yoursdirect Posted August 6, 2013 Posted August 6, 2013 Hi I have a 42 LCD tv waiting to be used in a new cab. Will this do a good enough job or is it really worth investing in an led? Seems a lot of money to so end when I have this good tv already, but then before I spend hours on the cabinet I want to make sure I will be happy with the result. Also is 42 a good size or would 46 give much improved results, it seems most of you go for 46 now? I also have a 32 lcd for the back box, i Again is it worth the money for a new led?
Carny_Priest Posted August 6, 2013 Posted August 6, 2013 You can always throw money at a problem, but I'm a big believer in recycling. You can certainly test it without placing in a cab. If it plays acceptably then go with it. If it doesn't play acceptably then you spend the money.
Gilrock Posted August 7, 2013 Posted August 7, 2013 If you can try to hook up the TV's to a PC and see how you like the look before building a cabinet custom fitted to those TV's. The TV size is going to be your preference. I chose a 40" TV because that was the closest size to fit a standard cabinet. I could have picked anything I wanted at the time because I started from scratch. I avoided the 46" size because I remember not liking playing machines that were wide...it always felt like I was hugging a volkswagon. Standard size cabs just feel more comfortable to me and the more you stretch the tables the worse they are going to look.
yoursdirect Posted August 8, 2013 Author Posted August 8, 2013 Thanks for the comments guys, I think 42 size wise will be perfect for me. Does LEDmake a massive diffrence, i know they are brighter? but i guess with the brightness ect tweeked on the LCD you can get good results still.
