Execution of a command line command before Emulator starts
CptElevator
Hello,
i use different key layouts with the Ultimate i/O, especially with the WinUAE.
Before the Emu starts i have to send a simple command line execution to the card e.g.:
c:/winipacv2.exe -amiga.ipc
and for the rest of the emus
c:/winipacv2.exe -default.ipc.
My Question:
Where is the best and simple place for the command? Should i place them in the HyperHQ (under executable or something else, now the field is filled with: c:/HyperSpin/MAME/mame.exe) or have i create a seperate batch file for every emu wich include the MAME startup?
Can anybody help me?
Greets, Matthias
  • 3 weeks later...
Have you considered upgrading to rocketlauncher?
You can easily change ipac configs using Rons script as explained in this thread.
I am using Rons script bundled with DJVJs idle volume adjuster and it works well but you can just use Ron's script to change pac configs on a per system basis.
Also here is a great guide for Winuae setup for Amiga.
I'm assuming you are using the old hyperlaunch because of where this thread is not RocketLauncher or rocketlauncher.
Regards
