OK just updated to rlauncher and hyper spin 1.4 now RlauncherUI can't find Daphne
vincefaro
Noob question, But How do I change the path to the emulator, When I am in RlauncherUI , Daphne won't run because it can't find the emulator because the path i wrong, How do I change this? Thanks
You set the path to the emulator when you setup the system.
Off the top of my head I think it's:
Under Global go to the emulators tab. Scroll down to Daphne and double click it. That should open the box where you put in the paths.
I can't remember which ones you fill and which you leave blank for Daphne though. The Daphne tutorial probably says.
For Daphne you select the Roms folder Which is A Framefile that pints to the Video files. There is no Selector for where the emulator needs to point.
