fery65 Posted September 24, 2015 Posted September 24, 2015 Hello I need help here, I am new member. Everybody knows that it does not exist a perfect emulator but there are emulators which are nearly perfect. I would like to know if it is possible to choose the emulator for one system example super nintendo and choose another one for some games which does not work properly with the emulator chosen by default. For example you configure snes9x 1.53 to play snes roms and I want to know if I can configure snes9x 1.52 for some games which does not work well with 1.53 version. Thank you very much for answers
Styphelus Posted September 24, 2015 Posted September 24, 2015 Yes, that is possible. Instructions here: http://www.rlauncher.com/wiki/index.php?title=Alternate_Emu_Mapping I would use Retroarch with the snes core instead of Snes9x but that's your choice. However, I've read that the bsnes core in retroarch is supposed to be the most accurate and can can emulate all SNES games without problems. Not sure if it's true. I use the snes core. Would anyone recommend the bsnes core instead os snes in retroarch? If benes can emulate every game without issues, that would save you the trouble of setting up 2 separate emulators.
Awakened Posted September 24, 2015 Posted September 24, 2015 BSNES Balanced runs almost every officially released game perfectly. The one exception I know of is Air Strike Patrol, which doesn't render a shadow under the plane unless you use BSNES Accuracy. But I think the Genesis version of that game is supposed to be as good or better and doesn't have that problem on Genesis Plus GX as far as I know. Balanced should run fine on most modern processors, so you'd only use SNES9x for faster fast forwarding or for faster ROM booting. The BSNES cores have to convert ROMs into ROM folders in RAM, so it takes an extra second to boot.
fery65 Posted September 25, 2015 Author Posted September 25, 2015 Thank you very very much Styphelus for your help I al trying to do it, to change emulaor for one system but for the moment I can't manage to do this. I am reading your link but not so easy to do it. Maybe if you have alredy done this you can explain me better because I am french hahahaha and English language is not my friend hahahaha
fery65 Posted September 25, 2015 Author Posted September 25, 2015 No thanks I think I am understanding a bit more hahaha thanks anyway
