Retroarch and 3DO Problem
Styphelus
Has anyone been able to get Retroarch 1.2.2 stable to work with the Panasonic 3DO?
Seems like the cores are broken. Retroarch crashes right away. Tried updatng them without any luck.
I was able to get it going using an old core and an old config file. Using an old core and attempting to create a new config file results in a black screen. For some reason using an old config works but once in a while a get a crash when exiting a game.
However, everything work perfectly fine on my year old Retroarch setup.
I have the right bios (panafz10.bin). I have it working but it only works with an old config file and an old core. Don't think there's such a thing as a new bios for the new retroarch version.
Weird. Every other system is working perfectly fine except for this one. Oh well. I'll just have to keep my old config file.
It's ok. I'll be switching over to 4DO anyway because you can't change discs in Retroarch. No way to play Wing Commander on this system.
I just played a little of Lucienne's Quest without issue.
RA 1.2.2 on OpenELEC v6
Core Info:
display_name = "3DO (4DO)"
authors = "JohnnyDude|FreeDO team"
supported_extensions = "iso|cue"
corename = "4DO"
manufacturer = "Various"
categories = "Emulator"
systemname = "3DO"
license = "LGPL with additional notes"
permissions = ""
display_version = "v1.3.2.3"
supports_no_game = "false"
firmware_count = 1
firmware0_desc = "panafz10.bin (Panasonic FZ-10 BIOS)"
firmware0_path = "panafz10.bin"
firmware0_opt = "false"
All games are ISO...no CUE's.  Unfortunately, I am stuck with RA since I an running it on OE.
John
"There are some who call me.......Tim."
The 3D Atlas(?) game was the only one i got to run from the hyperspin ready set, as that was the only ISO format game i could find in the set, img crashes for me too..
The tosec set however is iso and works for me
How did you get the mess systems like a5200 and colecovision to run?
