Games won't launch from Hyperspin
Bushgopher
K so ive got everything set up for mame and can launch any game in RocketLauncher but when i go into Hyperspin none of the games will load for some reason.  All i get is a working symbol for a bout a second and then nothing happens when trying to run a game.  Wondering if there's anyone who could shed some light on my problem.  Ive checked out a lot of forums and tried altering the rom path in my settings ini but nothing works.
LOG
09:20:21 PM | HyperSpin Started
09:20:21 PM | Going FullScreen
09:20:21 PM | Checking for updates
09:20:21 PM | Update Check Complete
09:20:21 PM | Startup program unavailable
09:20:21 PM | Playing intro video
09:20:28 PM | Error intializing joysticks
09:20:28 PM | Menu Mode is multi
09:20:28 PM | Loading Main Menu.xml
09:20:28 PM | Main Menu.xml successfully loaded
09:20:28 PM | Main Menu wheel loaded successfully
09:20:31 PM | Loading MAME.xml
09:20:31 PM | Main Menu.xml successfully loaded
09:20:32 PM | MAME wheel loaded successfully
09:20:37 PM | Launching Game
09:20:37 PM | Using HyperLaunch
09:20:37 PM | Getting HyperLaunch path
09:20:37 PM | HyperLaunch located at G:\hyperspin133\HyperLaunch.exe
09:20:37 PM | Running HyperLaunch.exe
09:20:37 PM | HyperLaunch Command Line is: G:\hyperspin133\HyperLaunch.exe "MAME" "volfied"
09:20:46 PM | Loading Main Menu.xml
09:20:46 PM | Main Menu.xml successfully loaded
09:20:46 PM | Main Menu wheel loaded successfully
09:20:51 PM | Exit program unavailable
09:20:51 PM | Quiting Hyperspin
09:20:51 PM | Bye!
HYPERLAUNCH LOG
09:20:37 PM | HyperLaunch v2.25c09:20:37 PM | System Specs:HyperSpin Dir: G:\hyperspin133OS: WIN_VISTAOS Language: 0409OS Admin Status: YesMonitor #1 (\\.\DISPLAY1): 1280x720 (1280x690 work)HyperSpin Res: 1280x720AHK Version: 1.1.07.0309:20:37 PM | HyperLaunch received "MAME" and "volfied"09:20:37 PM | INI Keys read09:20:37 PM | Checking paths09:20:37 PM | Finished injecting functions into module09:20:37 PM | Module is built09:20:37 PM | Running module:;-----------------------------------------------------------;Built in script;-----------------------------------------------------------#NoTrayIconDetectHiddenWindows, ONSetTitleMatchMode, 2SendMode, Event0 = 2exitEmulatorKey = EscemuPath = G:\hyperspin133\Emulators\MAME\romPath = G:\roms\MAME roms\ROMs\romPathFromIni = G:\roms\MAME roms\ROMs\romExtension = .7zromExtensionOrig = .7zromExtensions = zip,7zexecutable = mame64.exesystemName = MAMEromName = volfieddaemonToolsPath =skipchecks = falsefadeIn = falsefadeOut = falsefadeColor = 0x000000fadeInDuration = 500fadeOutDuration = 500fadeInDelay = 0fadeInInterruptKeys = {LControl}{RControl}{LAlt}{RAlt}{LShift}{RShift}{LWin}{RWin}{AppsKey}{F1}{F2}{F3}{F4}{F5}{F6}{F7}{F8}{F9}{F10}{F11}{F12}{Left}{Right}{Up}{Down}{Home}{End}{PgUp}{PgDn}{Del}{Ins}{BS}{Capslock}{Numlock}{PrintScreen}{Pause}gameStartImgPath = G:\hyperspin133\Media\MAME\Images\GameStart\moduleExtensionPath = G:\hyperspin133\Modules\Module Extensions\7zEnable = false7zExtractDir = C:\Users\BUSHYA~1\AppData\Local\Temp\Hyperspin\7zExtractDirOrig =7zDelTemp = true7zFormats = .zip,.rar,.7z,.gzip,.tar7zFormatsNoP = zip,rar,7z,gzip,tarmgEnabled = falsemgKey = NumpadSubmgSelectKey = EntermgExitKey = EscmultiGameImgPath = G:\hyperspin133\Media\MAME\Images\MultiGame\mgBackgroundColor = FF000000mgSidePadding = 0.2mgYOffset = 500mgImageAdjust = 1mgFont = ArialmgText1Options = x10p y30p w80p Centre cBBFFFFFF r4 s100 Bold ItalicmgText1Text = Please select a gamemgText2Options = w96p cFFFFFFFF r4 s50 Center Bold ItalicmgText2Offset = 70mgUseSound = truemgSoundfreq = 300mgExitEffect = nonemgSelectedEffect = rotatemgUseGameArt = falsemgArtworkDir = Artwork1Hotkey, Esc, CloseProcess;-----------------------------------------------------------;Module script;-----------------------------------------------------------;MAME;ver. .157;MAME.exe|MAME64.exe;----------------------------------------------------------------------------; Notes:; No need to edit mame.ini and set your rom folder, module sends the rompath for you.;----------------------------------------------------------------------------
GUI_ID := FadeInStart()
Run, %executable% %romName%, %emuPath%, Hide, exePID
WinWait, Ahk_pid %exePID%
WinGetClass,exeWinClass, ahk_pid %exePID%
WinWaitActive, Ahk_class %exeWinClass%
if(ErrorLevel != 0){
if (ErrorLevel = 1){
Error = Failed Validity
}else if(ErrorLevel = 2){
Error = Missing Files
}else if(ErrorLevel = 3){
Error = Fatal Error
}else if(ErrorLevel = 4){
Error = Device Error
}else if(ErrorLevel = 5){
Error = Game Does Not Exist
}else if(ErrorLevel = 6){
Error = Invalid Config
}else if(ErrorLevel = 7 || ErrorLevel = 8 || ErrorLevel = 9){
Error = Identification Error
}else{
Error = Mame Error
MsgBox Mame Error - %Error%
GUI_ID2 := FadeInExit()
Process, WaitClose, %executable%
GUI_ID4 := FadeOutExit()
WinActivate, Hyperspin
ExitApp
CloseProcess:
GUI_ID3 := FadeOutStart()
WinClose, Ahk_class %exeWinClass%
return
hideDesktop(){
FadeInStart(){
FadeInExit(){
FadeOutStart(){
Suspend, On
FadeOutExit(){
7z(7zP, 7zN, 7zE, 7zExtractDir){
7zCleanUp() {
CheckFile(file,msg="",timeout=6){
IfNotExist, %file%
If msg
ScriptError(msg, timeout)
Else
ScriptError("Cannot find " . file, timeout)
Return %file%
ScriptError(error,timeout=6){
MsgBox,48,Error,%error%,%timeout%
ExitApp
Any help would be appreciated. Thanks
I think you also have to manually tell Hyperspin to look at RocketLauncher in an ini because it's pointing at Hyperlaunch by default.
I feel like I had this problem, but I sorted it out a while ago.
Check the ... hyperspin.ini I beleive and do a ctrl+F search for "hyperlaunch" Unless I am mistaken that should fix the issue.
If I am wrong I know one of our peers here will correct me, as this I beleive is a common issue
Thanks for the reply but im kinda dumb at this.  Either there is no hyperspin.ini file or i cant find it.  Also once i do find it and do a (ctrl f) and search for hyperlaunch, whats that gonna do or what should be done after that?
No worries, I know my response wasn't very precise lol.
I'm trying to run off memory here (I'm at work, and am not allowed to pull out my laptop {Which is my hyperspin machine lol}) so forgive me if I'm not hitting it on the nose.
I think that the hyperspin.ini (If it's not in the main Hyperspin folder) is located in the settings folder.
Once you do find the line pointing to the old Hyperlaunch program (It should be something like C:\Hyperspin\Hyperlaunch\Hyperlaunch.exe, depending on how your directories are setup) You will just want to change it so it's pointing at RocketLauncher (Something like: C:\Hyperspin\RocketLauncher\RocketLauncher.exe, again depending on how your directories are setup)
Once I get a chance I'll try to pull it up for sure, but I'm about 70% sure that is where it's located.
