Guys help Upgrading Visual Pinball from 9.1.2 to Latest build
marcdaddy
Hi Guys my Cabinet has been playing perfectly for a longtime and noticed some of the re-releases of older tables require a newer version of Visual Pinball, Do i just download the stand alone 9.1.5 exe and replace my older exe ( should i rename the new version to match my older working version ? ) Thanks guys!! Im hoping having to redo everthing and thought that might work.
Do exactly as you said download the latest exe and rename as you said and replace the older version. You will need to put the freeImage.dll included in the download into the folder where the exe is as well.
do exactly as you said download the latest exe and rename as you said and replace the older version. You will need to put the freeimage.dll included in the download into the folder where the exe is as well.
thanks that worked!!
