krish21 Posted October 30, 2015 Posted October 30, 2015 Ok long story short. Every time I start Hyperspin I can't use my 360 controller. When i start a game and exit again my controller just woks fine in Hyperspin. And now the long version for more information. I installed Hyperspin 1.4, Rocketlauncher, emulators and Xpadder how described in many tutorials. Then I set up my consoles and games. Afterwards I started to set up in RocketLauncherUi my Xpadder profiles to play with my Xbox 360 controller. I made a profile for every system. Until now everything just worked fine. I can start Hyperspin choose my console and game and start it. In the games my 360 controller works as intended. Then i wanted to use my controller in the Hyperspin menu. In RocketLauncherUi I set up a default and a frontend profile for the global system. When I test the profiles in the keymapper window everything is ok. But when I start Hyperspin my controller isn't working and I have to use my keyboard. After starting a game my contoller is working in the game and after exiting the game it is also working in the Hyperspin menu (this is because of my frontend profile right?) So why is my controller not working when I start hyperspin?
Aorin Posted October 30, 2015 Posted October 30, 2015 You can try using Startup Script here > http://www.hyperspin-fe.com/files/file/7415-hyperspin-startup-script/ It will load the script when you open Hyperspin, you'll be able to use your gamepad to control your Hyperspin setup, when you launch a game, your xpadder profile will load, this script will be deactivated when you launch the game, when you get back to HS, your xpadder profile will unload and the script will load again, it works like a charm for me. Remember to put HyperHQ to open this script and everything should work fine. Aorin
krish21 Posted October 30, 2015 Author Posted October 30, 2015 You can try using Startup Script here > http://www.hyperspin-fe.com/files/file/7415-hyperspin-startup-script/ It will load the script when you open Hyperspin, you'll be able to use your gamepad to control your Hyperspin setup, when you launch a game, your xpadder profile will load, this script will be deactivated when you launch the game, when you get back to HS, your xpadder profile will unload and the script will load again, it works like a charm for me. Remember to put HyperHQ to open this script and everything should work fine. Well that sounds great but do you know why Hyperspin isn't loading my default profile when it's starting?
Aorin Posted October 30, 2015 Posted October 30, 2015 I can't tell, though I assure you can use this startup script, you won't regret it. Aorin
