majorspawn Posted April 12, 2016 Posted April 12, 2016 Hi Guys, The latest version of raine emu (uses the same ahk as neoraine v1.3.3) supports and works with neogeo cd 3.2 universe bios!! released by Razoola on his website which is fantastic. There is a small issue though when running samsho2 and this bios file as the game is approx 40% slower, I have not found this problem with other games so far. The way to fix this is to revert to the standard neocdz.bin bios file which does not exibit this problem when running the game or running the game at 110 fames per second instead of 60 which can be manually changed in neocd options via Tab but this is not saved anywhere. So technically the samsho2 game is not playable. Resolution: create another emulator directory for raine with the default neocdz.bin bios, then setup this emu as a new global emulator. Then configure samsho2 under games in Hyperlaunch to use this as an "alternate emulator" when launching this game only. I have also found that some other games are affected by the universe bios such as kof99 and aodk which have graphical artifacts. Majority work fine but you can use the above workaround to have the best of both worlds. cheers MS My Arcade Projects: SNES PC Project Vewlix Cabinet LS-30 Rotary Joysticks
majorspawn Posted April 14, 2016 Author Posted April 14, 2016 resolved read above My Arcade Projects: SNES PC Project Vewlix Cabinet LS-30 Rotary Joysticks
