Nvidia shield not recognizing hard drive
badhemi
Today I tried plugging in my hard drive to my nvidia tv after downloading from computer. Well it shows usb3005 but not the series of UUID numbers above it like before. I tried my other Hargrove and it did the same thing. This happened the other day too. Anyone else have this problem? I tried restarting too
Have you tried mounting it in the Nvidia shield settings???
I did another system reset and now it's working. Not sure how to mount in settings.
so I unplugged the harddrive after unmounting and plugged it back in and it's doing the same thing just showing usb3005. Is there something wrong with es explorer
Did you get it working???
yes I did. I have to have it off or on sleep mode insert hardrive then turn on. Otherwise it will have just the usb3000 number. Hey I got Atari 5200 to work but can't figure out rom path. I posted in the thread. Thanks for the tips
Help, same problem!!!
I had to uninstall es explorer and reinstall. Then with the power off or sleep mode I insert hard drive then I hit the b button to get out of asking for default usb. I then hit use as external drive then it's ok. Once it's in then you can turn off and on with it in. Its just if you plug it in when it's on it goes to usb 3002 and doesn't show uui number
Did you sort it??? I think there maybe a glitch :/ If it won't mount no matter how you try and connect it, plug it in to a PC and edit something on the drive, unmount and then try it again in your shield :)
yes I did but it has to be in sleep or off to mount. Or if you hit default for that usb then it locks it out. Must be a glitch
