GOG Games wheel possible? [SOLVED]
QuinnHQ
Hello guys,
Having some trouble trying to setup a wheel for my GOG games. I setup the wheel through HyperHQ, and then open Rocketlauncher, but it doesnt have any modules connected with GOG. I am sure it should be PCLauncher.AHK. Does anyone know how I could add this? Please.
Enable "Virtual Emulator" in the PCLauncher module. Leave path and extension blank.
Create a system called "PC Games" in RL (Can't recall if this was there on 1st install of RL)
Copy all the shortcuts (LNK files) to 1 directory and point the "PC Games" system to it in RL. Choose PCLauncher as  default emulator.
Is there a way to keep it in a GOG wheel? Or has to be PC Games? I have the GOG icon in the left side of the Rocketlauncher program...
Yeah should work the same. I was just thinking about any artwork that may exist. I guess a lot of that stuff will have to be done manually anyway.
Sent from my SGH-I337M using Tapatalk
Yes, you can have GOG in its own separate wheel.
Open the PCLauncher module in Notepad and under MSystem manually add the system name "GOG". Save and close.
Now open Rocketlauncher
Now when you click on the modules tab the PC Launcher module should list under the GOG system icon.
I recommend using the quick and easy method of setting up all the GOG games in one lot in HS by following this:
http://www.hyperspin-fe.com/topic/14530-gog-games-dark-forces/
