MD |   DEBUG1  | +156   | GetActiveWindowStatus - Title: RocketLauncherUI v1.0.0.3 [ FE = Hyperspin | Plugin = HyperSpin ] | Class: HwndWrapper[RocketLauncherUI.exe;;e930eb83-be12-4dbb-8aef-2519ca09ece9] | State: 1 | X: -8 | Y: -8 | Width: 1382 | Height: 744 | Window HWND: 0x550b52 | Process ID: 7236 | Process Path: O:\RocketLauncher\RocketLauncherUI\RocketLauncherUI.exe
21:31:06:894 | MD |   DEBUG1  | +0     | GetActiveWindowStatus - Title: RocketLauncherUI v1.0.0.3 [ FE = Hyperspin | Plugin = HyperSpin ] | Class: HwndWrapper[RocketLauncherUI.exe;;e930eb83-be12-4dbb-8aef-2519ca09ece9] | State: 1 | X: -8 | Y: -8 | Width: 1382 | Height: 744 | Window HWND: 0x550b52 | Process ID: 7236 | Process Path: O:\RocketLauncher\RocketLauncherUI\RocketLauncherUI.exe
21:31:06:896 | MD |     INFO  | +0     | WinWaitActive - Waiting for "ahk_class SDL_app"
Can you help me please??
Thanks in advance
OK the problem is the configuration.
I read your istructions and now work.
But I have to configure all the game one by one manually??
Thanks
Hey,
By asking, do you mean in ScummVM, do you need to configure each one manually?  Yes.
Thanks,
Ron
Thanks
OK Thanks
I will do
  On 7/27/2015 at 2:59 PM, rfancella said:
Hey,
Thanks,
Ron
