HyperSpin X-Arcade Multiple keyboards
SlottedPig
Hi all,
Im new to the scene and so far everything has been good.  I have come across a weird issue and im hoping someone can help.  I have 2 x-arcade tanksticks, 1 x-arcade dual stick all plugged in.  If i run MAME64UI with the multiple keyboard option on, everything works perfectly for 4 players.  If i run the same game through hyperspin, i dont get any input unless i load the mame gui toggle multi keyboard on that specific game and then go back in. Thoughts?
In mameui go to "options--->default game options" and enable for all games at once.
Sent from my SGH-I337M using Tapatalk
Ah... OK, try this: in RL under the global module settings. Then the Mame tab, then put this under parameters:
-multikey
This should add the parameter to every occurrence of mame.
ok so i figured out a different workaround for this and the controls are working fine except whenever q and s are pressed during a 2 player game it bounces back to hyperspin.  I already tried changing the exit script keys in rlui.  its a good thing this is cool because it is a lot of annoying work lol.
  On 3/5/2016 at 5:40 AM, agent47 said:
If you change or remove the exit script hotkey there's no reason why it should still be exiting.
Just means the exit command is not coming from RL. Still coming from mame???
What was your workaround?
