jcake2 Posted December 31, 2015 Posted December 31, 2015 Hi guys wondering if can help with a issue I'm having . When I run saw emulator with or without rocketlauncher , I'm getting a window pop-up that tells me overriding config settings , physical size to small . And wants me to hit enter to make full screen . I tried almost everything in the gui of the emulator too correct it . Running on a tv with 1920x1080 res . I like the emulator a lot , looks great but this is causing me a black screen on my hyperspin till I hit enter on keyboard , which is a pain when using my arcade, doesn't flow well any help would be helpful thank you
rastan Posted December 31, 2015 Posted December 31, 2015 I used to use the emulator but then everyone said MAME runs the games better so I cut out the AAE emulator and just used MAME.
Metalzoic Posted December 31, 2015 Posted December 31, 2015 On 12/31/2015 at 7:38 PM, jcake2 said: Hi guys wondering if can help with a issue I'm having . When I run saw emulator with or without rocketlauncher , I'm getting a window pop-up that tells me overriding config settings , physical size to small . And wants me to hit enter to make full screen . I tried almost everything in the gui of the emulator too correct it . Running on a tv with 1920x1080 res . I like the emulator a lot , looks great but this is causing me a black screen on my hyperspin till I hit enter on keyboard , which is a pain when using my arcade, doesn't flow well any help would be helpful thank you Not sure. This happening with all games? And which version of AAE are you using. I'm running AAE update #2 (latest/final version) and it works perfectly, no issues. Maybe try that one if you're running an older version.
Metalzoic Posted December 31, 2015 Posted December 31, 2015 On 12/31/2015 at 7:49 PM, rastan said: I used to use the emulator but then everyone said MAME runs the games better so I cut out the AAE emulator and just used MAME. AAE isn't perfect, but it definitely runs them better than MAME. It's easily noticeable just comparing Asteroids/Deluxe in both, the AAE version runs and animates much smoother with less aliasing. MAME looks janky by comparison. That's up though 168. I haven't compared in yesterdays MAME 169 release.
jcake2 Posted December 31, 2015 Author Posted December 31, 2015 running lastest version had no troubles on pc monitor only when i brought over too tv , tried reinstalling it too .... weird ty for help. i'll keep chipping at it and let ya know if i find it
Metalzoic Posted December 31, 2015 Posted December 31, 2015 On 12/31/2015 at 10:55 PM, jcake2 said: running lastest version had no troubles on pc monitor only when i brought over too tv , tried reinstalling it too .... weird ty for help. i'll keep chipping at it and let ya know if i find it Fine on monitor, but screwy on a TV? Did you change the type of connection cables? Like Dual Link DVI to HDMI etc...
