So I built a new cabinet, having issues with keymapping , etc
geekygreek7
Hi guys,
Thanks for taking the time to read this. I've spent hours and hours trying to figure this out. I have had a handful of problems and after researching so much, it's down to a small handful now.
Lets tackle the first one first; Dolphin exiting when pressing escape key (when launched individually through the exe file). YAY! But if it's launched through hyperspin, the escape key does not work. NO IDEA why this is the case!!! Couple other emulators I'm having issues with that do the same thing (specifically emulators that require ALT+F4 to exit *omg so lame*!).
I've purchased the xtension sitdown arcade setup with the emulation pad from recroommasters so I want to get it working with that.
I've tried messing with keymapping but it doesnt seem to be doing anything (maybe I dont know how to use it).
Any screenshots or even video that I need to provide I will! I will give anything to have someone help me with this!! <3
Thanks so much. Looking forward to the replies.
I don't use Dolphin and have no emulators that require Alt-F4 to exit so I can't help much. However it would help if you said what you're running. I'm guessing the latest HyperSpin and the latest RocketLauncher? What do you have you exit key set as in RocketLauncherUI?
Keymapper isn't a program or setting exactly, it's more the tab where you can set up the different programs you can use to do keymapping (AHK, Xpadder etc...) so you need to know how to use those and that's where you tell RL to use them.
Not much help for you other than that. Good luck.
HI thanks for your reply.
Yes latest hyperspin and rocketlauncher. I figured the Exit Emulator keystroke would be good enough but it doesn't take control of the action like I would think it should.
Here's a screenshot of the setting. Gamecube emulator (dolphin). opens fine in hyperspin, it's just getting it to close and go back to hyperspin that's the issue (kega fusion has the same issue im trying to figure out right now). What could I be doing wrong? :( This awesome arcade setup going in my parlor and I can't finalize this simple thing >.<
Thank you again.
