Nintendo DS Help
demonseed
Hey Guys,
I am new to this Nintendo ds thing and noticed with No$gba the games speed off too fast every time and run at like 2000%. I go into the emulation settings and change it to speed=realtime auto which fixes the issue.. however each time I close or open new game it does it again?
Also many games I get the error "No$GBA: How to fix " save data cannot be accessed"  I found a way to stop it by setting the GBA Cartridge media to AUTO however same as above I have to reset each game? I am an idiot? what am I missing here?
I have tried DSemume.. and it works but it does a weird thing.. ever load I hear a "PING" noise.. no idea why.. like the windows ping noise when you get a error window? I attached my log if someone knows the issue.
I set up retroarch and it works fine for me, however the controller does not utilize the pointer? I have gone into Xpadder and made a profile under E:\Rocketlauncher\Profiles\Xpadder\Nintendo DS and under the same dir under Default directory.  It works in testing but does not load on games? Anyone help?
Thanks so much
00:10:26:914 | RL |     INFO  | +N/A   | Main - RocketLauncher v1.0.1.4 (www.rlauncher.com)
00:10:26:914 | RL |  WARNING  | +0     | Main - You have "Logging_Log_Command_Window" enabled. This is only for logging errors being dumped to the command window from an executable. This may cause issues with running some executables and needs to be turned off when you are done.
00:10:27:085 | RL |     INFO  | +172   | Main - System Specs:
					RocketLauncher Dir: E:\Rocketlauncher
					RocketLauncher is: 32-bit
					OS: Microsoft Windows 7 Professional
					SKU: Professional
					Total Memory: 8016.31 MB
					Free Memory: 4750.24 MB
					Used Memory: 3266.074 MB
					SystemType: 64-bit
					Physical Processors: 1
					Logical Processors: 4
					GPU 1 Name: Intel(R) HD Graphics
					GPU 1 RAM: -1924.00 MB
					GPU 1 Driver Version: 9.17.10.3347
					Sound 1 Device: High Definition Audio Device
					Sound 1 Status: Enabled
					Sound 2 Device: High Definition Audio Device
					Sound 2 Status: Enabled
					OS Admin Status: Yes
					Latest .Net Version: v4.0.30319
					Monitor #1 (\\.\DISPLAY1): 1440x900 (1440x856 work) [Landscape] (Primary)
					Current AHK Desktop Width: 1440
					Current AHK Desktop Height: 900
					AutoHotkey Path: C:\Program Files\AutoHotkey\AutoHotkey.exe
					AHK Version: 1.1.09.04
					Unicode: No
00:10:27:085 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\RocketLauncher.exe exists
00:10:27:085 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					FileDescription         	RocketLauncher
					FileVersion             	1.0.1.4
					LegalCopyright          	©2015 RocketLauncher
					CompanyName             	Your favorite Front End companion! Visit us @ www.rlauncher.com
					File Size:			2063360 bytes
					Created:			5/23/2015 - 10:53:13 PM
					Modified:			11/26/2015 - 12:43:10 AM
00:10:27:085 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\Array.ahk exists
00:10:27:101 | RL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Extension.
00:10:27:101 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			4924 bytes
					Created:			11/26/2015 - 12:43:11 AM
					Modified:			11/26/2015 - 12:43:11 AM
00:10:27:116 | RL |     INFO  | +16    | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\BinHexRW.ahk exists
00:10:27:116 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
00:10:27:116 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			5077 bytes
					Created:			5/24/2015 - 8:27:48 AM
					Modified:			11/26/2015 - 12:42:57 AM
00:10:27:116 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\BlockInput.exe exists
					FileDescription
					InternalName
					OriginalFilename
					ProductName
					File Size:			657920 bytes
					Created:			5/24/2015 - 8:26:42 AM
					Modified:			1/2/2014 - 10:27:34 PM
00:10:27:132 | RL |     INFO  | +15    | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\CLR_L.ahk exists
00:10:27:132 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Extension.
00:10:27:132 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			5474 bytes
					Created:			9/6/2015 - 8:32:14 PM
					Modified:			9/6/2015 - 8:32:14 PM
00:10:27:132 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\Control_AniGif.ahk exists
00:10:27:148 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Extension.
00:10:27:148 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			5716 bytes
					Created:			5/24/2015 - 8:26:30 AM
					Modified:			4/29/2013 - 1:56:02 PM
00:10:27:148 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\gdip.ahk exists
00:10:27:163 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Extension.
00:10:27:163 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			88789 bytes
					Created:			5/24/2015 - 7:02:39 AM
					Modified:			1/13/2013 - 5:07:30 PM
00:10:27:179 | RL |     INFO  | +15    | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\gdip_alt.ahk exists
00:10:27:179 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
00:10:27:179 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			5895 bytes
					Created:			5/24/2015 - 8:25:59 AM
					Modified:			6/28/2015 - 6:41:33 AM
00:10:27:179 | RL |   DEBUG1  | +0     | gdip_alt.ahk Version: 1.0.2
00:10:27:179 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\gsdll32.dll exists
00:10:27:194 | RL |   DEBUG1  | +16    | CheckFile - Attributes:
					File Size:			13090816 bytes
					Created:			5/24/2015 - 8:25:19 AM
					Modified:			1/6/2015 - 9:20:42 PM
00:10:27:194 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\itextsharp.dll exists
00:10:27:194 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					FileDescription         	iTextSharp
					FileVersion             	5.4.2.0
					InternalName            	itextsharp.dll
					LegalCopyright          	Copyright (C) 1999-2013 by Bruno Lowagie and Paulo Soares. All Rights Reserved.
					OriginalFilename        	itextsharp.dll
					ProductName             	iTextSharp
					ProductVersion          	5.4.2.0
					CompanyName             	1T3XT BVBA
					File Size:			3743744 bytes
					Created:			5/24/2015 - 8:24:07 AM
					Modified:			6/14/2013 - 2:06:21 PM
00:10:27:194 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\Java.ahk exists
00:10:27:210 | RL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Library.
00:10:27:210 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			7841 bytes
					Created:			5/24/2015 - 8:27:37 AM
					Modified:			12/23/2014 - 11:02:37 PM
00:10:27:210 | RL |   DEBUG1  | +0     | Java.ahk Version: 1.0.0
00:10:27:210 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\JSON.ahk exists
00:10:27:210 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Extension.
00:10:27:226 | RL |   DEBUG1  | +16    | CheckFile - Attributes:
					File Size:			9203 bytes
					Created:			5/24/2015 - 8:26:08 AM
					Modified:			5/5/2013 - 2:22:25 PM
00:10:27:226 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\Origin.ahk exists
00:10:27:226 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
00:10:27:226 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			4904 bytes
					Created:			5/24/2015 - 8:26:27 AM
					Modified:			3/22/2015 - 2:51:41 PM
00:10:27:241 | RL |   DEBUG1  | +16    | Origin.ahk Version: 1.0.2
00:10:27:241 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\RegRW64.ahk exists
00:10:27:241 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Extension.
00:10:27:257 | RL |   DEBUG1  | +15    | CheckFile - Attributes:
					File Size:			6915 bytes
					Created:			5/24/2015 - 8:28:09 AM
					Modified:			5/8/2014 - 3:06:39 AM
00:10:27:257 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\RIni.ahk exists
00:10:27:257 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Extension.
00:10:27:272 | RL |   DEBUG1  | +16    | CheckFile - Attributes:
					File Size:			67561 bytes
					Created:			5/24/2015 - 8:28:04 AM
					Modified:			6/5/2013 - 6:56:23 PM
00:10:27:272 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\SevenZipSharp.dll exists
00:10:27:272 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					FileDescription         	SevenZipSharp
					FileVersion             	0.64.5717.6837
					InternalName            	SevenZipSharp.dll
					LegalCopyright          	Copyright (C) Markovtsev Vadim 2009, 2010, licenced under LGPLv3
					OriginalFilename        	SevenZipSharp.dll
					ProductName             	SevenZipSharp
					ProductVersion          	0.64.5717.6837
					CompanyName             	Markovtsev Vadim
					File Size:			167424 bytes
					Created:			5/24/2015 - 8:27:30 AM
					Modified:			11/26/2015 - 12:43:04 AM
00:10:27:288 | RL |     INFO  | +15    | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\Steam.ahk exists
00:10:27:288 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
00:10:27:288 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			5347 bytes
					Created:			5/24/2015 - 8:28:20 AM
					Modified:			3/22/2015 - 2:52:25 PM
00:10:27:288 | RL |   DEBUG1  | +0     | Steam.ahk Version: 1.0.2
00:10:27:288 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\VA.ahk exists
00:10:27:304 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Extension.
00:10:27:304 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			34688 bytes
					Created:			5/24/2015 - 8:26:53 AM
					Modified:			3/1/2013 - 9:05:47 PM
00:10:27:304 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\VA_Extension.ahk exists
00:10:27:319 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
00:10:27:319 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			3833 bytes
					Created:			5/24/2015 - 8:28:38 AM
					Modified:			1/13/2015 - 8:16:56 PM
00:10:27:319 | RL |   DEBUG1  | +0     | VA_Extension.ahk Version: 1.0.1
00:10:27:319 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Lib\7z.ahk exists
00:10:27:335 | RL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Library.
00:10:27:335 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			29149 bytes
					Created:			5/29/2015 - 11:47:30 PM
					Modified:			11/26/2015 - 12:42:55 AM
00:10:27:335 | RL |   DEBUG1  | +0     | 7z.ahk Version: 1.0.2
00:10:27:335 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Lib\Bezel.ahk exists
00:10:27:350 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
00:10:27:350 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			104277 bytes
					Created:			5/24/2015 - 8:28:01 AM
00:10:27:350 | RL |   DEBUG1  | +0     | Bezel.ahk Version: 1.1.7
00:10:27:350 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Lib\Fade.ahk exists
00:10:27:366 | RL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Library.
00:10:27:366 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			38251 bytes
					Created:			5/24/2015 - 8:26:50 AM
					Modified:			11/26/2015 - 12:43:06 AM
00:10:27:366 | RL |   DEBUG1  | +0     | Fade.ahk Version: 1.1.4
00:10:27:366 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Lib\Fade Init.ahk exists
00:10:27:366 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
00:10:27:382 | RL |   DEBUG1  | +16    | CheckFile - Attributes:
					File Size:			1065 bytes
					Created:			5/24/2015 - 8:27:38 AM
					Modified:			11/26/2015 - 12:43:12 AM
00:10:27:382 | RL |   DEBUG1  | +0     | Fade Init.ahk Version: 1.0.2
00:10:27:382 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Lib\Fade Animations.ahk exists
00:10:27:397 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
00:10:27:397 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			81174 bytes
					Created:			5/24/2015 - 8:27:41 AM
00:10:27:413 | RL |   DEBUG1  | +15    | Fade Animations.ahk Version: 1.1.10
00:10:27:413 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Lib\Keymapper.ahk exists
00:10:27:428 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
00:10:27:428 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			33453 bytes
					Created:			5/24/2015 - 8:28:11 AM
					Modified:			5/30/2015 - 9:18:27 PM
00:10:27:428 | RL |   DEBUG1  | +0     | Keymapper.ahk Version: 1.1.2
00:10:27:444 | RL |     INFO  | +15    | CheckFile - Checking if E:\Rocketlauncher\Lib\Keymapper Init.ahk exists
00:10:27:444 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
00:10:27:444 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			3461 bytes
					Created:			5/24/2015 - 8:26:35 AM
					Modified:			5/30/2015 - 9:18:57 PM
00:10:27:444 | RL |   DEBUG1  | +0     | Keymapper Init.ahk Version: 1.0.4
00:10:27:460 | RL |     INFO  | +16    | CheckFile - Checking if E:\Rocketlauncher\Lib\MultiGame.ahk exists
00:10:27:460 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
00:10:27:475 | RL |   DEBUG1  | +16    | CheckFile - Attributes:
					File Size:			40753 bytes
					Created:			5/24/2015 - 8:24:03 AM
					Modified:			9/6/2015 - 8:32:13 PM
00:10:27:475 | RL |   DEBUG1  | +0     | MultiGame.ahk Version: 1.0.8
00:10:27:475 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Lib\MultiGame Init.ahk exists
00:10:27:491 | RL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Library.
00:10:27:491 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			161 bytes
					Created:			5/24/2015 - 8:28:32 AM
					Modified:			4/14/2013 - 1:33:19 PM
00:10:27:491 | RL |   DEBUG1  | +0     | MultiGame Init.ahk Version: 1.0.0
00:10:27:506 | RL |     INFO  | +16    | CheckFile - Checking if E:\Rocketlauncher\Lib\MultiPlayer.ahk exists
00:10:27:506 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
00:10:27:506 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			66452 bytes
					Created:			5/24/2015 - 8:23:41 AM
					Modified:			11/26/2015 - 12:42:52 AM
00:10:27:506 | RL |   DEBUG1  | +0     | MultiPlayer.ahk Version: 1.0.7
00:10:27:522 | RL |     INFO  | +15    | CheckFile - Checking if E:\Rocketlauncher\Lib\Pause.ahk exists
00:10:27:538 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
00:10:27:538 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			392193 bytes
					Created:			5/24/2015 - 8:26:19 AM
					Modified:			11/26/2015 - 12:43:03 AM
00:10:27:538 | RL |   DEBUG1  | +0     | Pause.ahk Version: 1.1.5
00:10:27:553 | RL |     INFO  | +16    | CheckFile - Checking if E:\Rocketlauncher\Lib\Pause Init.ahk exists
00:10:27:553 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
00:10:27:569 | RL |   DEBUG1  | +15    | CheckFile - Attributes:
					File Size:			553 bytes
					Created:			5/24/2015 - 8:24:21 AM
					Modified:			9/6/2015 - 8:31:51 PM
00:10:27:569 | RL |   DEBUG1  | +0     | Pause Init.ahk Version: 1.0.3
00:10:27:569 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Lib\Password.ahk exists
00:10:27:569 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
00:10:27:584 | RL |   DEBUG1  | +16    | CheckFile - Attributes:
					File Size:			10025 bytes
					Created:			5/24/2015 - 8:24:18 AM
					Modified:			9/6/2015 - 8:31:55 PM
00:10:27:584 | RL |   DEBUG1  | +0     | Password.ahk Version: 1.0.2
00:10:27:584 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Lib\Rom Mapping Launch Menu.ahk exists
00:10:27:584 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
00:10:27:600 | RL |   DEBUG1  | +15    | CheckFile - Attributes:
					File Size:			74101 bytes
					Modified:			11/26/2015 - 12:42:54 AM
00:10:27:600 | RL |   DEBUG1  | +0     | Rom Mapping Launch Menu.ahk Version: 1.0.6
00:10:27:600 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Lib\Shared.ahk exists
00:10:27:600 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
00:10:27:616 | RL |   DEBUG1  | +16    | CheckFile - Attributes:
					File Size:			139893 bytes
					Modified:			11/26/2015 - 12:43:02 AM
00:10:27:616 | RL |   DEBUG1  | +0     | Shared.ahk Version: 1.3.5
00:10:27:616 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Lib\Statistics.ahk exists
00:10:27:616 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
00:10:27:631 | RL |   DEBUG1  | +16    | CheckFile - Attributes:
					File Size:			26143 bytes
					Created:			5/24/2015 - 8:26:45 AM
					Modified:			4/9/2015 - 4:16:56 AM
00:10:27:631 | RL |   DEBUG1  | +0     | Statistics.ahk Version: 1.0.3
00:10:27:631 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Lib\Statistics Init.ahk exists
00:10:27:631 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
00:10:27:631 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			33 bytes
					Modified:			12/23/2014 - 11:23:48 PM
00:10:27:647 | RL |   DEBUG1  | +15    | Statistics Init.ahk Version: 1.0.1
00:10:27:647 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Lib\Virtual Drive.ahk exists
00:10:27:662 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
00:10:27:662 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			18329 bytes
					Created:			5/29/2015 - 11:47:33 PM
					Modified:			11/26/2015 - 12:42:58 AM
00:10:27:662 | RL |   DEBUG1  | +0     | Virtual Drive.ahk Version: 1.0.3
00:10:27:662 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Lib\XHotkey.ahk exists
00:10:27:662 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
00:10:27:678 | RL |   DEBUG1  | +15    | CheckFile - Attributes:
					File Size:			26540 bytes
					Created:			5/24/2015 - 8:28:26 AM
					Modified:			9/6/2015 - 8:32:04 PM
00:10:27:678 | RL |   DEBUG1  | +0     | XHotkey.ahk Version: 1.0.4
00:10:27:678 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Lib\XHotkey Init.ahk exists
00:10:27:694 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
00:10:27:694 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			1063 bytes
					Created:			5/24/2015 - 8:26:46 AM
					Modified:			9/6/2015 - 8:31:50 PM
00:10:27:694 | RL |   DEBUG1  | +0     | XHotkey Init.ahk Version: 1.0.2
00:10:27:694 | RL |   DEBUG1  | +0     | Main - Raw CLI received: "-s Nintendo DS -r Arkanoid DS (USA) (En,Fr,De,Es,It) -e DeSmuME -f E:\Hyperspin\HyperSpin.exe -p HyperSpin -c 1"
00:10:27:694 | RL |   DEBUG1  | +0     | Main - Received this dbName with no path via CLI: "Arkanoid DS (USA) (En,Fr,De,Es,It)"
00:10:27:694 | RL |   DEBUG1  | +0     | Main - dbName: Arkanoid DS (USA) (En,Fr,De,Es,It)
00:10:27:709 | RL |     INFO  | +16    | Main - Arkanoid DS (USA) (En,Fr,De,Es,It) is being forced via CLI to use the emulator: DeSmuME
00:10:27:709 | RL |     INFO  | +0     | Main - Loading Front End Plugin: "HyperSpin"
00:10:27:709 | RL |     INFO  | +0     | Main - RocketLauncher received "Nintendo DS" and "Arkanoid DS (USA) (En,Fr,De,Es,It)"
00:10:27:740 | RL |     INFO  | +31    | Main - Did not find a "E:\Rocketlauncher\Settings\Nintendo DS\Game Options.ini" file, skipping any game-specific options.
00:10:27:740 | RL |     INFO  | +0     | Main - Checking for a [DeSmuME] section in E:\Rocketlauncher\Settings\Nintendo DS\Emulators.ini
00:10:27:740 | RL |     INFO  | +0     | Main - Checking for a [DeSmuME] section in E:\Rocketlauncher\Settings\Global Emulators.ini
00:10:27:740 | RL |     INFO  | +0     | Main - Found [DeSmuME] in E:\Rocketlauncher\Settings\Global Emulators.ini
00:10:27:756 | RL |     INFO  | +15    | CheckFile - Checking if E:\Rocketlauncher\Modules\DeSmuME\DeSmuME.ahk exists
00:10:27:756 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			4627 bytes
					Created:			5/24/2015 - 8:28:53 AM
					Modified:			4/4/2015 - 2:06:16 AM
00:10:27:772 | RL |     INFO  | +16    | Main - CRC Check - CRC matches, this is an official unedited module.
00:10:27:772 | RL |     INFO  | +0     | Main - Arkanoid DS (USA) (En,Fr,De,Es,It) will use module: E:\Rocketlauncher\Modules\DeSmuME\DeSmuME.ahk
00:10:27:787 | RL |     INFO  | +16    | Main - Using standard method with "Rom Extension" SkipChecks or without any SkipChecks.
00:10:27:787 | RL |     INFO  | +0     | CheckFile - Checking if E:\Hyperspin\Emulators\Nintendo DS\DeSmuME_0.9.9_x64.exe exists
00:10:27:803 | RL |   DEBUG1  | +15    | CheckFile - Attributes:
					File Size:			4682240 bytes
					Created:			12/18/2015 - 10:59:13 PM
					Modified:			4/27/2013 - 8:53:12 PM
00:10:27:803 | RL |     INFO  | +0     | Main - INI Keys read
00:10:27:803 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\7z.exe exists
00:10:27:803 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					FileVersion             	15.06 beta
					InternalName            	7z
					LegalCopyright          	Copyright (c) 1999-2015 Igor Pavlov
					ProductVersion          	15.06 beta
					File Size:			262144 bytes
					Created:			5/24/2015 - 8:26:40 AM
					Modified:			11/26/2015 - 12:42:56 AM
00:10:27:803 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\7z.dll exists
00:10:27:818 | RL |   DEBUG1  | +16    | CheckFile - Attributes:
					FileDescription         	7z Plugin
					InternalName            	7z
					OriginalFilename        	7z.dll
					File Size:			1012224 bytes
					Created:			5/24/2015 - 8:28:28 AM
					Modified:			11/26/2015 - 12:43:05 AM
00:10:27:818 | RL |     INFO  | +0     | Main - "Arkanoid DS (USA) (En,Fr,De,Es,It)" does not qualify for MultiGame. Only roms with any of these strings in their name are acceptable: (Disc,(Disk,(Cart,(Tape,(Cassette,(Part,(Side
00:10:27:818 | RL |     INFO  | +0     | CheckPaths - Started
00:10:27:818 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom: H:\DS READY\Arkanoid DS (USA) (En,Fr,De,Es,It).7z
00:10:27:850 | RL |     INFO  | +31    | CheckPaths - Found rom: H:\DS READY\Arkanoid DS (USA) (En,Fr,De,Es,It).7z
00:10:27:850 | RL |   DEBUG1  | +0     | CheckPaths - Current romName: Arkanoid DS (USA) (En,Fr,De,Es,It)
00:10:27:850 | RL |   DEBUG1  | +0     | CheckPaths - Current romPath: H:\DS READY
00:10:27:865 | RL |   DEBUG1  | +16    | CheckPaths - Current romExtension: .7z
00:10:27:865 | RL |     INFO  | +0     | CheckPaths - Ended
00:10:27:865 | RL |     INFO  | +0     | BuildScript - User Variables:
					; INJECTED VARIABLES
					#NoTrayIcon
					#InstallKeybdHook
					DetectHiddenWindows, ON
					SetTitleMatchMode, 2
					SendMode, Event
					0 = 12
					pluginPath = E:\Rocketlauncher\Plugins
					pluginName = HyperSpin
					pluginExt = .plugin
					contextOnExit = 1
					rlMode =
					rlTitle = RocketLauncher
					rlVersion = 1.0.1.4
					rlAuthor = djvj
					rlURL = www.rlauncher.com
					langFile = E:\Rocketlauncher\Data\Language\Localization.ini
					primMonitor = 1
					frontendPID =
					frontendPath = E:\Hyperspin
					frontendExe = HyperSpin.exe
					frontendExt = exe
					frontendName = HyperSpin
					frontendDrive = E:
					exitEmulatorKey = ~Esc|H3:1joy6
					restoreFE = Restore and Click
					exitScriptKey = ~q & ~s
					toggleCursorKey = ~e & ~t
					emuFullPath = E:\Hyperspin\Emulators\Nintendo DS\DeSmuME_0.9.9_x64.exe
					emuPath = E:\Hyperspin\Emulators\Nintendo DS
					emuName = DeSmuME
					emuExt = exe
					romPath = H:\DS READY
					romPathFromIni = H:\DS READY
					romExtension = .7z
					romExtensionOrig = .7z
					romExtensions = 7z|zip|rar|nds
					executable = DeSmuME_0.9.9_x64.exe
					systemDbName = Nintendo DS
					systemName = Nintendo DS
					dbPath =
					dbName = Arkanoid DS (USA) (En,Fr,De,Es,It)
					dbExt =
					romName = Arkanoid DS (USA) (En,Fr,De,Es,It)
					romMapPath =
					romMappingEnabled = false
					romMappingHideParent = false
					romMappingMenuWidth = 400
					romMappingMenuMargin = 65
					romMappingTextMargin = 15
					romMappingGameNameTextFont = Bebas Neue
					romMappingGameNameTextOptions = cFFFFFFFF r4 s40 Regular
					romMappingMenuFlagWidth = 55
					altArchiveNameOnly =
					altRomNameOnly =
					altArchiveAndRomName =
					altArchiveAndManyRomNames =
					altRomNamesOnly =
					romMapScenario =
					skipchecks = false
					romMatchExt = false
					blockInputTime = 0
					blockInputFile = E:\Rocketlauncher\Module Extensions\BlockInput.exe
					errorLevelReporting = false
					lockLaunch = false
					lockLaunchGame =
					screenRotationAngle = 0
					screenRotationAngleGame =
					logFile = E:\Rocketlauncher\RocketLauncher.log
					logLevel = 10
					logShowDebugConsole = true
					logIncludeModule = true
					logShowCommandWindow = false
					logCommandWindow = true
					rlDebugConsoleStdout = 7
					sysType = 64-bit
					broadcastWindowTitle =
					navUpKey = Up
					navDownKey = Down
					navLeftKey = Left
					navRightKey = Right
					navSelectKey = 1
					navP2UpKey = Numpad8
					navP2DownKey = Numpad2
					navP2LeftKey = Numpad4
					navP2RightKey = Numpad6
					navP2SelectKey = NumpadEnter
					originalWidth = 1440
					originalHeight = 900
					vdEnabled = false
					vdFullPath =
					vdUseSCSI = true
					vdDriveLetter =
					vdAddDrive = true
					servoStikEnabled = false
					servoStikExitMode = false
					ledblinkyEnabled = false
					ledblinkySystemName =
					ledblinkyFullPath =
					ledblinkyProfilePath = E:\Rocketlauncher\Profiles\LEDBlinky
					ledblinkyRLProfile = E:\Rocketlauncher\Profiles\LEDBlinky\RocketLauncher
					emuIdleShutdown = 0
					hideCursor = true
					hideEmu = false
					hideFE = false
					fadeIn = false
					fadeInDuration = 500
					fadeInDelay = 0
					fadeInExitDelay = 0
					fadeOutExitDelay = 0
					fadeOut = false
					fadeOutExtraScreen = false
					fadeOutDuration = 500
					fadeOutTransitionAnimation = LegacyFadeOutTransition
					fadeOutDelay = 0
					fadeLyrInterpolation = 7
					fadeMuteEmulator = false
					fadeUseBackgrounds = false
					fadeClickThrough = false
					fadeWidthBaseRes = 1920
					fadeHeightBaseRes = 1080
					fadeLyr1Color = FF000000
					fadeLyr2X = 0
					fadeLyr2Y = 0
					fadeLyr2W =
					fadeLyr2H =
					fadeLyr2Adjust = 1
					fadeLyr2PicPad = 0
					fadeLyr3Pos = Center
					fadeLyr3X = 450
					fadeLyr3Y = 5
					fadeLyr3W =
					fadeLyr3H =
					fadeLyr3Adjust = 1
					fadeLyr3PicPad = 0
					fadeLyr3Speed = 750
					fadeLyr3Type = imageandbar
					fadeLyr3Repeat = 1
					fadeLyr3StaticX = 0
					fadeLyr3StaticY = 870|1575
					fadeLyr3StaticW =
					fadeLyr3StaticH =
					fadeLyr3StaticAdjust = 1
					fadeLyr3StaticPicPad = 0
					fadeLyr4Adjust = 1
					fadeLyr4X = 1792|952
					fadeLyr4Y = 891|1596
					fadeLyr4W = 128
					fadeLyr4H =
					fadeLyr4Pos = No Alignment
					fadeLyr4FPS = 50
					fadeLyr4PicPad = 0
					fadeTranspGifColor = FFFFFF
					fadeBarWindow = Image
					fadeBarWindowX =
					fadeBarWindowY =
					fadeBarWindowW = 900
					fadeBarWindowH =
					fadeBarWindowR = 30
					fadeBarWindowM = 30
					fadeBarWindowHatchStyle = 8
					fadeBar = true
					fadeBarNon7zProgressTime = 0
					fadeBarBack = true
					fadeBarBackColor = FF555555
					fadeBarH = 30
					fadeBarR = 10
					fadeBarColor = DD00BFFF
					fadeBarHatchStyle = 8
					fadeBarPercentageText = true
					fadeBarInfoText = true
					fadeBarXOffset = 0
					fadeBarYOffset = 150
					fadeRomInfoSystemName = image
					fadeRomInfoManufacturer = text with label
					fadeRomInfoGenre = disabled
					fadeRomInfoRating = image
					fadeRomInfoTextMargin = 7
					fadeStatsInfoTextMargin = 7
					fadeText1X = 0
					fadeText1Y = 0
					fadeText1 = Loading Game
					fadeText2X = 0
					fadeText2Y = 0
					fadeText3 = Loading Game
					fadeText4 = Loading Complete
					fadeFont = Bebas Neue
					fadeExtractionTime = disabled
					fadeExtractionTimeTextX = 0
					fadeExtractionTimeTextY = 0
					fadeInterruptKey =
					detectFadeErrorEnabled = false
					fadeImgPath = E:\Rocketlauncher\Media\Fade
					RLDataPath = E:\Rocketlauncher\Data
					RLMediaPath = E:\Rocketlauncher\Media
					RLErrSoundPath = E:\Rocketlauncher\Media\Sounds\Error
					modulesPath = E:\Rocketlauncher\Modules
					moduleFullName = E:\Rocketlauncher\Modules\DeSmuME\DeSmuME.ahk
					moduleName = DeSmuME
					modulePath = E:\Rocketlauncher\Modules\DeSmuME
					moduleExtension = ahk
					moduleExtensionsPath = E:\Rocketlauncher\Module Extensions
					libPath = E:\Rocketlauncher\Lib
					7zEnabled = true
					7zPath = E:\Rocketlauncher\Module Extensions\7z.exe
					7zDllPath = E:\Rocketlauncher\Module Extensions\7z.dll
					7zExtractPath = C:\Users\Lenovo\AppData\Local\Temp\HS
					7zExtractPathOrig =
					7zAttachSystemName = false
					7zDelTemp = true
					7zSounds = true
					mgEnabled = false
					mgKey = ~NumpadSub
					mgBackgroundColor = FF000000
					mgSidePadding = 0.2
					mgWidthBaseRes = 1920
					mgHeightBaseRes = 1080
					mgYOffset = 500|800
					mgFont = Arial
					mgText2Offset = 100
					mgUseSound = true
					mgSoundfreq = 300
					mgExitEffect = none
					mgSelectedEffect = rotate
					mgUseGameArt = false
					mgCandidate =
					mgOnLaunch = false
					pauseEnabled = false
					pauseKey = m
					pauseBackToMenuBarKey = n
					pauseZoomInKey = C
					pauseZoomOutKey = V
					pauseHiToTextPath = E:\Rocketlauncher\Module Extensions\HiToText.exe
					pauseSaveStateKeyCodes = {Shift down}{F1 down}{F1 up}{Shift up}|{Shift down}{F2 down}{F2 up}{Shift up}|{Shift down}{F3 down}{F3 up}{Shift up}|{Shift down}{F4 down}{F4 up}{Shift up}|{Shift down}{F5 down}{F5 up}{Shift up}|{Shift down}{F6 down}{F6 up}{Shift up}|{Shift down}{F7 down}{F7 up}{Shift up}|{Shift down}{F8 down}{F8 up}{Shift up}|{Shift down}{F9 down}{F9 up}{Shift up}|{Shift down}{F10 down}{F10 up}{Shift up}
					pauseLoadStateKeyCodes = {F1 down}{F1 up}|{F2 down}{F2 up}|{F3 down}{F3 up}|{F4 down}{F4 up}|{F5 down}{F5 up}|{F6 down}{F6 up}|{F7 down}{F7 up}|{F8 down}{F8 up}|{F9 down}{F9 up}|{F10 down}{F10 up}
					keymapperEnabled = true
					keymapperAHKMethod = External
					keymapper = xpadder
					xpadderFullPath = E:\Hyperspin\Utilities\Xpadder\Xpadder.exe
					joyToKeyFullPath = E:\Utilities\JoyToKey\JoyToKey.exe
					keymapperProfilePath = E:\Rocketlauncher\Profiles\xpadder
					keymapperFrontEndProfileName = RocketLauncherUI
					keymapperFrontEndProfile = xpadder
					keymapperRocketLauncherProfileEnabled = true
					joyIDsEnabled = true
					joyIDsPreferredControllersGlobal = Controller (Xbox 360 Wireless Receiver for Windows)
					joyIDsPreferredControllersSystem = use_global
					joyIDsPreferredControllersOnExit =
					CustomJoyNamesEnabled = false
					CustomJoyNames =
					rotateMethod = false
					FEProfile = E:\Rocketlauncher\Profiles\xpadder\RocketLauncherUI
					defaultProfile = E:\Rocketlauncher\Profiles\xpadder\_Default
					systemProfile = E:\Rocketlauncher\Profiles\xpadder\Nintendo DS
					xPadderSystemProfile = E:\Rocketlauncher\Profiles\xpadder\Nintendo DS\_Default
					emuProfile = E:\Rocketlauncher\Profiles\xpadder\Nintendo DS\DeSmuME
					romProfile = E:\Rocketlauncher\Profiles\xpadder\Nintendo DS\Arkanoid DS (USA) (En,Fr,De,Es,It)
					RocketLauncherProfile = E:\Rocketlauncher\Profiles\xpadder\RocketLauncher
					blankProfile = E:\Rocketlauncher\Profiles\xpadder\_Default\blank
					ahkFEProfile = E:\Rocketlauncher\Profiles\AHK\RocketLauncherUI
					ahkDefaultProfile = E:\Rocketlauncher\Profiles\AHK\_Default
					ahkSystemProfile = E:\Rocketlauncher\Profiles\AHK\Nintendo DS
					ahkEmuProfile = E:\Rocketlauncher\Profiles\AHK\Nintendo DS\DeSmuME
					ahkRomProfile = E:\Rocketlauncher\Profiles\AHK\Nintendo DS\Arkanoid DS (USA) (En,Fr,De,Es,It)
					ahkRocketLauncherProfile = E:\Rocketlauncher\Profiles\AHK\RocketLauncher
					bezelEnabled = false
					bezelICEnabled = false
					statisticsEnabled = true
					pressDuration = -1
					emuVolume = 1
					dxwndIni = E:\Rocketlauncher\Module Extensions\dxwnd\dxwnd.ini
					dxwndFullPath = E:\Rocketlauncher\Module Extensions\dxwnd\dxwnd.exe
					mon1O =
					pacDrivedllFile = E:\Rocketlauncher\Module Extensions\PacDrive32.dll
					userFadeAnimIniFile = E:\Rocketlauncher\Lib\User Fade Animations.ini
00:10:27:912 | RL |     INFO  | +46    | BuildScript - Loaded XHotkey Init.ahk scripts
00:10:27:912 | RL |     INFO  | +0     | BuildScript - Loaded Keymapper Init.ahk scripts
00:10:27:912 | RL |     INFO  | +0     | BuildScript - Loaded Statistics Init.ahk scripts
00:10:27:928 | RL |  WARNING  | +16    | BuildScript - "E:\Rocketlauncher\Lib\User Functions Init.ahk" not found
00:10:27:928 | RL |   DEBUG1  | +0     | BuildScript - Module starts on line: 2
00:10:27:928 | RL |     INFO  | +0     | BuildScript - Validating module
00:10:27:928 | RL |     INFO  | +0     | BuildScript - Validation complete
00:10:27:928 | RL |     INFO  | +0     | BuildScript - Module:
					MEmu = DeSmuME
					MEmuV =  v0.9.9
					MURL = http://www.desmume.com/
					MAuthor = djvj
					MVersion = 2.0.6
					MCRC = 67395915
					iCRC = ACC0671E
					MID = 635038268882946453
					MSystem = "Nintendo DS"
					; Notes:
					; The example module ini from GIT comes with some of the vertical games already configured for vertical mode.
					; Uncheck View->Show Toolbar
					; Set View->Screen seperation to black, also choose your border (I prefer 5px)
					; Open the desmume.ini and add "Show Console=0" anywhere to stop the console window from showing up
					; Per-game vertical/rotation settings can be controlled via the module settings in RocketLauncherUI
					StartModule()
					BezelGUI()
					FadeInStart()
					fullscreen := IniReadCheck(settingsFile, "Settings", "Fullscreen","true",,1)
					vertical := IniReadCheck(settingsFile, "Settings|" . romName, "Vertical","false",,1)
					lcdsLayout := IniReadCheck(settingsFile, "Settings|" . romName, "LCDs_Layout",0,,1)
					lcdsSwap := IniReadCheck(settingsFile, "Settings|" . romName, "LCDs_Swap",0,,1)
					; X432R support
					SplitPath, executable,,,,exeNoExt
					x432rIni := emuPath . "\" . exeNoExt . ".ini"	; this fork always names the ini after the executable name
					x432riniFound :=
					If FileExist(x432rIni) {
						Log("Module - Found X432R DeSmuME Emu")
						desmumeIni := x432rIni
						x432riniFound := true
					} Else
						desmumeIni := CheckFile(emuPath . "\desmume.ini")
					currentRotate := IniReadCheck(desmumeIni, "Video", "Window Rotate",0,,1)
					currentRotateSet := IniReadCheck(desmumeIni, "Video", "Window Rotate Set",0,,1)
					currentLCDsLayout := IniReadCheck(desmumeIni, "Video", "LCDsLayout",0,,1)
					currentLCDsSwap := IniReadCheck(desmumeIni, "Video", "LCDsSwap",0,,1)
					If (vertical = "true"  && (currentRotate = 0 || currentRotateSet = 0)) {
						IniWrite, 270, %desmumeIni%, Video, Window Rotate
						IniWrite, 270, %desmumeIni%, Video, Window Rotate Set
					} Else If (vertical != "true"  && (currentRotate != 0 || currentRotateSet != 0)) {
						IniWrite, 0, %desmumeIni%, Video, Window Rotate
						IniWrite, 0, %desmumeIni%, Video, Window Rotate Set
					If (currentLCDsLayout != lcdsLayout)
						IniWrite, %lcdsLayout%, %desmumeIni%, Video, LCDsLayout
					If (currentLCDsSwap != lcdsSwap)
						IniWrite, %lcdsLayout%, %desmumeIni%, Video, LCDsSwap
					hideEmuObj := Object("ahk_class ConsoleWindowClass",0,"ahk_class DeSmuME",1)	; Hide_Emu will hide these windows. 0 = will never unhide, 1 = will unhide later
					BezelStart()
					If bezelPath {	; defining xscale and yscale relative to the bezel windowed mode
						IniWrite, 0, %desmumeIni%, Display, Window Split Border Drag
						If vertical = true
							screenGapPixels := (bezelScreenWidth - 2*192*bezelScreenHeight/256 ) // 2
						Else
							screenGapPixels := (bezelScreenHeight - 2*192*bezelScreenWidth/256 ) // 2
						IniWrite, %screenGapPixels%, %desmumeIni%, Display, ScreenGap
					If (bezelEnabled = "true" || fullscreen = "true")
						IniWrite, 0, %desmumeIni%, Display, Show Toolbar	; turn off the toolbar
					If x432riniFound {
						IniRead, currentWindowFS, %desmumeIni%, X432R, WindowFullScreen
						If (currentWindowFS != 1 && fullscreen = "true")
							IniWrite, 1, %desmumeIni%, X432R, WindowFullScreen
						Else If (currentWindowFS != 0 && fullscreen != "true")
							IniWrite, 0, %desmumeIni%, X432R, WindowFullScreen
					HideEmuStart()
					Run(executable . " """ . romPath . "\" . romName . romExtension . """", emuPath)
					WinWait("ahk_class DeSmuME")
					WinWaitActive("ahk_class DeSmuME")
					BezelDraw()
					If (Fullscreen = "true" && !x432riniFound)
					{	WinGetPos, x, y, w, h, ahk_class DeSmuME ; Getting original position of the emu, so we know when it goes Fullscreen
						Send, !{Enter} ; Go Fullscreen, DeSmuME does not support auto-fullscreen yet
						Loop { ; looping so we know when to destroy the GUI
							Sleep, 200
							WinGetPos, x2, y2, w2, h2, ahk_class DeSmuME
							;ToolTip, x=%x%`ny=%y%`nw=%w%`nh=%h%`nx2=%x2%`ny2=%y2%`nw2=%w2%`nh2=%h2%
							If ( x != x2 ) ; x changes when emu goes fullscreen, so we will break here and destroy the GUI
								Break
						Sleep, 200 ; Need a moment for the emu to finish going Fullscreen, otherwise we see the background briefly
					HideEmuEnd()
					FadeInExit()
					7zCleanUp()
					BezelExit()
					FadeOutExit()
					ExitModule()
					BezelLabel:
						disableHideTitleBar := true
						WinSet, Transparent, 0, ahk_class ConsoleWindowClass
					Return
					CloseProcess:
						FadeOutStart()
						WinClose("ahk_class DeSmuME")
					Return
00:10:27:959 | RL |     INFO  | +31    | BuildScript - Loaded Multi-Player scripts
00:10:27:959 | RL |     INFO  | +0     | BuildScript - Loaded Statistics.ahk script
00:10:27:959 | RL |  WARNING  | +0     | BuildScript - "E:\Rocketlauncher\Lib\User Functions.ahk" not found
00:10:27:959 | RL |     INFO  | +0     | BuildScript - Finished injecting functions into module
00:10:27:974 | RL |     INFO  | +16    | Main - Module is built
00:10:27:974 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\AutoHotkey.dll exists
00:10:27:974 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			785408 bytes
					Modified:			4/19/2013 - 6:16:32 PM
00:10:27:974 | RL |     INFO  | +0     | Main - Running module
00:10:27:974 | RL |     INFO  | +0     | Main - Starting timer to watch if Front End gets displaced and restore it if it does.
00:10:28:099 | MD |     INFO  | +N/A   | Module initialized
00:10:28:099 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Started
00:10:28:130 | MD |   DEBUG2  | +31    | XHotkeyTableCreation - KeyGroup ~Esc not in TableKeyGroups
00:10:28:130 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 1 check
00:10:28:130 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 2 check
00:10:28:130 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~Esc" to call label: "CloseProcess"
00:10:28:130 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Ended
00:10:28:130 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Started
00:10:28:162 | MD |   DEBUG2  | +31    | XHotkeyTableCreation - KeyGroup ~1joy6 not in TableKeyGroups ~Esc,
00:10:28:162 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 1 check
00:10:28:162 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 2 check
00:10:28:162 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Using extended Hotkey method for key(s): "~1joy6" to call a group label
00:10:28:193 | MD |   DEBUG2  | +31    | XHotkeyTableCreation - Ended
00:10:28:193 | MD |   DEBUG2  | +0     | Keymapper - Checking for the JoyIDs_Preferred_Controllers key  in E:\Rocketlauncher\Settings\Nintendo DS\Games JoyIDs.ini under section [Arkanoid DS (USA) (En,Fr,De,Es,It)]
00:10:28:193 | MD |     INFO  | +0     | LoadPreferredControllers - Started
00:10:28:224 | MD |   DEBUG2  | +31    | LoadPreferredControllers - JoyIDsPreferredControllers = Controller (Xbox 360 Wireless Receiver for Windows)
00:10:28:255 | MD |   DEBUG2  | +32    | LoadPreferredControllers - Creating a list of currently connected joysticks
00:10:28:255 | MD |     INFO  | +0     | GetJoystickArray - Started
00:10:28:255 | MD |   DEBUG2  | +0     | GetJoystickArray - Joysticks Detected: 1000000000000000
00:10:28:255 | MD |     INFO  | +0     | GetJoystickGUID - Started
00:10:28:255 | MD |     INFO  | +0     | GetJoystickGUID - Ended and found GUID: 5041DB96E6EDE4118001444553540000
00:10:28:286 | MD |   DEBUG2  | +31    | GetJoystickArray - ID: 1 | Port: 0 | Name: Controller (Xbox 360 Wireless Receiver for Windows) | MID: 045e | PID: 02a1 | GUID: 5041DB96E6EDE4118001444553540000
00:10:28:318 | MD |     INFO  | +31    | GetJoystickArray - Ended
00:10:28:318 | MD |   DEBUG2  | +0     | LoadPreferredControllers - Preferred Order Sorting List -> 1.01|045e|02a1|5041DB96E6EDE4118001444553540000
00:10:28:349 | MD |     INFO  | +31    | LoadPreferredControllers - Sorting Currently Connected joysticks List to match the order of the Preferred Controller List
00:10:28:349 | MD |     INFO  | +0     | LoadPreferredControllers - Assigning the New Joystick IDs according to the preferred list for the active controllers
00:10:28:349 | MD |     INFO  | +0     | ChangeJoystickID - Started
00:10:28:349 | MD |   DEBUG2  | +0     | ChangeJoystickID - Swapping Joystick ID: 00000000 to the New Joystick ID: 00000000, for the Joystick VID_045e&PID_02a1&GUID_5041DB96E6EDE4118001444553540000
00:10:28:380 | MD |     INFO  | +31    | ChangeJoystickID - Ended
00:10:28:380 | MD |     INFO  | +0     | LoadPreferredControllers - Ended
00:10:28:380 | MD |     INFO  | +0     | CheckFile - Checking if E:\Hyperspin\Utilities\Xpadder\Xpadder.exe exists
00:10:28:411 | MD |   DEBUG1  | +32    | CheckFile - Attributes:
					File Size:			1178624 bytes
					Created:			6/16/2015 - 11:46:34 AM
					Modified:			2/2/2014 - 3:10:38 PM
00:10:28:411 | MD |     INFO  | +0     | Keymapper - Loading xpadder
00:10:28:411 | MD |     INFO  | +0     | RunKeymapper - Started, using method "load"
00:10:28:411 | MD |     INFO  | +0     | GetJoystickArray - Started
00:10:28:442 | MD |   DEBUG2  | +31    | GetJoystickArray - Joysticks Detected: 1000000000000000
00:10:28:474 | MD |     INFO  | +31    | GetJoystickGUID - Started
00:10:28:505 | MD |     INFO  | +31    | GetJoystickGUID - Ended and found GUID: 5041DB96E6EDE4118001444553540000
00:10:28:505 | MD |   DEBUG2  | +0     | GetJoystickArray - ID: 1 | Port: 0 | Name: Controller (Xbox 360 Wireless Receiver for Windows) | MID: 045e | PID: 02a1 | GUID: 5041DB96E6EDE4118001444553540000
00:10:28:536 | MD |     INFO  | +31    | GetJoystickArray - Ended
00:10:28:536 | MD |   DEBUG2  | +0     | RunKeymapper - Found your keymapper application here: "E:\Hyperspin\Utilities\Xpadder\Xpadder.exe"
00:10:28:536 | MD |   DEBUG2  | +0     | RunKeymapper - Looping through controllers to find xpadder profiles for each one
00:10:28:536 | MD |   DEBUG2  | +0     | RunKeymapper - ID: 1 Now searching for a matching profile for this controller: "Controller (Xbox 360 Wireless Receiver for Windows)"
00:10:28:536 | MD |   DEBUG2  | +0     | GetProfile - Searching for these profiles (| delimited): E:\Rocketlauncher\Profiles\xpadder\Nintendo DS\Arkanoid DS (USA) (En,Fr,De,Es,It)|E:\Rocketlauncher\Profiles\xpadder\Nintendo DS\DeSmuME|E:\Rocketlauncher\Profiles\xpadder\Nintendo DS\_Default|E:\Rocketlauncher\Profiles\xpadder\_Default|E:\Rocketlauncher\Profiles\xpadder\_Default\blank
00:10:28:567 | MD |   DEBUG2  | +32    | GetProfile - Searching for a Player 1 profile -> E:\Rocketlauncher\Profiles\xpadder\Nintendo DS\Arkanoid DS (USA) (En,Fr,De,Es,It)\Controller (Xbox 360 Wireless Receiver for Windows)\p1.xpadderprofile
00:10:28:567 | MD |   DEBUG2  | +0     | GetProfile - Searching for a Player 1 profile -> E:\Rocketlauncher\Profiles\xpadder\Nintendo DS\Arkanoid DS (USA) (En,Fr,De,Es,It)\p1.xpadderprofile
00:10:28:567 | MD |   DEBUG2  | +0     | GetProfile - Searching for a Player 1 profile -> E:\Rocketlauncher\Profiles\xpadder\Nintendo DS\DeSmuME\Controller (Xbox 360 Wireless Receiver for Windows)\p1.xpadderprofile
00:10:28:567 | MD |   DEBUG2  | +0     | GetProfile - Searching for a Player 1 profile -> E:\Rocketlauncher\Profiles\xpadder\Nintendo DS\DeSmuME\p1.xpadderprofile
00:10:28:598 | MD |   DEBUG2  | +31    | GetProfile - Searching for a Player 1 profile -> E:\Rocketlauncher\Profiles\xpadder\Nintendo DS\_Default\Controller (Xbox 360 Wireless Receiver for Windows)\p1.xpadderprofile
00:10:28:630 | MD |   DEBUG2  | +31    | GetProfile - Searching for a Player 1 profile -> E:\Rocketlauncher\Profiles\xpadder\Nintendo DS\_Default\p1.xpadderprofile
00:10:28:630 | MD |   DEBUG2  | +0     | GetProfile - Searching for a Player 1 profile -> E:\Rocketlauncher\Profiles\xpadder\_Default\Controller (Xbox 360 Wireless Receiver for Windows)\p1.xpadderprofile
00:10:28:630 | MD |   DEBUG2  | +0     | GetProfile - Searching for a Player 1 profile -> E:\Rocketlauncher\Profiles\xpadder\_Default\p1.xpadderprofile
00:10:28:661 | MD |     INFO  | +31    | GetProfile - Loading Player 1 Profile -> E:\Rocketlauncher\Profiles\xpadder\_Default\p1.xpadderprofile
00:10:28:661 | MD |     INFO  | +0     | RunXpadder - Started
00:10:28:661 | MD |     INFO  | +0     | Process - Exist JoyToKey.exe
00:10:28:661 | MD |   DEBUG2  | +0     | RunXpadder - Closing xpadder to refresh controllers seen by xpadder
00:10:28:692 | MD |     INFO  | +31    | Run - Running: E:\Hyperspin\Utilities\Xpadder\Xpadder.exe /C
00:10:28:786 | MD |   DEBUG1  | +94    | Run - "Xpadder.exe /C" Process ID: 1016
00:10:28:786 | MD |   DEBUG2  | +0     | RunXpadder - Creating an array of connected controllers and profiles to arrange according to the order found in E:\Hyperspin\Utilities\Xpadder\xpadder.ini
00:10:28:786 | MD |     INFO  | +0     | Process - WaitClose Xpadder.exe 2
00:10:29:222 | MD |   DEBUG2  | +437   | RunXpadder - Reading the order in E:\Hyperspin\Utilities\Xpadder\xpadder.ini and arranging profiles found to match that order
00:10:29:222 | MD |   DEBUG2  | +0     | RunXpadder - No more controllers to be found
00:10:29:222 | MD |     INFO  | +0     | Run - Running: E:\Hyperspin\Utilities\Xpadder\Xpadder.exe "E:\Rocketlauncher\Profiles\xpadder\_Default\p1.xpadderprofile" /M
00:10:29:285 | MD |   DEBUG1  | +62    | Run - "Xpadder.exe "E:\Rocketlauncher\Profiles\xpadder\_Default\p1.xpadderprofile" /M" Process ID: 4352
00:10:29:285 | MD |     INFO  | +0     | RunXpadder - Ended
00:10:29:285 | MD |     INFO  | +0     | RunKeymapper - Ended
00:10:29:285 | MD |     INFO  | +0     | Keymapper - Loading External AHK Keymapping
00:10:29:285 | MD |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\AhkLauncher.exe exists
00:10:29:316 | MD |   DEBUG1  | +31    | CheckFile - Attributes:
					FileDescription         	AhkLauncher
					FileVersion             	1.0.0.0
					InternalName            	AhkLauncher.exe
					LegalCopyright          	Copyright ©  2013
					OriginalFilename        	AhkLauncher.exe
					ProductName             	AhkLauncher
					ProductVersion          	1.0.0.0
					File Size:			11264 bytes
					Created:			5/24/2015 - 8:28:06 AM
					Modified:			9/4/2013 - 6:30:52 PM
00:10:29:347 | MD |     INFO  | +32    | RunAHKKeymapper - Started
00:10:29:347 | MD |   DEBUG1  | +0     | RunAHKKeymapper - Loading Arkanoid DS (USA) (En,Fr,De,Es,It), DeSmuME, Nintendo DS, or _Default AHK Keymapper profile
00:10:29:347 | MD |     INFO  | +0     | GetAHKProfile - Started
00:10:29:378 | MD |   DEBUG2  | +31    | GetAHKProfile - Searching for: E:\Rocketlauncher\Profiles\AHK\Nintendo DS\Arkanoid DS (USA) (En,Fr,De,Es,It).ahk
00:10:29:378 | MD |   DEBUG2  | +0     | GetAHKProfile - Searching for: E:\Rocketlauncher\Profiles\AHK\Nintendo DS\DeSmuME.ahk
00:10:29:378 | MD |   DEBUG2  | +0     | GetAHKProfile - Searching for: E:\Rocketlauncher\Profiles\AHK\Nintendo DS.ahk
00:10:29:410 | MD |   DEBUG2  | +31    | GetAHKProfile - Searching for: E:\Rocketlauncher\Profiles\AHK\_Default.ahk
00:10:29:410 | MD |     INFO  | +0     | GetAHKProfile - Ended and no profile found
00:10:29:410 | MD |   DEBUG1  | +0     | RunAHKKeymapper - If AhkLauncher.exe is running, need to close it first before a new profile can be loaded
00:10:29:441 | MD |     INFO  | +31    | Process - Exist AhkLauncher.exe
00:10:29:441 | MD |     INFO  | +0     | RunAHKKeymapper - Ended
00:10:29:441 | MD |     INFO  | +0     | StartModule - Started
00:10:29:441 | MD |     INFO  | +0     | StartModule - MEmu: DeSmuME
					MEmuV: v0.9.9
					MURL: http://www.desmume.com/
					MAuthor: djvj
					MVersion: 2.0.6
					MCRC: 67395915
					iCRC: ACC0671E
					MID:
					MSystem: "Nintendo DS"
00:10:29:441 | MD |     INFO  | +0     | StartModule - You have a supported System Name for this module: "Nintendo DS"
00:10:29:441 | MD |     INFO  | +0     | PluginInit - Started
00:10:29:472 | MD |   DEBUG1  | +31    | BuildDatabaseTable - Started - Building Table for: Name|Cloneof|Manufacturer|Year|Genre|Rating
00:10:29:472 | MD |     INFO  | +0     | CheckFile - Checking if E:\Hyperspin\Databases\Nintendo DS\Nintendo DS.xml exists
00:10:29:503 | MD |   DEBUG1  | +32    | CheckFile - Attributes:
					File Size:			674993 bytes
					Created:			12/18/2015 - 10:59:52 PM
					Modified:			12/18/2015 - 10:59:54 PM
00:10:29:503 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Searching for a "Game Name" in the database
00:10:29:503 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Found "Game Name" in the database!
00:10:29:534 | MD |   DEBUG1  | +31    | BuildDatabaseTable - Searching database for: Name
00:10:29:534 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Found "Name" with a value: "Arkanoid DS"
00:10:29:534 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Searching database for: Cloneof
00:10:29:534 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Could not find: Cloneof
00:10:29:534 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Searching database for: Manufacturer
00:10:29:566 | MD |   DEBUG1  | +31    | BuildDatabaseTable - Could not find: Manufacturer
00:10:29:597 | MD |   DEBUG1  | +31    | BuildDatabaseTable - Searching database for: Year
00:10:29:597 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Could not find: Year
00:10:29:597 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Searching database for: Genre
00:10:29:628 | MD |   DEBUG1  | +31    | BuildDatabaseTable - Could not find: Genre
00:10:29:628 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Searching database for: Rating
00:10:29:628 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Found "Rating" with a value: "Other - NR (Not Rated)"
00:10:29:628 | MD |   DEBUG2  | +0     | PluginInit - GameInfo:
					GameInfo Label: Name | GameInfo Value: Arkanoid DS
					GameInfo Label: Rating | GameInfo Value: Other - NR (Not Rated)
00:10:29:628 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Ended
00:10:29:659 | MD |   DEBUG1  | +32    | BuildAssetsTable - Started - Building Table for: Game Logo|System Logo
00:10:29:659 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a Game Logo: E:\Hyperspin\Media\Nintendo DS\Images\Wheel\Arkanoid DS (USA) (En,Fr,De,Es,It).png
00:10:29:659 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a System Logo: E:\Hyperspin\Media\Main Menu\Images\Wheel\Nintendo DS.png
00:10:29:690 | MD |   DEBUG1  | +31    | BuildAssetsTable - Ended
00:10:29:690 | MD |   DEBUG1  | +0     | BuildAssetsTable - Started - Building Table for: Artwork1|Box Art|Cartridge|Flyers|Letters|Other
00:10:29:690 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a Artwork1: E:\Hyperspin\Media\Nintendo DS\Images\Artwork1\Arkanoid DS (USA) (En,Fr,De,Es,It).png
00:10:29:690 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a Box Art: E:\Hyperspin\Media\Nintendo DS\Images\Artwork2\Arkanoid DS (USA) (En,Fr,De,Es,It).png
00:10:29:690 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a Cartridge: E:\Hyperspin\Media\Nintendo DS\Images\Artwork3\Arkanoid DS (USA) (En,Fr,De,Es,It).png
00:10:29:722 | MD |   DEBUG1  | +31    | BuildAssetsTable - Searching for a Flyers: E:\Hyperspin\Media\Nintendo DS\Images\Artwork4\Arkanoid DS (USA) (En,Fr,De,Es,It).png
00:10:29:722 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a Letters: E:\Hyperspin\Media\Nintendo DS\Images\Letters
00:10:29:784 | MD |   DEBUG1  | +62    | BuildAssetsTable - Searching for a Other: E:\Hyperspin\Media\Nintendo DS\Images\Other
00:10:29:784 | MD |   DEBUG2  | +0     | BuildAssetsTable - Media assets found:
					Asset Label: Letters | Asset Path1:  E:\Hyperspin\Media\Nintendo DS\Images\Letters\!.png | Asset Extension1:  png | Asset Type1:  system
					Asset Label: Letters | Asset Path2:  E:\Hyperspin\Media\Nintendo DS\Images\Letters\'.png | Asset Extension2:  png | Asset Type2:  system
					Asset Label: Letters | Asset Path3:  E:\Hyperspin\Media\Nintendo DS\Images\Letters\(.png | Asset Extension3:  png | Asset Type3:  system
					Asset Label: Letters | Asset Path4:  E:\Hyperspin\Media\Nintendo DS\Images\Letters\0.png | Asset Extension4:  png | Asset Type4:  system
					Asset Label: Letters | Asset Path5:  E:\Hyperspin\Media\Nintendo DS\Images\Letters\1.png | Asset Extension5:  png | Asset Type5:  system
					Asset Label: Letters | Asset Path6:  E:\Hyperspin\Media\Nintendo DS\Images\Letters\2.png | Asset Extension6:  png | Asset Type6:  system
					Asset Label: Letters | Asset Path7:  E:\Hyperspin\Media\Nintendo DS\Images\Letters\3.png | Asset Extension7:  png | Asset Type7:  system
					Asset Label: Letters | Asset Path8:  E:\Hyperspin\Media\Nintendo DS\Images\Letters\4.png | Asset Extension8:  png | Asset Type8:  system
					Asset Label: Letters | Asset Path9:  E:\Hyperspin\Media\Nintendo DS\Images\Letters\5.png | Asset Extension9:  png | Asset Type9:  system
					Asset Label: Letters | Asset Path10:  E:\Hyperspin\Media\Nintendo DS\Images\Letters\6.png | Asset Extension10:  png | Asset Type10:  system
					Asset Label: Letters | Asset Path11:  E:\Hyperspin\Media\Nintendo DS\Images\Letters\7.png | Asset Extension11:  png | Asset Type11:  system
					Asset Label: Letters | Asset Path12:  E:\Hyperspin\Media\Nintendo DS\Images\Letters\8.png | Asset Extension12:  png | Asset Type12:  system
					Asset Label: Letters | Asset Path13:  E:\Hyperspin\Media\Nintendo DS\Images\Letters\9.png | Asset Extension13:  png | Asset Type13:  system
					Asset Label: Letters | Asset Path14:  E:\Hyperspin\Media\Nintendo DS\Images\Letters\a.png | Asset Extension14:  png | Asset Type14:  system
					Asset Label: Letters | Asset Path15:  E:\Hyperspin\Media\Nintendo DS\Images\Letters\b.png | Asset Extension15:  png | Asset Type15:  system
					Asset Label: Letters | Asset Path16:  E:\Hyperspin\Media\Nintendo DS\Images\Letters\c.png | Asset Extension16:  png | Asset Type16:  system
					Asset Label: Letters | Asset Path17:  E:\Hyperspin\Media\Nintendo DS\Images\Letters\d.png | Asset Extension17:  png | Asset Type17:  system
					Asset Label: Letters | Asset Path18:  E:\Hyperspin\Media\Nintendo DS\Images\Letters\e.png | Asset Extension18:  png | Asset Type18:  system
					Asset Label: Letters | Asset Path19:  E:\Hyperspin\Media\Nintendo DS\Images\Letters\f.png | Asset Extension19:  png | Asset Type19:  system
					Asset Label: Letters | Asset Path20:  E:\Hyperspin\Media\Nintendo DS\Images\Letters\g.png | Asset Extension20:  png | Asset Type20:  system
					Asset Label: Letters | Asset Path21:  E:\Hyperspin\Media\Nintendo DS\Images\Letters\h.png | Asset Extension21:  png | Asset Type21:  system
					Asset Label: Letters | Asset Path22:  E:\Hyperspin\Media\Nintendo DS\Images\Letters\i.png | Asset Extension22:  png | Asset Type22:  system
					Asset Label: Letters | Asset Path23:  E:\Hyperspin\Media\Nintendo DS\Images\Letters\j.png | Asset Extension23:  png | Asset Type23:  system
					Asset Label: Letters | Asset Path24:  E:\Hyperspin\Media\Nintendo DS\Images\Letters\k.png | Asset Extension24:  png | Asset Type24:  system
					Asset Label: Letters | Asset Path25:  E:\Hyperspin\Media\Nintendo DS\Images\Letters\l.png | Asset Extension25:  png | Asset Type25:  system
					Asset Label: Letters | Asset Path26:  E:\Hyperspin\Media\Nintendo DS\Images\Letters\m.png | Asset Extension26:  png | Asset Type26:  system
					Asset Label: Letters | Asset Path27:  E:\Hyperspin\Media\Nintendo DS\Images\Letters\n.png | Asset Extension27:  png | Asset Type27:  system
					Asset Label: Letters | Asset Path28:  E:\Hyperspin\Media\Nintendo DS\Images\Letters\o.png | Asset Extension28:  png | Asset Type28:  system
					Asset Label: Letters | Asset Path29:  E:\Hyperspin\Media\Nintendo DS\Images\Letters\p.png | Asset Extension29:  png | Asset Type29:  system
					Asset Label: Letters | Asset Path30:  E:\Hyperspin\Media\Nintendo DS\Images\Letters\q.png | Asset Extension30:  png | Asset Type30:  system
					Asset Label: Letters | Asset Path31:  E:\Hyperspin\Media\Nintendo DS\Images\Letters\r.png | Asset Extension31:  png | Asset Type31:  system
					Asset Label: Letters | Asset Path32:  E:\Hyperspin\Media\Nintendo DS\Images\Letters\s.png | Asset Extension32:  png | Asset Type32:  system
					Asset Label: Letters | Asset Path33:  E:\Hyperspin\Media\Nintendo DS\Images\Letters\t.png | Asset Extension33:  png | Asset Type33:  system
					Asset Label: Letters | Asset Path34:  E:\Hyperspin\Media\Nintendo DS\Images\Letters\u.png | Asset Extension34:  png | Asset Type34:  system
					Asset Label: Letters | Asset Path35:  E:\Hyperspin\Media\Nintendo DS\Images\Letters\v.png | Asset Extension35:  png | Asset Type35:  system
					Asset Label: Letters | Asset Path36:  E:\Hyperspin\Media\Nintendo DS\Images\Letters\w.png | Asset Extension36:  png | Asset Type36:  system
					Asset Label: Letters | Asset Path37:  E:\Hyperspin\Media\Nintendo DS\Images\Letters\x.png | Asset Extension37:  png | Asset Type37:  system
					Asset Label: Letters | Asset Path38:  E:\Hyperspin\Media\Nintendo DS\Images\Letters\y.png | Asset Extension38:  png | Asset Type38:  system
					Asset Label: Letters | Asset Path39:  E:\Hyperspin\Media\Nintendo DS\Images\Letters\z.png | Asset Extension39:  png | Asset Type39:  system
					Asset Label: Other | Asset Path1:  E:\Hyperspin\Media\Nintendo DS\Images\Other\Pointer.png | Asset Extension1:  png | Asset Type1:  system
00:10:29:815 | MD |   DEBUG1  | +32    | BuildAssetsTable - Ended
00:10:29:815 | MD |   DEBUG1  | +0     | BuildAssetsTable - Started - Building Table for: Game Video|System Video
00:10:29:815 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a Game Video: E:\Hyperspin\Media\Nintendo DS\Video\Arkanoid DS (USA) (En,Fr,De,Es,It).*
00:10:29:815 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a System Video: E:\Hyperspin\Media\Main Menu\Video\Nintendo DS.*
00:10:29:815 | MD |   DEBUG1  | +0     | BuildAssetsTable - Ended
00:10:29:846 | MD |     INFO  | +31    | PluginInit - Ended
00:10:29:846 | MD |   DEBUG1  | +0     | StartModule - Setting romName to the dbName sent to RocketLauncher: Arkanoid DS (USA) (En,Fr,De,Es,It)
00:10:29:846 | MD |     INFO  | +0     | Hiding mouse cursor
00:10:29:878 | MD |   DEBUG2  | +31    | XHotkeyTableCreation - Started
00:10:29:878 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - KeyGroup ~e&~t not in TableKeyGroups ~Esc,~1joy6,
00:10:29:909 | MD |   DEBUG2  | +31    | XHotkeyTableCreation - Post loop 1 check
00:10:29:909 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 2 check
00:10:29:909 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~e & ~t" to call label: "ToggleCursor"
00:10:29:909 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Ended
00:10:29:940 | MD |     INFO  | +31    | StartModule - Ended
00:10:29:940 | MD |     INFO  | +0     | Module Setting - [Settings] - Fullscreen: true
00:10:29:940 | MD |     INFO  | +0     | Module Setting - [Settings] - Vertical: false
00:10:29:940 | MD |     INFO  | +0     | Module Setting - [Arkanoid DS (USA) (En,Fr,De,Es,It)] - Vertical: false
00:10:29:971 | MD |     INFO  | +32    | Module Setting - [Settings] - LCDs_Layout: 0
00:10:29:971 | MD |     INFO  | +0     | Module Setting - [Arkanoid DS (USA) (En,Fr,De,Es,It)] - LCDs_Layout: 0
00:10:29:971 | MD |     INFO  | +0     | Module Setting - [Settings] - LCDs_Swap: 0
00:10:29:971 | MD |     INFO  | +0     | Module Setting - [Arkanoid DS (USA) (En,Fr,De,Es,It)] - LCDs_Swap: 0
00:10:29:002 | MD |     INFO  | +31    | CheckFile - Checking if E:\Hyperspin\Emulators\Nintendo DS\desmume.ini exists
00:10:30:002 | MD |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			1258 bytes
					Created:			12/18/2015 - 10:59:23 PM
					Modified:			12/21/2015 - 12:08:34 AM
00:10:30:002 | MD |     INFO  | +0     | Module Setting - [Video] - Window Rotate: 0
00:10:30:002 | MD |     INFO  | +0     | Module Setting - [Video] - Window Rotate Set: 0
00:10:30:034 | MD |     INFO  | +31    | Module Setting - [Video] - LCDsLayout: 0
00:10:30:034 | MD |     INFO  | +0     | Module Setting - [Video] - LCDsSwap: 0
00:10:30:034 | MD |     INFO  | +0     | 7z - Started, received H:\DS READY\Arkanoid DS (USA) (En,Fr,De,Es,It).7z. If rom is an archive, it will extract to C:\Users\Lenovo\AppData\Local\Temp\HS
00:10:30:034 | MD |   DEBUG1  | +0     | 7z - Using Standard method to extract this rom
00:10:30:065 | MD |   DEBUG1  | +31    | 7z - ".7z" found in .zip,.rar,.7z,.lzh,.gzip,.tar
00:10:30:065 | MD |     INFO  | +0     | CheckFile - Checking if H:\DS READY\Arkanoid DS (USA) (En,Fr,De,Es,It).7z exists
00:10:30:096 | MD |   DEBUG1  | +31    | CheckFile - Attributes:
					File Size:			34856944 bytes
					Created:			12/20/2015 - 11:08:55 AM
					Modified:			12/20/2015 - 11:09:08 AM
00:10:30:190 | MD |     INFO  | +94    | 7z - Archive name matches rom name; DLL found rom inside archive using "findFileInZip": "Arkanoid DS (USA) (En,Fr,De,Es,It).nds"
00:10:30:221 | MD |   DEBUG1  | +31    | 7z - Invoked COM Object, ROM extracted size: 67108864 bytes
00:10:30:221 | MD |   DEBUG1  | +0     | 7z - Checking if this archive has already been extracted in C:\Users\Lenovo\AppData\Local\Temp\HS\Arkanoid DS (USA) (En,Fr,De,Es,It)
00:10:30:252 | MD |   DEBUG1  | +31    | 7z - File does not already exist in C:\Users\Lenovo\AppData\Local\Temp\HS\Arkanoid DS (USA) (En,Fr,De,Es,It), proceeding to extract it.
00:10:30:252 | MD |   DEBUG1  | +0     | 7z - File found in archive
00:10:30:252 | MD |     INFO  | +0     | 7z - Extracted path of rom will be 111 in length and within the 255 character limit.
00:10:30:252 | MD |     INFO  | +0     | 7z - The 7zExtractPath has 104068 MB of free space which is enough to extract this game: 67 MB
00:10:30:283 | MD |   DEBUG1  | +32    | 7z - Logging is debug or higher, dumping 7z Extraction info to log
00:10:30:283 | MD |   DEBUG1  | +0     | 7z - Starting 7z extraction of H:\DS READY\Arkanoid DS (USA) (En,Fr,De,Es,It).7z  to C:\Users\Lenovo\AppData\Local\Temp\HS\Arkanoid DS (USA) (En,Fr,De,Es,It)
00:10:30:314 | MD |     INFO  | +31    | Process - Wait 7z.exe 2
00:10:30:314 | MD |   DEBUG1  | +0     | 7z - Starting 7zTimeout Timer
00:10:30:392 | MD |   DEBUG1  | +78    | Extracting file:		|	Percentage Extracted:   0%
00:10:30:502 | MD |   DEBUG1  | +109   | Extracting file:	Arkanoid DS (USA) (En,Fr,De,Es,It).nds	|	Percentage Extracted:   6%
00:10:30:611 | MD |   DEBUG1  | +109   | Extracting file:	Arkanoid DS (USA) (En,Fr,De,Es,It).nds	|	Percentage Extracted:   6%
00:10:30:720 | MD |   DEBUG1  | +109   | Extracting file:	Arkanoid DS (USA) (En,Fr,De,Es,It).nds	|	Percentage Extracted:  13%
00:10:30:829 | MD |   DEBUG1  | +110   | Extracting file:	Arkanoid DS (USA) (En,Fr,De,Es,It).nds	|	Percentage Extracted:  13%
00:10:30:938 | MD |   DEBUG1  | +109   | Extracting file:	Arkanoid DS (USA) (En,Fr,De,Es,It).nds	|	Percentage Extracted:  19%
00:10:31:048 | MD |   DEBUG1  | +109   | Extracting file:	Arkanoid DS (USA) (En,Fr,De,Es,It).nds	|	Percentage Extracted:  25%
00:10:31:157 | MD |   DEBUG1  | +109   | Extracting file:	Arkanoid DS (USA) (En,Fr,De,Es,It).nds	|	Percentage Extracted:  25%
00:10:31:266 | MD |   DEBUG1  | +109   | Extracting file:	Arkanoid DS (USA) (En,Fr,De,Es,It).nds	|	Percentage Extracted:  31%
00:10:31:375 | MD |   DEBUG1  | +110   | Extracting file:	Arkanoid DS (USA) (En,Fr,De,Es,It).nds	|	Percentage Extracted:  31%
00:10:31:484 | MD |   DEBUG1  | +109   | Extracting file:	Arkanoid DS (USA) (En,Fr,De,Es,It).nds	|	Percentage Extracted:  38%
00:10:31:594 | MD |   DEBUG1  | +109   | Extracting file:	Arkanoid DS (USA) (En,Fr,De,Es,It).nds	|	Percentage Extracted:  38%
00:10:31:703 | MD |   DEBUG1  | +109   | Extracting file:	Arkanoid DS (USA) (En,Fr,De,Es,It).nds	|	Percentage Extracted:  44%
00:10:31:812 | MD |   DEBUG1  | +109   | Extracting file:	Arkanoid DS (USA) (En,Fr,De,Es,It).nds	|	Percentage Extracted:  44%
00:10:31:921 | MD |   DEBUG1  | +110   | Extracting file:	Arkanoid DS (USA) (En,Fr,De,Es,It).nds	|	Percentage Extracted:  50%
00:10:32:030 | MD |   DEBUG1  | +109   | Extracting file:	Arkanoid DS (USA) (En,Fr,De,Es,It).nds	|	Percentage Extracted:  56%
00:10:32:140 | MD |   DEBUG1  | +109   | Extracting file:	Arkanoid DS (USA) (En,Fr,De,Es,It).nds	|	Percentage Extracted:  69%
00:10:32:249 | MD |   DEBUG1  | +109   | Extracting file:	Arkanoid DS (USA) (En,Fr,De,Es,It).nds	|	Percentage Extracted:  81%
00:10:32:358 | MD |   DEBUG1  | +109   | Extracting file:	Arkanoid DS (USA) (En,Fr,De,Es,It).nds	|	Percentage Extracted: 100%
00:10:32:467 | MD |   DEBUG1  | +110   | Extracting file:	Arkanoid DS (USA) (En,Fr,De,Es,It).nds	|	Percentage Extracted: 100%
00:10:32:561 | MD |   DEBUG1  | +93    | 7zTimeout - 7z.exe is no longer running
00:10:32:576 | MD |   DEBUG1  | +16    | Extracting file:	Arkanoid DS (USA) (En,Fr,De,Es,It).nds	|	Percentage Extracted: 100%
00:10:32:576 | MD |   DEBUG1  | +0     | 7z - 7z.exe returned a percentage >= 100, assuming extraction is complete
00:10:32:608 | MD |   DEBUG1  | +31    | 7z - Finished 7z extraction
00:10:32:608 | MD |   DEBUG1  | +0     | 7z - Found file in C:\Users\Lenovo\AppData\Local\Temp\HS\Arkanoid DS (USA) (En,Fr,De,Es,It)\Arkanoid DS (USA) (En,Fr,De,Es,It).nds
00:10:32:608 | MD |   DEBUG1  | +0     | 7z - romPath changed from "H:\DS READY" to "C:\Users\Lenovo\AppData\Local\Temp\HS\Arkanoid DS (USA) (En,Fr,De,Es,It)"
00:10:32:608 | MD |   DEBUG1  | +0     | 7z - romName changed from "Arkanoid DS (USA) (En,Fr,De,Es,It)" to "Arkanoid DS (USA) (En,Fr,De,Es,It)"
00:10:32:639 | MD |   DEBUG1  | +31    | 7z - romExtension changed from ".7z" to ".nds"
00:10:32:672 | MD |     INFO  | +31    | 7z - Ended
00:10:32:672 | MD |     INFO  | +0     | Run - Running: E:\Hyperspin\Emulators\Nintendo DS\DeSmuME_0.9.9_x64.exe "C:\Users\Lenovo\AppData\Local\Temp\HS\Arkanoid DS (USA) (En,Fr,De,Es,It)\Arkanoid DS (USA) (En,Fr,De,Es,It).nds"
00:10:32:719 | MD |   DEBUG1  | +47    | Run - "DeSmuME_0.9.9_x64.exe "C:\Users\Lenovo\AppData\Local\Temp\HS\Arkanoid DS (USA) (En,Fr,De,Es,It)\Arkanoid DS (USA) (En,Fr,De,Es,It).nds"" Process ID: 4944
00:10:32:719 | MD |   DEBUG1  | +0     | GetActiveWindowStatus - Title: RocketLauncher v1.0.1.4 Debug Console | Class: ConsoleWindowClass | State: 0 | X: 66 | Y: 66 | Width: 668 | Height: 331 | Window HWND: 0x290406 | Process ID: 1188 | Process Path: E:\Rocketlauncher\RocketLauncher.exe
00:10:32:719 | MD |     INFO  | +0     | WinWait - Waiting for "ahk_class DeSmuME"
00:10:33:852 | MD |   DEBUG1  | +1139  | GetActiveWindowStatus - Title: DeSmuME 0.9.9 x64 | Class: DeSmuME | State: 0 | X: 132 | Y: 132 | Width: 264 | Height: 430 | Window HWND: 0x80308 | Process ID: 4944 | Process Path: E:\Hyperspin\Emulators\Nintendo DS\DeSmuME_0.9.9_x64.exe
00:10:33:855 | MD |   DEBUG1  | +0     | GetActiveWindowStatus - Title: DeSmuME 0.9.9 x64 | Class: DeSmuME | State: 0 | X: 132 | Y: 132 | Width: 264 | Height: 430 | Window HWND: 0x80308 | Process ID: 4944 | Process Path: E:\Hyperspin\Emulators\Nintendo DS\DeSmuME_0.9.9_x64.exe
00:10:33:857 | MD |     INFO  | +0     | WinWaitActive - Waiting for "ahk_class DeSmuME"
00:10:33:957 | MD |   DEBUG1  | +109   | GetActiveWindowStatus - Title: Paused | Class: DeSmuME | State: 0 | X: 132 | Y: 132 | Width: 264 | Height: 430 | Window HWND: 0x80308 | Process ID: 4944 | Process Path: E:\Hyperspin\Emulators\Nintendo DS\DeSmuME_0.9.9_x64.exe
00:10:34:415 | MD |     INFO  | +453   | Process - WaitClose DeSmuME_0.9.9_x64.exe
00:10:38:306 | MD |   DEBUG1  | +3884  | CloseProcess - Started, user requested to end launched application
00:10:38:342 | MD |     INFO  | +47    | WinClose - Closing: ahk_class DeSmuME
00:10:38:627 | MD |   DEBUG1  | +281   | CloseProcess - Ended
00:10:38:627 | MD |     INFO  | +0     | 7zCleanUp - Started
00:10:38:720 | MD |   DEBUG1  | +93    | 7zCleanUp - Deleted C:\Users\Lenovo\AppData\Local\Temp\HS\Arkanoid DS (USA) (En,Fr,De,Es,It)
00:10:38:720 | MD |     INFO  | +0     | 7zCleanUp - Ended
00:10:38:720 | MD |     INFO  | +0     | ExitModule - Started
00:10:38:720 | MD |     INFO  | +0     | Starting Updating Statistics:
00:10:38:720 | MD |   DEBUG2  | +0     | Total Elapsed Time in Pause in seconds: 0
00:10:38:720 | MD |   DEBUG2  | +0     | gameSectionStartTime:15999134
00:10:38:720 | MD |   DEBUG2  | +0     | ElapsedTime:8
00:10:38:752 | MD |   DEBUG2  | +31    | Statistics cleared game name: Arkanoid DS
00:10:38:783 | MD |   DEBUG2  | +32    | Loaded game statistics from ini files:
					Number_of_Times_Played: 2
					Last_Time_Played: Monday December 21, 2015 12:09:08 AM
					Average_Time_Played: 5
					Total_Time_Played: 10
					System_Total_Played_Time: 146
					Total_Global_Played_Time: 11127
00:10:38:783 | MD |   DEBUG2  | +0     | Updated Statistics: Number_of_Times_Played: 3
					Last_Time_Played: Monday December 21, 2015 12:10:29 AM
					Average_Time_Played: 6
					Total_Time_Played: 18
					System_Total_Played_Time: 154
					Total_Global_Played_Time: 11135
00:10:38:845 | MD |     INFO  | +62    | Game section statistics updated.
00:10:38:876 | MD |     INFO  | +31    | RunKeymapper - Started, using method "unload"
00:10:38:876 | MD |     INFO  | +0     | GetJoystickArray - Started
00:10:38:876 | MD |   DEBUG2  | +0     | GetJoystickArray - Joysticks Detected: 1000000000000000
00:10:38:876 | MD |     INFO  | +0     | GetJoystickGUID - Started
00:10:38:876 | MD |     INFO  | +0     | GetJoystickGUID - Ended and found GUID: 5041DB96E6EDE4118001444553540000
00:10:38:908 | MD |   DEBUG2  | +31    | GetJoystickArray - ID: 1 | Port: 0 | Name: Controller (Xbox 360 Wireless Receiver for Windows) | MID: 045e | PID: 02a1 | GUID: 5041DB96E6EDE4118001444553540000
00:10:38:908 | MD |     INFO  | +0     | GetJoystickArray - Ended
00:10:38:908 | MD |   DEBUG2  | +0     | RunKeymapper - Looping through controllers to find xpadder profiles for each one
00:10:38:908 | MD |   DEBUG2  | +0     | RunKeymapper - ID: 1 Now searching for a matching profile for this controller: "Controller (Xbox 360 Wireless Receiver for Windows)"
00:10:38:908 | MD |   DEBUG2  | +0     | GetProfile - Searching for these profiles (| delimited): E:\Rocketlauncher\Profiles\xpadder\_Default\blank
00:10:38:908 | MD |   DEBUG2  | +0     | GetProfile - Searching -> E:\Rocketlauncher\Profiles\xpadder\_Default\blank.xpadderprofile
00:10:38:939 | MD |     INFO  | +32    | GetProfile - Loading Profile -> E:\Rocketlauncher\Profiles\xpadder\_Default\blank.xpadderprofile
00:10:38:939 | MD |     INFO  | +0     | RunXpadder - Started
00:10:38:939 | MD |     INFO  | +0     | Process - Exist JoyToKey.exe
00:10:38:939 | MD |   DEBUG2  | +0     | RunXpadder - Closing xpadder to refresh controllers seen by xpadder
00:10:38:939 | MD |     INFO  | +0     | Run - Running: E:\Hyperspin\Utilities\Xpadder\Xpadder.exe /C
00:10:38:970 | MD |   DEBUG1  | +31    | Run - "Xpadder.exe /C" Process ID: 4480
00:10:38:970 | MD |   DEBUG2  | +0     | RunXpadder - Creating an array of connected controllers and profiles to arrange according to the order found in E:\Hyperspin\Utilities\Xpadder\xpadder.ini
00:10:38:970 | MD |     INFO  | +0     | Process - WaitClose Xpadder.exe 2
00:10:39:188 | MD |   DEBUG2  | +218   | RunXpadder - Reading the order in E:\Hyperspin\Utilities\Xpadder\xpadder.ini and arranging profiles found to match that order
00:10:39:188 | MD |   DEBUG2  | +0     | RunXpadder - No more controllers to be found
00:10:39:188 | MD |     INFO  | +0     | Run - Running: E:\Hyperspin\Utilities\Xpadder\Xpadder.exe "E:\Rocketlauncher\Profiles\xpadder\_Default\blank.xpadderprofile" /M
00:10:39:220 | MD |   DEBUG1  | +31    | Run - "Xpadder.exe "E:\Rocketlauncher\Profiles\xpadder\_Default\blank.xpadderprofile" /M" Process ID: 3592
00:10:39:251 | MD |     INFO  | +32    | RunXpadder - Ended
00:10:39:251 | MD |     INFO  | +0     | RunKeymapper - Ended
00:10:39:251 | MD |     INFO  | +0     | RunAHKKeymapper - Started
00:10:39:251 | MD |   DEBUG1  | +0     | RunAHKKeymapper - Unloading AhkLauncher
00:10:39:251 | MD |   DEBUG1  | +0     | RunAHKKeymapper - If AhkLauncher.exe is running, need to close it first before a new profile can be loaded
00:10:39:251 | MD |     INFO  | +0     | Process - Exist AhkLauncher.exe
00:10:39:282 | MD |     INFO  | +31    | RunAHKKeymapper - Ended
00:10:39:282 | MD |     INFO  | +0     | Restoring mouse cursor
00:10:39:282 | MD |     INFO  | +0     | ExitModule - Ended
00:10:39:313 | MD |     INFO  | +31    | End of Module Logs
00:10:39:329 | RL |     INFO  | +11357 | Main - Module ended, exiting RocketLauncher normally
00:10:39:329 | RL |     INFO  | +0     | ExitScript - Started
00:10:39:329 | RL |     INFO  | +0     | SystemCursor - Restoring mouse cursor
00:10:39:344 | RL |     INFO  | +15    | ExitScript - Ended
Yes that's the default i don't get it I made a new one it should work... Any suggestions on how to manually fix? I always has issues with swapping profiles on xpadder. I have has it work with other systems.
Unfortunately even if the profile is in the right place you can't get the pointer working properly with DS on retroarch.
There is no way to map the buttons to the pointer in RA. That means you have to use a key mapper to map pad buttons to the mouse. This causes problems as the mouse pointer wouldn't always be over the screen and therefore won't always register the click for the DS.
I haven't been able to find a perfect solution for this yet...
I set up retroarch and it works fine for me, however the controller does not utilize the pointer? I have gone into Xpadder and made a profile under E:\Rocketlauncher\Profiles\Xpadder\Nintendo DS and under the same dir under Default directory.  It works in testing but does not load on games? Anyone help?
There's a core option called "Pointer Emulation" that you can select left stick or right stick to control the touchscreen's pointer. R2 or Right Trigger acts as your "touch the screen" input.
Unfortunately though - no way in RA to map the tap.
You can map it by remapping R2 to any axis, button and key (it lets you set one for each) using a core override config. Turn off per core configs and turn on core overrides in retroarch.cfg, then create a Desmume folder in your config folder. Then make a Desmume.cfg text file in that folder with these contents (replacing nul with your axis, button or key):
input_player1_r2_axis = "nul"
input_player1_r2_btn = "nul"
input_player1_r2 = "nul"
