Complete Guide for American Laser Games/WoW ActionMax in HypeSpin And HL3.
rfancella
I have not found the cdrom iso, but I managed to download a torrent so full compound
In the root folder there are all files bat of 13 games, all running in fullscreen, clicking a screen appears green and then part of the game.
Then there is a DATA folder inside which there is all the singe folders ROM and FRAMEFILE are empty.
I followed the guide and I did the procedure several times, skipping the installer since singe folder there are all the folders of all games with audio and video files you need, but I can not boot games HLHQ I copied and renamed files BATCH, TXT and SINGE, and moved to the FRAMEFILE, but I can not start the games, always appears to me the error message that tells me that I must tell the daphne thing must start.
But by making a few attempts I managed to do something, now when I launch the game opens the green screen, the same as when I start the game directly from the batch, but after a second closes everything.
I'm going crazy I can not make it work.
  • Replies 222
Please post your HyperLaunch.log file set to troubleshooting and your Daphne_log.txt using code tags.
Thanks,
Ron
Thanks so much for your directions getting this working! I have got everything working correctly now, I think. I could not have done it without your help.
This is the setting of the emulator
I put the folder path as Rom framefile because it is the only path that led me to this result, if I put as rom path "singe" I get this error message
This is HL LOG
10:28:22:489 | HL |     INFO  | +N/A   | Main - HyperLaunch v3.1.0.3 BETA (www.hyperlaunch.net)
10:28:23:728 | HL |     INFO  | +1234  | Main - System Specs:
				HyperLaunch Dir: C:\HyperSpin
				HyperLaunch is: 32-bit
				OS: Microsoft Windows 7 Home Premium
				SKU: Home Premium
				Total Memory: 766.87 MB
				Free Memory: 173.57 MB
				Used Memory: 593.293 MB
				SystemType: 32-bit
				Physical Processors: 1
				Logical Processors: 2
				GPU 1 Name: NVIDIA GeForce4 MX 440 with AGP8X
				GPU 1 RAM: 0.00 MB
				GPU 1 Driver Version: 7.7.7.2
				Sound 1 Device: C-Media AC97 Audio Device
				Sound 1 Status: Enabled
				OS Language: Italian_Standard
				OS Admin Status: Yes
				Monitor #1 (\\.\DISPLAY1): 1600x900 (1600x860 work)
				Monitor #1 Orientation: Landscape
				Current AHK Desktop Width: 1600
				Current AHK Desktop Height: 900
				AutoHotkey Path:
				AHK Version: 1.1.09.04
				Unicode: No
10:28:23:728 | HL |     INFO  | +0     | CheckFile - Checking if C:\HyperSpin\HyperLaunch.exe exists
10:28:23:730 | HL |     INFO  | +0     | CheckFile - Checking if C:\HyperSpin\Module Extensions\dxwnd\dxwnd.ini exists
10:28:23:730 | HL |     INFO  | +0     | CheckFile - Checking if C:\HyperSpin\Module Extensions\dxwnd\dxwnd.exe exists
10:28:23:743 | HL |     INFO  | +16    | CheckFile - Checking if C:\HyperSpin\Plugins\HyperSpin.plugin exists
10:28:23:753 | HL |     INFO  | +15    | Main - Loading Front End Plugin: "HyperSpin"
10:28:23:753 | HL |     INFO  | +0     | Main - HyperLaunch received "American Laser Games" and "mad dog mccree"
10:28:23:771 | HL |     INFO  | +16    | Main - mad dog mccree is using the default emulator: Daphne Singe
10:28:23:771 | HL |     INFO  | +0     | Main - Checking for a [Daphne Singe] section in C:\HyperSpin\Settings\American Laser Games\Emulators.ini
10:28:23:771 | HL |     INFO  | +0     | Main - Checking for a [Daphne Singe] section in C:\HyperSpin\Settings\Global Emulators.ini
10:28:23:771 | HL |     INFO  | +0     | Main - Found [Daphne Singe] in C:\HyperSpin\Settings\Global Emulators.ini
10:28:23:771 | HL |     INFO  | +0     | CheckFile - Checking if C:\HyperSpin\Modules\Daphne Singe\Daphne Singe.ahk exists
10:28:23:896 | HL |     INFO  | +125   | Main - CRC Check - CRC matches, this is an official unedited module.
10:28:23:896 | HL |     INFO  | +0     | Main - mad dog mccree will use module: C:\HyperSpin\Modules\Daphne Singe\Daphne Singe.ahk
10:28:23:933 | HL |     INFO  | +31    | Main - Did not find a "C:\HyperSpin\Settings\American Laser Games\Game Options.ini" file, skipping any game-specific options.
10:28:23:933 | HL |     INFO  | +0     | Main - Using standard method with "Rom Extension" SkipChecks or without any SkipChecks.
10:28:23:935 | HL |     INFO  | +16    | Main - INI Keys read
10:28:23:937 | HL |     INFO  | +0     | CheckFile - Checking if C:\HyperSpin\Module Extensions\7z.exe exists
10:28:23:944 | HL |     INFO  | +0     | CheckFile - Checking if C:\HyperSpin\Module Extensions\7z.dll exists
10:28:23:960 | HL |     INFO  | +16    | CheckFile - Checking if C:\HyperSpin\Module Extensions\FontReg.exe exists
10:28:24:183 | HL |     INFO  | +218   | Main - "mad dog mccree" does not qualify for MultiGame. Only roms with any of these strings in their name are acceptable: (Disc,(Disk,(Cart,(Tape,(Cassette,(Part,(Side
10:28:24:183 | HL |     INFO  | +0     | CheckPaths - Started
10:28:24:185 | HL |     INFO  | +16    | CheckPaths - Found rom: C:\Daphne Singe\data\framefile\mad dog mccree.singe
10:28:24:185 | HL |     INFO  | +0     | CheckPaths - Ended
10:28:24:185 | HL |     INFO  | +0     | BuildScript - User Variables:
				; INJECTED VARIABLES
				#NoTrayIcon
				#InstallKeybdHook
				DetectHiddenWindows, ON
				SetTitleMatchMode, 2
				SendMode, Event
				0 = 8
				pluginPath = C:\HyperSpin\Plugins
				pluginName = HyperSpin
				pluginExt = .plugin
				hlMode =
				hlTitle = HyperLaunch
				hlVersion = 3.1.0.3 BETA
				hlAuthor = djvj
				hlURL = www.hyperlaunch.net
				langFile = C:\HyperSpin\Data\Language\Localization.ini
				frontendPID = 0
				frontendPath = C:\HyperSpin
				frontendExe = HyperSpin.exe
				frontendExt = exe
				frontendName = HyperSpin
				frontendDrive = C:
				exitEmulatorKey = ~Esc
				exitEmulatorKeyWait = 0
				forceHoldKey = ~Esc
				restoreFE = false
				exitScriptKey = ~q & ~s
				toggleCursorKey = ~e & ~t
				emuFullPath = C:\Daphne Singe\data\daphne.exe
				emuPath = C:\Daphne Singe\data
				emuName = Daphne Singe
				emuExt = exe
				romPath = C:\Daphne Singe\data\framefile
				romPathFromIni = C:\Daphne Singe\data\framefile
				romExtension = .singe
				romExtensionOrig = .singe
				romExtensions = singe|bat|txt
				executable = daphne.exe
				systemName = American Laser Games
				dbPath =
				dbName = mad dog mccree
				dbExt =
				romName = mad dog mccree
				romMapPath =
				romMappingEnabled = false
				romMappingMenuWidth = 400
				romMappingMenuMargin = 65
				romMappingTextMargin = 15
				romMappingMenuFlagWidth = 55
				altArchiveNameOnly =
				altRomNameOnly =
				altArchiveAndRomName =
				altArchiveAndManyRomNames =
				altRomNamesOnly =
				romMapScenario =
				skipchecks = false
				romMatchExt = false
				blockInputTime = 0
				blockInputFile = C:\HyperSpin\Module Extensions\BlockInput.exe
				errorLevelReporting = false
				lockLaunch = false
				lockLaunchGame =
				screenRotationAngle = 0
				screenRotationAngleGame =
				logFile = C:\HyperSpin\HyperLaunch.log
				logLevel = 3
				logShowDebugConsole = false
				logIncludeModule = true
				logShowCommandWindow = false
				logCommandWindow = false
				hlDebugConsoleStdout =
				sysLang = Italian_Standard
				sysType = 32-bit
				navUpKey = Up
				navDownKey = Down
				navLeftKey = Left
				navRightKey = Right
				navSelectKey = Enter
				navP2UpKey = Numpad8
				navP2DownKey = Numpad2
				navP2LeftKey = Numpad4
				navP2RightKey = Numpad6
				navP2SelectKey = NumpadEnter
				originalWidth = 1600
				originalHeight = 900
				dtEnabled = false
				dtPath =
				dtUseSCSI = true
				dtAddDrive = true
				servoStikEnabled = false
				ledblinkyEnabled = false
				ledblinkyFullPath =
				ledblinkyProfilePath = C:\HyperSpin\Profiles\LEDBlinky
				ledblinkyHLProfile = C:\HyperSpin\Profiles\LEDBlinky\HyperLaunch
				emuIdleShutdown = 0
				hideCursor = false
				hideEmu = false
				hideFE = false
				fadeIn = false
				fadeInDuration = 500
				fadeInDelay = 0
				fadeInExitDelay = 0
				fadeOutExitDelay = 0
				fadeOut = true
				fadeOutExtraScreen = false
				fadeOutDuration = 500
				fadeOutDelay = 0
				fadeLyrInterpolation = 0
				fadeMuteEmulator = false
				fadeUseBackgrounds = false
				fadeXScale =
				fadeYScale =
				fadeLyr1Color = FF000000
				fadeLyr2X = 300
				fadeLyr2Y = 300
				fadeLyr2Adjust = 1
				fadeLyr2PicPad = 0
				fadeLyr2Prefix = Layer 2
				fadeLyr3Pos = Center
				fadeLyr3X = 300
				fadeLyr3Y = 300
				fadeLyr3Adjust = 0.75
				fadeLyr3PicPad = 0
				fadeLyr3Speed = 750
				fadeLyr3Type = imageandbar
				fadeLyr3Repeat = 1
				fadeLyr3StaticX = 0
				fadeLyr3StaticY = 870|1575
				fadeLyr3StaticAdjust = 1
				fadeLyr3StaticPicPad = 0
				fadeLyr4Adjust = 0.75
				fadeLyr4X = 100
				fadeLyr4Y = 100
				fadeLyr4FPS = 10
				fadeLyr4PicPad = 0
				fadeTranspGifColor = FFFFFF
				fadeBarWindow = false
				fadeBarWindowX =
				fadeBarWindowY =
				fadeBarWindowW = 600
				fadeBarWindowH = 120
				fadeBarWindowR = 20
				fadeBarWindowM = 20
				fadeBarWindowHatchStyle = 8
				fadeBar = 7zOnly
				fadeBarNon7zProgressTime = 0
				fadeBarBack = true
				fadeBarBackColor = FF555555
				fadeBarH = 20
				fadeBarR = 5
				fadeBarColor = DD00BFFF
				fadeBarHatchStyle = 3
				fadeBarPercentageText = true
				fadeBarInfoText = true
				fadeBarXOffset = 0
				fadeBarYOffset = 100
				fadeRomInfoDescription = text
				fadeRomInfoSystemName = text
				fadeRomInfoYear = text
				fadeRomInfoGenre = text
				fadeRomInfoRating = text
				fadeRomInfoTextMargin = 5
				fadeStatsInfoTextMargin = 5
				fadeText1X = 0
				fadeText1Y = 0
				fadeText1 = Loading Game
				fadeText2X = 0
				fadeText2Y = 0
				fadeText3 = Loading Game
				fadeText4 = Loading Complete
				fadeFont = Arial
				fadeExtractionTime = disabled
				fadeExtractionTimeTextX = 0
				fadeExtractionTimeTextY = 0
				fadeInterruptKey =
				detectFadeErrorEnabled = true
				fadeImgPath = C:\HyperSpin\Media\Fade
				HLDataPath = C:\HyperSpin\Data
				HLMediaPath = C:\HyperSpin\Media
				HLErrSoundPath = C:\HyperSpin\Media\Sounds\Error
				modulesPath = C:\HyperSpin\Modules
				moduleFullName = C:\HyperSpin\Modules\Daphne Singe\Daphne Singe.ahk
				moduleName = Daphne Singe
				modulePath = C:\HyperSpin\Modules\Daphne Singe
				moduleExtension = ahk
				moduleExtensionsPath = C:\HyperSpin\Module Extensions
				libPath = C:\HyperSpin\Lib
				7zEnabled = false
				7zPath = C:\HyperSpin\Module Extensions\7z.exe
				7zDllPath = C:\HyperSpin\Module Extensions\7z.dll
				7zExtractPath = C:\Documents and Settings\MAME\Impostazioni locali\Temp\HS
				7zExtractPathOrig =
				7zAttachSystemName = false
				7zDelTemp = true
				7zSounds = true
				mgEnabled = false
				mgKey = ~NumpadSub
				mgBackgroundColor = FF000000
				mgSidePadding = 0.2
				mgXScale = 1
				mgYScale = 1
				mgYOffset = 500|800
				mgFont = Arial
				mgText2Offset = 100
				mgUseSound = true
				mgSoundfreq = 300
				mgExitEffect = none
				mgSelectedEffect = rotate
				mgUseGameArt = false
				mgArtworkDir = Artwork1
				mgCandidate =
				mgOnLaunch = false
				hpEnabled = false
				hpKey = ~NumpadAdd
				hpBackToMenuBarKey = X
				hpZoomInKey = C
				hpZoomOutKey = V
				hpHiToTextPath = C:\HyperSpin\Module Extensions\HiToText.exe
				hpSaveStateKeyCodes =
				hpLoadStateKeyCodes =
				keymapperEnabled = false
				keymapperAHKMethod = false
				keymapper = xpadder
				xpadderFullPath = C:\Utilities\Xpadder\xpadder.exe
				joyToKeyFullPath = C:\Utilities\JoyToKey\JoyToKey.exe
				keymapperProfilePath = C:\HyperSpin\Profiles\xpadder
				JoyIDsEnabled = false
				JoyIDsPreferredControllersSystem = use_global
				CustomJoyNamesEnabled = false
				CustomJoyNames =
				rotateMethod = false
				FEProfile = C:\HyperSpin\Profiles\xpadder\HyperSpin
				defaultProfile = C:\HyperSpin\Profiles\xpadder\_Default
				systemProfile = C:\HyperSpin\Profiles\xpadder\American Laser Games
				xPadderSystemProfile = C:\HyperSpin\Profiles\xpadder\American Laser Games\_Default
				emuProfile = C:\HyperSpin\Profiles\xpadder\American Laser Games\Daphne Singe
				romProfile = C:\HyperSpin\Profiles\xpadder\American Laser Games\mad dog mccree
				HyperLaunchProfile = C:\HyperSpin\Profiles\xpadder\HyperLaunch
				blankProfile = C:\HyperSpin\Profiles\xpadder\_Default\blank
				ahkFEProfile = C:\HyperSpin\Profiles\AHK\HyperSpin
				ahkDefaultProfile = C:\HyperSpin\Profiles\AHK\_Default
				ahkSystemProfile = C:\HyperSpin\Profiles\AHK\American Laser Games
				ahkEmuProfile = C:\HyperSpin\Profiles\AHK\American Laser Games\Daphne Singe
				ahkRomProfile = C:\HyperSpin\Profiles\AHK\American Laser Games\mad dog mccree
				ahkHyperLaunchProfile = C:\HyperSpin\Profiles\AHK\HyperLaunch
				bezelEnabled = false
				bezelICEnabled = false
				statisticsEnabled = true
				pressDuration = -1
				emuVolume = 1
				dxwndIni = C:\HyperSpin\Module Extensions\dxwnd\dxwnd.ini
				dxwndFullPath = C:\HyperSpin\Module Extensions\dxwnd\dxwnd.exe
				mon1O = 0
				pacDrivedllFile = C:\HyperSpin\Module Extensions\PacDrive32.dll
10:28:24:187 | HL |     INFO  | +0     | BuildScript - Loaded XHotkey Init.ahk scripts
10:28:24:187 | HL |     INFO  | +0     | BuildScript - Loaded Fade Init.ahk scripts
10:28:24:187 | HL |     INFO  | +0     | BuildScript - Loaded Statistics Init.ahk scripts
10:28:24:187 | HL |     INFO  | +0     | BuildScript - Loaded User Functions Init.ahk script
10:28:24:187 | HL |     INFO  | +0     | BuildScript - Validating module
10:28:24:190 | HL |     INFO  | +0     | BuildScript - Validation complete
10:28:24:190 | HL |     INFO  | +0     | BuildScript - Module:
				MEmu = Daphne Singe
				MEmuV =  v1.14
				MURL = http://www.singeengine.com/cms/
				MAuthor = djvj
				MVersion = 2.0.3
				MCRC = D73E9B2
				iCRC = 727919E9
				MID = 635038268880264228
				MSystem = "American Laser Games","WoW Action Max"
				; Notes:
				; Rom_Extension should be singe
				; Your framefiles need to exist in the same dir as your Rom_Path, in each game's subfolder, and have a txt extension. The filename should match the name in your xml.
				; If you are upgrading from the old daphne-singe-v1.0 to 1.14, don't forget to copy the old singe dir to the new emu folder, it doesn't come with the contents of that folder that you need.
				; For this emu to work, paths need to be set in the singe files pointing to the movie files. The old method was done with manual file edits. The new method has the module do it for you automatically.
				; NEW METHOD:
				; Do nothing!
				; OLD METHOD:
				; American Laser Games
				; For example,  If you rompath is C:Hyperspin\Games\American Laser Games\, the drugwars game would be found in C:Hyperspin\Games\American Laser Games\maddog\
				; and the framefile would be in C:Hyperspin\Games\American Laser Games\maddog\maddog.txt
				; To change the dir you want to run your games from:
				; 1. Backup all your /daphne/singe/ROMNAME/ROMNAME.singe, cdrom-globals.singe, and service.singe files, most games all three in each romdir
				; 2. Move all the folders in your /daphne/singe/ folder to the new location you want. You should have one folder for each game.
				; 3. Open each ROMNAME.singe, cdrom-globals.singe, and service.singe in notepad and do a find/replace of all instances shown below. For example using an SMB share:
				; Old
				; ("singe/
				; New:
				; ("//SERVER/Hyperspin/Games/American Laser Games/
				; If using a local drive, it would look something like this C:/Hyperspin/Games/American Laser Games/
				; WoW Action Max
				; Emu_Path should be something like this C:\HyperSpin\Emulators\WoW Action Max\daphne-singe\
				; Rom_Path has to point to where all the m2v video files are kept
				; Your framefiles need to exist in the same dir as your rompath and all have txt extensions. The filename should match the name in your xml.
				; 1. Backup your /daphne/singe/Action Max/Emulator.singe file
				; 2. Move all the files (except Emulator.singe) in your /daphne/singe/Action Max/ folder to the new location you want.
				; 3. Open Emulator.singe in notepad and do a find/replace of all instances shown below. For example using an SMB share:
				; Old
				; "singe/Action Max/
				; New:
				; "//SERVER/Hyperspin/Games/WoW Action Max/
				; If using a local drive, it would look something like this C:/Hyperspin/Games/WoW Action Max/
				; There should be 18 instances that need replacing.
				; 4. The only file that should be in your /daphne/singe/Action Max/ dir should be the edited Emulator.singe file (and your backup).
				StartModule()
				BezelGUI()
				FadeInStart()
				fullscreen := IniReadCheck(settingsFile, "settings", "Fullscreen","true",,1)
				daphneWidth := IniReadCheck(settingsFile, "settings", "daphneWidth","1024",,1)
				daphneHeight := IniReadCheck(settingsFile, "settings", "daphneHeight","768",,1)
				singePathUpdate := IniReadCheck(settingsFile, "settings", "SingePathUpdate","true",,1)
				forcePathUpdate := IniReadCheck(settingsFile, "settings", "ForcePathUpdate","false",,1)
				BezelStart()
				; Emptying variables If they are not set
				fullscreen := If fullscreen = "true" ? " -fullscreen_window" : ""	; fullscreen_window mode allows guncon and aimtraks to work
				If bezelPath   ; this variable is only filled if bezel is enabled and a valid bezel image is found
				{	params:= params . " -ignore_aspect_ratio"
					daphneWidth := " -x " . Round(bezelScreenWidth)  ;bezelScreenWidth variable is defined on the BezelStart function and it gives the desired width that your game screen should have while using this bezel
					daphneHeight := " -y " . Round(bezelScreenHeight) ;idem above
				} Else {
					daphneWidth := " -x " . daphneWidth
					daphneHeight := " -y " . daphneHeight
				hideEmuObj := Object("DAPHNE ahk_class SDL_app",1)	; Hide_Emu will hide these windows. 0 = will never unhide, 1 = will unhide later
				If singePathUpdate = true
					SingePathUpdate()
				HideEmuStart()	; This fully ensures windows are completely hidden even faster than winwait
				; This allows us to send variables, that when empty, are not sent to the Run command
				Run(executable . " singe vldp" . daphneWidth . daphneHeight . fullscreen . " -framefile """ . romPath . "\" . romName . ".txt"" -script """ . romPath . "\" . romName . ".singe""", emuPath)
				WinWait("DAPHNE ahk_class SDL_app")
				WinWaitActive("DAPHNE ahk_class SDL_app")
				BezelDraw()
				HideEmuEnd()
				FadeInExit()
				7zCleanUp()
				FadeOutExit()
				ExitModule()
				SingePathUpdate(){
					Global romPath,romName,updatedLines,forcePathUpdate,systemName,emuPath
					Log("SingePathUpdate - Started")
					FileFullPath := []
					updatedLines := 0
					singeData :=
					singeCount :=
					singeUpdateStrings := ["dofile(","spriteLoad","io.input","io.output","fontLoad","soundLoad"]	; look for these strings in the singe files
					; Check if paths have been updated prior
					romSingeFile := romPath . "\" . romName . ".singe"
					FileRead, romSingeData, %romSingeFile%
					StringReplace, rompathCommonSlash, romPath, \, /, all
					If InStr(romSingeData, rompathCommonSlash)
						If (forcePathUpdate = "false") {
							Log("SingePathUpdate - """ . romSingeFile . """ contains the current Rom Path. Skipping the SingePathUpdate function because your files appear to have the correct paths already set. If you want to force a path update, please set the ForcePathUpdate variable in the Daphne Singe module options in HLHQ to true.")
							Log("SingePathUpdate - Ended")
							Return
					If InStr(systemName, "Action") {	; WoW Action Max
						emuSingeFile := emuPath . "\singe\ActionMax\Emulator.singe"
						FileRead, emuSingeData, %emuSingeFile%
						FileFullPath[1,1] := emuSingeFile
						FileFullPath[1,2] := emuSingeData
						FileFullPath[2,1] := romSingeFile
						FileFullPath[2,2] := romSingeData
						Log("SingePathUpdate - Added the " . romName . ".singe and Emulator.singe to be updated",4)
					} Else {	; basically only American Laser Games
						Loop, % romPath . "\*.singe"
						{	FileRead, singeData, %A_LoopFileFullPath%
							Loop % singeUpdateStrings.MaxIndex() {	; for each string in the array
								If InStr(singeData, singeUpdateStrings[A_Index]) {	; check each singe file for the strings
									singeCount++
									FileFullPath[singeCount,1] := A_LoopFileFullPath	; building a table of each .singe file in the romPath and storing it in row 1
									FileFullPath[singeCount,2] := singeData		; inserting the file data into row 2
									Log("SingePathUpdate - Found a file that needs to have its paths updated: " . A_LoopFileFullPath,4)
									Break	; go to next file
					Log("SingePathUpdate - " . FileFullPath.MaxIndex() . " files will have their paths updated")
					Loop, % FileFullPath.MaxIndex()
						currentSingeIndex := A_Index
						Log("SingePathUpdate - Now updating this singe file's paths: " . FileFullPath[currentSingeIndex,1],4)
						updatedText :=
						currentData := FileFullPath[currentSingeIndex,2]
						Loop, Parse, currentData, `n, `r
							oldSingeLine := A_LoopField
							lineUpdated :=
							Loop % singeUpdateStrings.MaxIndex()	; for each string in the array
								If InStr(oldSingeLine, singeUpdateStrings[A_Index]) {	; check each singe file for the strings
									updatedText .= (If A_Index = 1 ? "" : "`r`n") . UpdateLine(oldSingeLine, singeUpdateStrings[A_Index])
									lineUpdated := 1
							If !lineUpdated	; if line was not found above, just put the old line back
								updatedText .= (If A_Index = 1 ? "" : "`r`n") . A_LoopField
						Log("SingePathUpdate - Deleting file: " . FileFullPath[currentSingeIndex,1],4)
						FileDelete, % FileFullPath[currentSingeIndex,1]
						Log("SingePathUpdate - Recreating file: " . FileFullPath[currentSingeIndex,1],4)
						FileAppend, %updatedText%, % FileFullPath[currentSingeIndex,1]
					Log(updatedLines . " Singe paths updated by HyperLaunch.")
					Return
				UpdateLine(oldLine, string) {
					Global rompath,emuPath,systemName,updatedLines
					StringReplace, emupathCommonSlash, emuPath, \, /, all
					StringReplace, string2, string, ., \., all
					regex = i)%string2%.*/\K(?:.(?!/))+$|%string2%.*\\\K(?:.(?!\\))+$
					If RegExMatch(RegExReplace(oldLine,"\s*$",""), regex, matchedLine)
						If (InStr(systemName, "Action") and InStr(matchedLine, "framework.singe"))
							Line := RegExReplace(RegExReplace(oldLine,"\s*$",""), string2 . "\(.*\)$", string . "(" . """" . emupathCommonSlash . "/singe/singe/" . matchedLine)
						Else If (InStr(systemName, "Action") and InStr(matchedLine, "emulator.singe"))
							Line := RegExReplace(RegExReplace(oldLine,"\s*$",""), string2 . "\(.*\)$", string . "(" . """" . emupathCommonSlash . "/singe/ActionMax/" . matchedLine)
						Else
							Line := RegExReplace(RegExReplace(oldLine,"\s*$",""), string2 . "\(.*\)$", string . "(" . """" . rompathCommonSlash . "/" . matchedLine)
						updatedLines++
					} Else
						Line := oldLine
					Log("UpdateLine - " . line,4)
					Return Line
				HaltEmu:
					Send, {P}
				Return
				RestoreEmu:
					Winrestore, AHK_class %EmulatorClass%
					Send, {P}
				Return
				CloseProcess:
					FadeOutStart()
					BezelExit()
					WinClose("DAPHNE ahk_class SDL_app")
					;Process, Close, %executable% ; WoW Action Max module used this
				Return
10:28:24:401 | HL |     INFO  | +203   | BuildScript - Loaded Multi-Player scripts
10:28:24:407 | HL |     INFO  | +16    | BuildScript - Loaded Statistics.ahk script
10:28:24:409 | HL |     INFO  | +0     | BuildScript - Loaded User Functions.ahk script
10:28:24:409 | HL |     INFO  | +0     | BuildScript - Finished injecting functions into module
10:28:24:413 | HL |     INFO  | +0     | Main - Module is built
10:28:24:413 | HL |     INFO  | +0     | CheckFile - Checking if C:\HyperSpin\AutoHotkey.dll exists
10:28:24:446 | HL |     INFO  | +31    | Main - Running module
10:28:26:448 | MD |     INFO  | +N/A   | Module initialized
10:28:26:511 | MD |     INFO  | +62    | StartModule - Started
10:28:26:511 | MD |     INFO  | +0     | StartModule - MEmu: Daphne Singe
				MEmuV: v1.14
				MURL: http://www.singeengine.com/cms/
				MAuthor: djvj
				MVersion: 2.0.3
				MCRC: D73E9B2
				iCRC: 727919E9
				MID:
				MSystem: "American Laser Games","WoW Action Max"
10:28:26:511 | MD |     INFO  | +0     | StartModule - You have a supported System Name for this module: "American Laser Games"
10:28:26:536 | MD |     INFO  | +32    | PluginInit - Started
10:28:26:755 | MD |     INFO  | +218   | CheckFile - Checking if C:\HyperSpin\Databases\American Laser Games\American Laser Games.xml exists
10:28:26:757 | MD |     INFO  | +0     | PluginInit - Ended
10:28:26:759 | MD |     INFO  | +0     | StartModule - Ended
10:28:26:759 | MD |     INFO  | +0     | StartGlobalUserFeatures - Starting
10:28:26:759 | MD |     INFO  | +0     | StartGlobalUserFeatures - Ending
10:28:27:321 | MD |     INFO  | +563   | Module Setting - [settings] - Fullscreen: true
10:28:27:321 | MD |     INFO  | +0     | Module Setting - [settings] - daphneWidth: 1024
10:28:27:321 | MD |     INFO  | +0     | Module Setting - [settings] - daphneHeight: 768
10:28:27:321 | MD |     INFO  | +0     | Module Setting - [settings] - SingePathUpdate: true
10:28:27:323 | MD |     INFO  | +0     | Module Setting - [settings] - ForcePathUpdate: false
10:28:27:323 | MD |     INFO  | +0     | SingePathUpdate - Started
10:28:27:411 | MD |     INFO  | +94    | SingePathUpdate - "C:\Daphne Singe\data\framefile\mad dog mccree.singe" contains the current Rom Path. Skipping the SingePathUpdate function because your files appear to have the correct paths already set. If you want to force a path update, please set the ForcePathUpdate variable in the Daphne Singe module options in HLHQ to true.
10:28:27:411 | MD |     INFO  | +0     | SingePathUpdate - Ended
10:28:27:411 | MD |     INFO  | +0     | Run - Running: C:\Daphne Singe\data\daphne.exe singe vldp -x 1024 -y 768 -fullscreen_window -framefile "C:\Daphne Singe\data\framefile\mad dog mccree.txt" -script "C:\Daphne Singe\data\framefile\mad dog mccree.singe"
10:28:30:170 | MD |     INFO  | +2765  | WinWait - Waiting for "DAPHNE ahk_class SDL_app"
10:28:33:207 | MD |     INFO  | +3032  | WinWaitActive - Waiting for "DAPHNE ahk_class SDL_app"
10:28:33:394 | MD |     INFO  | +187   | Process - WaitClose daphne.exe
10:28:37:518 | MD |     INFO  | +4125  | StopGlobalUserFeatures - Starting
10:28:37:518 | MD |     INFO  | +0     | StopGlobalUserFeatures - Ending
10:28:37:518 | MD |     INFO  | +0     | DefaultAnimateFadeOut - Started
10:28:38:022 | MD |     INFO  | +500   | DefaultAnimateFadeOut - Ended
10:28:38:022 | MD |     INFO  | +0     | ExitModule - Started
10:28:38:022 | MD |     INFO  | +0     | Starting Updating Statistics:
10:28:38:510 | MD |     INFO  | +484   | Game section statistics updated.
10:28:38:512 | MD |     INFO  | +0     | ExitModule - Ended
10:28:38:512 | MD |     INFO  | +0     | End of Module Logs
10:28:38:732 | HL |     INFO  | +14297 | Main - Module ended, exiting HyperLaunch normally
10:28:38:732 | HL |     INFO  | +0     | ExitScript - Started
10:28:38:926 | HL |     INFO  | +187   | SystemCursor - Restoring mouse cursor
10:28:38:955 | HL |     INFO  | +32    | ExitScript - Ended
Daphne log
--DAPHNE version 1.0.10
--Command line is: C:\Daphne Singe\data\daphne.exe singe vldp -x 1024 -y 768 -fullscreen_window -framefile C:\Daphne Singe\data\framefile\mad dog mccree.txt -script C:\Daphne Singe\data\framefile\mad dog mccree.singe
--CPU : GenuineIntel 2800 MHz || Mem : 768 megs
--OS : Windows XP/.NET || Video : NVIDIA GeForce4 MX 440 with AGP8X
--OpenGL: Compiled In
--RGB2YUV Function: MMX
--Line Blending Function: MMX
--Audio Mixing Function: MMX
Setting screen width to 1024
Setting screen height to 768
Set 1600x900 at 32 bpp with flags: 20
Initializing sound system ...
No joysticks detected
Remapping input ...
Framefile parse succeeded. Video/Audio directory is: c:/Daphne Singe/data/singe/maddog/
YUV overlay is done in software (ie unaccelerated).
Booting ROM ...
Starting Singe version 1.14
Search to 1 received [blocking]
SINGE: Unable to load font.
SINGE: Unable to load sprite C:/Daphne Singe/data/framefile/bullet.png!
SINGE: Unable to load sprite C:/Daphne Singe/data/framefile/star.png!
SINGE: Unable to load sprite C:/Daphne Singe/data/framefile/credits.png!
SINGE: Unable to load sprite C:/Daphne Singe/data/framefile/reload.png!
SINGE: Unable to load sprite C:/Daphne Singe/data/framefile/pistol.png!
SINGE: Unable to load sprite C:/Daphne Singe/data/framefile/choice.yes.png!
SINGE: Unable to load sprite C:/Daphne Singe/data/framefile/choice.no.png!
SINGE: Unable to load sprite C:/Daphne Singe/data/framefile/crosshaira.png!
SINGE: Unable to load sprite C:/Daphne Singe/data/framefile/choice.easy.png!
SINGE: Unable to load sprite C:/Daphne Singe/data/framefile/choice.med.png!
SINGE: Unable to load sprite C:/Daphne Singe/data/framefile/choice.hard.png!
SINGE: Unable to load sprite C:/Daphne Singe/data/framefile/choice1.png!
SINGE: Unable to load sprite C:/Daphne Singe/data/framefile/choice2.png!
SINGE: Unable to load sprite C:/Daphne Singe/data/framefile/choice3.png!
SINGE: Unable to load sprite C:/Daphne Singe/data/framefile/choice4.png!
SINGE: Unable to load sprite C:/Daphne Singe/data/framefile/choice.rel1.png!
SINGE: Unable to load sprite C:/Daphne Singe/data/framefile/choice.rel2.png!
SINGE: Unable to load sprite C:/Daphne Singe/data/framefile/choice.rel3.png!
SINGE: Could not open C:/Daphne Singe/data/framefile/shot.wav: Couldn't open C:/Daphne Singe/data/framefile/shot.wav
SINGE: Could not open C:/Daphne Singe/Daphne SINGE/data/singe/maddog/bottlebreak.wav: Couldn't open C:/Daphne Singe/Daphne SINGE/data/singe/maddog/bottlebreak.wav
SINGE: Could not open C:/Daphne Singe/Daphne SINGE/data/singe/maddog/hs.wav: Couldn't open C:/Daphne Singe/Daphne SINGE/data/singe/maddog/hs.wav
SINGE: Could not open C:/Daphne Singe/data/framefile/service.singe: Couldn't open C:/Daphne Singe/data/framefile/service.singe
Freeing memory used to store audio stream...
Shutting down sound system...
Shutting down video display...
It seems to me that Hyperlaunch not give any error, I think that the problem is in the daphne.
All those errors mean that your singe files are not pointing to the correct locations. Did you move your Singe install directory?
If you really must move your games, I'd suggest using a symbolic directory link rather than try to edit all the files manually.
  jedfactor said:
Hi
I managed to download all the files from the singe website before they got taken down, and I went through your guide and started setting up the action max bat files, but I got this error:
Could not open file : F:/Games/Hyperspin/Emulators/daphne_singe/singe/ActionMax/./video_ActionMaxIntro.m2v
Could not initialize laserdisc player!
I don't seem to have the ActionMaxIntro file, do you know where I can get this?
Thanks
Hi can anyone help with this?
Thanks
wOOt! Glad it's sorted!
Thanks,
Ron
  jedfactor said:
How can you change the controls for AMG games?
Well,
If you are talking about 'ALG' games... ;)
The majority of them are mouse. You cannot change them.
The few that use buttons and joystick, I would do it with the built in keymapper or an external one if you are using one.
Thanks,
Ron
  jedfactor said:
Yes ALG I meant lol, thanks, Any idea on the ActionMaxIntro file?
Yes,
That should have come with all the other m2v and ogg files from the Daphne Singe website.
Does the file not exist in "...\singe\ActionMax" ??
Thanks,
Ron
Thanks, strange I didn't have the file.
I'm getting this error now:
--Command line is: F:\Games\Hyperspin\Emulators\daphne_singe\daphne.exe singe vldp -x 800 -y 600 -fullscreen_window -noserversend -framefile F:\Games\Hyperspin\Emulators\daphne_singe\singe/ActionMax/frame_38AmbushAlley.txt -script F:\Games\Hyperspin\Emulators\daphne_singe\singe/ActionMax/38AmbushAlley.singe
--CPU : GenuineIntel 2800 MHz || Mem : 4096 megs
--OS : Windows NT Derivative || Video : NVIDIA GeForce GTX 880M
Setting screen width to 800
Setting screen height to 600
Set 1920x1080 at 32 bpp with flags: 20
Joystick #0 was successfully opened
Framefile parse succeeded. Video/Audio directory is: F:/Games/Hyperspin/Emulators/daphne_singe/singe/ActionMax/./
Booting ROM ...
SINGE: Script Error!
SINGE: error compiling script: ...mes\Hyperspin\Emulators\daphne_singe\singe/ActionMax/38AmbushAlley.singe:11: malformed number near '205dofile'
Any idea what is causing this?
Booting ROM ...
When posting logs of any type, please use code tags. They prevent the forum from messing up the post. If you are unsure how to use code tags, please see this post:
http://www.hyperspin-fe.com/forum/showthread.php?31072-The-HyperNoobie-Guide-For-Posting-To-The-Fourm
Did this happen the second time you tried to run the game?
If you copy the singe file from the original ActionMax archive and rename it again to "38AmbushAlley.singe". Launch. If it works once but not the second time, there is an update to the module that fixes the module corrupting the singe files. Update your setup please. This was just relased this weekend.
Thanks,
Ron
Thanks,
Ron
This same exact thing was happening to me with "38AmbushAlley.singe" specifically I updated (Did a pull, to daphne singe 2.0.5.ahk module) and now none of the ALG or ActionMax bat files load in HyperLaunchHQ. I followed your guide and had everything working 10 minutes ago. Read this post and said "Let me update my module" and now nothing. I deleted over the old file so now I am stuck with not being able to launch daphne-singe. Do you know how I can fix this issue?
Nevermind I was able to fix it. I just copied and pasted the prior version of Daphne Singe.ahk (2.0.3) and Daphne Singe.isd. The newest update (2.0.5) only came with Daphne Singe.ahk and not Daphne Singe.isd so no game was launching correctly but the corrupt issue remains.
Edit: Funny, now the previous Daphne Singe module I was using is giving problems as well. I guess I'll just update and leave it. I can run all the bat files fine outside of HyperLaunch anyways and they also work in HyperSpin too.
Edit 2: does anybody know if TimeGal or Ninja Hayate has any system intro videos in American Laser Games System Menu? I synced everything through hypersync, but those were the only two games without a video intro.
Thanks,
Ron
Any news for my problem?
I had posted daphne log and Hl log.
Yes,
Please change your Rom Paths in HLHQ to "c:/Daphne Singe/data/singe" and not the framefile directory. Test and post your daphne_log.txt using code tags this time. Also change your logging level to Troubleshooting and post it after the change.
Thanks,
Ron
Hi,
A couple things. There is no need to have the bat file launch the game. I only created the bat files to test outside HyperLaunch. I do understand that it works. There have been a hand full of people here resort to this method. But, there are just a couple things you have to have right and it will work like a dream!
1). That singe is in your Global Emulator -> Daphne Singe -> Rom Extensions.
2). The folder structure.
3). The name of the txt and singe files.
4). The Rom Paths in HLHQ.
1). Be sure singe is your rom extension in HLHQ -> GLOBAL -> Emulators -> Daphne Singe.
2). Your folder structure should match your xml and look like this:
For ALG -> ...\{Emulator}\singe\crimepatrol (etc... The folder names should match the rom names: crimepatrol, drugwars, maddog, etc)
For Action Max -> ...\{Emulator}\singe\ActionMax (all the Action Max files should be here)
3). The txt (framefiles) and singe files should match the names of the roms for both ALG and for Action Max:
ALG = Crime Patrol -> ...\{Emulator}\singe\crimepatrol\crimepatrol.txt & ...\{Emulator}\singe\crimepatrol\crimepatrol.singe
ALG = Mad Dog McMcree -> ...\{Emulator}\singe\maddog\maddog.txt & ...\{Emulator}\singe\maddog\maddog.singe
Action Max = ...\{Emulator}\singe\ActionMax\38AmbushAlley.txt & ...\{Emulator}\singe\ActionMax\38AmbushAlley.singe
Action Max = ...\{Emulator}\singe\ActionMax\BlueThunder.txt & ...\{Emulator}\singe\ActionMax\BlueThunder
4). For ALG your rom path should be "...\{Emulator}\singe" and for Action Max the rom path should be "...\{Emulator}\singe\ActionMax"
If All the above is correct they should all launch right.
I did find one thing. If your files are all good and in the above structure, set SingePathUpdate to false if the games do not launch. This is with the new Module V2.0.5
Hope this helps some.
Thanks,
Ron
Thanks,
Ron
How do you change the singepathupdate?
I can't get anything working using hyperlaunch, but most games are working outside of hyperlaunch using the bat files fine. have set up everything as you have shown so not sure what the problem is.
To change the SingePathUpdate:
Open HyperLaunchHQ and click on the system on the left.
Then the Modules tab on top.
Select Daphne Singe.ahk
Click the "Edit Global Module Settings" button just above it.
In that window you should have six options, one of them is SingePathUpdate. Set it to false and test.
Thanks,
Ron
  rfancella said:
Yes,
Thanks,
Ron
I had already tried this setting
--Command line is: C:\Daphne Singe\data\daphne.exe singe vldp -x 1024 -y 768 -fullscreen_window -framefile C:\Daphne Singe\data\singe\maddog\frame_maddog_cdrom.txt -script C:\Daphne Singe\data\singe\maddog\frame_maddog_cdrom.singe
Script C:\Daphne Singe\data\singe\maddog\frame_maddog_cdrom.singe does not exist.
Unknown command line parameter or parameter value:
-script
Bad command line or initialization problem (see daphne_log.txt for details).
To run DAPHNE, you must specify which game to run and which laserdisc player you are using.
For example, try 'daphne lair noldp' to run Dragon's Lair in testing mode.
...snip...
See step 3 in the post above (post #95). Your singe and txt files should match your database. Is the entry in your database:
<game name="maddog" index="true" image="m">
       <description>Mad Dog McCree</description>
       <cloneof></cloneof>
       <crc></crc>
       <manufacturer>American Laser Games</manufacturer>
       <year>1990</year>
       <genre>Gun</genre>
       <rating>AAMA - Red (Life Like Violence Strong)</rating>
       <enabled>Yes</enabled>
   </game>
If your rom name is maddog, the txt and singe files should be named maddog.txt and maddog.singe.
If the rom name is frame_maddog_cdrom, then your txt and singe files should be named frame_maddog_cdrom.txt and frame_maddog_cdrom.singe.
Does this help at all??
Thanks,
Ron
Thanks,
Ron
This solved my issues. Thanks for the solution and this fantastic guide! Only remaining issue now is, when I launch ActionMax games from HyperLaunchHQ I get the "Daphne, a Laserdisc Arcade Game Emulator has stopped working" error message. Which means the application crashed. Windows 7 x64 ultimate (Just so you know what operating system this is operating in.) I'll post my Daphne.exe log text (from Daphne Singe) and HLHQ Troubleshooting log.
[code]
21:12:01:568 | HL |     INFO  | +N/A   | Main - HyperLaunch v3.1.0.4 BETA (www.hyperlaunch.net)
21:12:01:675 | HL |     INFO  | +109   | Main - System Specs:
				HyperLaunch Dir: R:\HyperSpin\HyperLaunch
				OS: Microsoft Windows 7 Enterprise
				SKU: Enterprise
				Total Memory: 16325.30 MB
				Free Memory: 7249.95 MB
				Used Memory: 9075.355 MB
				SystemType: 64-bit
				Logical Processors: 8
				GPU 1 Name: NVIDIA GeForce GTX 760
				GPU 1 RAM: -2048.00 MB
				GPU 1 Driver Version: 9.18.13.4709
				Sound 1 Device: NVIDIA Virtual Audio Device (Wave Extensible) (WDM)
				Sound 2 Device: Saffire Audio
				Sound 2 Status: Enabled
				Sound 3 Device: Bluetooth Audio Device
				Sound 3 Status: Enabled
				Sound 4 Device: NVIDIA High Definition Audio
				Sound 4 Status: Enabled
				Sound 5 Device: Realtek High Definition Audio
				Sound 5 Status: Enabled
				Monitor #1 (\\.\DISPLAY1): 1920x1080 (1920x1040 work)
				Current AHK Desktop Width: 1920
				Current AHK Desktop Height: 1080
				AutoHotkey Path:
				Unicode: No
21:12:01:677 | HL |     INFO  | +0     | CheckFile - Checking if R:\HyperSpin\HyperLaunch\HyperLaunch.exe exists
21:12:01:679 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				FileDescription         	Your favorite Front End companion! Visit us @ www.hyperlaunch.net
				FileVersion             	3.1.0.4
				LegalCopyright          	�2014 HyperLaunch
				CompanyName             	HyperLaunch BETA
				File Size:			966656 bytes
				Created:			2/7/2015 - 7:50:35 PM
				Modified:			2/1/2015 - 8:12:19 PM
21:12:01:681 | HL |     INFO  | +0     | CheckFile - Checking if R:\HyperSpin\HyperLaunch\Module Extensions\dxwnd\dxwnd.ini exists
21:12:01:683 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			409 bytes
				Created:			2/7/2015 - 7:52:01 PM
				Modified:			2/1/2015 - 8:12:26 PM
21:12:01:684 | HL |     INFO  | +0     | CheckFile - Checking if R:\HyperSpin\HyperLaunch\Module Extensions\dxwnd\dxwnd.exe exists
21:12:01:686 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				FileDescription         	DxWnd MFC application
				FileVersion             	1, 0, 0, 1
				InternalName            	DxWnd
				LegalCopyright          	Copyright (C) 2004/2012
				OriginalFilename        	DxWnd.exe
				ProductName             	DxWnd application
				ProductVersion          	1, 0, 0, 1
				File Size:			539136 bytes
21:12:01:689 | HL |     INFO  | +16    | CheckFile - Checking if R:\HyperSpin\HyperLaunch\Module Extensions\BinHexRW.ahk exists
21:12:01:695 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
21:12:01:697 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			4961 bytes
				Created:			2/7/2015 - 7:51:58 PM
				Modified:			2/1/2015 - 8:12:24 PM
21:12:01:699 | HL |     INFO  | +0     | CheckFile - Checking if R:\HyperSpin\HyperLaunch\Module Extensions\BlockInput.exe exists
21:12:01:703 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				FileDescription
				InternalName
				OriginalFilename
				ProductName
				File Size:			657920 bytes
21:12:01:704 | HL |     INFO  | +15    | CheckFile - Checking if R:\HyperSpin\HyperLaunch\Module Extensions\CLR.ahk exists
21:12:01:720 | HL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Extension.
21:12:01:722 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			10586 bytes
				Modified:			2/1/2015 - 8:12:25 PM
21:12:01:725 | HL |     INFO  | +0     | CheckFile - Checking if R:\HyperSpin\HyperLaunch\Module Extensions\COM.ahk exists
21:12:01:731 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Extension.
21:12:01:734 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			26342 bytes
21:12:01:736 | HL |     INFO  | +15    | CheckFile - Checking if R:\HyperSpin\HyperLaunch\Module Extensions\Control_AniGif.ahk exists
21:12:01:741 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Extension.
21:12:01:743 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			5716 bytes
21:12:01:746 | HL |     INFO  | +0     | CheckFile - Checking if R:\HyperSpin\HyperLaunch\Module Extensions\dxwnd\dxwnd.ini exists
21:12:01:749 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
21:12:01:750 | HL |     INFO  | +0     | CheckFile - Checking if R:\HyperSpin\HyperLaunch\Module Extensions\dxwnd\dxwnd.exe exists
21:12:01:753 | HL |   DEBUG1  | +16    | CheckFile - Attributes:
				InternalName            	DxWnd
21:12:01:755 | HL |     INFO  | +0     | CheckFile - Checking if R:\HyperSpin\HyperLaunch\Module Extensions\gdip.ahk exists
21:12:01:760 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Extension.
21:12:01:763 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			88789 bytes
				Created:			2/7/2015 - 7:51:59 PM
21:12:01:765 | HL |     INFO  | +0     | CheckFile - Checking if R:\HyperSpin\HyperLaunch\Module Extensions\gdip_alt.ahk exists
21:12:01:769 | HL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
21:12:01:773 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			3394 bytes
21:12:01:775 | HL |   DEBUG1  | +0     | gdip_alt.ahk Version: 1.0.1
21:12:01:776 | HL |     INFO  | +0     | CheckFile - Checking if R:\HyperSpin\HyperLaunch\Module Extensions\gsdll32.dll exists
21:12:01:779 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			13090816 bytes
				Modified:			2/1/2015 - 8:12:27 PM
21:12:01:781 | HL |     INFO  | +0     | CheckFile - Checking if R:\HyperSpin\HyperLaunch\Module Extensions\itextsharp.dll exists
21:12:01:784 | HL |   DEBUG1  | +15    | CheckFile - Attributes:
				FileDescription         	iTextSharp
				FileVersion             	5.4.2.0
				InternalName            	itextsharp.dll
				LegalCopyright          	Copyright (C) 1999-2013 by Bruno Lowagie and Paulo Soares. All Rights Reserved.
				OriginalFilename        	itextsharp.dll
				ProductName             	iTextSharp
				ProductVersion          	5.4.2.0
				CompanyName             	1T3XT BVBA
				File Size:			3743744 bytes
				Created:			2/7/2015 - 7:52:00 PM
				Modified:			2/1/2015 - 8:12:28 PM
21:12:01:786 | HL |     INFO  | +0     | CheckFile - Checking if R:\HyperSpin\HyperLaunch\Module Extensions\Java.ahk exists
21:12:01:801 | HL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
21:12:01:805 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			7841 bytes
21:12:01:807 | HL |   DEBUG1  | +0     | Java.ahk Version: 1.0.0
21:12:01:809 | HL |     INFO  | +0     | CheckFile - Checking if R:\HyperSpin\HyperLaunch\Module Extensions\JSON.ahk exists
21:12:01:814 | HL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Extension.
21:12:01:817 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			9203 bytes
21:12:01:818 | HL |     INFO  | +0     | CheckFile - Checking if R:\HyperSpin\HyperLaunch\Module Extensions\Origin.ahk exists
21:12:01:823 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
21:12:01:826 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			4897 bytes
21:12:01:827 | HL |   DEBUG1  | +0     | Origin.ahk Version: 1.0.0
21:12:01:830 | HL |     INFO  | +16    | CheckFile - Checking if R:\HyperSpin\HyperLaunch\Module Extensions\PacDrive32.dll exists
21:12:01:832 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			69120 bytes
21:12:01:834 | HL |     INFO  | +0     | CheckFile - Checking if R:\HyperSpin\HyperLaunch\Module Extensions\RegRW64.ahk exists
21:12:01:838 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Extension.
21:12:01:841 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			6915 bytes
21:12:01:843 | HL |     INFO  | +0     | CheckFile - Checking if R:\HyperSpin\HyperLaunch\Module Extensions\RIni.ahk exists
21:12:01:849 | HL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Extension.
21:12:01:858 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			67561 bytes
21:12:01:860 | HL |     INFO  | +15    | CheckFile - Checking if R:\HyperSpin\HyperLaunch\Module Extensions\SevenZipSharp.dll exists
21:12:01:870 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				FileDescription         	SevenZipSharp
				FileVersion             	0.64.4841.31212
				InternalName            	SevenZipSharp.dll
				LegalCopyright          	Copyright (C) Markovtsev Vadim 2009, 2010, licenced under LGPLv3
				OriginalFilename        	SevenZipSharp.dll
				ProductName             	SevenZipSharp
				ProductVersion          	0.64.4841.31212
				CompanyName             	Markovtsev Vadim
				File Size:			165888 bytes
21:12:01:872 | HL |     INFO  | +0     | CheckFile - Checking if R:\HyperSpin\HyperLaunch\Module Extensions\Steam.ahk exists
21:12:01:876 | HL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
21:12:01:881 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			5326 bytes
21:12:01:883 | HL |   DEBUG1  | +0     | Steam.ahk Version: 1.0.0
21:12:01:884 | HL |     INFO  | +0     | CheckFile - Checking if R:\HyperSpin\HyperLaunch\Module Extensions\VA.ahk exists
21:12:01:889 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Extension.
21:12:01:892 | HL |   DEBUG1  | +15    | CheckFile - Attributes:
				File Size:			34688 bytes
21:12:01:893 | HL |     INFO  | +0     | CheckFile - Checking if R:\HyperSpin\HyperLaunch\Module Extensions\VA_Extension.ahk exists
21:12:01:899 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
21:12:01:902 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			3833 bytes
21:12:01:904 | HL |   DEBUG1  | +0     | VA_Extension.ahk Version: 1.0.1
21:12:01:907 | HL |     INFO  | +16    | CheckFile - Checking if R:\HyperSpin\HyperLaunch\Lib\Bezel.ahk exists
21:12:01:929 | HL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
21:12:01:933 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			101720 bytes
				Created:			2/7/2015 - 7:50:53 PM
				Modified:			2/1/2015 - 8:12:21 PM
21:12:01:936 | HL |   DEBUG1  | +0     | Bezel.ahk Version: 1.0.8
21:12:01:938 | HL |     INFO  | +15    | CheckFile - Checking if R:\HyperSpin\HyperLaunch\Lib\Fade.ahk exists
21:12:01:943 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
21:12:01:947 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			36402 bytes
21:12:01:949 | HL |   DEBUG1  | +0     | Fade.ahk Version: 1.0.9
21:12:01:951 | HL |     INFO  | +0     | CheckFile - Checking if R:\HyperSpin\HyperLaunch\Lib\Fade Init.ahk exists
21:12:01:955 | HL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
21:12:01:959 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			999 bytes
21:12:01:961 | HL |   DEBUG1  | +0     | Fade Init.ahk Version: 1.0.1
21:12:01:964 | HL |     INFO  | +0     | CheckFile - Checking if R:\HyperSpin\HyperLaunch\Lib\Fade Animations.ahk exists
21:12:01:969 | HL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Library.
21:12:01:972 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			67602 bytes
21:12:01:975 | HL |   DEBUG1  | +0     | Fade Animations.ahk Version: 1.1.1
21:12:01:976 | HL |     INFO  | +0     | CheckFile - Checking if R:\HyperSpin\HyperLaunch\Lib\HyperPause.ahk exists
21:12:01:994 | HL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
21:12:01:999 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			392193 bytes
21:12:01:001 | HL |   DEBUG1  | +16    | HyperPause.ahk Version: 1.0.7
21:12:02:003 | HL |     INFO  | +0     | CheckFile - Checking if R:\HyperSpin\HyperLaunch\Lib\HyperPause Init.ahk exists
21:12:02:019 | HL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Library.
21:12:02:023 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			537 bytes
21:12:02:025 | HL |   DEBUG1  | +0     | HyperPause Init.ahk Version: 1.0.1
21:12:02:027 | HL |     INFO  | +0     | CheckFile - Checking if R:\HyperSpin\HyperLaunch\Lib\Keymapper.ahk exists
21:12:02:032 | HL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
21:12:02:035 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			32953 bytes
21:12:02:038 | HL |   DEBUG1  | +0     | Keymapper.ahk Version: 1.0.9
21:12:02:041 | HL |     INFO  | +0     | CheckFile - Checking if R:\HyperSpin\HyperLaunch\Lib\Keymapper Init.ahk exists
21:12:02:045 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
21:12:02:048 | HL |   DEBUG1  | +15    | CheckFile - Attributes:
				File Size:			3435 bytes
21:12:02:050 | HL |   DEBUG1  | +0     | Keymapper Init.ahk Version: 1.0.2
21:12:02:052 | HL |     INFO  | +0     | CheckFile - Checking if R:\HyperSpin\HyperLaunch\Lib\MultiGame.ahk exists
21:12:02:058 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
21:12:02:061 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			40584 bytes
21:12:02:063 | HL |   DEBUG1  | +16    | MultiGame.ahk Version: 1.0.6
21:12:02:065 | HL |     INFO  | +0     | CheckFile - Checking if R:\HyperSpin\HyperLaunch\Lib\MultiGame Init.ahk exists
21:12:02:078 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
21:12:02:081 | HL |   DEBUG1  | +16    | CheckFile - Attributes:
				File Size:			161 bytes
21:12:02:084 | HL |   DEBUG1  | +0     | MultiGame Init.ahk Version: 1.0.0
21:12:02:086 | HL |     INFO  | +0     | CheckFile - Checking if R:\HyperSpin\HyperLaunch\Lib\MultiPlayer.ahk exists
21:12:02:091 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
21:12:02:106 | HL |   DEBUG1  | +15    | CheckFile - Attributes:
				File Size:			58605 bytes
				Modified:			2/6/2015 - 9:28:23 AM
21:12:02:108 | HL |   DEBUG1  | +0     | MultiPlayer.ahk Version: 1.0.4
21:12:02:110 | HL |     INFO  | +16    | CheckFile - Checking if R:\HyperSpin\HyperLaunch\Lib\Password.ahk exists
21:12:02:115 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
21:12:02:117 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			10035 bytes
21:12:02:119 | HL |   DEBUG1  | +0     | Password.ahk Version: 1.0.0
21:12:02:122 | HL |     INFO  | +0     | CheckFile - Checking if R:\HyperSpin\HyperLaunch\Lib\Rom Mapping Launch Menu.ahk exists
21:12:02:127 | HL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Library.
21:12:02:130 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			73560 bytes
21:12:02:132 | HL |   DEBUG1  | +0     | Rom Mapping Launch Menu.ahk Version: 1.0.3
21:12:02:134 | HL |     INFO  | +0     | CheckFile - Checking if R:\HyperSpin\HyperLaunch\Lib\Shared.ahk exists
21:12:02:141 | HL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
21:12:02:143 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			140963 bytes
21:12:02:145 | HL |   DEBUG1  | +0     | Shared.ahk Version: 1.2.1
21:12:02:147 | HL |     INFO  | +0     | CheckFile - Checking if R:\HyperSpin\HyperLaunch\Lib\Statistics.ahk exists
21:12:02:158 | HL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
21:12:02:161 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			26170 bytes
21:12:02:169 | HL |   DEBUG1  | +0     | Statistics.ahk Version: 1.0.2
21:12:02:171 | HL |     INFO  | +0     | CheckFile - Checking if R:\HyperSpin\HyperLaunch\Lib\Statistics Init.ahk exists
21:12:02:190 | HL |   DEBUG1  | +31    | CRC Check - CRC matches, this is an official unedited Library.
21:12:02:193 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			33 bytes
21:12:02:195 | HL |   DEBUG1  | +0     | Statistics Init.ahk Version: 1.0.1
21:12:02:197 | HL |     INFO  | +0     | CheckFile - Checking if R:\HyperSpin\HyperLaunch\Lib\XHotkey.ahk exists
21:12:02:203 | HL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Library.
21:12:02:207 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			29623 bytes
21:12:02:209 | HL |   DEBUG1  | +0     | XHotkey.ahk Version: 1.0.2
21:12:02:211 | HL |     INFO  | +0     | CheckFile - Checking if R:\HyperSpin\HyperLaunch\Lib\XHotkey Init.ahk exists
21:12:02:216 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
21:12:02:219 | HL |   DEBUG1  | +16    | CheckFile - Attributes:
				File Size:			1236 bytes
21:12:02:222 | HL |   DEBUG1  | +0     | XHotkey Init.ahk Version: 1.0.0
21:12:02:224 | HL |   DEBUG1  | +0     | Main - Raw CLI received: "-s WoW Action Max -r 38AmbushAlley -f R:\HyperSpin\HyperSpin.exe -p HyperSpin"
21:12:02:225 | HL |   DEBUG1  | +0     | Main - Received this dbName with no path via CLI: "38AmbushAlley"
21:12:02:226 | HL |   DEBUG1  | +0     | Main - dbName: 38AmbushAlley
21:12:02:232 | HL |     INFO  | +0     | CheckFile - Checking if R:\HyperSpin\HyperLaunch\Plugins\HyperSpin.plugin exists
21:12:02:235 | HL |   DEBUG1  | +16    | CheckFile - Attributes:
				File Size:			8827 bytes
				Created:			2/7/2015 - 7:52:04 PM
				Modified:			2/6/2015 - 9:28:24 AM
21:12:02:237 | HL |     INFO  | +0     | Main - Loading Front End Plugin: "HyperSpin"
21:12:02:239 | HL |     INFO  | +0     | Main - HyperLaunch received "WoW Action Max" and "38AmbushAlley"
21:12:02:250 | HL |     INFO  | +15    | Main - 38AmbushAlley is using the default emulator: Daphne Singe
21:12:02:259 | HL |     INFO  | +0     | Main - Checking for a [Daphne Singe] section in R:\HyperSpin\HyperLaunch\Settings\WoW Action Max\Emulators.ini
21:12:02:261 | HL |     INFO  | +0     | Main - Found [Daphne Singe] in R:\HyperSpin\HyperLaunch\Settings\WoW Action Max\Emulators.ini
21:12:02:264 | HL |     INFO  | +0     | CheckFile - Checking if R:\HyperSpin\HyperLaunch\Modules\Daphne Singe\Daphne Singe.ahk exists
21:12:02:267 | HL |   DEBUG1  | +16    | CheckFile - Attributes:
				File Size:			10042 bytes
				Created:			2/10/2015 - 4:28:19 AM
				Modified:			1/1/1601 - 12:00:00 AM
21:12:02:270 | HL |     INFO  | +0     | Main - CRC Check - CRC matches, this is an official unedited module.
21:12:02:272 | HL |     INFO  | +0     | Main - 38AmbushAlley will use module: R:\HyperSpin\HyperLaunch\Modules\Daphne Singe\Daphne Singe.ahk
21:12:02:288 | HL |     INFO  | +15    | Main - Did not find a "R:\HyperSpin\HyperLaunch\Settings\WoW Action Max\Game Options.ini" file, skipping any game-specific options.
21:12:02:305 | HL |     INFO  | +16    | Main - Using standard method with "Rom Extension" SkipChecks or without any SkipChecks.
21:12:02:313 | HL |     INFO  | +16    | Main - INI Keys read
21:12:02:330 | HL |     INFO  | +15    | CheckFile - Checking if R:\HyperSpin\HyperLaunch\Module Extensions\7z.exe exists
21:12:02:333 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				FileVersion             	9.20
				InternalName            	7z
				ProductVersion          	9.20
				File Size:			163840 bytes
21:12:02:341 | HL |     INFO  | +0     | CheckFile - Checking if R:\HyperSpin\HyperLaunch\Module Extensions\7z.dll exists
21:12:02:346 | HL |   DEBUG1  | +16    | CheckFile - Attributes:
				FileVersion             	9.20
				InternalName            	7za
				ProductVersion          	9.20
				File Size:			914432 bytes
21:12:02:348 | HL |     INFO  | +0     | CheckFile - Checking if R:\HyperSpin\HyperLaunch\Module Extensions\FontReg.exe exists
21:12:02:352 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				FileDescription         	Font Registration Utility (x86-32)
				FileVersion             	2.1.3.0
				OriginalFilename        	FontReg.exe
				File Size:			6144 bytes
21:12:02:370 | HL |     INFO  | +15    | Main - "38AmbushAlley" does not qualify for MultiGame. Only roms with any of these strings in their name are acceptable: (Disc,(Disk,(Cart,(Tape,(Cassette,(Part,(Side
21:12:02:372 | HL |     INFO  | +0     | CheckPaths - Started
21:12:02:374 | HL |   DEBUG1  | +0     | CheckPaths - Looking for rom: R:\HyperSpin\Emulators\daphne-singe\singe\ActionMax\38AmbushAlley.singe
21:12:02:376 | HL |     INFO  | +16    | CheckPaths - Found rom: R:\HyperSpin\Emulators\daphne-singe\singe\ActionMax\38AmbushAlley.singe
21:12:02:378 | HL |   DEBUG1  | +0     | CheckPaths - Current romName: 38AmbushAlley
21:12:02:380 | HL |   DEBUG1  | +0     | CheckPaths - Current romPath: R:\HyperSpin\Emulators\daphne-singe\singe\ActionMax
21:12:02:382 | HL |   DEBUG1  | +0     | CheckPaths - Current romExtension: .singe
21:12:02:384 | HL |     INFO  | +0     | CheckPaths - Ended
21:12:02:387 | HL |     INFO  | +0     | BuildScript - User Variables:
				#NoTrayIcon
				#InstallKeybdHook
				SendMode, Event
				0 = 8
				pluginPath = R:\HyperSpin\HyperLaunch\Plugins
				pluginExt = .plugin
				hlMode =
				hlVersion = 3.1.0.4 BETA
				hlAuthor = djvj
				langFile = R:\HyperSpin\HyperLaunch\Data\Language\Localization.ini
				frontendPID = 0
				frontendPath = R:\HyperSpin
				frontendExt = exe
				frontendDrive = R:
				forceHoldKey = ~Esc
				restoreFE = false
				emuFullPath = R:\HyperSpin\Emulators\daphne-singe\daphne.exe
				emuPath = R:\HyperSpin\Emulators\daphne-singe
				emuExt = exe
				romPath = R:\HyperSpin\Emulators\daphne-singe\singe\ActionMax
				romPathFromIni = R:\HyperSpin\Emulators\daphne-singe\singe\ActionMax
				systemName = WoW Action Max
				dbPath =
				dbName = 38AmbushAlley
				dbExt =
				romName = 38AmbushAlley
				romMapPath =
				altRomNameOnly =
				altRomNamesOnly =
				romMapScenario =
				skipchecks = false
				romMatchExt = false
				blockInputTime = 0
				blockInputFile = R:\HyperSpin\HyperLaunch\Module Extensions\BlockInput.exe
				lockLaunch = false
				lockLaunchGame =
				logFile = R:\HyperSpin\HyperLaunch\HyperLaunch.log
				logLevel = 10
				sysType = 64-bit
				navUpKey = Up
				navDownKey = Down
				navLeftKey = Left
				navRightKey = Right
				originalWidth = 1920
				originalHeight = 1080
				dtEnabled = false
				dtPath =
				dtUseSCSI = true
				dtAddDrive = true
				ledblinkyFullPath =
				ledblinkyProfilePath = R:\HyperSpin\HyperLaunch\Profiles\LEDBlinky
				ledblinkyHLProfile = R:\HyperSpin\HyperLaunch\Profiles\LEDBlinky\HyperLaunch
				emuIdleShutdown = 0
				hideCursor = false
				hideEmu = false
				hideFE = false
				fadeIn = false
				fadeInDelay = 0
				fadeInExitDelay = 0
				fadeOut = false
				fadeOutDelay = 0
				fadeLyrInterpolation = 7
				fadeWidthBaseRes = 1920
				fadeHeightBaseRes = 1080
				fadeLyr2X = 0
				fadeLyr2Y = 0
				fadeLyr2W =
				fadeLyr2H =
				fadeLyr2Adjust = 1
				fadeLyr2PicPad = 0
				fadeLyr3X = 450
				fadeLyr3Y = 450
				fadeLyr3W =
				fadeLyr3H =
				fadeLyr3Adjust = 1
				fadeLyr3PicPad = 0
				fadeLyr3Speed = 750
				fadeLyr3Repeat = 1
				fadeLyr3StaticX = 0
				fadeLyr3StaticW =
				fadeLyr3StaticH =
				fadeLyr4Adjust = 1
				fadeLyr4X = 1792|952
				fadeLyr4Y = 891|1596
				fadeLyr4W = 128
				fadeLyr4H =
				fadeLyr4Pos = No Alignment
				fadeLyr4FPS = 50
				fadeLyr4PicPad = 0
				fadeBarWindow = Image
				fadeBarWindowX =
				fadeBarWindowY =
				fadeBarWindowW = 900
				fadeBarWindowH =
				fadeBarWindowR = 30
				fadeBarWindowM = 30
				fadeBar = 7zOnly
				fadeBarBack = true
				fadeBarH = 30
				fadeBarR = 10
				fadeBarHatchStyle = 8
				fadeBarXOffset = 0
				fadeBarYOffset = 150
				fadeRomInfoSystemName = image
				fadeRomInfoManufacturer = text with label
				fadeRomInfoGenre = disabled
				fadeRomInfoRating = image
				fadeRomInfoTextMargin = 7
				fadeStatsInfoTextMargin = 7
				fadeText1X = 0
				fadeText1Y = 0
				fadeText2X = 0
				fadeText2Y = 0
				fadeFont = Bebas Neue
				fadeInterruptKey =
				fadeImgPath = R:\HyperSpin\HyperLaunch\Media\Fade
				HLDataPath = R:\HyperSpin\HyperLaunch\Data
				HLMediaPath = R:\HyperSpin\HyperLaunch\Media
				HLErrSoundPath = R:\HyperSpin\HyperLaunch\Media\Sounds\Error
				modulesPath = R:\HyperSpin\HyperLaunch\Modules
				moduleFullName = R:\HyperSpin\HyperLaunch\Modules\Daphne Singe\Daphne Singe.ahk
				modulePath = R:\HyperSpin\HyperLaunch\Modules\Daphne Singe
				moduleExtensionsPath = R:\HyperSpin\HyperLaunch\Module Extensions
				libPath = R:\HyperSpin\HyperLaunch\Lib
				7zEnabled = false
				7zPath = R:\HyperSpin\HyperLaunch\Module Extensions\7z.exe
				7zDllPath = R:\HyperSpin\HyperLaunch\Module Extensions\7z.dll
				7zExtractPath = C:\Users\Isiah\AppData\Local\Temp\HS
				7zExtractPathOrig =
				7zDelTemp = true
				7zSounds = true
				mgEnabled = false
				mgKey = ~NumpadSub
				mgSidePadding = 0.2
				mgWidthBaseRes = 1920
				mgHeightBaseRes = 1080
				mgYOffset = 500|800
				mgFont = Arial
				mgText2Offset = 100
				mgUseSound = true
				mgSoundfreq = 300
				mgExitEffect = none
				mgCandidate =
				mgOnLaunch = false
				hpEnabled = false
				hpKey = ~NumpadAdd
				hpZoomInKey = C
				hpZoomOutKey = V
				hpHiToTextPath = R:\HyperSpin\HyperLaunch\Module Extensions\HiToText.exe
				keymapper = xpadder
				xpadderFullPath = R:\HyperSpin\Utilities\Xpadder\Xpadder.exe
				joyToKeyFullPath = R:\HyperSpin\Utilities\JoyToKey\JoyToKey.exe
				keymapperProfilePath = R:\HyperSpin\HyperLaunch\Profiles\xpadder
				JoyIDsPreferredControllersGlobal =
				CustomJoyNames =
				FEProfile = R:\HyperSpin\HyperLaunch\Profiles\xpadder\HyperSpin
				defaultProfile = R:\HyperSpin\HyperLaunch\Profiles\xpadder\_Default
				systemProfile = R:\HyperSpin\HyperLaunch\Profiles\xpadder\WoW Action Max
				xPadderSystemProfile = R:\HyperSpin\HyperLaunch\Profiles\xpadder\WoW Action Max\_Default
				emuProfile = R:\HyperSpin\HyperLaunch\Profiles\xpadder\WoW Action Max\Daphne Singe
				romProfile = R:\HyperSpin\HyperLaunch\Profiles\xpadder\WoW Action Max\38AmbushAlley
				HyperLaunchProfile = R:\HyperSpin\HyperLaunch\Profiles\xpadder\HyperLaunch
				blankProfile = R:\HyperSpin\HyperLaunch\Profiles\xpadder\_Default\blank
				ahkFEProfile = R:\HyperSpin\HyperLaunch\Profiles\AHK\HyperSpin
				ahkDefaultProfile = R:\HyperSpin\HyperLaunch\Profiles\AHK\_Default
				ahkSystemProfile = R:\HyperSpin\HyperLaunch\Profiles\AHK\WoW Action Max
				ahkEmuProfile = R:\HyperSpin\HyperLaunch\Profiles\AHK\WoW Action Max\Daphne Singe
				ahkRomProfile = R:\HyperSpin\HyperLaunch\Profiles\AHK\WoW Action Max\38AmbushAlley
				ahkHyperLaunchProfile = R:\HyperSpin\HyperLaunch\Profiles\AHK\HyperLaunch
				pressDuration = -1
				emuVolume = 1
				dxwndIni = R:\HyperSpin\HyperLaunch\Module Extensions\dxwnd\dxwnd.ini
				dxwndFullPath = R:\HyperSpin\HyperLaunch\Module Extensions\dxwnd\dxwnd.exe
				mon1O = 0
				pacDrivedllFile = R:\HyperSpin\HyperLaunch\Module Extensions\PacDrive32.dll
				userFadeAnimIniFile = R:\HyperSpin\HyperLaunch\Lib\User Fade Animations.ini
21:12:02:391 | HL |     INFO  | +16    | BuildScript - Loaded XHotkey Init.ahk scripts
21:12:02:393 | HL |     INFO  | +0     | BuildScript - Loaded Statistics Init.ahk scripts
21:12:02:395 | HL |  WARNING  | +0     | BuildScript - "R:\HyperSpin\HyperLaunch\Lib\User Functions Init.ahk" not found
21:12:02:398 | HL |   DEBUG1  | +0     | BuildScript - Module starts on line: 2
21:12:02:399 | HL |     INFO  | +0     | BuildScript - Validating module
21:12:02:403 | HL |     INFO  | +0     | BuildScript - Validation complete
21:12:02:404 | HL |     INFO  | +0     | BuildScript - Module:
				MEmu = Daphne Singe
				MEmuV =  v1.14
				MAuthor = djvj
				MVersion = 2.0.5
				MCRC = 6509AFA2
				iCRC = 777E5B50
				; Notes:
				; NEW METHOD:
				; Do nothing!
				; OLD METHOD:
				; Old
				; ("singe/
				; New:
				; WoW Action Max
				; Old
				; New:
				StartModule()
				BezelGUI()
				FadeInStart()
				globalParams := IniReadCheck(settingsFile,"settings","globalParams","",,1)
				params := IniReadCheck(settingsFile,romName,"params","",,1)
				params := " " . globalParams . " " .  params
				BezelStart()
				{	params := params . " -ignore_aspect_ratio"
				} Else {
					SingePathUpdate()
				Run(executable . " singe vldp" . daphneWidth . daphneHeight . fullscreen . params . " -framefile """ . romPath . "\" . romName . ".txt"" -script """ . romPath . "\" . romName . ".singe""", emuPath)
				BezelDraw()
				HideEmuEnd()
				FadeInExit()
				7zCleanUp()
				FadeOutExit()
				ExitModule()
				SingePathUpdate(){
					FileFullPath := []
					updatedLines := 0
					singeData :=
					singeCount :=
							Return
									singeCount++
						updatedText :=
							currentLine := A_Index
							lineUpdated :=
									updatedText .= (If currentLine = 1 ? "" : "`r`n") . UpdateLine(oldSingeLine, singeUpdateStrings[A_Index])
									lineUpdated := 1
								updatedText .= (If currentLine = 1 ? "" : "`r`n") . A_LoopField
					exitapp
					Return
						Else
						updatedLines++
					} Else
						Line := oldLine
					Return Line
				HaltEmu:
					Send, {P}
				Return
				RestoreEmu:
					Send, {P}
				Return
				CloseProcess:
					FadeOutStart()
					BezelExit()
				Return
21:12:02:417 | HL |     INFO  | +15    | BuildScript - Loaded Multi-Player scripts
21:12:02:420 | HL |     INFO  | +0     | BuildScript - Loaded Statistics.ahk script
21:12:02:424 | HL |  WARNING  | +16    | BuildScript - "R:\HyperSpin\HyperLaunch\Lib\User Functions.ahk" not found
21:12:02:425 | HL |     INFO  | +0     | BuildScript - Finished injecting functions into module
21:12:02:428 | HL |     INFO  | +0     | Main - Module is built
21:12:02:430 | HL |     INFO  | +0     | CheckFile - Checking if R:\HyperSpin\HyperLaunch\AutoHotkey.dll exists
21:12:02:447 | HL |   DEBUG1  | +15    | CheckFile - Attributes:
				File Size:			785408 bytes
				Created:			2/7/2015 - 7:50:46 PM
				Modified:			2/1/2015 - 8:12:11 PM
21:12:02:454 | HL |     INFO  | +16    | Main - Running module
21:12:02:458 | HL |     INFO  | +0     | Main - Starting timer to watch if Front End gets displaced and restore it if it does.
21:12:02:580 | MD |     INFO  | +N/A   | Module initialized
21:12:02:583 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~Esc" to call label: "CloseProcess"
21:12:02:587 | MD |     INFO  | +0     | StartModule - Started
21:12:02:589 | MD |     INFO  | +0     | StartModule - MEmu: Daphne Singe
				MEmuV: v1.14
				MAuthor: djvj
				MVersion: 2.0.5
				MCRC: 6509AFA2
				iCRC: 777E5B50
				MID:
21:12:02:591 | MD |     INFO  | +0     | StartModule - You have a supported System Name for this module: "WoW Action Max"
21:12:02:613 | MD |     INFO  | +31    | PluginInit - Started
21:12:02:640 | MD |   DEBUG1  | +31    | BuildDatabaseTable - Started - Building Table for: Name|Cloneof|Manufacturer|Year|Genre|Rating
21:12:02:643 | MD |     INFO  | +0     | CheckFile - Checking if R:\HyperSpin\Databases\WoW Action Max\WoW Action Max.xml exists
21:12:02:647 | MD |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			1927 bytes
				Created:			2/7/2015 - 4:06:30 AM
				Modified:			2/7/2015 - 4:06:30 AM
21:12:02:649 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Searching for a "Game Name" in the database
21:12:02:653 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Found "Game Name" in the database!
21:12:02:655 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Searching database for: Name
21:12:02:671 | MD |   DEBUG1  | +31    | BuildDatabaseTable - Found "Name" with a value: ".38 Ambush Alley"
21:12:02:705 | MD |   DEBUG1  | +32    | BuildDatabaseTable - Searching database for: Cloneof
21:12:02:707 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Could not find: Cloneof
21:12:02:709 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Searching database for: Manufacturer
21:12:02:711 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Found "Manufacturer" with a value: "Sourcing International Ltd."
21:12:02:713 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Searching database for: Year
21:12:02:716 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Found "Year" with a value: "1987"
21:12:02:738 | MD |   DEBUG1  | +31    | BuildDatabaseTable - Searching database for: Genre
21:12:02:767 | MD |   DEBUG1  | +31    | BuildDatabaseTable - Found "Genre" with a value: "Gun"
21:12:02:769 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Searching database for: Rating
21:12:02:773 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Found "Rating" with a value: "HSRS - PG (Parental Guidance)"
21:12:02:775 | MD |   DEBUG2  | +0     | PluginInit - GameInfo:
				GameInfo Label: Genre | GameInfo Value:
				GameInfo Label: Manufacturer | GameInfo Value:
				GameInfo Label: Name | GameInfo Value:
				GameInfo Label: Rating | GameInfo Value:
				GameInfo Label: Year | GameInfo Value:
21:12:02:777 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Ended
21:12:02:780 | MD |   DEBUG1  | +0     | BuildAssetsTable - Started - Building Table for: Game Logo|System Logo
21:12:02:803 | MD |   DEBUG1  | +31    | BuildAssetsTable - Searching for: R:\HyperSpin\Media\WoW Action Max\Images\Wheel\38AmbushAlley.png
21:12:02:828 | MD |   DEBUG1  | +31    | BuildAssetsTable - Searching for: R:\HyperSpin\Media\Main Menu\Images\Wheel\WoW Action Max.png
21:12:02:834 | MD |   DEBUG2  | +0     | BuildAssetsTable - Media assets found:
				Asset Label: Game Logo | Asset Path1:  R:\HyperSpin\Media\WoW Action Max\Images\Wheel\38AmbushAlley.png | Asset Extension1:  png | Asset Type1:  game
				Asset Label: System Logo | Asset Path1:  R:\HyperSpin\Media\Main Menu\Images\Wheel\WoW Action Max.png | Asset Extension1:  png | Asset Type1:  system
21:12:02:836 | MD |   DEBUG1  | +0     | BuildAssetsTable - Ended
21:12:02:874 | MD |   DEBUG1  | +47    | BuildAssetsTable - Started - Building Table for: Artwork1|Box Art|Cartridge|Flyers|Letters|Other
21:12:02:905 | MD |   DEBUG1  | +31    | BuildAssetsTable - Searching for: R:\HyperSpin\Media\WoW Action Max\Images\Artwork1\38AmbushAlley.png
21:12:02:907 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for: R:\HyperSpin\Media\WoW Action Max\Images\Artwork2\38AmbushAlley.png
21:12:02:910 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for: R:\HyperSpin\Media\WoW Action Max\Images\Artwork3\38AmbushAlley.png
21:12:02:912 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for: R:\HyperSpin\Media\WoW Action Max\Images\Artwork4\38AmbushAlley.png
21:12:02:914 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for: R:\HyperSpin\Media\WoW Action Max\Images\Letters
21:12:03:125 | MD |   DEBUG1  | +219   | BuildAssetsTable - Searching for: R:\HyperSpin\Media\WoW Action Max\Images\Other
21:12:03:133 | MD |   DEBUG2  | +0     | BuildAssetsTable - Media assets found:
				Asset Label: Cartridge | Asset Path1:  R:\HyperSpin\Media\WoW Action Max\Images\Artwork3\38AmbushAlley.png | Asset Extension1:  png | Asset Type1:  game
				Asset Label: Letters | Asset Path1:  R:\HyperSpin\Media\WoW Action Max\Images\Letters\!.png | Asset Extension1:  png | Asset Type1:  system
				Asset Label: Letters | Asset Path2:  R:\HyperSpin\Media\WoW Action Max\Images\Letters\'.png | Asset Extension2:  png | Asset Type2:  system
				Asset Label: Letters | Asset Path3:  R:\HyperSpin\Media\WoW Action Max\Images\Letters\(.png | Asset Extension3:  png | Asset Type3:  system
				Asset Label: Letters | Asset Path4:  R:\HyperSpin\Media\WoW Action Max\Images\Letters\0.png | Asset Extension4:  png | Asset Type4:  system
				Asset Label: Letters | Asset Path5:  R:\HyperSpin\Media\WoW Action Max\Images\Letters\1.png | Asset Extension5:  png | Asset Type5:  system
				Asset Label: Letters | Asset Path6:  R:\HyperSpin\Media\WoW Action Max\Images\Letters\2.png | Asset Extension6:  png | Asset Type6:  system
				Asset Label: Letters | Asset Path7:  R:\HyperSpin\Media\WoW Action Max\Images\Letters\3.png | Asset Extension7:  png | Asset Type7:  system
				Asset Label: Letters | Asset Path8:  R:\HyperSpin\Media\WoW Action Max\Images\Letters\4.png | Asset Extension8:  png | Asset Type8:  system
				Asset Label: Letters | Asset Path9:  R:\HyperSpin\Media\WoW Action Max\Images\Letters\5.png | Asset Extension9:  png | Asset Type9:  system
				Asset Label: Letters | Asset Path10:  R:\HyperSpin\Media\WoW Action Max\Images\Letters\6.png | Asset Extension10:  png | Asset Type10:  system
				Asset Label: Letters | Asset Path11:  R:\HyperSpin\Media\WoW Action Max\Images\Letters\7.png | Asset Extension11:  png | Asset Type11:  system
				Asset Label: Letters | Asset Path12:  R:\HyperSpin\Media\WoW Action Max\Images\Letters\8.png | Asset Extension12:  png | Asset Type12:  system
				Asset Label: Letters | Asset Path13:  R:\HyperSpin\Media\WoW Action Max\Images\Letters\9.png | Asset Extension13:  png | Asset Type13:  system
				Asset Label: Letters | Asset Path14:  R:\HyperSpin\Media\WoW Action Max\Images\Letters\a.png | Asset Extension14:  png | Asset Type14:  system
				Asset Label: Letters | Asset Path15:  R:\HyperSpin\Media\WoW Action Max\Images\Letters\b.png | Asset Extension15:  png | Asset Type15:  system
				Asset Label: Letters | Asset Path16:  R:\HyperSpin\Media\WoW Action Max\Images\Letters\c.png | Asset Extension16:  png | Asset Type16:  system
				Asset Label: Letters | Asset Path17:  R:\HyperSpin\Media\WoW Action Max\Images\Letters\d.png | Asset Extension17:  png | Asset Type17:  system
				Asset Label: Letters | Asset Path18:  R:\HyperSpin\Media\WoW Action Max\Images\Letters\e.png | Asset Extension18:  png | Asset Type18:  system
				Asset Label: Letters | Asset Path19:  R:\HyperSpin\Media\WoW Action Max\Images\Letters\f.png | Asset Extension19:  png | Asset Type19:  system
				Asset Label: Letters | Asset Path20:  R:\HyperSpin\Media\WoW Action Max\Images\Letters\g.png | Asset Extension20:  png | Asset Type20:  system
				Asset Label: Letters | Asset Path21:  R:\HyperSpin\Media\WoW Action Max\Images\Letters\h.png | Asset Extension21:  png | Asset Type21:  system
				Asset Label: Letters | Asset Path22:  R:\HyperSpin\Media\WoW Action Max\Images\Letters\i.png | Asset Extension22:  png | Asset Type22:  system
				Asset Label: Letters | Asset Path23:  R:\HyperSpin\Media\WoW Action Max\Images\Letters\j.png | Asset Extension23:  png | Asset Type23:  system
				Asset Label: Letters | Asset Path24:  R:\HyperSpin\Media\WoW Action Max\Images\Letters\k.png | Asset Extension24:  png | Asset Type24:  system
				Asset Label: Letters | Asset Path25:  R:\HyperSpin\Media\WoW Action Max\Images\Letters\l.png | Asset Extension25:  png | Asset Type25:  system
				Asset Label: Letters | Asset Path26:  R:\HyperSpin\Media\WoW Action Max\Images\Letters\m.png | Asset Extension26:  png | Asset Type26:  system
				Asset Label: Letters | Asset Path27:  R:\HyperSpin\Media\WoW Action Max\Images\Letters\n.png | Asset Extension27:  png | Asset Type27:  system
				Asset Label: Letters | Asset Path28:  R:\HyperSpin\Media\WoW Action Max\Images\Letters\o.png | Asset Extension28:  png | Asset Type28:  system
				Asset Label: Letters | Asset Path29:  R:\HyperSpin\Media\WoW Action Max\Images\Letters\p.png | Asset Extension29:  png | Asset Type29:  system
				Asset Label: Letters | Asset Path30:  R:\HyperSpin\Media\WoW Action Max\Images\Letters\q.png | Asset Extension30:  png | Asset Type30:  system
				Asset Label: Letters | Asset Path31:  R:\HyperSpin\Media\WoW Action Max\Images\Letters\r.png | Asset Extension31:  png | Asset Type31:  system
				Asset Label: Letters | Asset Path32:  R:\HyperSpin\Media\WoW Action Max\Images\Letters\s.png | Asset Extension32:  png | Asset Type32:  system
				Asset Label: Letters | Asset Path33:  R:\HyperSpin\Media\WoW Action Max\Images\Letters\t.png | Asset Extension33:  png | Asset Type33:  system
				Asset Label: Letters | Asset Path34:  R:\HyperSpin\Media\WoW Action Max\Images\Letters\u.png | Asset Extension34:  png | Asset Type34:  system
				Asset Label: Letters | Asset Path35:  R:\HyperSpin\Media\WoW Action Max\Images\Letters\v.png | Asset Extension35:  png | Asset Type35:  system
				Asset Label: Letters | Asset Path36:  R:\HyperSpin\Media\WoW Action Max\Images\Letters\w.png | Asset Extension36:  png | Asset Type36:  system
				Asset Label: Letters | Asset Path37:  R:\HyperSpin\Media\WoW Action Max\Images\Letters\x.png | Asset Extension37:  png | Asset Type37:  system
				Asset Label: Letters | Asset Path38:  R:\HyperSpin\Media\WoW Action Max\Images\Letters\y.png | Asset Extension38:  png | Asset Type38:  system
				Asset Label: Letters | Asset Path39:  R:\HyperSpin\Media\WoW Action Max\Images\Letters\z.png | Asset Extension39:  png | Asset Type39:  system
				Asset Label: Other | Asset Path1:  R:\HyperSpin\Media\WoW Action Max\Images\Other\Pointer.png | Asset Extension1:  png | Asset Type1:  system
21:12:03:136 | MD |   DEBUG1  | +0     | BuildAssetsTable - Ended
21:12:03:138 | MD |   DEBUG1  | +0     | BuildAssetsTable - Started - Building Table for: game|system
21:12:03:159 | MD |   DEBUG1  | +31    | BuildAssetsTable - Searching for: R:\HyperSpin\Media\WoW Action Max\Video\38AmbushAlley.*
21:12:03:166 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for: R:\HyperSpin\Media\Main Menu\Video\WoW Action Max.*
21:12:03:168 | MD |   DEBUG1  | +0     | BuildAssetsTable - Ended
21:12:03:170 | MD |     INFO  | +0     | PluginInit - Ended
21:12:03:186 | MD |   DEBUG1  | +31    | StartModule - Setting romName to the dbName sent to HyperLaunch: 38AmbushAlley
21:12:03:220 | MD |   DEBUG2  | +31    | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~e & ~t" to call label: "ToggleCursor"
21:12:03:251 | MD |     INFO  | +32    | StartModule - Ended
21:12:03:255 | MD |     INFO  | +0     | Module Setting - [settings] - Fullscreen: true
21:12:03:281 | MD |     INFO  | +31    | Module Setting - [settings] - globalParams:
21:12:03:291 | MD |     INFO  | +0     | Module Setting - [settings] - daphneWidth: 1024
21:12:03:294 | MD |     INFO  | +0     | Module Setting - [settings] - daphneHeight: 768
21:12:03:312 | MD |     INFO  | +31    | Module Setting - [settings] - SingePathUpdate: false
21:12:03:323 | MD |     INFO  | +0     | Module Setting - [settings] - ForcePathUpdate: false
21:12:03:325 | MD |     INFO  | +0     | Module Setting - [38AmbushAlley] - params:
21:12:03:345 | MD |     INFO  | +31    | Run - Running: R:\HyperSpin\Emulators\daphne-singe\daphne.exe singe vldp -x 1024 -y 768 -fullscreen_window   -framefile "R:\HyperSpin\Emulators\daphne-singe\singe\ActionMax\38AmbushAlley.txt" -script "R:\HyperSpin\Emulators\daphne-singe\singe\ActionMax\38AmbushAlley.singe"
21:12:03:607 | MD |   DEBUG1  | +265   | Run - "daphne.exe singe vldp -x 1024 -y 768 -fullscreen_window   -framefile "R:\HyperSpin\Emulators\daphne-singe\singe\ActionMax\38AmbushAlley.txt" -script "R:\HyperSpin\Emulators\daphne-singe\singe\ActionMax\38AmbushAlley.singe"" Process ID: 21260
21:12:03:615 | MD |   DEBUG1  | +0     | GetActiveWindowStatus - Title: HyperLaunch HQ v1.1.1.2 [ FE = HyperSpin | Plugin = HyperSpin ] | Class: HwndWrapper[HyperLaunchHQ.exe;;70939630-0533-43e4-9fdb-3311dd8985da] | State: 0 | X: 518 | Y: 89 | Width: 1173 | Height: 871 | Window HWND: 0x11a1120 | Process ID: 23228 | Process Path: R:\HyperSpin\HyperLaunch\HyperLaunchHQ\HyperLaunchHQ.exe
21:12:03:617 | MD |     INFO  | +0     | WinWait - Waiting for "DAPHNE ahk_class SDL_app"
21:12:05:245 | MD |   DEBUG1  | +1638  | GetActiveWindowStatus - Title: DAPHNE: First Ever Multiple Arcade Laserdisc Emulator =] | Class: SDL_app | State: 0 | X: 0 | Y: 0 | Width: 1920 | Height: 1080 | Window HWND: 0xa30036 | Process ID: 21260 | Process Path: R:\HyperSpin\Emulators\daphne-singe\daphne.exe
21:12:05:247 | MD |   DEBUG1  | +0     | GetActiveWindowStatus - Title: DAPHNE: First Ever Multiple Arcade Laserdisc Emulator =] | Class: SDL_app | State: 0 | X: 0 | Y: 0 | Width: 1920 | Height: 1080 | Window HWND: 0xa30036 | Process ID: 21260 | Process Path: R:\HyperSpin\Emulators\daphne-singe\daphne.exe
21:12:05:248 | MD |     INFO  | +0     | WinWaitActive - Waiting for "DAPHNE ahk_class SDL_app"
21:12:05:355 | MD |   DEBUG1  | +110   | GetActiveWindowStatus - Title: DAPHNE: First Ever Multiple Arcade Laserdisc Emulator =] | Class: SDL_app | State: 0 | X: 0 | Y: 0 | Width: 1920 | Height: 1080 | Window HWND: 0xa30036 | Process ID: 21260 | Process Path: R:\HyperSpin\Emulators\daphne-singe\daphne.exe
21:12:05:519 | MD |     INFO  | +156   | Process - WaitClose daphne.exe
21:12:08:142 | MD |   DEBUG1  | +2620  | CloseProcess - Started, user requested to end launched application
21:12:08:145 | MD |     INFO  | +0     | WinClose - Closing: DAPHNE ahk_class SDL_app
21:12:13:971 | MD |   DEBUG1  | +5835  | CloseProcess - Ended
21:12:13:977 | MD |     INFO  | +0     | ExitModule - Started
21:12:14:029 | MD |     INFO  | +62    | Starting Updating Statistics:
21:12:14:033 | MD |   DEBUG2  | +0     | Total Elapsed Time in Pause in seconds: 0
21:12:14:035 | MD |   DEBUG2  | +0     | gameSectionStartTime:2285735978
21:12:14:037 | MD |   DEBUG2  | +0     | ElapsedTime:10
21:12:14:039 | MD |   DEBUG2  | +0     | Statistics cleared game name: 38AmbushAlley
21:12:14:161 | MD |   DEBUG2  | +125   | Loaded game statistics from ini files:
				Number_of_Times_Played: 7
				Last_Time_Played: Tuesday February 10, 2015 09:11:38 PM
				Average_Time_Played: 6
				Total_Time_Played: 45
				System_Total_Played_Time: 145
				Total_Global_Played_Time: 4169
21:12:14:163 | MD |   DEBUG2  | +0     | Updated Statistics: Number_of_Times_Played: 8
				Last_Time_Played: Tuesday February 10, 2015 09:12:03 PM
				Average_Time_Played: 7
				Total_Time_Played: 55
				System_Total_Played_Time: 155
				Total_Global_Played_Time: 4179
21:12:14:329 | MD |     INFO  | +172   | Game section statistics updated.
21:12:14:364 | MD |     INFO  | +31    | ExitModule - Ended
21:12:14:367 | MD |     INFO  | +0     | End of Module Logs
21:12:14:419 | HL |     INFO  | +11965 | Main - Module ended, exiting HyperLaunch normally
21:12:14:421 | HL |     INFO  | +0     | ExitScript - Started
21:12:14:466 | HL |     INFO  | +47    | SystemCursor - Restoring mouse cursor
21:12:14:500 | HL |     INFO  | +31    | ExitScript - Ended
[/code]
--Command line is: R:\HyperSpin\Emulators\daphne-singe\daphne.exe singe vldp -x 1024 -y 768 -fullscreen_window -framefile R:\HyperSpin\Emulators\daphne-singe\singe\ActionMax\38AmbushAlley.txt -script R:\HyperSpin\Emulators\daphne-singe\singe\ActionMax\38AmbushAlley.singe
--CPU : GenuineIntel 3600 MHz || Mem : 4096 megs
--OS : Windows XP/.NET || Video : NVIDIA GeForce GTX 760
Framefile parse succeeded. Video/Audio directory is: R:/HyperSpin/Emulators/daphne-singe/singe/ActionMax/./
Booting ROM ...
Search to 819 received [blocking]
Stop
Any idea what is going wrong here? pretty sure the paths are set up correctly.
--Command line is: F:\Games\Hyperspin\Emulators\daphne_singe\daphne.exe singe vldp -x 1024 -y 768 -fullscreen_window -framefile F:\Games\Hyperspin\Emulators\daphne_singe\singe\ActionMax\SonicFury.txt -script F:\Games\Hyperspin\Emulators\daphne_singe\singe\ActionMax\SonicFury.singe
Could not open framefile : F:\Games\Hyperspin\Emulators\daphne_singe\singe\ActionMax\SonicFury.txt
Also can't get this to work, not sure what the issue is.
--Command line is: F:\Games\Hyperspin\Emulators\daphne_singe\daphne.exe singe vldp -x 800 -y 600 -fullscreen_window -noserversend -framefile singe\ActionMax\frame_38AmbushAlley.txt -script singe\ActionMax\38AmbushAlley.singe
Framefile parse succeeded. Video/Audio directory is: singe/ActionMax/./
Booting ROM ...
SINGE: error compiling script: singe\ActionMax\38AmbushAlley.singe:10: malformed number near '312sensorY'
