Image/Game Pixelation in HS
Skeeball_Fanatic
Hi Guys
Forgive me if there is an easy answer for this.  I'm basically a beginner, even though I've been here a while, and I've only survived by following tutorials to the letter.  So please be gentle with me.
I am using MAMEuifx .153 (as I got all my downloads etc from the Simply Austin youtube tutorial, so I just followed his lead).  I've got everything running perfectly, which is awesome because I tried it on my own and it ended in tears once before.  But my problem is this:
When I launch a game in HS, the title screens and game play is very pixelated.  Just to make sure it's not a problem with my system etc, I have launched the same games in MAMEuifx and also with RocketLauncher and each time they work fine.  So it's only in HS.  Which is driving me crazy because if it weren't for this issue I'd be up and running!
Does anyone have any thoughts?  Thanks in advance.
Yours hopefully
Skeeballer!
If it only happens in HyperSpin then I doubt HyperSpin is using RocketLauncher to launch the games. I would have said to turn on Bilinear filtering in RocketLauncher but it sounds as if that is already on.
How do you have HyperHQ set for mame? Is the launch method set to normal or HyperLaunch? Is the path to HyperLaunch set to RocketLauncher in the HyperSpin Settings.ini?
Perhaps run through the guide you used again.
Thanks for your reply. I understand some of those words ;).
Those are good tips and I thank you for that. When I'm home tomorrow I will check them (although I do think they are set as per your questions).
Edit: I forgot I had the laptop in the car. I have checked those things you suggested and they seem to be correct. HyperHQ is set to execute HyperLaunch and the settings.ini path points directly to the RL executable.
I don't know what bilinear filtering is, nor how to check if it's turned on in RL. I'll do a google search.
Thanks again. If you think of anything else I welcome your suggestion.
Further edit: thanks to you providing me with the term "bilinear filtering" it appears that it is actually set to off in RL and a google search has led me here:http://www.rlauncher.com/forum/archive/index.php/t-1832.html which seems to have the answer. Thanks once more and finally gigapig.
Further and final edit:http://www.hyperspin-fe.com/topic/13405-need-help-with-hyperspin-video-setting-games-in-pixels/ for anyone that might stumble onto this thread with this problem, gigapig has taken a pic that shows where to go in rlui. I have done it and the problem is solved. You're a legend gp.
