progets Posted March 20, 2016 Posted March 20, 2016 Not in any order - making sure the emulator and game works on its own before trying to use it in RL (RocketLauncher) or HS (HyperSpin) - read the module notes to make sure the version of the emulator is supported and they have the proper settings - don't use ROM sets other than NoIntro (a lot of renaming is needed then) - don't use HS without RL (HL (HyperLaucher) is outdated and will have less support)) - you need to use a xpadder or joytokey to get "everything" in most cases - do you have the BIOS files for the emulator if needed - don't update RLUI (RocketLaucherUI) unless needed (once you get things setup don't mess with them unless your need to and want to update and fix your emulators) - don't ever enable joystick control in HyperHQ (it never ends well) - make sure you have the proper paths in HyperHQ for rom extentions, path to emulator and videos - make sure your emulator has the correct extentions defined in your build Let's hear some more!
diskmach Posted March 20, 2016 Posted March 20, 2016 Having enough free time to get 75 systems working and fully functional? Nintendo 3DS wheels thread || Nintendo 3DS wheel set download Bandai Wonderswan Color wheels thread || Bandai Wonderswan wheels thread NEC PC Engine wheels COMPLETED || Nintendo Wiiware wheels COMPLETED
