ghm8439 Posted October 1, 2015 Posted October 1, 2015 I have an upright arcade cabinet. When i play a 2 player game like pac man both games only work through the player 1 joystick. How can i set the 2 player games to play player 1 through the left joystick and player 2 through the right joystick. What is confusing is that the controls and buttons for both joysticks are recognized as two separate joysticks when setting up the joysticks via the in game setup.
Agrajag Posted October 1, 2015 Posted October 1, 2015 Those games only had a single set of controls that you took turns on, so I guess they will ignore whatever you've set the Player 2 controls to in MAME's Input (General) menu. Have you tried Input (This Game)? I'm not in a position to test it right now but thinking about it you may even have to set player 1's controls to be both the left stick and the right stick at the same time. HyperSpin behaving oddly? Read about known bugs here: http://www.hyperspin-fe.com/topic/4590-known-bugs-and-handy-hints-for-hyperspin/ The installer for HyperSpin now includes HyperLaunch 2. Go here for support: http://www.hyperspin-fe.com/forum/122-hyperlaunch-2/ HyperLaunch3 is now called RocketLauncher. Go here for support: http://www.rlauncher.com/forum/content.php Read this for ftp login info: http://www.hyperspin-fe.com/topic/2320-ftp-access-must-read/ Platinum members get 25% off an Emumovies subscription: http://www.hyperspin-fe.com/topic/1211-emumovies-code/
iNTiGOD Posted October 2, 2015 Posted October 2, 2015 Those games only had a single set of controls that you took turns on, so I guess they will ignore whatever you've set the Player 2 controls to in MAME's Input (General) menu. Have you tried Input (This Game)? I'm not in a position to test it right now but thinking about it you may even have to set player 1's controls to be both the left stick and the right stick at the same time. An example is PACMAN MAME High Score Tutorial For HyperSpin
