Krabat Posted December 11, 2015 Posted December 11, 2015 Hi, GameCards.exe is a little tool that helps you add or update backgrounds into RocketLauncher. Based on GameCards images package, now you can have a dedicated HyperPause background. * Requierements : ------------------------- Fully compatible with HyperSpin + RocketLauncher or KodiBox v7, v8 installation * Installation : -------------------- Place the GameCards.exe tool into a folder like \GameCards for example Golden Rules : - Under the GameCards tool, each system Folder must be declared : \Sega Genesis or \SNK Neo Geo - The name of the folders must be the same declared into HyperSpin XML systems (Main Menu.xml). If not declared, the GameCards will be ignored. - GameCards must be added into the System Folder - Gamecards are jpg files and EACH PICTURE NAME = ROM NAME into XML HyperSPin system database - XML HyperSpin database must be unicode (UTF-8) (the tool correct some HTML tags that cause errors regarding to the standard XML structure definition) I provide too GameCards : approx 1500 ( Genesis and Snes ) * Use : ----------- Launch GameCards.exe by double clic *** HyperSpin configuration : ----------------------------- a) RocketLauncher Folder asked : Select your RocketLauncher installation folder like : \HyperSpin\RocketLauncher HyperSpin Databases XML Folder asked : Select your HyperSpin Databases folder like : \HyperSpin\Databases *** KodiBox configuration : ------------------------ a) RocketLauncher Folder asked : Select your RocketLauncher installation folder like : \KodiBox\RocketLauncher HyperSpin Databases XML Folder asked : Select your HyperSpin Databases folder like : \KodiBox\Databases * Results : --------------- Each GameCards will be placed under Media\Backgrounds\<system name>\<game name>\Background 1.jpg of RocketLauncher The GameCard will be displayed when you will use the HyperPause menu for the related game A log file history (GameCards.log) indicates (Modified) if changes appears, new GameCards (Added) or (Skipped) because the GameCards is not found into the database system XML file Just launch GameCards.exe again to update your RocketLauncher backgrounds, when you have added or modified GameCards The GameCards.ini stores the configuration paths to bypass first launch questions The Download link is : https://mega.nz/#F!VNYiwSoA!OBvwhv8oonpR2IHFz8VXdg Choose EN for English Tree ... Enjoy !
