Vishay, Babcock or Cherry
The Vishays and X-Pins are proven to be compatible with the PinDMD and are probably both pretty safe bets. Not sure about the other two brands...
Is this a trick question? Babcock and Cherry are a pretty rare find (i believe they have stopped making dmds years ago). On top of that, they are confirmed NOT working with pindmd1, unconfirmed for pindmd2.
What will work, without too much trouble:
Vishay 5 volt led, or 12v plasma will work, as will X-Pin and Pinled.
not come across a babcock yet as far as im aware. cherry 12v does not work with pinDMD1 not tried with a pinDMD2 as wowter mentioned. these displays are very rare not sure if you can even buy them?
