(Help) Mapping dreamcast to 2 player arcade
Gambino147
I'm having trouble with controller mapping in nulldc and demul.
With nulldc I've had little luck getting things right. I've tried most combinations for the arcade stick in plugins and either the buttons are all very wrong or it doesn't have a start button mapped.
I go into maple and try map the controller, I click on the square and I get a default of -F4 'I think' and it doesn't let me map the stick at all. If I mash on the square I can get it to run a count down that just freezes nulldc at the 5 second mark.
I couldn't work out any mapping in Demul so any advice with this emulator would be greatly appreciated.
Demule is the better emulator, what are you using for your cab controls? ipac, tank stick, etc
Demule maps just fine, go to input config setting
Ok. I'm using a PS3/PS4 venom arcade stick pcb. I've managed to map all of the buttons but the stick only registers as one input in Demul.
In nulldc everything maps but nothing registers in game. I got xpadder and mapped the sticks to that, again no luck in nulldc. I've just decided to use the controller for that emulator as I'm sure it's the PS3/PS4 that's making it not work.
