badhemi Posted February 19, 2016 Posted February 19, 2016 This shows on pc but not on Android. Does anyone have these showing on android and my wheel sounds don't work on Android. I checked settings in settings ini and they are set to true
reznnate Posted February 20, 2016 Posted February 20, 2016 You need to be more specific. As you can see from most videos on youtube, the default 'special.swf' files look fine. I have run into alternate .swf files that render improperly (the monk versions are transparent).
badhemi Posted February 20, 2016 Author Posted February 20, 2016 I'm talking about the SPECIAL A1 joystick and exit and start swf files. They don't show on android except one. In HBMAME. They all show on pc
reznnate Posted February 22, 2016 Posted February 22, 2016 Are they the same .swf special files used by other systems? If not, perhaps those files won't render properly on Android. If so, llook at the .ini file special parameters and compare against a working one. There must be a difference.
badhemi Posted February 22, 2016 Author Posted February 22, 2016 Are they the same .swf special files used by other systems? If not, perhaps those files won't render properly on Android. If so, llook at the .ini file special parameters and compare against a working one. There must be a difference. I did and some had false on some so I changed it and all I get is the joystick but not free play. Not sure how to get that
badhemi Posted February 22, 2016 Author Posted February 22, 2016 Are they the same .swf special files used by other systems? If not, perhaps those files won't render properly on Android. If so, llook at the .ini file special parameters and compare against a working one. There must be a difference. do you have a sample ini.to compare?
reznnate Posted February 23, 2016 Posted February 23, 2016 Any of your working .ini's should be enough for you. Basically I'm wondering if the .swf files are different and causing the issue OR the .ini settings are different and causing the issue.
badhemi Posted February 23, 2016 Author Posted February 23, 2016 Any of your working .ini's should be enough for you. Basically I'm wondering if the .swf files are different and causing the issue OR the .ini settings are different and causing the issue. I'll send you an ini file later
badhemi Posted February 24, 2016 Author Posted February 24, 2016 I set all defaults to false and they all have joystick but no free game or exit
badhemi Posted February 29, 2016 Author Posted February 29, 2016 Any of your working .ini's should be enough for you. Basically I'm wondering if the .swf files are different and causing the issue OR the .ini settings are different and causing the issue. I got the joystick to show. Where does the free play go? Is it a special or go in background folder
badhemi Posted March 1, 2016 Author Posted March 1, 2016 Any of your working .ini's should be enough for you. Basically I'm wondering if the .swf files are different and causing the issue OR the .ini settings are different and causing the issue. figured it out rezznate had no specialb1 and b2
