Error launching CPS3 in 1.4
mi4chel
Good morning friends,
I'm making a new installation of Hyperspin 1.4 0 + RL. I am using emulators he had in the previous version of HS.
For I have found problems with the emulator CPS3. From outside HS it works correctly, since RocketLauncherUI also works, but since HS, the emulator appears but does not load any game and this HS background and not charge anything.
In the log I can see is called the emulator + rom name. If I run it from a "cmd" I open the game smoothly.
You know that it may be due?
Frontend and use the Plugin "HyperSpin"
Thank you.
A greeting.
CPS3 games have their own emulator? I thought they all worked fine in MAME.
Good morning,
if you have its own emulator. I discovered the problem, it seems to move from version 1.3 to 1.4 + RL, something has changed and the next parameter was false:
Putting this in the setting of HS, it has worked
hyperlaunch = true
Apparently without this parameter, the command line happens to the HS is "emulator" + "name rom".
When I put this parameter, the command line happens to him is "emulator" + name rom
Thank you
A greeting.
