Demul 5.8.2 setup
JoeC3109
All setup and upto date now;) thank you for the wrist slap:D. Will also put myself on the naughty step for not installing the GIT sooner.
Thanks for all your help.
  • 2 months later...
Why emus are such a pain? (sigh)
My analog and D-Pad don't work in this emu (360 pad), also I can't make it 2x on graphics for some aliasing (for lack of proper CRT shaders) without huge frame drops. I shouldn't get those FPS drops with mys system. Is there anything special to setup graphics wise?
  • 1 month later...
Can anyone help me configure the module for demul?
I have one file that I called Demul.ini and put over the demul module folder. There inside there are control and global configurations for the ahk module to read, but no matter what it is not read in any case, I get this on the log. Mind the GlobalMax: false, I can't make it fullscreen!.
edit: solved
Try the Fullscreen setting instead.
As far as controls go, I answered this last week here.
Thank you gigapig, I solved it myself, really, this is hard to follow. With demul v0.5.7 you had to have a settings.ini, now it happens to be called as the module name, well, demul.ini? no, it seems not, tested with "Demul (v0.5.8).ini" and voila, it reads the default configurations.
I wanted to add that demul is REALLY SLOW. I am buying a new graphics card not only because this, but almost I would say.
I had to set (for dx11 since dx10 4:3 aspect ratio is broken) resolution to x1, disable vsync, and set layers to 32, no post shaders. "Disable autosort" is automatically configured for every game but if I had to choose I would uncheck it, this pumps up your PC requirements but I balance that with the above settings. With the option checked it causes many glitches I can't forgive.
You can configure Auto Sort on a per game basis as some require it to be diabled and some not.
Yes, it's already set in the "Demul (v0.5.8).ini" file.
So you already have each game tested with a different setting for Auto Sort? I was thinking that info might be good to share, but there are other settings which might not work.
But if all games were tested and we know what game needs Auto sort (List Sortng) enabled or disabled, that surely would help.
djvj did it. I don't remember where I downloaded this from, but it's supposed to be on his ftp folder (it is not).
edit: ah yes! it comes with hyperlaunch, just check the demul module, you will find the ini there.
Thanks Dogway, but I know where the ini is. It's the information that needs to be added to it, per game that I am interested in.
Perhaps someone has already setup list sorting for each individual game.
haven't you checked?
It's all there:
[dygolf]
Controls =standard
ListSorting=true
Bios=8 - Naomi epr-21577h (USA)
[lupinsho]
Controls =standard
ListSorting=true
[meltyba]
Controls = ggxstyle
ListSorting=true
[meltybld]
Controls =standard
ListSorting=true
[mok]
Controls =standard
ListSorting=true
[clubkrte]
Controls =ClubKart
ListSorting=true
Bios=33 - Naomi 2 epr-23608c (Export)
It's all there:
[dygolf]
Controls =standard
ListSorting=true
[lupinsho]
Controls =standard
ListSorting=true
[meltyba]
Controls = ggxstyle
ListSorting=true
[meltybld]
Controls =standard
ListSorting=true
[mok]
Controls =standard
ListSorting=true
[clubkrte]
Controls =ClubKart
ListSorting=true
I had, but I was checking my Demul 58.ini, I then checked the Demul 59 (Example).ini and yes your quite right, they are there. Thank you. Why they differ I'm not sure.
I want to confirm these with other folks around.
I managed to get both Club Kart (2001 and 2003) working. For 2001 you have to go to test mode enter Game Test Mode or menu, and from there disable Card Reader, then you can pass the screen and play. Still I had to change the left and right controls from the module ini since they were switched (75, and 77). Another thing is with Club Kart 2003. The camera gets stuck in front of the driver helmet instead of just right back, so the thing is unplayable, is it only me?
I have another question, why Ninja Assault only works with mouse? I have nowhere set mouse for my controls so I'm very confused with this.
Also when I test demul outside HyperSpin, when I click on Stop demul crashes, does this usually happen? Should I click Exit instead?
Yes, it does the same for me.
Thanks gigapig, some meatful feedback at last, the forums look pretty much dead. Mostly no response to my posts or threads.
No problem, I'll have a look at the games you mention later.
You noticed that as well. It's Summer, people are doing exams, on vacations etc, or have got what they needed and moved on?
  • 1 month later...
Does someone know how to show crosshair in demul? i read it's the F11 hotkey, but nothing happens here.
I also have many questions most of them regarding control, now it's not a matter of mapping keys, it's that nothing works until I go to service mode or something. I tried on some games but didn't make any change. I tried to look for help on configuring controls in service mode in youtube, etc but didn't find anything.
These are a list of games I have problems with:
faulty controls:
ninja assault (can't move pointer)
brave fighter (can't move pointer "at all")
nascar (no controls at all)
air pilot
18 wheeler
gun survivor 2 (can't turn)
what is the usual procedure?
It does but it's very small, it looks like a small red triangle.
Test in with Extreme Hunting 2
I want
If you mean the white reticle at the very beginning, isn't that just his normal windows mouse pointer which he must have changed from the default?
Yes, it might probably be that. Although at 2.18 you can see the normal mouse cursor appear... how can that happen?
