NewYears1978 Posted January 11, 2016 Posted January 11, 2016 This might be an easy fix but what happens is this: I am in HyperSpin and I click start on a game, and before the emu loads up the screen goes black for a split second, then shows HS again, then goes into the emulator. Upon exiting the emulator the same thing happens. I thought Fades would solve so I added in and out fades and now this happens (same thing): I click start on game, Fade loads, then HS shows for a split second before emu shows. Quitting emu, I see HS menu for a split second before fade shows then HS shows again. Any way to smooth this out? I have seen videos (Simply Austins for instance) without this issue. I thought it was xpadder profiles loading but I disabled xpadder and it still did it. I also messed with hide frontend, hide emulator, restore etc options but that didn't help. Thanks in advance. Edit: A friend just led me to the fact that it might be from when the cmd window in retroarch pops up. I tried mame and the transition was smooth so he may be right..so is there any way to fix? Are you an HTPC user? Do you like Kodi/XBMC?If so, check out these Kodi Style Themes!-----------------------------------------------------------------------------------------------------Aeon Nox 13 by @dark13Aeon MQ6 by @NewYears1978 >> Click here to see Current Progress-----------------------------------------------------------------------------------------------------If you're new and going for your first install, I HIGHLY recommend Simply Austin's Tutorials.
