  • 0
MUGEN presque configuré... Help !
Gius3ppe
Question
Bonjour,
Je rencontre un soucis avec le sytème MUGEN : lorsque je lance un jeu via HyperLaunchHQ, il s'ouvre et se referme !
Ma Config :
Sous HyperLanchHQ :
Emulators :
Path : H:\HYPERSPIN\Emulators\Mugen\PCLAUNCHER.exe
Rom Extensions : lnk
Module : H:\HYPERSPIN\Modules\MUGEN\MUGEN.ahk
Virtual Emulator non coché.
Mon MUGEN.ahk :
MEmu = MUGEN
MEmuV = N/A
MURL = http://www.elecbyte.com/
MAuthor = brolly & djvj
MVersion = 2.0
MCRC = FA399B17
iCRC = DB922C06
MID = 635038268906726252
MSystem = "MUGEN"
; Notes:
; Default location to launch the games will be in your romPath with a subfolder for each game (named after the rom in the xml).
; Each game's folder, should contain a MUGEN.exe
; If you don't want to use the above path/exe, create an ini in the folder of this module with the same name as this module.
; Place each game in it using the example below. gamePath should start from your romPath and end with the exe to the game.
; moduleName ini contains an entry for each game, pointing to the MUGEN.exe
; It can also contain an exitHack setting which can be 1 or 0, typically you only add these to mugen 1.0+ games and set it to 0
; This will override the whole exit hack code needed for older mugen versions
; example:
; [bastard]
; gamePath = Bastard\WinBastard.exe
; [street Fighter Legends]
; gamePath = Street Fighter Legends\mugen.exe
; exitHack = 0
; emuPath and exe need to point to a dummy exe, like PCLauncher.exe
; romPath needs to point to the dir with all the blank txt files and the settings.ini
; Escape will only close the game from the main menu, it is needed for in-game menu usage otherwise.
; Fullscreen and controls are done via in-game options for each game. To speed up configuring of games, configure one game then save its settings to a default.cfg and paste it into each game's Saves folder.
; Controls are done via in-game options for each game.
; Larger games are inherently slower to load, this is MUGEN, nothing you can do about it but get a faster HD.
StartModule()
FadeInStart()
remapWinKeys := IniReadCheck(settingsFile, "Settings", "remapWinKeys","true",,1) ; This remaps windows Start keys to Return to prevent accidental leaving of game
gamePath := IniReadCheck(settingsFile, romName, "gamePath",A_Space,,1)
exitHack := IniReadCheck(settingsFile, romName, "exitHack","1",,1)
gamePath := romPath . "\" . (If (!gamePath or gamePath = "ERROR") ? (romName . "\MUGEN.exe") : (gamePath))
CheckFile(gamePath,"Could not find " . gamePath . "`nPlease place your game in it's own folder in your Rom_Path or define a custom gamePath in " . SettingsFile)
SplitPath, gamePath,gExe, gPath
If remapWinKeys = true
{ Hotkey, RWin, WinRemap
Hotkey, LWin, WinRemap
Err := Run(gExe, gPath, "UseErrorLevel", game_PID)
If Err
ScriptError("Failed to launch " . romName)
WinWait("ahk_pid " . game_PID)
WinWaitActive("ahk_pid " . game_PID)
WinGetTitle, gameTitle, ahk_pid %game_PID%
FadeInExit()
If ( exitHack = 1) ; Sometimes mugen crashes during exit and doesn't close, so we need to do a workaround to detect it, this doesn't seem to happen on MUGEN 1.0
{ If gameTitle != HyperSpin ; If the user exited mugen in under 1500ms then we don't need to do this otherwise the script would hang
IfWinExist, %gameTitle%
Loop {
Sleep, 1000
WinGet, gameState, MinMax, %gameTitle%
If ( gameState != 1 ) ; Mugen window minimized or closed
Break
Sleep 2000
FadeOutExit() ; this needs to be on its own line so it does not error
Process("Close", game_PID)
Process("Close", executable) ;on some machines/games, MUGEN doesn't close itself properly, this is the work around to make sure it does
} Else
Process("WaitClose", game_PID)
7zCleanUp()
FadeOutExit()
ExitModule()
WinRemap:
Return
CloseProcess:
FadeOutStart()
WinClose(gameTitle . " ahk_pid " . game_PID)
Return
Quelqu'un a une idée ???
Merci d'avance !
4 answers to this question
Bonjour je n'utilise pas mugen, mais as-tu essayé avec un autre module, type pclauncher?
Merci ashurax pour ta piste...
Mais j'ai fini par trouver !
- J'ai complètement refait mon \modules\mugen\mugen.ini j'ai réécrit tous les game path.
- J'ai refait tous les lnk
- J'ai contrôlé la gamelist dans HyperLaunchHQ (tout ok)
- Il faut quitter HyperLaunchHQ (je ne sais pas pourquoi) avant de tester avec HyperLaunch
Tout fonctionne !
nickel! ^^
Je reste un peu déçu par MUGEN et OpenBOR...
Me suis un peu rendu fou à faire fonctionner ces systèmes et je ne pense pas beaucoup les utiliser... Ça reste un peu "sommaire" comme réalisations... C'est juste mon avis.
Sent from my iPhone using Tapatalk - now Free
