Hyperspin loads full screen then jumps to windowed
thenoob
Last thing I'm trying to track down.
All my emulators are playing in windowed mode
I cross over to hyperspin, they load fullscreen then quickly jump to windowed mode. What setting in RL needs to be adjusted? It's all the emulators (right now it's mame and retroarch I'm using)
Everything works fine outside HS, but what needs to be adjusted inside to keep fullscreen??
I'll set them all to false again and try it again.
It's weird because on initial load first screen is in fullscreen then jumps to windowed.
Jumped to hyperHQ, that's set to full screen so its good there
Tried it and it still does the same thing
Mame/retro arch/ everything I have is doing it.
Didn't do it on my previous HS build.
Then should I leave them all to "defaulut or true?
They all work fullscreen outside HS, I'm confused this has never been an issue
maybe check the settings for each system to see if they are set to full screen because even if you have the global set to TRUE for fullscreen.... if a system setting is set to false that could cause a problem.
Well I figured it out
It was a mixture of turning off the bezels.
Then going Into the global module settings for each system and selecting
Aspect ratio - core provided.
That fixed everything. Thanks for the guidance now to finish things up!!
