diskmach Posted November 13, 2015 Posted November 13, 2015 I put in quite a lot of work in getting Saturn to work, and at the first test after I felt is was quite complete, it worked flawlessly in RL and HS. Second test: flawlessly in RL - in HS when it goes to fullscreen, it leaves the lower bar of the main window sitting in the middle of the screen to the left?? I tried out all the various settings in SSF, reinstalled it, tried with R3 instead of R4, nothing helps. One member in RL forums had the the same problem, but it apparently went away after reinstalling Windows. Short of that, any ideas how to fix this? Nintendo 3DS wheels thread || Nintendo 3DS wheel set download Bandai Wonderswan Color wheels thread || Bandai Wonderswan wheels thread NEC PC Engine wheels COMPLETED || Nintendo Wiiware wheels COMPLETED
diskmach Posted December 9, 2015 Author Posted December 9, 2015 Not a lot of discussion taking place here, but a solution to this problem seems to be using the test version from SSF´s site. I haven´t tested it much though, so you might experience other problems with this build. Remember to just copy over the settings from the R4 or R3 folder. Nintendo 3DS wheels thread || Nintendo 3DS wheel set download Bandai Wonderswan Color wheels thread || Bandai Wonderswan wheels thread NEC PC Engine wheels COMPLETED || Nintendo Wiiware wheels COMPLETED
