Wiskas Posted September 27, 2013 Posted September 27, 2013 Hi. I have have no experience with wood working so my questions is: Any router will be good for slot cutting? For example cheapest router for 30 pounds? I know i need to buy bits for router so price for 3 off them is 35 pounds.So this set well be good for t molding? Router ~30 + bits 35=65 pounds.... Size of MDF is 18 mm "To cut the correct slot for standard arcade T-moulding you need: - 6702A Slot cutter (Diam 47.63mm Kerf 2.03mm) - B25 Bearing (Outer Diam 28.58mm, Inner Diam 7.94) - A200B Arbor (Shank 6.35mm)"
jimmyuk86 Posted September 27, 2013 Posted September 27, 2013 Hi. I have have no experience with wood working so my questions is:Any router will be good for slot cutting? For example cheapest router for 30 pounds? I know i need to buy bits for router so price for 3 off them is 35 pounds.So this set well be good for t molding? Router ~30 + bits 35=65 pounds.... Size of MDF is 18 mm "To cut the correct slot for standard arcade T-moulding you need: - 6702A Slot cutter (Diam 47.63mm Kerf 2.03mm) - B25 Bearing (Outer Diam 28.58mm, Inner Diam 7.94) - A200B Arbor (Shank 6.35mm)" You got to get the right size slot cutter arbor for your router..theres 2 sizes. 1/2" and 1/4" some routers come with reducing collets so getting a 1/2" router is probably a safer bet. £30 Pounds sounds like a cheap arse router but if your only using it specifically for the T-moulding then i guess it would do the job. Doesnt matter on the depth on the mdf you can adjust the slot cut on the routers plunge. The slot cutter i bought came complete with both bearing, arbour and cutter.
Wiskas Posted September 28, 2013 Author Posted September 28, 2013 You got to get the right size slot cutter arbor for your router..theres 2 sizes. 1/2" and 1/4" some routers come with reducing collets so getting a 1/2" router is probably a safer bet. £30 Pounds sounds like a cheap arse router but if your only using it specifically for the T-moulding then i guess it would do the job. Doesnt matter on the depth on the mdf you can adjust the slot cut on the routers plunge. The slot cutter i bought came complete with both bearing, arbour and cutter. ThankYou for advice but still i need help. Could U please paste links with cheap router for this job ( yes router for one job only) Can be on ebay.co.uk or other UK store...also some links with slot bits... I following this guide http://www.coldbeamgames.com/blog.html and info about slot cuter i get from ther... "I bought a router and some t-moulding samples. I then needed the correct sized slot cutter bit, arbor and bearing. After a lot of searching I found a site here in the UK ( http://www.routercutter.co.uk/ ). To cut the correct slot for standard arcade T-moulding you need: - 6702A Slot cutter (Diam 47.63mm Kerf 2.03mm) - B25 Bearing (Outer Diam 28.58mm, Inner Diam 7.94) - A200B Arbor (Shank 6.35mm) So you can see in the picture the slot and the T-moulding sitting just right." All this 3 iteams i found http://www.routercutter.co.uk/ is around 35 pounds...so i can order, only the router is a problem...please give me a links.... Egzample http://www.ebay.co.uk/itm/Ferm-Router-DIY-Power-Tool-230v-Variable-Speed-6-Bits-/390637389981?pt=UK_Home_Garden_PowerTools_SM&hash=item5af3cd889d http://www.argos.co.uk/static/Product/partNumber/7113914.htm#pdpProductReviews Sorry for my english...
emb Posted September 28, 2013 Posted September 28, 2013 It's a little outside your price range (I think it equates to 60 pounds) ; it's a great entry level router. http://www.homedepot.com/p/Ryobi-R163K-Fixed-Base-Router-R163K/203325690#.UkbTA2go7GU This was the first router I bought and I still love it! The router has now become my most frequently used tool. It can be used for so many applications.... I cannot imagine living without it! Sent from my Galaxy Tab 2 using Tapatalk HD %5BSIGPIC%5D[/sIGPIC] Download HyperSpin Tools and check out my MAME cabinet
mikekim Posted September 30, 2013 Posted September 30, 2013 I picked up a 1/2" MAC router from B&Q for £69. also picked up a 1/4" Trend 6 bit set for £12. It does the job without any issues. i had to order a separate slot cutter from the US
Wiskas Posted September 30, 2013 Author Posted September 30, 2013 Thx for info... So looks like it's have to be router 1/2 or 1/4 will do the job also? So confuse.... Looks like t molding is not that cheep router, bits + t molding over 100 pounds.... Any other solution for nice edges??? Thx for help guys....
scooner Posted September 30, 2013 Posted September 30, 2013 Gday wiskas either way if you want to do t-moulding or you just want nice edges your gonna need a router. If it were me i would be getting a 1/4" trimming router and you can get all the bits you need for it, bullnose, chamfer, or a slotter for t-moulding. The trimming router is easier to use for a beginner in my opinion,as you can use it in one hand and doesnt have the power of a 1/2" router which scare some people. Here's an example of what you want . The bit you want looks like this . Hope this helps.
Wiskas Posted September 30, 2013 Author Posted September 30, 2013 www.argos.co.uk/m/static/Product/partNumber/7113914/c_1/1|category_root|Home+and+garden|33005908/c_2/2|33005908|DIY+tools+and+power+tools|33007178/c_3/3|cat_33007178|DIY+power+tools|33013811/c_4/4|cat_33013811|Routers|33021294.htm This router will be good??????? please give me links where i can bay cheep correct router in UK ...thx
