dustytrenchcoat Posted February 20, 2016 Posted February 20, 2016 Hey everyone, very new to the world of arcade emulation - and I used Simply Austins videos to set up RL and HyperSpin. I'm at the point now testing the Sega Genesis system with a couple ROMs. They display properly and launch via RetroArch using the function in RLUI. when I try to launch the same ROM via HyperSpin, this is the error I receive: http://iforce.co.nz/i/zuje1z5m.j3m.png This is my setup in HyperHQ: http://iforce.co.nz/i/lghcjodr.353.png I've got Rocket Launcher and Hyperspin in different directories, correctly pointing to each other where required - just ticked over 1am here and I'm just stumped as to where the problem lie. If anyone could shed some light on where to begin for troubleshooting, or even a straight forward fix, it would be much appreciated. I'll be checking the thread after some shut-eye, so don't worry if I don't reply straight away. EDIT: apologies for not posting this in the support subforum, just seen that it was there. Newb mistake - blame it on the sleep
JoyStickKilla Posted February 20, 2016 Posted February 20, 2016 Set your default plugin and frontend path in rlui
dustytrenchcoat Posted February 20, 2016 Author Posted February 20, 2016 Cheers for that - I did try that earlier, but it didn't work for me. I also needed to disable fade in the global settings, but I was too tired to figure that out. Glad it was a quick fix
dustytrenchcoat Posted February 20, 2016 Author Posted February 20, 2016 Well for me it did - had to change interpolation type from "HighQualityBicubic" to "Off" in general settings - HS would error out, but the game loaded in the background, weird stuff
