Bruiserh89 Posted February 7, 2016 Posted February 7, 2016 Hey guys this might be an easy one for you to answer but I have a rom that is from the EU region and the xml database I have is only for the US version. How can I add this EU version to my database? Is it as simple as renaming the rom the US version or do I need to add the EU version to the database? I have Don's tools and know you can rename roms to match the database. I also noted you can generate your own database for your roms but I'd like to keep the database I'm currently using and just add roms to it when necessary. Cheers
Bruiserh89 Posted February 7, 2016 Author Posted February 7, 2016 I guess you could rename the rom. Proper way would be to just open the db in a text editor and add another entry for that game. Cheers mate. I'll try just renaming the rom first because I don't know how to go about the text editor process.
Spawk Posted February 7, 2016 Posted February 7, 2016 You can rename if you're sure you are not going to use us version. The database (.xml) is editable with notepad if you wish to add it instead of renaming. Sent from my SGH-I337M using Tapatalk
Bruiserh89 Posted February 7, 2016 Author Posted February 7, 2016 You can rename if you're sure you are not going to use us version. The database (.xml) is editable with notepad if you wish to add it instead of renaming. Sent from my SGH-I337M using Tapatalk Ah ok. Thanks Spawk. Yeah I don't need the US version and I'll keep notepad in mind for future ref.
Spawk Posted February 7, 2016 Posted February 7, 2016 Actually, notepad does have issues if it is a particularly big database so if you ever run into any problems, I would suggest installing "notepad++". It's free, just Google it. Sent from my SGH-I337M using Tapatalk
