Nuon in hyperspin
akiles500
I tested with this configuration and doens´t work:
Nuon.ini:
[exe info]
path = C:\Hyperspin\Emulators\Nuon\
rompath = C:\Hyperspin\Emulators\Nuon\roms\
userompath = true
exe = nWrap.exe
romextension = run
parameters =
searchsubfolders = false
pcgame = false
winstate = HIDDEN
hyperlaunch = true
Hyeprlaunch.ahk:
;**********************************NUON*****************************************
else if(systemName = "NUON" && executable = "NWrap.exe")
hideDesktop()
Hotkey, %exitEmulatorKey%, CloseProcess
msgbox, %emupath%%executable%
msgbox, %rompath%%romname%\nuon%romextension%
run, %emupath%%executable% "%rompath%%romname%\nuon%romextension%", %emupath%, UseErrorLevel
process, waitClose, nWrap.exe
and nwrap.ini:
This is the resolution you want your computer to return to on exit.
#No sanity checks are performed so make sure it's a resolution your computer can actually support.
[Resolution]
Horizontal = 640
Vertical = 480
ColorDepth = 32
RefreshRate = 60
nwrap F:\NUON\nuon.run
   hideDesktop()
did you read my setup guide in the theme announcement of how to set it up?
Sopht I tested other time with this configuration and doens´t work,EXAMPLE:spaceinvaderxl game:
First I have mount the image of game with daemon tools,then I have copied the files nuon.run and spaceinv.dat to rom folder of emulator Nuon.I have the name of nuon.run by spaceinvadersxl and I have created a file Xml in database with the name myself:
Then I have created the ini file:
[exe info]
userompath = true
exe = NWrap.exe
romextension = run
parameters =
pcgame = false
winstate = HIDDEN
hyperlaunch = true
And hyperlaunch.ahk:
hideDesktop()
and nwrap.ini:
[Resolution]
Horizontal = 640
Vertical = 480
ColorDepth = 32
RefreshRate = 60
With this configuration run the emulator Nuance in hyperspin but I didn´t see nothing,is the screen in black.
What am I doing wrong?
Greetings
OK so under:
you should have a folder for every rom, so it should be like this:
C:\Hyperspin\Emulators\Nuon\roms\SpaceInvadersXL\nuon.run
C:\Hyperspin\Emulators\Nuon\roms\SpaceInvadersXL\nuon.dat
C:\Hyperspin\Emulators\Nuon\roms\Tempest3000\nuon.run
C:\Hyperspin\Emulators\Nuon\roms\Tempest3000\nuon.dat
where the game folder is the 'romname' in the database. Then it should work for you.
Sopht you have a pack with all configurated..Upload here because is system is very complicated for all people what understand it.Greetings
Sopht a good pack nuon but I have a doubt.For example:
With the game spaceinvadersxl,you have created a folder in roms folder with each game.
We only have what introduce all files of game spaceinvaders and change the names the files with extension .dat and .run like spaceinvadersxl.run and spaceinvaderxl.dat
Sopht the emulator run but the screen is in black.This is mi log Hyperpsin:
04:08:17 PM | HyperSpin Started
04:08:17 PM | Startup Program Unvavailable
04:08:17 PM | Menu mode is multi
04:08:17 PM | Menu.xml found
04:08:17 PM | Entering fullscreen mode
04:08:17 PM | Setting resolution to 640x480 refreshrate is 0
04:08:18 PM | Main Menu.xml loaded
04:08:19 PM | Loading wheel images
04:08:19 PM | Entering Menu
04:08:24 PM | Menu.xml found
04:08:24 PM | Nuon.xml loaded
04:08:24 PM | Loading wheel images
04:08:24 PM | Entering Menu
04:08:27 PM | Pausing Animations
04:08:28 PM | Running HyperLaunch.exe
04:08:28 PM | Command Line is: HyperLaunch.exe "Nuon" "spaceinvadersxl"
04:09:29 PM | Menu.xml found
04:09:29 PM | Main Menu.xml loaded
04:09:29 PM | Loading wheel images
04:09:29 PM | Entering Menu
04:09:33 PM | Exiting HyperSpin
04:09:33 PM | Quiting program
04:09:33 PM | Exit Program Unvavailable
04:09:33 PM | Bye!
Sopht it doens´t work,I have tried a lot of time and nothing,my configuration is this:
Hyperlaunch.ahk:
else if(systemName = "NUON" && executable = "nWrap.exe")
hideDesktop()
NUON.ini:
[exe info]
path = C:\Hyperspin\Emulators\NUON\
rompath = C:\Hyperspin\Emulators\NUON\roms\
userompath = true
exe = nWrap.exe
romextension = run
parameters =
searchsubfolders = true
pcgame = false
winstate = HIDDEN
hyperlaunch = true
My Roms folder:
And in ofthe folder Spaceinvadersxl with the two files:
and my nWrap.ini:
#NWrap, fullscreen wrapper for nuance, a NUON emulator.
#Coded by SophT
#This is the resolution you want your computer to return to on exit.
[Resolution]
Horizontal = 640
Vertical = 480
ColorDepth = 32
RefreshRate = 60
And here a video testing:
http://www.megaupload.com/?d=TPDU5GBL
Sopht say me what I,m making wrong.
Greetings
Sopht the emulator runs like it see in this image:
But I have to give to Ctrl+Alt+Supr for finalize the process nwrap.exe and then it.s see this screen:
Why it,s see the explorer files for choose the file had to enter directly the game.
My path is this:C:\Hyperspin\Emulators\NUON\roms\ like it´s see in my NUON.ini:
[exe info]
userompath = true
exe = nWrap.exe
romextension = run
parameters =
pcgame = false
winstate = HIDDEN
hyperlaunch = true
Greetings
Oh, I see the problem for you!
It is written to look for titles in English - I didn't think about it in other languages!
here this one should work for you Akiles:
http://rapidshare.de/files/48251677/NWrap.exe.html
It was waiting for the window 'open' to appear - but for you it's 'Abrir'.
  • 4 weeks later...
I just downloaded your nwrap.exe. I am having the same problem that akiles500 was having. I renamed the files to nuon.dat and nuon.run. But I still get a black screen with the mouse cursor on it.
  • 9 months later...
Please Sopht, can u upload this again for me ?
my system says "Abrir" too and the original wrapper dont work for me ....
Tanks
