petercobra Posted September 30, 2013 Posted September 30, 2013 Iso hlp with wierd thing... Since Im gathering $ for all missing parts for my cab (ledwiz,ipac,buttons,fans itp and extra $ for shipping from ebay to Poland Q_Q) Im using gamepad for VP. Ive added another switch for my buttons to remove lag with contactors. When I plug adaptor my gamepad starts glitching. X/Y axis turns off, windows recognize pad over and over again. Everything is ok when I unplug gamepad or contactor adaptor. Ive two different circuits. One is for microswitch and one for contactor. I just glued two parts from broken microswitches to get extra one. Any ideas whats going on? p.s. gamepad isnt connected to contactors. (i figured that it must be separated after I burned one:p) Since Im electronic noob here is my current schematic http://i43.tinypic.com/2e4kxfc.jpg
maxxsinner Posted September 30, 2013 Posted September 30, 2013 From what I can see on your pic petercobra, you are trying to have two separate switches off a single button - one to control the contactor and one to send a signal to the gamepad? As long as both switches are separated electrically, it should work fine. Can you post a photo of what you have created? Might make it easier to fault find. Electropin - Enough lights to land a jet on an aircraft carrierHigh Voltage Pinball - Cause one build just wasn't enough Voltek Arcade - Funglo pedestal style mame cabinet Pinball Electrical Tutorial - Wire All Your Bling With Confidence and Fewer House Fires
petercobra Posted October 22, 2013 Author Posted October 22, 2013 Problem solved. All I had to do was to buy 1 amper diodes and add them to contactor
