rfancella Posted July 22, 2014 Posted July 22, 2014 HOLLY @$%@ % %$#@ GOT IT Working!!!! This is the working log from Dahpne running in hyperspin. Unfortunately not sure how I did it, but I think it was the framefile which looked like this .\ 4666 gpworld.m2v 51210 gpdiags.m2v and I changed it to . 4666 gpworld.m2v 51210 gpdiags.m2v But also when thorgh HQ and launchHQ and check all setting, could have maybe reset some thing by trying to use hyperspin in normal mode and then changing it back to hyperluanch in HQ. Maybe a hyperspin guru can tell from log file what I did and help the next poor soul. Thank you so much rfancella for your help on this. --DAPHNE version 1.0.12 --Command line is: D:\HyperSpin\Emulators\Daphne\daphne.exe gpworld vldp -blank_searches -prefer_samples -noissues -fastboot -fullscreen -x 1024 -y 768 -min_seek_delay 1000 -seek_frames_per_ms 20 -homedir . -sound_buffer 2048 -framefile D:\HyperSpin\Emulators\Daphne\framefile\gpworld\gpworld.txt --CPU : GenuineIntel 3300 MHz || Mem : 4096 megs --OS : Windows XP/.NET || Video : NVIDIA GeForce GTX 275 --OpenGL: Compiled In --RGB2YUV Function: MMX --Line Blending Function: MMX --Audio Mixing Function: MMX Setting alternate home dir: . Setting screen width to 1024 Setting screen height to 768 Setting sound buffer size to 2048 Set 1024x768 at 32 bpp with flags: 80000001 Initializing sound system ... Joystick #0 was successfully opened Remapping input ... Loading compressed ROM image gpw_6162a.bin...16384 bytes read. Loading compressed ROM image gpw_6163.bin...16384 bytes read. Loading compressed ROM image gpw_6164.bin...16384 bytes read. Loading compressed ROM image gpw_6148.bin...4096 bytes read. Loading compressed ROM image gpw_6149.bin...16384 bytes read. Loading compressed ROM image gpw_6150.bin...16384 bytes read. Loading compressed ROM image gpw_6151.bin...16384 bytes read. Loading compressed ROM image gpw_6152.bin...16384 bytes read. Loading compressed ROM image gpw_6153.bin...16384 bytes read. Loading compressed ROM image gpw_6154.bin...16384 bytes read. Loading compressed ROM image gpw_6155.bin...16384 bytes read. Loading compressed ROM image gpw_6156.bin...16384 bytes read. Loading compressed ROM image gpw_6157.bin...16384 bytes read. Loading compressed ROM image gpw_6158.bin...16384 bytes read. Loading compressed ROM image gpw_6146.bin...32 bytes read. Loading compressed ROM image gpw_6147.bin...256 bytes read. Loading compressed ROM image gpw_5501.bin...256 bytes read. Framefile parse succeeded. Video/Audio directory is: D:/HyperSpin/Emulators/Daphne/framefile/gpworld/./ YUV overlay is done in software (ie unaccelerated). Booting ROM ... LDV1000: Reject received (ignored) Play Display disable received Unsupported LD-V1000 Command Received: f2 Search to 5041 received search succeeded d0 LDP : Received pause while disc was not playing, ignoring LDP : Received pause while disc was not playing, ignoring Play LDP : disc is already playing, play command ignored Play Freeing memory used to store audio stream... Shutting down sound system... Shutting down video display... Glad you got it all sorted out!! Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
crashdogy Posted July 22, 2014 Posted July 22, 2014 Glad you got it all sorted out!!Thanks, Ron Thanks again for help on this sent you a message was wondering if you had guide for Atari 8-Bit setup whit MESS ?
