joeyjojojjjjjj Posted September 14, 2013 Posted September 14, 2013 Hello fellow hyperspinners, I had to redo my hyperspin cabinet due a bad hard drive. I took the time to "mint" my rom sets so it was not a complete wasted of time to redo everything. However I am now experiencing a problem. I set hyperspin to start automatically when windows(7 64bit) starts and hyperspin keeps losing windows focus. I have narrowed it down to my Steam client stealing focus. I have had hyperspin running and booting with no problems for months and this time I installed some PC games through my steam account, now I got the focus problem. anyone know what to do???
joeyjojojjjjjj Posted September 17, 2013 Author Posted September 17, 2013 do you have teamviewer installed? no. EDIT: I have tried everything I can think of, still not working. I have tried to delay the start of steam by 20 seconds after hyperspin is up, and as soon as steam loads hyperspin loses focus. It does not matter if I set a delay of 5 min, hyperspin still freezes when steam loads. I have also tried to disable the steam client and use steam offline mode, nothing works(games wont load). I hate to say it because it sounds dumb but I may have to download warez versions of my games just so I can run them without steam loading. I would like to know how other people are dealing with this problem. anybody??
joeyjojojjjjjj Posted September 22, 2013 Author Posted September 22, 2013 I had to uninstall steam to fix the problem. Seems that hyperspin and steam do not play well together, or at least don't boot well together.
raungst Posted November 21, 2013 Posted November 21, 2013 I have a similar problem, and I do have teamviewer installed. If I try to shell Hyperspin with InstantSheller, HS loses focus. If I just have HS in the startup folder, everything works fine, though windows isn't quite as hidden. Is there a way to have teamviewer and still have HS shelled. When I used MaLa it worked fine shelled with teamviewer.
Deadly Posted November 22, 2013 Posted November 22, 2013 Open HLHQ Global Settings Main DESKTOP - set all to false. If your windows taskbar is set to autohide uncheck it. See if that does you any good.
raungst Posted November 22, 2013 Posted November 22, 2013 I didn't have any of those set to true. I disabled teamviewer from starting at startup, and everything works as expected so Teamviewer is definitely the problem. Curious if theres anything I can do to get focus back to HS. Can you shell a AHK script that would launch HS, wait a little, and then try to get focus? Teamviewer isn't essential, but its helpful for maintenance of the cab.
HocEman Posted September 8, 2014 Posted September 8, 2014 Sorry to open an old thread, but I was having similar problems with TeamViewer and HyperSpin losing focus. I figured others could benefit from my solution. I had HS running as the shell and it would "freeze" a few seconds after starting. TeamViewer is setup for "unattended access" as it makes it easy to manage PCs that do not have a mouse and keyboard always connected (I do this with my HTPCs too). I stumbled across this thread and sure enough, if I disabled TeamViewer HS did not freeze. I have had some "focus" issues on my HTPC's and was able to solve them with EventGhost. I applied the same concept here and it worked. I was able to use EventGhost to launch HS, wait 5 seconds and then bring HS to focus. I then set EventGhost as the shell and I still have the same "Non-Windows" Arcade PC that boots straight into HS!
