rfancella Posted March 28, 2014 Author Posted March 28, 2014 So I had this working fine then decided to install Windows 8.1 Got Hyperspin running again no problems except with this emulator. It works but for some reason it wont mount the game. It unzips and then boots the game, but when I open daemon tools I can see it never got mounted. Other CD based systems work fine mounting, any ideas?? JDubbs21, The CD32 module does not use DT to mount the disc image. It passes the image name directly to WinUAE. Please set your Logging Level to Troubleshooting and post your HyperLaunch log as described in this thread: http://www.hyperspin-fe.com/forum/showthread.php?31072-The-HyperNoobie-Guide-For-Posting-To-The-Fourm Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
Jdubbs Posted March 28, 2014 Posted March 28, 2014 10:30:22:488 | HL | INFO | +N/A | Main - HyperLaunch v3.0.1.1c 10:30:22:597 | HL | INFO | +109 | Main - System Specs: HyperLaunch Dir: C:\HyperSpin\HyperLaunch OS: Microsoft Windows 8.1 Pro SKU: Professional Total Memory: 8124.79 MB Free Memory: 6404.01 MB Used Memory: 1720.785 MB SystemType: x64-based PC Physical Processors: 1 Logical Processors: 4 GPU 1 Name: NVIDIA GeForce GT 620 GPU 1 RAM: -2048.00 MB GPU 1 Driver Version: 9.18.13.3523 Sound 1 Device: High Definition Audio Device Sound 1 Status: Enabled Sound 2 Device: NVIDIA Virtual Audio Device (Wave Extensible) (WDM) Sound 2 Status: Enabled Sound 3 Device: NVIDIA High Definition Audio Sound 3 Status: Enabled Sound 4 Device: NVIDIA High Definition Audio Sound 4 Status: Enabled Sound 5 Device: NVIDIA High Definition Audio Sound 5 Status: Enabled Sound 6 Device: NVIDIA High Definition Audio Sound 6 Status: Enabled OS Language: English_United_States OS Admin Status: No Monitor #1 (\\.\DISPLAY1): 1600x900 (1600x860 work) AutoHotkey Path: AHK Version: 1.1.09.04 Unicode: No 10:30:22:597 | HL | INFO | +0 | Main - HyperSpin.exe coordinates are x y w h 10:30:22:597 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\HyperLaunch\HyperLaunch.exe exists 10:30:22:597 | HL | DEBUG1 | +0 | CheckFile - Attributes: FileDescription Your favorite Front End companion! FileVersion 3.0.1.1 LegalCopyright ©2013 HL squad ProductName djvj's one swell guy! ProductVersion 1.1.9.4 CompanyName djvj's one swell guy! File Size: 910336 bytes Created: 3/27/2014 - 2:26:30 PM Modified: 3/20/2014 - 10:13:16 AM 10:30:22:597 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\HyperLaunch\Module Extensions\itextsharp.dll exists 10:30:22:628 | HL | DEBUG1 | +31 | CheckFile - Attributes: FileDescription iTextSharp FileVersion 5.4.2.0 InternalName itextsharp.dll LegalCopyright Copyright (C) 1999-2013 by Bruno Lowagie and Paulo Soares. All Rights Reserved. OriginalFilename itextsharp.dll ProductName iTextSharp ProductVersion 5.4.2.0 CompanyName 1T3XT BVBA File Size: 3743744 bytes Created: 3/27/2014 - 2:26:31 PM Modified: 3/20/2014 - 10:13:17 AM 10:30:22:628 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\HyperLaunch\Module Extensions\SevenZipSharp.dll exists 10:30:22:628 | HL | DEBUG1 | +0 | CheckFile - Attributes: FileDescription SevenZipSharp FileVersion 0.64.4841.31212 InternalName SevenZipSharp.dll LegalCopyright Copyright (C) Markovtsev Vadim 2009, 2010, licenced under LGPLv3 OriginalFilename SevenZipSharp.dll ProductName SevenZipSharp ProductVersion 0.64.4841.31212 CompanyName Markovtsev Vadim File Size: 165888 bytes Created: 3/27/2014 - 2:26:31 PM Modified: 3/20/2014 - 10:13:17 AM 10:30:22:628 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\HyperLaunch\Module Extensions\gsdll32.dll exists 10:30:22:675 | HL | DEBUG1 | +47 | CheckFile - Attributes: File Size: 8818688 bytes Created: 3/27/2014 - 2:26:30 PM Modified: 3/20/2014 - 10:13:17 AM 10:30:22:675 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\HyperLaunch\Module Extensions\BlockInput.exe exists 10:30:22:707 | HL | DEBUG1 | +31 | CheckFile - Attributes: FileDescription FileVersion 1.1.09.04 InternalName OriginalFilename ProductName ProductVersion 1.1.09.04 File Size: 657920 bytes Created: 3/27/2014 - 11:09:03 PM Modified: 3/20/2014 - 10:13:17 AM 10:30:22:707 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\HyperLaunch\Module Extensions\gdip.ahk exists 10:30:22:707 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Extension. 10:30:22:722 | HL | DEBUG1 | +16 | CheckFile - Attributes: File Size: 88789 bytes Created: 3/27/2014 - 2:26:29 PM Modified: 3/20/2014 - 10:13:17 AM 10:30:22:722 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\HyperLaunch\Module Extensions\RIni.ahk exists 10:30:22:722 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Extension. 10:30:22:722 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 67561 bytes Created: 3/27/2014 - 2:26:29 PM Modified: 3/20/2014 - 10:13:17 AM 10:30:22:722 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\HyperLaunch\Module Extensions\CLR.ahk exists 10:30:22:722 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Extension. 10:30:22:738 | HL | DEBUG1 | +16 | CheckFile - Attributes: File Size: 10586 bytes Created: 3/27/2014 - 2:26:29 PM Modified: 3/20/2014 - 10:13:17 AM 10:30:22:738 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\HyperLaunch\Module Extensions\COM.ahk exists 10:30:22:738 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Extension. 10:30:22:738 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 26342 bytes Created: 3/27/2014 - 2:26:29 PM Modified: 3/20/2014 - 10:13:17 AM 10:30:22:738 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\HyperLaunch\Module Extensions\JSON.ahk exists 10:30:22:753 | HL | DEBUG1 | +15 | CRC Check - CRC matches, this is an official unedited Extension. 10:30:22:753 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 9203 bytes Created: 3/27/2014 - 2:26:29 PM Modified: 3/20/2014 - 10:13:17 AM 10:30:22:753 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\HyperLaunch\Lib\Fade Init.ahk exists 10:30:22:753 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 10:30:22:753 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 1145 bytes Created: 3/27/2014 - 2:26:29 PM Modified: 3/20/2014 - 10:13:16 AM 10:30:22:753 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\HyperLaunch\Lib\HyperPause Init.ahk exists 10:30:22:753 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 10:30:22:753 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 691 bytes Created: 3/27/2014 - 2:26:29 PM Modified: 3/20/2014 - 10:13:16 AM 10:30:22:753 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\HyperLaunch\Lib\Keymapper Init.ahk exists 10:30:22:753 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 10:30:22:753 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 3435 bytes Created: 3/27/2014 - 2:26:29 PM Modified: 3/20/2014 - 10:13:16 AM 10:30:22:753 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\HyperLaunch\Lib\MultiGame Init.ahk exists 10:30:22:769 | HL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Library. 10:30:22:769 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 161 bytes Created: 3/27/2014 - 2:26:29 PM Modified: 3/20/2014 - 10:13:16 AM 10:30:22:769 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\HyperLaunch\Lib\Statistics Init.ahk exists 10:30:22:769 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 10:30:22:769 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 167 bytes Created: 3/27/2014 - 2:26:29 PM Modified: 3/20/2014 - 10:13:16 AM 10:30:22:769 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\HyperLaunch\Lib\Fade.ahk exists 10:30:22:769 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 10:30:22:769 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 25516 bytes Created: 3/27/2014 - 2:26:29 PM Modified: 3/20/2014 - 10:13:16 AM 10:30:22:769 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\HyperLaunch\Lib\HyperPause.ahk exists 10:30:22:785 | HL | DEBUG1 | +15 | CRC Check - CRC matches, this is an official unedited Library. 10:30:22:785 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 360180 bytes Created: 3/27/2014 - 2:26:29 PM Modified: 3/20/2014 - 10:13:16 AM 10:30:22:785 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\HyperLaunch\Lib\Keymapper.ahk exists 10:30:22:800 | HL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Library. 10:30:22:800 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 30775 bytes Created: 3/27/2014 - 2:26:29 PM Modified: 3/20/2014 - 10:13:16 AM 10:30:22:800 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\HyperLaunch\Lib\MultiGame.ahk exists 10:30:22:816 | HL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Library. 10:30:22:816 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 36816 bytes Created: 3/27/2014 - 2:26:29 PM Modified: 3/20/2014 - 10:13:16 AM 10:30:22:816 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\HyperLaunch\Lib\Bezel.ahk exists 10:30:22:847 | HL | DEBUG1 | +31 | CRC Check - CRC matches, this is an official unedited Library. 10:30:22:847 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 83008 bytes Created: 3/27/2014 - 2:26:29 PM Modified: 3/20/2014 - 10:13:16 AM 10:30:22:847 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\HyperLaunch\Lib\Statistics.ahk exists 10:30:22:847 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 10:30:22:847 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 26153 bytes Created: 3/27/2014 - 2:26:29 PM Modified: 3/20/2014 - 10:13:16 AM 10:30:22:847 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\HyperLaunch\Lib\Rom Mapping Launch Menu.ahk exists 10:30:22:863 | HL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Library. 10:30:22:878 | HL | DEBUG1 | +15 | CheckFile - Attributes: File Size: 63798 bytes Created: 3/27/2014 - 2:26:29 PM Modified: 3/20/2014 - 10:13:16 AM 10:30:22:878 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\HyperLaunch\Lib\Shared.ahk exists 10:30:22:878 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 10:30:22:878 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 81966 bytes Created: 3/27/2014 - 2:26:29 PM Modified: 3/20/2014 - 10:13:16 AM 10:30:22:878 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\HyperLaunch\Lib\XHotkey.ahk exists 10:30:22:878 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 10:30:22:878 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 28374 bytes Created: 3/27/2014 - 2:26:30 PM Modified: 3/20/2014 - 10:13:16 AM 10:30:22:894 | HL | INFO | +16 | CheckFile - Checking if C:\HyperSpin\HyperLaunch\Lib\Fade Animations.ahk exists 10:30:22:894 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 10:30:22:894 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 49050 bytes Created: 3/27/2014 - 2:26:29 PM Modified: 3/20/2014 - 10:13:16 AM 10:30:22:894 | HL | INFO | +0 | Main - HyperLaunch received "Commodore Amiga CD32" and "Battletoads (Europe)" 10:30:22:910 | HL | INFO | +15 | Main - Battletoads (Europe) is using the default emulator: WinUAE 10:30:22:910 | HL | INFO | +0 | Main - Checking for a [WinUAE] section in C:\HyperSpin\HyperLaunch\Settings\Commodore Amiga CD32\Emulators.ini 10:30:22:910 | HL | INFO | +0 | Main - Checking for a [WinUAE] section in C:\HyperSpin\HyperLaunch\Settings\Global Emulators.ini 10:30:22:910 | HL | INFO | +0 | Main - Found [WinUAE] in C:\HyperSpin\HyperLaunch\Settings\Global Emulators.ini 10:30:22:910 | HL | INFO | +0 | CheckFile - Checking if C:\Hyperspin\HyperLaunch\Modules\WinUAE\WinUAE.ahk exists 10:30:22:910 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 11546 bytes Created: 3/27/2014 - 11:09:04 PM Modified: 3/20/2014 - 10:13:17 AM 10:30:22:910 | HL | INFO | +0 | Main - CRC Check - CRC matches, this is an official unedited module. 10:30:22:910 | HL | INFO | +0 | Main - Battletoads (Europe) will use module: C:\Hyperspin\HyperLaunch\Modules\WinUAE\WinUAE.ahk 10:30:22:925 | HL | INFO | +16 | Main - Using standard method with "Rom Extension" SkipChecks or without any SkipChecks. 10:30:22:941 | HL | INFO | +16 | Main - INI Keys read 10:30:22:941 | HL | INFO | +0 | CheckFile - Checking if C:\Hyperspin\HyperLaunch\Module Extensions\7z.exe exists 10:30:22:941 | HL | DEBUG1 | +0 | CheckFile - Attributes: FileDescription 7-Zip Console FileVersion 9.20 InternalName 7z LegalCopyright Copyright (c) 1999-2010 Igor Pavlov OriginalFilename 7z.exe ProductName 7-Zip ProductVersion 9.20 CompanyName Igor Pavlov File Size: 163840 bytes Created: 3/27/2014 - 2:26:30 PM Modified: 3/20/2014 - 10:13:17 AM 10:30:22:941 | HL | INFO | +0 | CheckFile - Checking if C:\Hyperspin\HyperLaunch\Module Extensions\7z.dll exists 10:30:22:941 | HL | DEBUG1 | +0 | CheckFile - Attributes: FileDescription 7z Standalone Plugin FileVersion 9.20 InternalName 7za LegalCopyright Copyright (c) 1999-2010 Igor Pavlov OriginalFilename 7za.dll ProductName 7-Zip ProductVersion 9.20 CompanyName Igor Pavlov File Size: 914432 bytes Created: 3/27/2014 - 2:26:30 PM Modified: 3/20/2014 - 10:13:17 AM 10:30:22:941 | HL | INFO | +0 | CheckPaths - Started 10:30:22:941 | HL | DEBUG1 | +0 | CheckPaths - Looking for rom: D:\Hyperspin Games\Commodore Amiga CD32\Battletoads (Europe).7z 10:30:22:941 | HL | INFO | +0 | CheckPaths - Found rom: D:\Hyperspin Games\Commodore Amiga CD32\Battletoads (Europe).7z 10:30:22:941 | HL | DEBUG1 | +0 | CheckPaths - Current romName: Battletoads (Europe) 10:30:22:941 | HL | DEBUG1 | +0 | CheckPaths - Current romPath: D:\Hyperspin Games\Commodore Amiga CD32 10:30:22:941 | HL | DEBUG1 | +0 | CheckPaths - Current romExtension: .7z 10:30:22:941 | HL | INFO | +0 | CheckFile - Checking if C:\Hyperspin\Emulators\WINUAE\winuae.exe exists 10:30:22:941 | HL | DEBUG1 | +0 | CheckFile - Attributes: FileDescription WinUAE FileVersion 2.6.1.0 InternalName WinUAE LegalCopyright © 1996-2013 under the GNU Public License (GPL) OriginalFilename WinUAE.exe ProductName WinUAE ProductVersion 2.6.1.0 File Size: 9861632 bytes Created: 6/19/2013 - 3:31:38 AM Modified: 6/19/2013 - 3:31:38 AM 10:30:22:941 | HL | INFO | +0 | CheckPaths - Ended 10:30:22:941 | HL | INFO | +0 | BuildScript - User Variables: ;---------------------------------------------------------------------------- ; INJECTED VARIABLES ;---------------------------------------------------------------------------- #NoTrayIcon #InstallKeybdHook DetectHiddenWindows, ON SetTitleMatchMode, 2 SendMode, Event 0 = 2 hlMode = frontendPID = 0 frontendPath = C:\Hyperspin frontendExe = HyperSpin.exe frontendExt = exe frontendName = HyperSpin frontendDrive = C: exitEmulatorKey = ~Esc exitEmulatorKeyWait = 0 forceHoldKey = ~Esc restoreFE = false exitScriptKey = ~q & ~s toggleCursorKey = ~e & ~t emuFullPath = C:\Hyperspin\Emulators\WINUAE\winuae.exe emuPath = C:\Hyperspin\Emulators\WINUAE emuName = WinUAE emuExt = exe romPath = D:\Hyperspin Games\Commodore Amiga CD32 romPathFromIni = D:\Hyperspin Games\Commodore Amiga CD32 romExtension = .7z romExtensionOrig = .7z romExtensions = 7z|cue executable = winuae.exe systemName = Commodore Amiga CD32 dbName = Battletoads (Europe) romName = Battletoads (Europe) romMapPath = romMappingEnabled = false romMappingLaunchMenuEnabled = false romMappingFirstMatchingExt = false romMappingShowAllRomsInArchive = true romMappingNumberOfWheelsByScreen = 7 romMappingMenuWidth = 300 romMappingMenuMargin = 50 romMappingTextFont = Bebas Neue romMappingTextOptions = cFFFFFFFF r4 s40 Bold romMappingDisabledTextColor = ff888888 romMappingTextSizeDifference = 5 romMappingTextMargin = 10 romMappingTitleTextFont = Bebas Neue romMappingTitleTextOptions = cFFFFFFFF r4 s60 Bold romMappingTitle2TextFont = Bebas Neue romMappingTitle2TextOptions = cFFFFFFFF r4 s15 Bold romMappingGameInfoTextFont = Bebas Neue romMappingGameInfoTextOptions = cFFFFFFFF r4 s15 Regular romMappingBackgroundBrush = aa000000 romMappingColumnBrush = 33000000 romMappingButtonBrush1 = 6f000000 romMappingButtonBrush2 = 33000000 romMappingBackgroundAlign = Stretch and Lose Aspect romMappingMenuFlagWidth = 40 romMappingMenuFlagSeparation = 5 romMappingDefaultMenuList = FullList romMappingSingleFilteredRomAutomaticLaunch = false skipchecks = false romMatchExt = true blockInputTime = 0 blockInputFile = C:\HyperSpin\HyperLaunch\Module Extensions\BlockInput.exe errorLevelReporting = false logFile = C:\HyperSpin\HyperLaunch\HyperLaunch.log logLabel := [" INFO"," WARNING"," ERROR"," DEBUG1"," DEBUG2"] logLevel = 10 logIncludeModule = true logIncludeFileProperties = true logShowCommandWindow = false logCommandWindow = false sysLang = English_United_States navUpKey = Up navDownKey = Down navLeftKey = Left navRightKey = Right navSelectKey = Enter navP2UpKey = Numpad8 navP2DownKey = Numpad2 navP2LeftKey = Numpad4 navP2RightKey = Numpad6 navP2SelectKey = NumpadEnter originalWidth = 1600 originalHeight = 900 dtEnabled = true dtPath = C:\Program Files (x86)\DAEMON Tools Lite\DTLite.exe dtUseSCSI = true dtAddDrive = true emuIdleShutdown = 0 hideCursor = false hideEmu = false hideFE = false fadeIn = false fadeInDuration = 500 fadeInTransitionAnimation = DefaultAnimateFadeIn fadeInDelay = 0 fadeInExitDelay = 0 fadeOutExitDelay = 0 fadeOut = false fadeOutExtraScreen = false fadeOutDuration = 500 fadeOutTransitionAnimation = DefaultAnimateFadeOut fadeOutDelay = 0 fadeLyrInterpolation = 7 fadeLyr1Color = FF000000 fadeLyr1AlignImage = Align to Top Left fadeLyr2Pos = Bottom Right Corner fadeLyr2X = 300 fadeLyr2Y = 300 fadeLyr2Adjust = 1 fadeLyr2PicPad = 0 fadeLyr3Pos = Center fadeLyr3X = 300 fadeLyr3Y = 300 fadeLyr3Adjust = 0.75 fadeLyr3Speed = 750 fadeLyr3Animation = DefaultFadeAnimation fadeLyr37zAnimation = DefaultFadeAnimation fadeLyr3Type = imageandbar fadeLyr3ImgFollow7zProgress = true fadeLyr3Repeat = 1 fadeLyr3PicPad = 0 fadeLyr4Adjust = 0.75 fadeLyr4X = 100 fadeLyr4Y = 100 fadeLyr4Pos = Above Layer 3 - Left fadeLyr4FPS = 10 fadeLyr4PicPad = 0 fadeTranspGifColor = FFFFFF fadeBarWindow = false fadeBarWindowX = fadeBarWindowY = fadeBarWindowW = 600 fadeBarWindowH = 120 fadeBarWindowR = 20 fadeBarWindowM = 20 fadeBarWindowHatchStyle = 8 fadeBarBack = true fadeBarBackColor = FF555555 fadeBarH = 20 fadeBarR = 5 fadeBarColor = DD00BFFF fadeBarHatchStyle = 3 fadeBarPercentageText = true fadeBarInfoText = true fadeBarXOffset = 0 fadeBarYOffset = 100 fadeRomInfoDescription = text fadeRomInfoSystemName = text fadeRomInfoYear = text fadeRomInfoManufacturer = text fadeRomInfoGenre = text fadeRomInfoRating = text fadeRomInfoOrder = Description|SystemName|Year|Manufacturer|Genre|Rating fadeRomInfoTextPlacement = topRight fadeRomInfoTextMargin = 5 fadeRomInfoText1Options = cFF555555 r4 s20 Bold fadeRomInfoText2Options = cFF555555 r4 s20 Bold fadeRomInfoText3Options = cFF555555 r4 s20 Bold fadeRomInfoText4Options = cFF555555 r4 s20 Bold fadeRomInfoText5Options = cFF555555 r4 s20 Bold fadeRomInfoText6Options = cFF555555 r4 s20 Bold fadeStats_Number_of_Times_Played = text with label fadeStats_Last_Time_Played = text with label fadeStats_Average_Time_Played = text with label fadeStats_Total_Time_Played = text with label fadeStats_System_Total_Played_Time = text with label fadeStats_Total_Global_Played_Time = text with label fadeStatsInfoOrder = Number_of_Times_Played|Last_Time_Played|Average_Time_Played|Total_Time_Played|System_Total_Played_Time|Total_Global_Played_Time fadeStatsInfoTextPlacement = topLeft fadeStatsInfoTextMargin = 5 fadeStatsInfoText1Options = cFF555555 r4 s20 Bold fadeStatsInfoText2Options = cFF555555 r4 s20 Bold fadeStatsInfoText3Options = cFF555555 r4 s20 Bold fadeStatsInfoText4Options = cFF555555 r4 s20 Bold fadeStatsInfoText5Options = cFF555555 r4 s20 Bold fadeStatsInfoText6Options = cFF555555 r4 s20 Bold fadeText1X = 0 fadeText1Y = 0 fadeText1Options = cFFFFFFFF r4 s20 Right Bold fadeText1 = Loading Game fadeText2X = 0 fadeText2Y = 0 fadeText2Options = cFFFFFFFF r4 s20 Right Bold fadeText2 = Extraction Complete fadeFont = Arial fadeSystemAndRomLayersOnly = false fadeInterruptKey = detectFadeErrorEnabled = true fadeImgPath = C:\Hyperspin\HyperLaunch\Media\Fade HLDataPath = C:\Hyperspin\HyperLaunch\Data HLMediaPath = C:\Hyperspin\HyperLaunch\Media HLErrSoundPath = C:\Hyperspin\HyperLaunch\Media\Sounds\Error modulesPath = C:\Hyperspin\HyperLaunch\Modules moduleFullName = C:\Hyperspin\HyperLaunch\Modules\WinUAE\WinUAE.ahk moduleName = WinUAE modulePath = C:\Hyperspin\HyperLaunch\Modules\WinUAE moduleExtension = ahk moduleExtensionsPath = C:\HyperSpin\HyperLaunch\Module Extensions libPath = C:\HyperSpin\HyperLaunch\Lib 7zEnabled = true 7zPath = C:\Hyperspin\HyperLaunch\Module Extensions\7z.exe 7zDllPath = C:\Hyperspin\HyperLaunch\Module Extensions\7z.dll 7zExtractPath = C:\Hyperspin\Temp 7zExtractPathOrig = 7zAttachSystemName = true 7zDelTemp = false 7zSounds = true 7zFormats = .zip,.rar,.7z,.lzh,.gzip,.tar 7zFormatsNoP = zip,rar,7z,lzh,gzip,tar mgEnabled = false mgKey = ~NumpadSub mgBackgroundColor = FF000000 mgSidePadding = 0.2 mgYOffset = 500 mgImageAdjust = 0 mgFont = Arial mgText1Options = x10p y30p w80p Center cBBFFFFFF r4 s100 BoldItalic mgText1Text = Please select a game mgText2Options = w96p cFFFFFFFF r4 s50 Center BoldItalic mgText2Offset = 70 mgUseSound = true mgSoundfreq = 300 mgExitEffect = none mgSelectedEffect = rotate mgUseGameArt = false mgArtworkDir = Artwork1 hpEnabled = true hpKey = ~NumpadAdd hpBackToMenuBarKey = X hpZoomInKey = C hpZoomOutKey = V hpScreenshotKey = ~PrintScreen hpHiToTextPath = C:\Hyperspin\HyperLaunch\Module Extensions\HiToText.exe hpSaveStateKeyCodes = hpLoadStateKeyCodes = keymapperEnabled = false keymapperAHKMethod = false keymapper = xpadderFullPath = C:\Hyperspin\Utilities\Xpadder\xpadder.exe joyToKeyFullPath = C:\Hyperspin\Utilities\JoyToKey\JoyToKey.exe keymapperProfilePath = C:\Hyperspin\HyperLaunch\Profiles\ keymapperFrontEndProfileName = HyperSpin keymapperFrontEndProfile = false keymapperHyperLaunchProfileEnabled = false JoyIDsEnabled = false JoyIDsPreferredControllersSystem = use_global JoyIDsPreferredControllersGlobal = use_global CustomJoyNamesEnabled = false CustomJoyNames = FEProfile = C:\Hyperspin\HyperLaunch\Profiles\\HyperSpin defaultProfile = C:\Hyperspin\HyperLaunch\Profiles\\_Default systemProfile = C:\Hyperspin\HyperLaunch\Profiles\\Commodore Amiga CD32 xPadderSystemProfile = C:\Hyperspin\HyperLaunch\Profiles\\Commodore Amiga CD32\_Default emuProfile = C:\Hyperspin\HyperLaunch\Profiles\\Commodore Amiga CD32\WinUAE romProfile = C:\Hyperspin\HyperLaunch\Profiles\\Commodore Amiga CD32\Battletoads (Europe) HyperLaunchProfile = C:\Hyperspin\HyperLaunch\Profiles\\HyperLaunch blankProfile = C:\Hyperspin\HyperLaunch\Profiles\\blank ahkFEProfile = C:\Hyperspin\HyperLaunch\Profiles\AHK\HyperSpin ahkDefaultProfile = C:\Hyperspin\HyperLaunch\Profiles\AHK\_Default ahkSystemProfile = C:\Hyperspin\HyperLaunch\Profiles\AHK\Commodore Amiga CD32 ahkEmuProfile = C:\Hyperspin\HyperLaunch\Profiles\AHK\Commodore Amiga CD32\WinUAE ahkRomProfile = C:\Hyperspin\HyperLaunch\Profiles\AHK\Commodore Amiga CD32\Battletoads (Europe) ahkHyperLaunchProfile = C:\Hyperspin\HyperLaunch\Profiles\AHK\HyperLaunch bezelEnabled = false statisticsEnabled = true 10:30:22:941 | HL | INFO | +0 | BuildScript - Loaded XHotkey Init.ahk scripts 10:30:22:941 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\HyperLaunch\Module Extensions\VA.ahk exists 10:30:22:941 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Extension. 10:30:22:941 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 34688 bytes Created: 3/27/2014 - 2:26:29 PM Modified: 3/20/2014 - 10:13:17 AM 10:30:22:941 | HL | INFO | +0 | BuildScript - Loaded HyperPause Init.ahk scripts 10:30:22:941 | HL | INFO | +0 | BuildScript - Loaded Statistics Init.ahk scripts 10:30:22:941 | HL | INFO | +0 | BuildScript - Loaded User Functions Init.ahk script 10:30:22:957 | HL | DEBUG1 | +15 | BuildScript - Module starts on line: 2 10:30:22:957 | HL | INFO | +0 | BuildScript - Module: MEmu = WinUAE MEmuV = v2.6.0 MURL = http://www.winuae.net/ MAuthor = brolly MVersion = 2.0.2 MCRC = 2283EB17 iCRC = 587D7C70 mId = 635138307631183750 MSystem = "Commodore Amiga","Commodore Amiga CD32","Commodore CDTV","Commodore Amiga CD" ;---------------------------------------------------------------------------- ; Notes: ; You can have specific configuration files inside a Configurations folder on WinUAE main dir. ; Just name them the same as the game name on the XML file. ; Make sure you create a host config files with these names: ; CD32 : cd32host.uae and cd32mousehost.uae; ; CDTV : cdtvhost.uae and cdtvmousehost.uae; ; Amiga : amigahost.uae; ; Amiga CD : amigacdhost.uae; ; cd32mouse and cdtvmouse are for mouse controlled games on these systems, you should configure ; Windows Mouse on Port1 and a CD32 pad on Port2. For Amiga and Amiga CD make sure you set both ; a joystick and a mouse on Port1 and only a joystick on Port2. ; Set all your other preferences like video display settings. And make sure you are saving a HOST ; configuration file and not a general configuration file. ; ; If you want to configure an exit key through WinUAE: ; Host-Input-Configuration #1-RAW Keyboard and then remap the desired key to Quit Emulator. ; If you want to configure a key to toggle fullscreen/windowed mode: ; Host-Input-Configuration #1-RAW Keyboard and then remap the desired key to Toggle windowed/fullscreen. ; ; CD32 and CDTV: ; A settings file called System_Name.ini should be placed on your module dir. on that file you can define if a ; game uses mouse or if it needs the special delay hack loading method amongst other things. Example of such a file: ; ; [Lemmings (Europe)] ; UseMouse=true ; ; [Project-X & F17 Challenge (Europe)] ; DelayHack=true ; ; Amiga: ; For MultiGame support make sure you don't change the default WinUAE diskswapper keys which are: ; END+1-0 (not numeric keypad) = insert image from swapper slot 1-10 ; END+SHIFT+1-0 = insert image from swapper slot 11-20 ; END+CTRL+1-4 = select drive ; ; To do that follow the same procedure as above for the exit ; key, but on F11 set it to Toggle windowed/fullscreen. Make sure you save your configuration afterwards. ; Note : If you want to use Send commands to WinUAE for any keys that you configured through Input-Configuration panel make sure you ; set those keys for Null Keyboard! This is a virtual keyboard that collects all input events that don't come from physical ; keyboards. This applies to the exit or windowed/fullscreen keys mentioned above. ; ; If you are using WHDLoad games, but want to keep your default user-startup file after exiting then make a copy of it in the ; WHDFolder\S (Set in PathToWHDFolder) and name it default-user-startup. This file will then be copied over S\user-startup on exit. ;---------------------------------------------------------------------------- StartModule() FadeInStart() settingsFile := modulePath . "\" . systemName . ".ini" Fullscreen := IniReadCheck(settingsFile, "Settings", "Fullscreen","true",,1) PathToWHDFolder := IniReadCheck(settingsFile, "Settings", "PathToWHDFolder", EmuPath . "\HDD\WHD",,1) PathToWorkBenchBase := IniReadCheck(settingsFile, "Settings", "PathToWorkBenchBase", EmuPath . "\HDD\Workbench31_Lite.vhd",,1) PathToWHDFolder := AbsoluteFromRelative(EmuPath, PathToWHDFolder) PathToWorkBenchBase := AbsoluteFromRelative(EmuPath, PathToWorkBenchBase) ; This object controls how the module reacts to different systems. MESS can play a lot of systems, but needs to know what system you want to run, so this module has to adapt. mType := Object("Commodore Amiga","a500","Commodore Amiga CD32","cd32","Commodore CDTV","cdtv","Commodore Amiga CD","amigacd") ident := mType[systemName] ; search object for the systemName identifier MESS uses If !ident ScriptError("Your systemName is: " . systemName . "`nIt is not one of the known supported systems for this WinUAE module: " . moduleName) windowClass = PCsuxRox ;Class name is different depending on if the game is being run windowed or fullscreen If ( Fullscreen = "true" ) windowClass = AmigaPowah specialcfg = %emuPath%Configurations\%romName%.uae If romExtension in .hdf,.vhd DefaultRequireWB := "true" Else DefaultRequireWB := "false" If romExtension in .zip,.lha,.rar,.7z { SlaveFile := COM_Invoke(HLObject, "findByExtension", romPath . "\" . romName . romExtension, "slave") If (SlaveFile) { If romName contains (AGA) DefaultOptions := "-s cycle_exact=false " . "-s immediate_blits=false " . "-s cpu_compatible=false " . "-s cpu_speed=max " . "-s cachesize=8192" ;AGA Else DefaultOptions := "-s cycle_exact=true " . "-s immediate_blits=false " . "-s cpu_compatible=false " . "-s cpu_speed=real " . "-s cachesize=8192 " ;Non-AGA } } usemouse := IniReadCheck(settingsFile, romName, "UseMouse","false",,1) delayhack := IniReadCheck(settingsFile, romName, "DelayHack","false",,1) options := IniReadCheck(settingsFile, romName, "Options",DefaultOptions,,1) videomode := IniReadCheck(settingsFile, romName, "VideoMode","PAL",,1) floppyspeed := IniReadCheck(settingsFile, romName, "FloppySpeed","turbo",,1) quickstartmode := IniReadCheck(settingsFile, romName, "QuickStartMode",A_Space,,1) immediateblitter := IniReadCheck(settingsFile, romName, "ImmediateBlitter","false",,1) requireswb := IniReadCheck(settingsFile, romName, "RequiresWB",DefaultRequireWB,,1) customwb := IniReadCheck(settingsFile, romName, "CustomWB",A_Space,,1) whdloadoptions := IniReadCheck(settingsFile, romName, "WHDLoadOptions","PRELOAD",,1) neverextract := IniReadCheck(settingsFile, romName, "NeverExtract","false",,1) fs := If (Fullscreen = "true") ? "true" : "false" videomode := (If videomode = "NTSC" ? ("-s ntsc=true") : ("")) floppyspeed := (If floppyspeed ? ("-s floppy_speed=" . floppyspeed) : ("")) If (requireswb = "true") { ident := "a1200" If (customwb) { PathToWorkBenchBase := %EmuPath% . "\" . customwb } CheckFile(PathToWorkBenchBase) wbDrive := "-s hardfile=rw,32,1,2,512," . """" . PathToWorkBenchBase . """" } If romExtension in .hdf,.vhd { ident := "a1200" gameDrive := "-s hardfile=rw,32,1,2,512," . """" . romPath . "\" . romName . romExtension . """" } If (immediateblitter = "true") { options := options . " " . "-s immediate_blits=true" } options := options . " " . videomode If (ident = "a500" or ident = "a1200") { If romName contains (AGA),(LW) ident := "a1200" If (SlaveFile) { CheckFile(PathToWHDFolder) ident := "a1200" ;Create the user-startup file to launch the game WHDUserStartupFile := PathToWHDFolder . "\S\user-startup" SplitPath, SlaveFile, SlaveName, SlaveFolder FileDelete, %WHDUserStartupFile% FileAppend, echo "";`n, %WHDUserStartupFile% FileAppend, echo "Running: %SlaveName%";`n, %WHDUserStartupFile% FileAppend, echo "";`n, %WHDUserStartupFile% FileAppend, cd dh1:%SlaveFolder%;`n, %WHDUserStartupFile% FileAppend, whdload %SlaveName% %whdloadoptions%;`n, %WHDUserStartupFile% } } 7z(romPath, romName, romExtension, 7zExtractPath) If FileExist(specialcfg) { ;Game specific configuration file exists configFile = %romName%.uae } Else { ;Game specific configuration file doesn't exist If (ident = "cd32" or ident = "cdtv") { configFile := If (usemouse = "true") ? ("host\" . ident . "mousehost.uae") : ("host\" . ident . "host.uae") quickcfg := If (ident = "cd32") ? ("-s quickstart=" . ident . "`,0 -s chipmem_size=8") : ("-s quickstart=" . ident . "`,0") If (delayhack = "true") options := options . " -s cdimage0=" . """" . romPath . "\" . romName . romExtension . """" . "`,delay" Else options := options . " -cdimage=" . """" . romPath . "\" . romName . romExtension . """" } Else { ;Amiga or Amiga CD game configFile := If systemName = "Commodore Amiga CD" ? "host\amigacdhost.uae" : "host\amigahost.uae" If quickstartmode quickcfg := "-s quickstart=" . quickstartmode Else quickcfg := If (ident = "a500") ? "-s quickstart=a500`,1" : "-s quickstart=a1200`,1" If (SlaveFile) { ;WHDLoad Game options := options . " -s filesystem=rw,WHD:" . """" . PathToWHDFolder . """" . " -s filesystem=ro,Games:" . """" . romPath . "\" . romName . romExtension . """" } Else If (gameDrive) { ;HDD Game options := options . " " . wbDrive . " " . gameDrive } Else If romExtension in .cue,.iso { ;Amiga CD game options := options . " " . wbDrive . " -cdimage=" . """" . romPath . "\" . romName . romExtension . """" . " -s win32.map_cd_drives=true -s scsi=true" } Else { ;Floppy Game ;MultiDisk loading, this will load the first 2 disks into drives 0 and 1 since some games can read from both drives and therefore ;the user won't need to change disks through the MG menu. We can have up to 4 drives, but most of the games will only support 2 drives ;so disks are only loaded into the first 2 for better compatibility. Remaining drives will be loaded into quick disk slots. romCount = % romTable.MaxIndex() If romName contains (Disk 1) { ;If the user boots any disk rather than the first one, multi disk support must be done through HyperLaunch MG menu if romCount > 1 { options := options . " -s nr_floppies=2" mgoptions := " -s floppy1=" . """" . romTable[2,1] . """" } } options := options . " " . floppyspeed . " -s floppy0=" . """" . romPath . "\" . romName . romExtension . """" . mgoptions if romCount > 1 { ;DiskSwapper ;diskswapper := " -diskswapper " Loop % romTable.MaxIndex() ; loop each item in our array { ;diskswapper := diskswapper . """" . romTable[A_Index,1] . """," diskswapper := diskswapper . " -s diskimage" . (A_Index-1) . "=" . """" . romTable[A_Index,1] . """" } options := options . diskswapper } } } } param1 := "-f " . """" . EmuPath . "\Configurations\" . configFile . """" . " " . quickcfg param2 := "-s use_gui=no -s gfx_fullscreen_amiga=" . fs param3 := options ;MsgBox, %param1% %param2% %param3% %param4% %param5% %param6% ;ExitApp ;disableActivateBlackScreen = true Run(Executable . A_Space . param1 . A_Space . param2 . A_Space . param3 . A_Space . param4 . A_Space . param5 . A_Space . param6 . A_Space . " -portable", emuPath) WinWait("ahk_class " . windowClass) WinWaitActive("ahk_class " . windowClass) FadeInExit() Process("WaitClose",executable) 7zCleanUp() FadeOutExit() ExitModule() MultiGame: If currentButton = 10 diskslot = 0 Else If currentButton > 10 diskslot := currentButton - 10 Else diskslot := currentButton If currentButton > 10 Send, {End Down}{Shift Down}%diskslot%{Shift Up}{End Up} Else Send, {End Down}%diskslot%{End Up} return CloseProcess: If (ident = "a500" or ident = "a1200") { If (SlaveFile) { CheckFile(PathToWHDFolder) ;Copy default-user-startup to user-startup if file exists IfExist, %PathToWHDFolder%\S\default-user-startup FileCopy,%PathToWHDFolder%\S\default-user-startup, %PathToWHDFolder%\S\user-startup, 1 } } FadeOutStart() WinClose, ahk_class %windowClass% return AbsoluteFromRelative(MasterPath, RelativePath) { VarSetCapacity(AbsP,260,0) DllCall( "shlwapi\PathCombineA", Str,AbsP, Str,MasterPath, Str,RelativePath ) Return AbsP } 10:30:22:957 | HL | INFO | +0 | BuildScript - Loaded HyperPause scripts 10:30:22:957 | HL | INFO | +0 | BuildScript - Loaded Statistics.ahk script 10:30:22:957 | HL | INFO | +0 | BuildScript - Loaded User Functions.ahk script 10:30:22:957 | HL | INFO | +0 | BuildScript - Finished injecting functions into module 10:30:22:957 | HL | INFO | +0 | Main - Module is built 10:30:22:957 | HL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\HyperLaunch\AutoHotkey.dll exists 10:30:22:957 | HL | DEBUG1 | +0 | CheckFile - Attributes: FileDescription AutoHotkey_H ANSI 32-bit FileVersion 1.1.09.04 InternalName AutoHotkey_H LegalCopyright Copyright (C) 2012 OriginalFilename AutoHotkey.exe ProductName AutoHotkey_H ProductVersion 1.1.09.04 File Size: 785408 bytes Created: 3/27/2014 - 2:26:30 PM Modified: 3/20/2014 - 10:13:16 AM 10:30:23:019 | HL | INFO | +63 | Main - Running module 10:30:23:019 | HL | INFO | +0 | Main - Starting timer to watch if Front End gets displaced and restore it if it does. 10:30:23:175 | MD | INFO | +N/A | Module initialized 10:30:23:175 | MD | INFO | +0 | StartModule - Started 10:30:23:175 | MD | INFO | +0 | StartModule - MEmu: WinUAE MEmuV: v2.6.0 MURL: http://www.winuae.net/ MAuthor: brolly MVersion: 2.0.2 MCRC: 2283EB17 iCRC: 587D7C70 MID: MSystem: "Commodore Amiga","Commodore Amiga CD32","Commodore CDTV","Commodore Amiga CD" 10:30:23:175 | MD | INFO | +0 | StartModule - You have a supported System Name for this module: "Commodore Amiga CD32" 10:30:23:175 | MD | DEBUG1 | +0 | StartModule - Leaving romName as is because Rom Mapping filled it with an Alternate_Rom_Name: Battletoads (Europe) 10:30:23:175 | MD | INFO | +0 | StartModule - Ended 10:30:23:175 | MD | INFO | +0 | StartGlobalUserFeatures - Starting 10:30:23:175 | MD | INFO | +0 | StartGlobalUserFeatures - Ending 10:30:23:175 | MD | INFO | +0 | Module Setting - [settings] - Fullscreen: true 10:30:23:175 | MD | INFO | +0 | Module Setting - [settings] - PathToWHDFolder: C:\Hyperspin\Emulators\WINUAE\HDD\WHD 10:30:23:175 | MD | INFO | +0 | Module Setting - [settings] - PathToWorkBenchBase: C:\Hyperspin\Emulators\WINUAE\HDD\Workbench31_Lite.vhd 10:30:23:379 | MD | INFO | +203 | CreateMGRomTable - Started 10:30:23:379 | MD | DEBUG1 | +0 | CreateMGRomTable - romTable does not exist, creating one for "Battletoads (Europe)" 10:30:23:379 | MD | INFO | +0 | CreateRomTable - Started 10:30:23:379 | MD | DEBUG1 | +0 | CreateRomTable - Checking for match: "Battletoads (Europe)" and "(Disc" 10:30:23:379 | MD | DEBUG1 | +0 | CreateRomTable - Checking for match: "Battletoads (Europe)" and "(Disk" 10:30:23:379 | MD | DEBUG1 | +0 | CreateRomTable - Checking for match: "Battletoads (Europe)" and "(Cart" 10:30:23:379 | MD | DEBUG1 | +0 | CreateRomTable - Checking for match: "Battletoads (Europe)" and "(Tape" 10:30:23:379 | MD | DEBUG1 | +0 | CreateRomTable - Checking for match: "Battletoads (Europe)" and "(Cassette" 10:30:23:379 | MD | DEBUG1 | +0 | CreateRomTable - Checking for match: "Battletoads (Europe)" and "(Part" 10:30:23:379 | MD | DEBUG1 | +0 | CreateRomTable - Checking for match: "Battletoads (Europe)" and "(Side" 10:30:23:379 | MD | INFO | +0 | CreateRomTable - Ended, 7 Loops to create table. 10:30:23:379 | MD | INFO | +0 | CreateMGRomTable - Ended 10:30:23:379 | MD | INFO | +0 | Module Setting - [battletoads (Europe)] - UseMouse: false 10:30:23:379 | MD | INFO | +0 | Module Setting - [battletoads (Europe)] - DelayHack: false 10:30:23:379 | MD | INFO | +0 | Module Setting - [battletoads (Europe)] - Options: 10:30:23:379 | MD | INFO | +0 | Module Setting - [battletoads (Europe)] - VideoMode: PAL 10:30:23:379 | MD | INFO | +0 | Module Setting - [battletoads (Europe)] - FloppySpeed: turbo 10:30:23:379 | MD | INFO | +0 | Module Setting - [battletoads (Europe)] - QuickStartMode: 10:30:23:379 | MD | INFO | +0 | Module Setting - [battletoads (Europe)] - ImmediateBlitter: false 10:30:23:379 | MD | INFO | +0 | Module Setting - [battletoads (Europe)] - RequiresWB: false 10:30:23:379 | MD | INFO | +0 | Module Setting - [battletoads (Europe)] - CustomWB: 10:30:23:379 | MD | INFO | +0 | Module Setting - [battletoads (Europe)] - WHDLoadOptions: PRELOAD 10:30:23:379 | MD | INFO | +0 | Module Setting - [battletoads (Europe)] - NeverExtract: false 10:30:23:379 | MD | INFO | +0 | 7z - Started, received D:\Hyperspin Games\Commodore Amiga CD32\Battletoads (Europe).7z. If rom is an archive, it will extract to C:\Hyperspin\Temp 10:30:23:379 | MD | DEBUG1 | +0 | 7z - Using Standard method to extract this rom 10:30:23:379 | MD | DEBUG1 | +0 | 7z - ".7z" found in .zip,.rar,.7z,.lzh,.gzip,.tar 10:30:23:379 | MD | INFO | +0 | CheckFile - Checking if D:\Hyperspin Games\Commodore Amiga CD32\Battletoads (Europe).7z exists 10:30:23:379 | MD | DEBUG1 | +0 | CheckFile - Attributes: File Size: 796831 bytes Created: 3/2/2014 - 3:57:14 PM Modified: 3/2/2014 - 3:57:14 PM 10:30:23:379 | MD | INFO | +0 | 7z - Archive name matches rom name; DLL found rom inside archive using "findFileInZip": "Battletoads (Europe).cue" 10:30:23:379 | MD | DEBUG1 | +0 | 7z - Invoked COM Object, ROM extracted size: 54825069 bytes 10:30:23:379 | MD | DEBUG1 | +0 | 7z - File already exists in 7z_Extract_Path with a size of: 54825069 bytes 10:30:23:379 | MD | DEBUG1 | +0 | 7z - File already exists in "C:\Hyperspin\Temp\Commodore Amiga CD32\Battletoads (Europe)". Breaking out of 7z to load existing file 10:30:23:379 | MD | INFO | +0 | 7z - Ended 10:30:23:379 | MD | INFO | +0 | Run - Running: C:\Hyperspin\Emulators\WINUAE\winuae.exe -f "C:\Hyperspin\Emulators\WINUAE\Configurations\host\cd32host.uae" -s quickstart=cd32,0 -s chipmem_size=8 -s use_gui=no -s gfx_fullscreen_amiga=true -cdimage="C:\Hyperspin\Temp\Commodore Amiga CD32\Battletoads (Europe)\Battletoads (Europe).cue" -portable 10:30:24:457 | MD | DEBUG1 | +1078 | Run - "winuae.exe -f "C:\Hyperspin\Emulators\WINUAE\Configurations\host\cd32host.uae" -s quickstart=cd32,0 -s chipmem_size=8 -s use_gui=no -s gfx_fullscreen_amiga=true -cdimage="C:\Hyperspin\Temp\Commodore Amiga CD32\Battletoads (Europe)\Battletoads (Europe).cue" -portable" Process ID: 1984 10:30:24:457 | MD | DEBUG1 | +0 | GetActiveWindowStatus - Title: HyperLaunch HQ v1.0.13.0 | Class: HwndWrapper[HyperLaunchHQ.exe;;b2048965-7d54-4b2a-b116-a9d83fa9641f] | State: 0 | X: 320 | Y: 32 | Width: 1150 | Height: 904 | Window HWND: 0x40372 | Process ID: 4392 | Process Path: C:\HyperSpin\HyperLaunch\HyperLaunchHQ\HyperLaunchHQ.exe 10:30:24:457 | MD | INFO | +0 | WinWait - Waiting for "ahk_class AmigaPowah" 10:30:25:672 | MD | DEBUG1 | +1219 | GetActiveWindowStatus - Title: WinUAE | Class: AmigaPowah | State: 0 | X: 0 | Y: 0 | Width: 1440 | Height: 900 | Window HWND: 0x203a0 | Process ID: 1984 | Process Path: C:\HyperSpin\Emulators\WINUAE\winuae.exe 10:30:25:673 | MD | DEBUG1 | +0 | GetActiveWindowStatus - Title: WinUAE | Class: AmigaPowah | State: 0 | X: 0 | Y: 0 | Width: 1440 | Height: 900 | Window HWND: 0x203a0 | Process ID: 1984 | Process Path: C:\HyperSpin\Emulators\WINUAE\winuae.exe 10:30:25:673 | MD | INFO | +0 | WinWaitActive - Waiting for "ahk_class AmigaPowah" 10:30:25:790 | MD | DEBUG1 | +109 | GetActiveWindowStatus - Title: WinUAE | Class: AmigaPowah | State: 0 | X: 0 | Y: 0 | Width: 1440 | Height: 900 | Window HWND: 0x203a0 | Process ID: 1984 | Process Path: C:\HyperSpin\Emulators\WINUAE\winuae.exe 10:30:25:790 | MD | INFO | +0 | Process - WaitClose winuae.exe 10:30:45:037 | MD | DEBUG1 | +19250 | CloseProcess - Started, user requested to end launched application 10:30:45:324 | MD | DEBUG1 | +297 | CloseProcess - Ended 10:30:45:547 | MD | INFO | +219 | StopGlobalUserFeatures - Starting 10:30:45:547 | MD | INFO | +0 | StopGlobalUserFeatures - Ending 10:30:45:547 | MD | INFO | +0 | ExitModule - Started 10:30:45:547 | MD | INFO | +0 | Starting Updating Statistics: 10:30:45:547 | MD | DEBUG2 | +0 | Total Elapsed Time in Pause in seconds: 0 10:30:45:547 | MD | DEBUG2 | +0 | gameSectionStartTime:549562 10:30:45:547 | MD | DEBUG2 | +0 | ElapsedTime:22 10:30:45:547 | MD | DEBUG2 | +0 | Statistics cleared game name: Battletoads 10:30:45:562 | MD | DEBUG2 | +16 | Loaded game statistics from ini files: Number_of_Times_Played: 1 Last_Time_Played: Friday March 28, 2014 02:39:41 AM Average_Time_Played: 8 Total_Time_Played: 8 System_Total_Played_Time: 305 Total_Global_Played_Time: 305 10:30:45:562 | MD | DEBUG2 | +0 | Updated Statistics: Number_of_Times_Played: 2 Last_Time_Played: Friday March 28, 2014 10:30:23 AM Average_Time_Played: 15 Total_Time_Played: 30 System_Total_Played_Time: 327 Total_Global_Played_Time: 327 10:30:45:578 | MD | INFO | +15 | Game section statistics updated. 10:30:45:578 | MD | INFO | +0 | ExitModule - Ended 10:30:45:578 | MD | INFO | +0 | End of Module Logs 10:30:45:687 | HL | INFO | +22672 | Main - Module ended, exiting HyperLaunch normally 10:30:45:687 | HL | INFO | +0 | ExitScript - Started 10:30:45:703 | HL | INFO | +15 | SystemCursor - Restoring mouse cursor 10:30:45:719 | HL | INFO | +16 | ExitScript - Ended If the games aren't suppose to get mounted it works perfectly, but you include a step to install DT so I'm a little confused
rfancella Posted March 28, 2014 Author Posted March 28, 2014 If the games aren't suppose to get mounted it works perfectly, but you include a step to install DT so I'm a little confused Thank you for the log. It looks good to me. That's a good point. It is not needed for Amiga CD32. But many people will not setup DT and if this is your first system, you will get an error. It's easier to just setup DT and have the module not use it (and not get an error) than to not setup DT and have it error out even if it's not needed. Either way, I can remove it from the guide if it's confusing. Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
Jdubbs Posted March 28, 2014 Posted March 28, 2014 Not confusing I just for some reason thought the first time I set it up I had it loading the cue then booting it. Either way thanks for all the help!!
rfancella Posted March 28, 2014 Author Posted March 28, 2014 Not confusing I just for some reason thought the first time I set it up I had it loading the cue then booting it. Either way thanks for all the help!! Thank you for the kind words. Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
jedah Posted May 10, 2014 Posted May 10, 2014 I have followed this guide but have hit a small snag and I am fairly sure it is something I have done but I cant see what it is. When I get to the HSHQ section I can't choose winUAE as the default emulator. I can only see FS-UAE. Does anyone know how to fix this please. Update: Fixed it. Now it is working. For some reason the WinUAE.ahk wasn't listed. So I updated them and this didn't work so I manually added it and now it is visible. Thanks for this Ron. It works really well.
rfancella Posted May 10, 2014 Author Posted May 10, 2014 I have followed this guide but have hit a small snag and I am fairly sure it is something I have done but I cant see what it is. When I get to the HSHQ section I can't choose winUAE as the default emulator. I can only see FS-UAE. Does anyone know how to fix this please. Look back at page 1 of this thread. Post #7 explains how to fix your issue. Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
clownstyle Posted May 11, 2014 Posted May 11, 2014 Hey Ron, great Amiga guides you have here. I decided to take the jump and upgrade my launcher. The cd32 games I have are all from the WHDLoad packs and are not in iso format. I take it this guide will not apply to them? I would still like to separate them from the normal Amiga games though, can winUAEloader be used for this? winUAEloader launches the Amiga and CD32 games without issue, but hyperlauncher will only load the Amiga games, and not the cd32 games - Should I be using the iso images for these games instead of the whdload pack? Thanks, Tim
rfancella Posted May 12, 2014 Author Posted May 12, 2014 Hey Ron, great Amiga guides you have here. I decided to take the jump and upgrade my launcher. The cd32 games I have are all from the WHDLoad packs and are not in iso format. I take it this guide will not apply to them?I would still like to separate them from the normal Amiga games though, can winUAEloader be used for this? winUAEloader launches the Amiga and CD32 games without issue, but hyperlauncher will only load the Amiga games, and not the cd32 games - Should I be using the iso images for these games instead of the whdload pack? Thanks, Tim You are correct. This guide would not apply. Please check my signature for all my guides. Use the Amiga guide using WinUAE only. That will load any WHDLoad packages you have. I would not use WinUAELoader for these. Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
clownstyle Posted May 13, 2014 Posted May 13, 2014 You are correct. This guide would not apply. Please check my signature for all my guides. Use the Amiga guide using WinUAE only. That will load any WHDLoad packages you have. I would not use WinUAELoader for these.Thanks, Ron Thanks.. Got me some images now instead, which work fine using the configuration you mentioned in your original post, but they will only work when I mount them using daemon tools and select the correct cd drive in winuae (and launch them from winuae) When I try to launch them from Hyperlaunch I just go directly to the CD32 boot menu (the one with the cd) almost like it isn't detecting the disk image. Any tips? Thanks, Tim
rfancella Posted May 13, 2014 Author Posted May 13, 2014 Thanks.. Got me some images now instead, which work fine using the configuration you mentioned in your original post, but they will only work when I mount them using daemon tools and select the correct cd drive in winuae (and launch them from winuae) When I try to launch them from Hyperlaunch I just go directly to the CD32 boot menu (the one with the cd) almost like it isn't detecting the disk image. Any tips? Thanks, Tim Tim, If they are valid CD images, they should load directly into WinUAE. Post your HyperLaunch log as described here: http://www.hyperspin-fe.com/forum/showthread.php?31072-The-HyperNoobie-Guide-For-Posting-To-The-Fourm Thank you, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
clownstyle Posted May 13, 2014 Posted May 13, 2014 Tim,If they are valid CD images, they should load directly into WinUAE. Post your HyperLaunch log as described here: http://www.hyperspin-fe.com/forum/showthread.php?31072-The-HyperNoobie-Guide-For-Posting-To-The-Fourm Thank you, Ron Thanks Ron, see below. 19:39:53:923 | HL | INFO | +N/A | Main - HyperLaunch v3.0.1.1c 19:39:54:001 | HL | INFO | +78 | Main - System Specs: HyperLaunch Dir: G:\Hyperspin\HyperLaunch OS: Microsoft Nox SKU: Ultimate Total Memory: 16272.02 MB Free Memory: 14625.37 MB Used Memory: 1646.648 MB SystemType: x64-based PC Physical Processors: 1 Logical Processors: 4 GPU 1 Name: LogMeIn Mirror Driver GPU 1 RAM: 0.00 MB GPU 1 Driver Version: 7.1.542.0 GPU 2 Name: Standard VGA Graphics Adapter GPU 2 RAM: 0.00 MB GPU 2 Driver Version: 6.1.7600.16385 GPU 3 Name: AMD Radeon HD 7900 Series GPU 3 RAM: -1024.00 MB GPU 3 Driver Version: 13.251.0.0 Sound 1 Device: Intel(R) Display Audio Sound 1 Status: Enabled Sound 2 Device: M-Audio Delta Audiophile Sound 2 Status: Enabled Sound 3 Device: USB Audio Device Sound 3 Status: Enabled Sound 4 Device: AMD High Definition Audio Device Sound 4 Status: Unknown Sound 5 Device: Realtek High Definition Audio Sound 5 Status: Enabled OS Language: English_United_States OS Admin Status: Yes Monitor #1 (\\.\DISPLAY1): 1680x1050 (1680x1010 work) Monitor #2 (\\.\DISPLAY2): 2960x1024 (2960x1024 work) AutoHotkey Path: AHK Version: 1.1.09.04 Unicode: No 19:39:54:001 | HL | INFO | +0 | Main - HyperSpin.exe coordinates are x y w h 19:39:54:001 | HL | INFO | +0 | CheckFile - Checking if G:\Hyperspin\HyperLaunch\HyperLaunch.exe exists 19:39:54:001 | HL | DEBUG1 | +0 | CheckFile - Attributes: FileDescription Your favorite Front End companion! FileVersion 3.0.1.1 LegalCopyright ©2013 HL squad ProductName djvj's one swell guy! ProductVersion 1.1.9.4 CompanyName djvj's one swell guy! File Size: 910336 bytes Created: 5/10/2014 - 7:23:06 PM Modified: 5/10/2014 - 7:23:06 PM 19:39:54:001 | HL | INFO | +0 | CheckFile - Checking if G:\Hyperspin\HyperLaunch\Module Extensions\itextsharp.dll exists 19:39:54:001 | HL | DEBUG1 | +0 | CheckFile - Attributes: FileDescription iTextSharp FileVersion 5.4.2.0 InternalName itextsharp.dll LegalCopyright Copyright (C) 1999-2013 by Bruno Lowagie and Paulo Soares. All Rights Reserved. OriginalFilename itextsharp.dll ProductName iTextSharp ProductVersion 5.4.2.0 CompanyName 1T3XT BVBA File Size: 3743744 bytes Created: 5/10/2014 - 9:57:00 PM Modified: 5/10/2014 - 9:57:00 PM 19:39:54:001 | HL | INFO | +0 | CheckFile - Checking if G:\Hyperspin\HyperLaunch\Module Extensions\SevenZipSharp.dll exists 19:39:54:001 | HL | DEBUG1 | +0 | CheckFile - Attributes: FileDescription SevenZipSharp FileVersion 0.64.4841.31212 InternalName SevenZipSharp.dll LegalCopyright Copyright (C) Markovtsev Vadim 2009, 2010, licenced under LGPLv3 OriginalFilename SevenZipSharp.dll ProductName SevenZipSharp ProductVersion 0.64.4841.31212 CompanyName Markovtsev Vadim File Size: 165888 bytes Created: 5/10/2014 - 7:23:06 PM Modified: 5/10/2014 - 7:23:06 PM 19:39:54:001 | HL | INFO | +0 | CheckFile - Checking if G:\Hyperspin\HyperLaunch\Module Extensions\gsdll32.dll exists 19:39:54:001 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 8818688 bytes Created: 5/10/2014 - 9:57:00 PM Modified: 5/10/2014 - 9:57:00 PM 19:39:54:001 | HL | INFO | +0 | CheckFile - Checking if G:\Hyperspin\HyperLaunch\Module Extensions\BlockInput.exe exists 19:39:54:001 | HL | DEBUG1 | +0 | CheckFile - Attributes: FileDescription FileVersion 1.1.09.04 InternalName OriginalFilename ProductName ProductVersion 1.1.09.04 File Size: 657920 bytes Created: 5/10/2014 - 9:57:00 PM Modified: 5/10/2014 - 9:57:00 PM 19:39:54:001 | HL | INFO | +0 | CheckFile - Checking if G:\Hyperspin\HyperLaunch\Module Extensions\gdip.ahk exists 19:39:54:001 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Extension. 19:39:54:001 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 88789 bytes Created: 5/10/2014 - 9:57:00 PM Modified: 5/10/2014 - 9:57:00 PM 19:39:54:001 | HL | INFO | +0 | CheckFile - Checking if G:\Hyperspin\HyperLaunch\Module Extensions\RIni.ahk exists 19:39:54:001 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Extension. 19:39:54:001 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 67561 bytes Created: 5/10/2014 - 9:57:00 PM Modified: 5/10/2014 - 9:57:00 PM 19:39:54:001 | HL | INFO | +0 | CheckFile - Checking if G:\Hyperspin\HyperLaunch\Module Extensions\CLR.ahk exists 19:39:54:001 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Extension. 19:39:54:001 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 10586 bytes Created: 5/10/2014 - 9:57:00 PM Modified: 5/10/2014 - 9:57:00 PM 19:39:54:001 | HL | INFO | +0 | CheckFile - Checking if G:\Hyperspin\HyperLaunch\Module Extensions\COM.ahk exists 19:39:54:001 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Extension. 19:39:54:001 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 26342 bytes Created: 5/10/2014 - 9:57:00 PM Modified: 5/10/2014 - 9:57:00 PM 19:39:54:001 | HL | INFO | +0 | CheckFile - Checking if G:\Hyperspin\HyperLaunch\Module Extensions\JSON.ahk exists 19:39:54:001 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Extension. 19:39:54:001 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 9203 bytes Created: 5/10/2014 - 9:57:00 PM Modified: 5/10/2014 - 9:57:00 PM 19:39:54:001 | HL | INFO | +0 | CheckFile - Checking if G:\Hyperspin\HyperLaunch\Lib\Fade Init.ahk exists 19:39:54:001 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 19:39:54:001 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 1145 bytes Created: 5/10/2014 - 9:57:00 PM Modified: 5/10/2014 - 9:57:00 PM 19:39:54:001 | HL | INFO | +0 | CheckFile - Checking if G:\Hyperspin\HyperLaunch\Lib\HyperPause Init.ahk exists 19:39:54:001 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 19:39:54:001 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 691 bytes Created: 5/10/2014 - 9:57:00 PM Modified: 5/10/2014 - 9:57:00 PM 19:39:54:001 | HL | INFO | +0 | CheckFile - Checking if G:\Hyperspin\HyperLaunch\Lib\Keymapper Init.ahk exists 19:39:54:001 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 19:39:54:001 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 3435 bytes Created: 5/10/2014 - 9:57:00 PM Modified: 5/10/2014 - 9:57:00 PM 19:39:54:001 | HL | INFO | +0 | CheckFile - Checking if G:\Hyperspin\HyperLaunch\Lib\MultiGame Init.ahk exists 19:39:54:017 | HL | DEBUG1 | +15 | CRC Check - CRC matches, this is an official unedited Library. 19:39:54:017 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 161 bytes Created: 5/10/2014 - 9:57:00 PM Modified: 5/10/2014 - 9:57:00 PM 19:39:54:017 | HL | INFO | +0 | CheckFile - Checking if G:\Hyperspin\HyperLaunch\Lib\Statistics Init.ahk exists 19:39:54:017 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 19:39:54:017 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 167 bytes Created: 5/10/2014 - 9:57:00 PM Modified: 5/10/2014 - 9:57:00 PM 19:39:54:017 | HL | INFO | +0 | CheckFile - Checking if G:\Hyperspin\HyperLaunch\Lib\Fade.ahk exists 19:39:54:017 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 19:39:54:017 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 25516 bytes Created: 5/10/2014 - 9:57:00 PM Modified: 5/10/2014 - 9:57:00 PM 19:39:54:017 | HL | INFO | +0 | CheckFile - Checking if G:\Hyperspin\HyperLaunch\Lib\HyperPause.ahk exists 19:39:54:017 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 19:39:54:017 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 360180 bytes Created: 5/10/2014 - 9:57:00 PM Modified: 5/10/2014 - 9:57:00 PM 19:39:54:017 | HL | INFO | +0 | CheckFile - Checking if G:\Hyperspin\HyperLaunch\Lib\Keymapper.ahk exists 19:39:54:017 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 19:39:54:017 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 30775 bytes Created: 5/10/2014 - 9:57:00 PM Modified: 5/10/2014 - 9:57:00 PM 19:39:54:017 | HL | INFO | +0 | CheckFile - Checking if G:\Hyperspin\HyperLaunch\Lib\MultiGame.ahk exists 19:39:54:017 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 19:39:54:017 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 36816 bytes Created: 5/10/2014 - 9:57:00 PM Modified: 5/10/2014 - 9:57:00 PM 19:39:54:017 | HL | INFO | +0 | CheckFile - Checking if G:\Hyperspin\HyperLaunch\Lib\Bezel.ahk exists 19:39:54:017 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 19:39:54:017 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 83008 bytes Created: 5/10/2014 - 9:57:00 PM Modified: 5/10/2014 - 9:57:00 PM 19:39:54:017 | HL | INFO | +0 | CheckFile - Checking if G:\Hyperspin\HyperLaunch\Lib\Statistics.ahk exists 19:39:54:017 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 19:39:54:017 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 26153 bytes Created: 5/10/2014 - 9:57:00 PM Modified: 5/10/2014 - 9:57:00 PM 19:39:54:017 | HL | INFO | +0 | CheckFile - Checking if G:\Hyperspin\HyperLaunch\Lib\Rom Mapping Launch Menu.ahk exists 19:39:54:017 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 19:39:54:017 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 63798 bytes Created: 5/10/2014 - 9:57:00 PM Modified: 5/10/2014 - 9:57:00 PM 19:39:54:017 | HL | INFO | +0 | CheckFile - Checking if G:\Hyperspin\HyperLaunch\Lib\Shared.ahk exists 19:39:54:017 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 19:39:54:017 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 81966 bytes Created: 5/10/2014 - 9:57:00 PM Modified: 5/10/2014 - 9:57:00 PM 19:39:54:017 | HL | INFO | +0 | CheckFile - Checking if G:\Hyperspin\HyperLaunch\Lib\XHotkey.ahk exists 19:39:54:032 | HL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Library. 19:39:54:032 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 28374 bytes Created: 5/10/2014 - 9:57:00 PM Modified: 5/10/2014 - 9:57:00 PM 19:39:54:032 | HL | INFO | +0 | CheckFile - Checking if G:\Hyperspin\HyperLaunch\Lib\Fade Animations.ahk exists 19:39:54:032 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 19:39:54:032 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 49050 bytes Created: 5/10/2014 - 9:57:00 PM Modified: 5/10/2014 - 9:57:00 PM 19:39:54:032 | HL | INFO | +0 | Main - HyperLaunch received "Commodore Amiga CD32" and "Alien Breed '92 Special Edition & Qwak (Europe)" 19:39:54:032 | HL | INFO | +0 | Main - Alien Breed '92 Special Edition & Qwak (Europe) is using the default emulator: WinUAE 19:39:54:032 | HL | INFO | +0 | Main - Checking for a [WinUAE] section in G:\Hyperspin\HyperLaunch\Settings\Commodore Amiga CD32\Emulators.ini 19:39:54:032 | HL | INFO | +0 | Main - Checking for a [WinUAE] section in G:\Hyperspin\HyperLaunch\Settings\Global Emulators.ini 19:39:54:032 | HL | INFO | +0 | Main - Found [WinUAE] in G:\Hyperspin\HyperLaunch\Settings\Global Emulators.ini 19:39:54:032 | HL | INFO | +0 | CheckFile - Checking if G:\Hyperspin\HyperLaunch\Modules\WinUAE\WinUAE.ahk exists 19:39:54:032 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 11546 bytes Created: 5/10/2014 - 9:57:00 PM Modified: 5/10/2014 - 9:57:00 PM 19:39:54:032 | HL | INFO | +0 | Main - CRC Check - CRC matches, this is an official unedited module. 19:39:54:032 | HL | INFO | +0 | Main - Alien Breed '92 Special Edition & Qwak (Europe) will use module: G:\Hyperspin\HyperLaunch\Modules\WinUAE\WinUAE.ahk 19:39:54:032 | HL | INFO | +0 | Main - Using standard method with "Rom Extension" SkipChecks or without any SkipChecks. 19:39:54:032 | HL | INFO | +0 | Main - INI Keys read 19:39:54:032 | HL | INFO | +0 | CheckFile - Checking if C:\Program Files\7-Zip\7z.exe exists 19:39:54:032 | HL | DEBUG1 | +0 | CheckFile - Attributes: FileDescription 7-Zip Console FileVersion 9.20 InternalName 7z LegalCopyright Copyright (c) 1999-2010 Igor Pavlov OriginalFilename 7z.exe ProductName 7-Zip ProductVersion 9.20 CompanyName Igor Pavlov File Size: 284160 bytes Created: 11/18/2010 - 9:08:30 PM Modified: 11/18/2010 - 9:08:30 PM 19:39:54:032 | HL | INFO | +0 | CheckFile - Checking if C:\Program Files\7-Zip\7z.dll exists 19:39:54:032 | HL | DEBUG1 | +0 | CheckFile - Attributes: FileDescription 7z Standalone Plugin FileVersion 9.20 InternalName 7za LegalCopyright Copyright (c) 1999-2010 Igor Pavlov OriginalFilename 7za.dll ProductName 7-Zip ProductVersion 9.20 CompanyName Igor Pavlov File Size: 1422336 bytes Created: 11/18/2010 - 9:24:20 PM Modified: 11/18/2010 - 9:24:20 PM 19:39:54:032 | HL | INFO | +0 | CheckPaths - Started 19:39:54:032 | HL | DEBUG1 | +0 | CheckPaths - Looking for rom: G:\Hyperspin\Emulators\Commodore Amiga CD32\roms\Alien Breed '92 Special Edition & Qwak (Europe).7z 19:39:54:032 | HL | DEBUG1 | +0 | CheckPaths - Looking for rom by name in subfolder: G:\Hyperspin\Emulators\Commodore Amiga CD32\roms\Alien Breed '92 Special Edition & Qwak (Europe)\Alien Breed '92 Special Edition & Qwak (Europe).7z 19:39:54:032 | HL | DEBUG1 | +0 | CheckPaths - Rom not found 19:39:54:032 | HL | DEBUG1 | +0 | CheckPaths - Looking for rom: G:\Hyperspin\Emulators\Commodore Amiga CD32\roms\Alien Breed '92 Special Edition & Qwak (Europe).zip 19:39:54:032 | HL | DEBUG1 | +0 | CheckPaths - Looking for rom by name in subfolder: G:\Hyperspin\Emulators\Commodore Amiga CD32\roms\Alien Breed '92 Special Edition & Qwak (Europe)\Alien Breed '92 Special Edition & Qwak (Europe).zip 19:39:54:032 | HL | DEBUG1 | +0 | CheckPaths - Rom not found 19:39:54:032 | HL | DEBUG1 | +0 | CheckPaths - Looking for rom: G:\Hyperspin\Emulators\Commodore Amiga CD32\roms\Alien Breed '92 Special Edition & Qwak (Europe).adf 19:39:54:032 | HL | DEBUG1 | +0 | CheckPaths - Looking for rom by name in subfolder: G:\Hyperspin\Emulators\Commodore Amiga CD32\roms\Alien Breed '92 Special Edition & Qwak (Europe)\Alien Breed '92 Special Edition & Qwak (Europe).adf 19:39:54:032 | HL | DEBUG1 | +0 | CheckPaths - Rom not found 19:39:54:032 | HL | DEBUG1 | +0 | CheckPaths - Looking for rom: G:\Hyperspin\Emulators\Commodore Amiga CD32\roms\Alien Breed '92 Special Edition & Qwak (Europe).info 19:39:54:032 | HL | DEBUG1 | +0 | CheckPaths - Looking for rom by name in subfolder: G:\Hyperspin\Emulators\Commodore Amiga CD32\roms\Alien Breed '92 Special Edition & Qwak (Europe)\Alien Breed '92 Special Edition & Qwak (Europe).info 19:39:54:032 | HL | DEBUG1 | +0 | CheckPaths - Rom not found 19:39:54:032 | HL | DEBUG1 | +0 | CheckPaths - Looking for rom: G:\Hyperspin\Emulators\Commodore Amiga CD32\roms\Alien Breed '92 Special Edition & Qwak (Europe).cue 19:39:54:032 | HL | DEBUG1 | +0 | CheckPaths - Looking for rom by name in subfolder: G:\Hyperspin\Emulators\Commodore Amiga CD32\roms\Alien Breed '92 Special Edition & Qwak (Europe)\Alien Breed '92 Special Edition & Qwak (Europe).cue 19:39:54:032 | HL | INFO | +0 | CheckPaths - Found rom by matching name in subfolder: G:\Hyperspin\Emulators\Commodore Amiga CD32\roms\Alien Breed '92 Special Edition & Qwak (Europe)\Alien Breed '92 Special Edition & Qwak (Europe).cue 19:39:54:032 | HL | DEBUG1 | +0 | CheckPaths - Current romName: Alien Breed '92 Special Edition & Qwak (Europe) 19:39:54:032 | HL | DEBUG1 | +0 | CheckPaths - Current romPath: G:\Hyperspin\Emulators\Commodore Amiga CD32\roms\Alien Breed '92 Special Edition & Qwak (Europe) 19:39:54:032 | HL | DEBUG1 | +0 | CheckPaths - Current romExtension: .cue 19:39:54:032 | HL | INFO | +0 | CheckFile - Checking if G:\Hyperspin\Emulators\WinUAE\winuae.exe exists 19:39:54:032 | HL | DEBUG1 | +0 | CheckFile - Attributes: FileDescription WinUAE FileVersion 2.6.1.0 InternalName WinUAE LegalCopyright © 1996-2013 under the GNU Public License (GPL) OriginalFilename WinUAE.exe ProductName WinUAE ProductVersion 2.6.1.0 File Size: 9861632 bytes Created: 6/19/2013 - 11:31:38 AM Modified: 6/19/2013 - 11:31:38 AM 19:39:54:032 | HL | INFO | +0 | CheckPaths - Ended 19:39:54:032 | HL | INFO | +0 | BuildScript - User Variables: ;---------------------------------------------------------------------------- ; INJECTED VARIABLES ;---------------------------------------------------------------------------- #NoTrayIcon #InstallKeybdHook DetectHiddenWindows, ON SetTitleMatchMode, 2 SendMode, Event 0 = 2 hlMode = frontendPID = 0 frontendPath = G:\Hyperspin frontendExe = HyperSpin.exe frontendExt = exe frontendName = HyperSpin frontendDrive = G: exitEmulatorKey = ~Esc exitEmulatorKeyWait = 0 forceHoldKey = ~Esc restoreFE = false exitScriptKey = ~q & ~s toggleCursorKey = ~e & ~t emuFullPath = G:\Hyperspin\Emulators\WinUAE\winuae.exe emuPath = G:\Hyperspin\Emulators\WinUAE emuName = WinUAE emuExt = exe romPath = G:\Hyperspin\Emulators\Commodore Amiga CD32\roms\Alien Breed '92 Special Edition & Qwak (Europe) romPathFromIni = G:\Hyperspin\Emulators\Commodore Amiga CD32\roms romExtension = .cue romExtensionOrig = .cue romExtensions = 7z|zip|adf|info|cue|iso executable = winuae.exe systemName = Commodore Amiga CD32 dbName = Alien Breed '92 Special Edition & Qwak (Europe) romName = Alien Breed '92 Special Edition & Qwak (Europe) romMapPath = romMappingEnabled = false romMappingLaunchMenuEnabled = false romMappingFirstMatchingExt = false romMappingShowAllRomsInArchive = true romMappingNumberOfWheelsByScreen = 7 romMappingMenuWidth = 300 romMappingMenuMargin = 50 romMappingTextFont = Bebas Neue romMappingTextOptions = cFFFFFFFF r4 s40 Bold romMappingDisabledTextColor = ff888888 romMappingTextSizeDifference = 5 romMappingTextMargin = 10 romMappingTitleTextFont = Bebas Neue romMappingTitleTextOptions = cFFFFFFFF r4 s60 Bold romMappingTitle2TextFont = Bebas Neue romMappingTitle2TextOptions = cFFFFFFFF r4 s15 Bold romMappingGameInfoTextFont = Bebas Neue romMappingGameInfoTextOptions = cFFFFFFFF r4 s15 Regular romMappingBackgroundBrush = aa000000 romMappingColumnBrush = 33000000 romMappingButtonBrush1 = 6f000000 romMappingButtonBrush2 = 33000000 romMappingBackgroundAlign = Stretch and Lose Aspect romMappingMenuFlagWidth = 40 romMappingMenuFlagSeparation = 5 romMappingDefaultMenuList = FullList romMappingSingleFilteredRomAutomaticLaunch = false skipchecks = false romMatchExt = false blockInputTime = 0 blockInputFile = G:\Hyperspin\HyperLaunch\Module Extensions\BlockInput.exe errorLevelReporting = false logFile = G:\Hyperspin\HyperLaunch\HyperLaunch.log logLabel := [" INFO"," WARNING"," ERROR"," DEBUG1"," DEBUG2"] logLevel = 10 logIncludeModule = true logIncludeFileProperties = true logShowCommandWindow = false logCommandWindow = false sysLang = English_United_States navUpKey = Up navDownKey = Down navLeftKey = Left navRightKey = Right navSelectKey = Enter navP2UpKey = Numpad8 navP2DownKey = Numpad2 navP2LeftKey = Numpad4 navP2RightKey = Numpad6 navP2SelectKey = NumpadEnter originalWidth = 1680 originalHeight = 1050 dtEnabled = true dtPath = C:\Program Files (x86)\DAEMON Tools Lite\DTLite.exe dtUseSCSI = true dtAddDrive = true emuIdleShutdown = 0 hideCursor = false hideEmu = false hideFE = false fadeIn = false fadeInDuration = 500 fadeInTransitionAnimation = DefaultAnimateFadeIn fadeInDelay = 0 fadeInExitDelay = 0 fadeOutExitDelay = 0 fadeOut = false fadeOutExtraScreen = false fadeOutDuration = 500 fadeOutTransitionAnimation = DefaultAnimateFadeOut fadeOutDelay = 0 fadeLyrInterpolation = 7 fadeLyr1Color = FF000000 fadeLyr1AlignImage = Align to Top Left fadeLyr2Pos = Bottom Right Corner fadeLyr2X = 300 fadeLyr2Y = 300 fadeLyr2Adjust = 1 fadeLyr2PicPad = 0 fadeLyr3Pos = Center fadeLyr3X = 300 fadeLyr3Y = 300 fadeLyr3Adjust = 0.75 fadeLyr3Speed = 750 fadeLyr3Animation = DefaultFadeAnimation fadeLyr37zAnimation = DefaultFadeAnimation fadeLyr3Type = imageandbar fadeLyr3ImgFollow7zProgress = true fadeLyr3Repeat = 1 fadeLyr3PicPad = 0 fadeLyr4Adjust = 0.75 fadeLyr4X = 100 fadeLyr4Y = 100 fadeLyr4Pos = Above Layer 3 - Left fadeLyr4FPS = 10 fadeLyr4PicPad = 0 fadeTranspGifColor = FFFFFF fadeBarWindow = false fadeBarWindowX = fadeBarWindowY = fadeBarWindowW = 600 fadeBarWindowH = 120 fadeBarWindowR = 20 fadeBarWindowM = 20 fadeBarWindowHatchStyle = 8 fadeBarBack = true fadeBarBackColor = FF555555 fadeBarH = 20 fadeBarR = 5 fadeBarColor = DD00BFFF fadeBarHatchStyle = 3 fadeBarPercentageText = true fadeBarInfoText = true fadeBarXOffset = 0 fadeBarYOffset = 100 fadeRomInfoDescription = text fadeRomInfoSystemName = text fadeRomInfoYear = text fadeRomInfoManufacturer = text fadeRomInfoGenre = text fadeRomInfoRating = text fadeRomInfoOrder = Description|SystemName|Year|Manufacturer|Genre|Rating fadeRomInfoTextPlacement = topRight fadeRomInfoTextMargin = 5 fadeRomInfoText1Options = cFF555555 r4 s20 Bold fadeRomInfoText2Options = cFF555555 r4 s20 Bold fadeRomInfoText3Options = cFF555555 r4 s20 Bold fadeRomInfoText4Options = cFF555555 r4 s20 Bold fadeRomInfoText5Options = cFF555555 r4 s20 Bold fadeRomInfoText6Options = cFF555555 r4 s20 Bold fadeStats_Number_of_Times_Played = text with label fadeStats_Last_Time_Played = text with label fadeStats_Average_Time_Played = text with label fadeStats_Total_Time_Played = text with label fadeStats_System_Total_Played_Time = text with label fadeStats_Total_Global_Played_Time = text with label fadeStatsInfoOrder = Number_of_Times_Played|Last_Time_Played|Average_Time_Played|Total_Time_Played|System_Total_Played_Time|Total_Global_Played_Time fadeStatsInfoTextPlacement = topLeft fadeStatsInfoTextMargin = 5 fadeStatsInfoText1Options = cFF555555 r4 s20 Bold fadeStatsInfoText2Options = cFF555555 r4 s20 Bold fadeStatsInfoText3Options = cFF555555 r4 s20 Bold fadeStatsInfoText4Options = cFF555555 r4 s20 Bold fadeStatsInfoText5Options = cFF555555 r4 s20 Bold fadeStatsInfoText6Options = cFF555555 r4 s20 Bold fadeText1X = 0 fadeText1Y = 0 fadeText1Options = cFFFFFFFF r4 s20 Right Bold fadeText1 = Loading Game fadeText2X = 0 fadeText2Y = 0 fadeText2Options = cFFFFFFFF r4 s20 Right Bold fadeText2 = Extraction Complete fadeFont = Arial fadeSystemAndRomLayersOnly = false fadeInterruptKey = detectFadeErrorEnabled = true fadeImgPath = G:\Hyperspin\HyperLaunch\Media\Fade HLDataPath = G:\Hyperspin\HyperLaunch\Data HLMediaPath = G:\Hyperspin\HyperLaunch\Media HLErrSoundPath = G:\Hyperspin\HyperLaunch\Media\Sounds\Error modulesPath = G:\Hyperspin\HyperLaunch\Modules moduleFullName = G:\Hyperspin\HyperLaunch\Modules\WinUAE\WinUAE.ahk moduleName = WinUAE modulePath = G:\Hyperspin\HyperLaunch\Modules\WinUAE moduleExtension = ahk moduleExtensionsPath = G:\Hyperspin\HyperLaunch\Module Extensions libPath = G:\Hyperspin\HyperLaunch\Lib 7zEnabled = false 7zPath = C:\Program Files\7-Zip\7z.exe 7zDllPath = C:\Program Files\7-Zip\7z.dll 7zExtractPath = C:\Program Files (x86)\DAEMON Tools Lite 7zExtractPathOrig = 7zAttachSystemName = false 7zDelTemp = true 7zSounds = true 7zFormats = .zip,.rar,.7z,.lzh,.gzip,.tar 7zFormatsNoP = zip,rar,7z,lzh,gzip,tar mgEnabled = false mgKey = ~NumpadSub mgBackgroundColor = FF000000 mgSidePadding = 0.2 mgYOffset = 500 mgImageAdjust = 1 mgFont = Arial mgText1Options = x10p y30p w80p Center cBBFFFFFF r4 s100 BoldItalic mgText1Text = Please select a game mgText2Options = w96p cFFFFFFFF r4 s50 Center BoldItalic mgText2Offset = 70 mgUseSound = true mgSoundfreq = 300 mgExitEffect = none mgSelectedEffect = rotate mgUseGameArt = false mgArtworkDir = Artwork1 hpEnabled = false hpKey = ~NumpadAdd hpBackToMenuBarKey = X hpZoomInKey = C hpZoomOutKey = V hpScreenshotKey = ~PrintScreen hpHiToTextPath = G:\Hyperspin\HyperLaunch\Module Extensions\HiToText.exe hpSaveStateKeyCodes = hpLoadStateKeyCodes = keymapperEnabled = false keymapperAHKMethod = false keymapper = xpadder xpadderFullPath = G:\Hyperspin\Utilities\Xpadder\xpadder.exe joyToKeyFullPath = G:\Hyperspin\Utilities\JoyToKey\JoyToKey.exe keymapperProfilePath = G:\Hyperspin\HyperLaunch\Profiles\xpadder keymapperFrontEndProfileName = HyperSpin keymapperFrontEndProfile = false keymapperHyperLaunchProfileEnabled = false JoyIDsEnabled = false JoyIDsPreferredControllersSystem = use_global JoyIDsPreferredControllersGlobal = use_global CustomJoyNamesEnabled = false CustomJoyNames = FEProfile = G:\Hyperspin\HyperLaunch\Profiles\xpadder\HyperSpin defaultProfile = G:\Hyperspin\HyperLaunch\Profiles\xpadder\_Default systemProfile = G:\Hyperspin\HyperLaunch\Profiles\xpadder\Commodore Amiga CD32 xPadderSystemProfile = G:\Hyperspin\HyperLaunch\Profiles\xpadder\Commodore Amiga CD32\_Default emuProfile = G:\Hyperspin\HyperLaunch\Profiles\xpadder\Commodore Amiga CD32\WinUAE romProfile = G:\Hyperspin\HyperLaunch\Profiles\xpadder\Commodore Amiga CD32\Alien Breed '92 Special Edition & Qwak (Europe) HyperLaunchProfile = G:\Hyperspin\HyperLaunch\Profiles\xpadder\HyperLaunch blankProfile = G:\Hyperspin\HyperLaunch\Profiles\xpadder\_Default\blank ahkFEProfile = G:\Hyperspin\HyperLaunch\Profiles\AHK\HyperSpin ahkDefaultProfile = G:\Hyperspin\HyperLaunch\Profiles\AHK\_Default ahkSystemProfile = G:\Hyperspin\HyperLaunch\Profiles\AHK\Commodore Amiga CD32 ahkEmuProfile = G:\Hyperspin\HyperLaunch\Profiles\AHK\Commodore Amiga CD32\WinUAE ahkRomProfile = G:\Hyperspin\HyperLaunch\Profiles\AHK\Commodore Amiga CD32\Alien Breed '92 Special Edition & Qwak (Europe) ahkHyperLaunchProfile = G:\Hyperspin\HyperLaunch\Profiles\AHK\HyperLaunch bezelEnabled = false statisticsEnabled = true 19:39:54:032 | HL | INFO | +0 | BuildScript - Loaded XHotkey Init.ahk scripts 19:39:54:032 | HL | INFO | +0 | BuildScript - Loaded Statistics Init.ahk scripts 19:39:54:032 | HL | DEBUG1 | +0 | BuildScript - Module starts on line: 2 19:39:54:032 | HL | INFO | +0 | BuildScript - Module: MEmu = WinUAE MEmuV = v2.6.0 MURL = http://www.winuae.net/ MAuthor = brolly MVersion = 2.0.2 MCRC = 2283EB17 iCRC = 587D7C70 mId = 635138307631183750 MSystem = "Commodore Amiga","Commodore Amiga CD32","Commodore CDTV","Commodore Amiga CD" ;---------------------------------------------------------------------------- ; Notes: ; You can have specific configuration files inside a Configurations folder on WinUAE main dir. ; Just name them the same as the game name on the XML file. ; Make sure you create a host config files with these names: ; CD32 : cd32host.uae and cd32mousehost.uae; ; CDTV : cdtvhost.uae and cdtvmousehost.uae; ; Amiga : amigahost.uae; ; Amiga CD : amigacdhost.uae; ; cd32mouse and cdtvmouse are for mouse controlled games on these systems, you should configure ; Windows Mouse on Port1 and a CD32 pad on Port2. For Amiga and Amiga CD make sure you set both ; a joystick and a mouse on Port1 and only a joystick on Port2. ; Set all your other preferences like video display settings. And make sure you are saving a HOST ; configuration file and not a general configuration file. ; ; If you want to configure an exit key through WinUAE: ; Host-Input-Configuration #1-RAW Keyboard and then remap the desired key to Quit Emulator. ; If you want to configure a key to toggle fullscreen/windowed mode: ; Host-Input-Configuration #1-RAW Keyboard and then remap the desired key to Toggle windowed/fullscreen. ; ; CD32 and CDTV: ; A settings file called System_Name.ini should be placed on your module dir. on that file you can define if a ; game uses mouse or if it needs the special delay hack loading method amongst other things. Example of such a file: ; ; [Lemmings (Europe)] ; UseMouse=true ; ; [Project-X & F17 Challenge (Europe)] ; DelayHack=true ; ; Amiga: ; For MultiGame support make sure you don't change the default WinUAE diskswapper keys which are: ; END+1-0 (not numeric keypad) = insert image from swapper slot 1-10 ; END+SHIFT+1-0 = insert image from swapper slot 11-20 ; END+CTRL+1-4 = select drive ; ; To do that follow the same procedure as above for the exit ; key, but on F11 set it to Toggle windowed/fullscreen. Make sure you save your configuration afterwards. ; Note : If you want to use Send commands to WinUAE for any keys that you configured through Input-Configuration panel make sure you ; set those keys for Null Keyboard! This is a virtual keyboard that collects all input events that don't come from physical ; keyboards. This applies to the exit or windowed/fullscreen keys mentioned above. ; ; If you are using WHDLoad games, but want to keep your default user-startup file after exiting then make a copy of it in the ; WHDFolder\S (Set in PathToWHDFolder) and name it default-user-startup. This file will then be copied over S\user-startup on exit. ;---------------------------------------------------------------------------- StartModule() FadeInStart() settingsFile := modulePath . "\" . systemName . ".ini" Fullscreen := IniReadCheck(settingsFile, "Settings", "Fullscreen","true",,1) PathToWHDFolder := IniReadCheck(settingsFile, "Settings", "PathToWHDFolder", EmuPath . "\HDD\WHD",,1) PathToWorkBenchBase := IniReadCheck(settingsFile, "Settings", "PathToWorkBenchBase", EmuPath . "\HDD\Workbench31_Lite.vhd",,1) PathToWHDFolder := AbsoluteFromRelative(EmuPath, PathToWHDFolder) PathToWorkBenchBase := AbsoluteFromRelative(EmuPath, PathToWorkBenchBase) ; This object controls how the module reacts to different systems. MESS can play a lot of systems, but needs to know what system you want to run, so this module has to adapt. mType := Object("Commodore Amiga","a500","Commodore Amiga CD32","cd32","Commodore CDTV","cdtv","Commodore Amiga CD","amigacd") ident := mType[systemName] ; search object for the systemName identifier MESS uses If !ident ScriptError("Your systemName is: " . systemName . "`nIt is not one of the known supported systems for this WinUAE module: " . moduleName) windowClass = PCsuxRox ;Class name is different depending on if the game is being run windowed or fullscreen If ( Fullscreen = "true" ) windowClass = AmigaPowah specialcfg = %emuPath%Configurations\%romName%.uae If romExtension in .hdf,.vhd DefaultRequireWB := "true" Else DefaultRequireWB := "false" If romExtension in .zip,.lha,.rar,.7z { SlaveFile := COM_Invoke(HLObject, "findByExtension", romPath . "\" . romName . romExtension, "slave") If (SlaveFile) { If romName contains (AGA) DefaultOptions := "-s cycle_exact=false " . "-s immediate_blits=false " . "-s cpu_compatible=false " . "-s cpu_speed=max " . "-s cachesize=8192" ;AGA Else DefaultOptions := "-s cycle_exact=true " . "-s immediate_blits=false " . "-s cpu_compatible=false " . "-s cpu_speed=real " . "-s cachesize=8192 " ;Non-AGA } } usemouse := IniReadCheck(settingsFile, romName, "UseMouse","false",,1) delayhack := IniReadCheck(settingsFile, romName, "DelayHack","false",,1) options := IniReadCheck(settingsFile, romName, "Options",DefaultOptions,,1) videomode := IniReadCheck(settingsFile, romName, "VideoMode","PAL",,1) floppyspeed := IniReadCheck(settingsFile, romName, "FloppySpeed","turbo",,1) quickstartmode := IniReadCheck(settingsFile, romName, "QuickStartMode",A_Space,,1) immediateblitter := IniReadCheck(settingsFile, romName, "ImmediateBlitter","false",,1) requireswb := IniReadCheck(settingsFile, romName, "RequiresWB",DefaultRequireWB,,1) customwb := IniReadCheck(settingsFile, romName, "CustomWB",A_Space,,1) whdloadoptions := IniReadCheck(settingsFile, romName, "WHDLoadOptions","PRELOAD",,1) neverextract := IniReadCheck(settingsFile, romName, "NeverExtract","false",,1) fs := If (Fullscreen = "true") ? "true" : "false" videomode := (If videomode = "NTSC" ? ("-s ntsc=true") : ("")) floppyspeed := (If floppyspeed ? ("-s floppy_speed=" . floppyspeed) : ("")) If (requireswb = "true") { ident := "a1200" If (customwb) { PathToWorkBenchBase := %EmuPath% . "\" . customwb } CheckFile(PathToWorkBenchBase) wbDrive := "-s hardfile=rw,32,1,2,512," . """" . PathToWorkBenchBase . """" } If romExtension in .hdf,.vhd { ident := "a1200" gameDrive := "-s hardfile=rw,32,1,2,512," . """" . romPath . "\" . romName . romExtension . """" } If (immediateblitter = "true") { options := options . " " . "-s immediate_blits=true" } options := options . " " . videomode If (ident = "a500" or ident = "a1200") { If romName contains (AGA),(LW) ident := "a1200" If (SlaveFile) { CheckFile(PathToWHDFolder) ident := "a1200" ;Create the user-startup file to launch the game WHDUserStartupFile := PathToWHDFolder . "\S\user-startup" SplitPath, SlaveFile, SlaveName, SlaveFolder FileDelete, %WHDUserStartupFile% FileAppend, echo "";`n, %WHDUserStartupFile% FileAppend, echo "Running: %SlaveName%";`n, %WHDUserStartupFile% FileAppend, echo "";`n, %WHDUserStartupFile% FileAppend, cd dh1:%SlaveFolder%;`n, %WHDUserStartupFile% FileAppend, whdload %SlaveName% %whdloadoptions%;`n, %WHDUserStartupFile% } } 7z(romPath, romName, romExtension, 7zExtractPath) If FileExist(specialcfg) { ;Game specific configuration file exists configFile = %romName%.uae } Else { ;Game specific configuration file doesn't exist If (ident = "cd32" or ident = "cdtv") { configFile := If (usemouse = "true") ? ("host\" . ident . "mousehost.uae") : ("host\" . ident . "host.uae") quickcfg := If (ident = "cd32") ? ("-s quickstart=" . ident . "`,0 -s chipmem_size=8") : ("-s quickstart=" . ident . "`,0") If (delayhack = "true") options := options . " -s cdimage0=" . """" . romPath . "\" . romName . romExtension . """" . "`,delay" Else options := options . " -cdimage=" . """" . romPath . "\" . romName . romExtension . """" } Else { ;Amiga or Amiga CD game configFile := If systemName = "Commodore Amiga CD" ? "host\amigacdhost.uae" : "host\amigahost.uae" If quickstartmode quickcfg := "-s quickstart=" . quickstartmode Else quickcfg := If (ident = "a500") ? "-s quickstart=a500`,1" : "-s quickstart=a1200`,1" If (SlaveFile) { ;WHDLoad Game options := options . " -s filesystem=rw,WHD:" . """" . PathToWHDFolder . """" . " -s filesystem=ro,Games:" . """" . romPath . "\" . romName . romExtension . """" } Else If (gameDrive) { ;HDD Game options := options . " " . wbDrive . " " . gameDrive } Else If romExtension in .cue,.iso { ;Amiga CD game options := options . " " . wbDrive . " -cdimage=" . """" . romPath . "\" . romName . romExtension . """" . " -s win32.map_cd_drives=true -s scsi=true" } Else { ;Floppy Game ;MultiDisk loading, this will load the first 2 disks into drives 0 and 1 since some games can read from both drives and therefore ;the user won't need to change disks through the MG menu. We can have up to 4 drives, but most of the games will only support 2 drives ;so disks are only loaded into the first 2 for better compatibility. Remaining drives will be loaded into quick disk slots. romCount = % romTable.MaxIndex() If romName contains (Disk 1) { ;If the user boots any disk rather than the first one, multi disk support must be done through HyperLaunch MG menu if romCount > 1 { options := options . " -s nr_floppies=2" mgoptions := " -s floppy1=" . """" . romTable[2,1] . """" } } options := options . " " . floppyspeed . " -s floppy0=" . """" . romPath . "\" . romName . romExtension . """" . mgoptions if romCount > 1 { ;DiskSwapper ;diskswapper := " -diskswapper " Loop % romTable.MaxIndex() ; loop each item in our array { ;diskswapper := diskswapper . """" . romTable[A_Index,1] . """," diskswapper := diskswapper . " -s diskimage" . (A_Index-1) . "=" . """" . romTable[A_Index,1] . """" } options := options . diskswapper } } } } param1 := "-f " . """" . EmuPath . "\Configurations\" . configFile . """" . " " . quickcfg param2 := "-s use_gui=no -s gfx_fullscreen_amiga=" . fs param3 := options ;MsgBox, %param1% %param2% %param3% %param4% %param5% %param6% ;ExitApp ;disableActivateBlackScreen = true Run(Executable . A_Space . param1 . A_Space . param2 . A_Space . param3 . A_Space . param4 . A_Space . param5 . A_Space . param6 . A_Space . " -portable", emuPath) WinWait("ahk_class " . windowClass) WinWaitActive("ahk_class " . windowClass) FadeInExit() Process("WaitClose",executable) 7zCleanUp() FadeOutExit() ExitModule() MultiGame: If currentButton = 10 diskslot = 0 Else If currentButton > 10 diskslot := currentButton - 10 Else diskslot := currentButton If currentButton > 10 Send, {End Down}{Shift Down}%diskslot%{Shift Up}{End Up} Else Send, {End Down}%diskslot%{End Up} return CloseProcess: If (ident = "a500" or ident = "a1200") { If (SlaveFile) { CheckFile(PathToWHDFolder) ;Copy default-user-startup to user-startup if file exists IfExist, %PathToWHDFolder%\S\default-user-startup FileCopy,%PathToWHDFolder%\S\default-user-startup, %PathToWHDFolder%\S\user-startup, 1 } } FadeOutStart() WinClose, ahk_class %windowClass% return AbsoluteFromRelative(MasterPath, RelativePath) { VarSetCapacity(AbsP,260,0) DllCall( "shlwapi\PathCombineA", Str,AbsP, Str,MasterPath, Str,RelativePath ) Return AbsP } 19:39:54:032 | HL | INFO | +0 | BuildScript - Loaded Statistics.ahk script 19:39:54:032 | HL | INFO | +0 | BuildScript - Finished injecting functions into module 19:39:54:032 | HL | INFO | +0 | Main - Module is built 19:39:54:032 | HL | INFO | +0 | CheckFile - Checking if G:\Hyperspin\HyperLaunch\AutoHotkey.dll exists 19:39:54:048 | HL | DEBUG1 | +15 | CheckFile - Attributes: FileDescription AutoHotkey_H ANSI 32-bit FileVersion 1.1.09.04 InternalName AutoHotkey_H LegalCopyright Copyright (C) 2012 OriginalFilename AutoHotkey.exe ProductName AutoHotkey_H ProductVersion 1.1.09.04 File Size: 785408 bytes Created: 5/10/2014 - 7:23:05 PM Modified: 5/10/2014 - 7:23:05 PM 19:39:54:048 | HL | INFO | +0 | Main - Running module 19:39:54:048 | HL | INFO | +0 | Main - Starting timer to watch if Front End gets displaced and restore it if it does. 19:39:54:110 | MD | INFO | +N/A | Module initialized 19:39:54:110 | MD | INFO | +0 | StartModule - Started 19:39:54:110 | MD | INFO | +0 | StartModule - MEmu: WinUAE MEmuV: v2.6.0 MURL: http://www.winuae.net/ MAuthor: brolly MVersion: 2.0.2 MCRC: 2283EB17 iCRC: 587D7C70 MID: MSystem: "Commodore Amiga","Commodore Amiga CD32","Commodore CDTV","Commodore Amiga CD" 19:39:54:110 | MD | INFO | +0 | StartModule - You have a supported System Name for this module: "Commodore Amiga CD32" 19:39:54:110 | MD | DEBUG1 | +0 | StartModule - Leaving romName as is because Rom Mapping filled it with an Alternate_Rom_Name: Alien Breed '92 Special Edition & Qwak (Europe) 19:39:54:110 | MD | INFO | +0 | StartModule - Ended 19:39:54:110 | MD | INFO | +0 | Module Setting - [settings] - Fullscreen: true 19:39:54:110 | MD | INFO | +0 | Module Setting - [settings] - PathToWHDFolder: G:\Hyperspin\Emulators\WinUAE\HDD\WHD 19:39:54:110 | MD | INFO | +0 | Module Setting - [settings] - PathToWorkBenchBase: G:\Hyperspin\Emulators\WinUAE\HDD\Workbench31_Lite.vhd 19:39:54:110 | MD | INFO | +0 | Module Setting - [Alien Breed '92 Special Edition & Qwak (Europe)] - UseMouse: false 19:39:54:110 | MD | INFO | +0 | Module Setting - [Alien Breed '92 Special Edition & Qwak (Europe)] - DelayHack: false 19:39:54:110 | MD | INFO | +0 | Module Setting - [Alien Breed '92 Special Edition & Qwak (Europe)] - Options: 19:39:54:110 | MD | INFO | +0 | Module Setting - [Alien Breed '92 Special Edition & Qwak (Europe)] - VideoMode: PAL 19:39:54:110 | MD | INFO | +0 | Module Setting - [Alien Breed '92 Special Edition & Qwak (Europe)] - FloppySpeed: turbo 19:39:54:110 | MD | INFO | +0 | Module Setting - [Alien Breed '92 Special Edition & Qwak (Europe)] - QuickStartMode: 19:39:54:110 | MD | INFO | +0 | Module Setting - [Alien Breed '92 Special Edition & Qwak (Europe)] - ImmediateBlitter: false 19:39:54:110 | MD | INFO | +0 | Module Setting - [Alien Breed '92 Special Edition & Qwak (Europe)] - RequiresWB: false 19:39:54:110 | MD | INFO | +0 | Module Setting - [Alien Breed '92 Special Edition & Qwak (Europe)] - CustomWB: 19:39:54:110 | MD | INFO | +0 | Module Setting - [Alien Breed '92 Special Edition & Qwak (Europe)] - WHDLoadOptions: PRELOAD 19:39:54:110 | MD | INFO | +0 | Module Setting - [Alien Breed '92 Special Edition & Qwak (Europe)] - NeverExtract: false 19:39:54:110 | MD | INFO | +0 | Run - Running: G:\Hyperspin\Emulators\WinUAE\winuae.exe -f "G:\Hyperspin\Emulators\WinUAE\Configurations\host\cd32host.uae" -s quickstart=cd32,0 -s chipmem_size=8 -s use_gui=no -s gfx_fullscreen_amiga=true -cdimage="G:\Hyperspin\Emulators\Commodore Amiga CD32\roms\Alien Breed '92 Special Edition & Qwak (Europe)\Alien Breed '92 Special Edition & Qwak (Europe).cue" -portable 19:39:54:173 | MD | DEBUG1 | +62 | Run - "winuae.exe -f "G:\Hyperspin\Emulators\WinUAE\Configurations\host\cd32host.uae" -s quickstart=cd32,0 -s chipmem_size=8 -s use_gui=no -s gfx_fullscreen_amiga=true -cdimage="G:\Hyperspin\Emulators\Commodore Amiga CD32\roms\Alien Breed '92 Special Edition & Qwak (Europe)\Alien Breed '92 Special Edition & Qwak (Europe).cue" -portable" Process ID: 2476 19:39:54:173 | MD | DEBUG1 | +0 | GetActiveWindowStatus - Title: HyperLaunch HQ v1.0.13.0 | Class: HwndWrapper[HyperLaunchHQ.exe;;c899f684-dbb0-4a70-9307-d899fc198f7e] | State: 0 | X: 253 | Y: 0 | Width: 856 | Height: 960 | Window HWND: 0x8017c | Process ID: 876 | Process Path: G:\Hyperspin\HyperLaunch\HyperLaunchHQ\HyperLaunchHQ.exe 19:39:54:173 | MD | INFO | +0 | WinWait - Waiting for "ahk_class AmigaPowah" 19:39:55:043 | MD | DEBUG1 | +858 | GetActiveWindowStatus - Title: WinUAE | Class: AmigaPowah | State: 0 | X: 0 | Y: 0 | Width: 800 | Height: 600 | Window HWND: 0x501e0 | Process ID: 2476 | Process Path: G:\Hyperspin\Emulators\WinUAE\winuae.exe 19:39:55:043 | MD | DEBUG1 | +0 | GetActiveWindowStatus - Title: WinUAE | Class: AmigaPowah | State: 0 | X: 0 | Y: 0 | Width: 800 | Height: 600 | Window HWND: 0x501e0 | Process ID: 2476 | Process Path: G:\Hyperspin\Emulators\WinUAE\winuae.exe 19:39:55:043 | MD | INFO | +0 | WinWaitActive - Waiting for "ahk_class AmigaPowah" 19:39:55:157 | MD | DEBUG1 | +125 | GetActiveWindowStatus - Title: WinUAE | Class: AmigaPowah | State: 0 | X: 0 | Y: 0 | Width: 800 | Height: 600 | Window HWND: 0x501e0 | Process ID: 2476 | Process Path: G:\Hyperspin\Emulators\WinUAE\winuae.exe 19:39:55:157 | MD | INFO | +0 | Process - WaitClose winuae.exe 19:40:40:473 | MD | DEBUG1 | +45303 | CloseProcess - Started, user requested to end launched application 19:40:40:595 | MD | DEBUG1 | +124 | CloseProcess - Ended 19:40:41:467 | MD | INFO | +874 | ExitModule - Started 19:40:41:467 | MD | INFO | +0 | Starting Updating Statistics: 19:40:41:467 | MD | DEBUG2 | +0 | Total Elapsed Time in Pause in seconds: 0 19:40:41:467 | MD | DEBUG2 | +0 | gameSectionStartTime:411234 19:40:41:467 | MD | DEBUG2 | +0 | ElapsedTime:47 19:40:41:467 | MD | INFO | +0 | CreateRomTable - Started 19:40:41:467 | MD | DEBUG1 | +0 | CreateRomTable - Checking for match: "Alien Breed '92 Special Edition & Qwak (Europe)" and "(Disc" 19:40:41:467 | MD | DEBUG1 | +0 | CreateRomTable - Checking for match: "Alien Breed '92 Special Edition & Qwak (Europe)" and "(Disk" 19:40:41:467 | MD | DEBUG1 | +0 | CreateRomTable - Checking for match: "Alien Breed '92 Special Edition & Qwak (Europe)" and "(Cart" 19:40:41:467 | MD | DEBUG1 | +0 | CreateRomTable - Checking for match: "Alien Breed '92 Special Edition & Qwak (Europe)" and "(Tape" 19:40:41:467 | MD | DEBUG1 | +0 | CreateRomTable - Checking for match: "Alien Breed '92 Special Edition & Qwak (Europe)" and "(Cassette" 19:40:41:467 | MD | DEBUG1 | +0 | CreateRomTable - Checking for match: "Alien Breed '92 Special Edition & Qwak (Europe)" and "(Part" 19:40:41:467 | MD | DEBUG1 | +0 | CreateRomTable - Checking for match: "Alien Breed '92 Special Edition & Qwak (Europe)" and "(Side" 19:40:41:467 | MD | INFO | +0 | CreateRomTable - Ended, 7 Loops to create table. 19:40:41:467 | MD | DEBUG2 | +0 | Statistics cleared game name: Alien Breed '92 Special Edition & Qwak 19:40:41:529 | MD | DEBUG2 | +62 | Loaded game statistics from ini files: Number_of_Times_Played: 8 Last_Time_Played: Tuesday May 13, 2014 07:28:57 PM Average_Time_Played: 15 Total_Time_Played: 120 System_Total_Played_Time: 301 Total_Global_Played_Time: 3593 19:40:41:529 | MD | DEBUG2 | +0 | Updated Statistics: Number_of_Times_Played: 9 Last_Time_Played: Tuesday May 13, 2014 07:39:54 PM Average_Time_Played: 19 Total_Time_Played: 167 System_Total_Played_Time: 348 Total_Global_Played_Time: 3640 19:40:41:545 | MD | INFO | +16 | Game section statistics updated. 19:40:41:545 | MD | INFO | +0 | ExitModule - Ended 19:40:41:545 | MD | INFO | +0 | End of Module Logs 19:40:41:576 | HL | INFO | +47518 | Main - Module ended, exiting HyperLaunch normally 19:40:41:576 | HL | INFO | +0 | ExitScript - Started 19:40:41:576 | HL | INFO | +0 | SystemCursor - Restoring mouse cursor 19:40:41:592 | HL | INFO | +16 | ExitScript - Ended Like I said they work fine from WinUAE, when I mount the image directly and run, but not from Hyperlaunch. Hopefully my log will shed some light on this. Many thanks
rfancella Posted May 13, 2014 Author Posted May 13, 2014 Thanks Ron, see below.Like I said they work fine from WinUAE, when I mount the image directly and run, but not from Hyperlaunch. Hopefully my log will shed some light on this. Many thanks Tim, This all looks good. As I said before, the WinUAE module loads the cue file directly into the emulator without mounting it. So your run command passed is: G:\Hyperspin\Emulators\WinUAE\winuae.exe -f "G:\Hyperspin\Emulators\WinUAE\Configurations\host\cd32host.uae" -s quickstart=cd32,0 -s chipmem_size=8 -s use_gui=no -s gfx_fullscreen_amiga=true -cdimage="G:\Hyperspin\Emulators\Commodore Amiga CD32\roms\Alien Breed '92 Special Edition & Qwak (Europe)\Alien Breed '92 Special Edition & Qwak (Europe).cue" -portable Can you copy and paste that into a command line and see if it runs or not? If it doesn't, please post your winuaelog.txt Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
clownstyle Posted May 13, 2014 Posted May 13, 2014 Can you copy and paste that into a command line and see if it runs or not? If it doesn't, please post your winuaelog.txt Thanks, Ron The command line launches winuae, but again just sits at cd32 boot screen awaiting cd WinUAE 2.6.1 (2013.06.19) (6.1 Service Pack 1 [2]) 64-bit 9.6.3C03 4 10:31 (c) 1995-2001 Bernd Schmidt - Core UAE concept and implementation. (c) 1998-2013 Toni Wilen - Win32 port, core code updates. (c) 1996-2001 Brian King - Win32 port, Picasso96 RTG, and GUI. (c) 1996-1999 Mathias Ortmann - Win32 port and bsdsocket support. (c) 2000-2001 Bernd Meyer - JIT engine. (c) 2000-2005 Bernd Roesch - MIDI input, many fixes. Press F12 to show the Settings Dialog (GUI), Alt-F4 to quit. End+F1 changes floppy 0, End+F2 changes floppy 1, etc. 'G:\Hyperspin\Emulators\WinUAE\winuae.exe' EXE: 'G:\Hyperspin\Emulators\WinUAE\', DATA: 'G:\Hyperspin\Emulators\WinUAE\', PLUGIN: 'G:\Hyperspin\Emulators\WinUAE\' WARNING: Unsupported 'G:\Hyperspin\Emulators\WinUAE\winuae.ini' enabled Total physical RAM 16272M, all RAM 30029M. Attempting to reserve: 2049M. Reserved: 0x87EB0000-0xFFFB0000 (78100000 1921M) CLOCKFREQ: QPF 3.31MHz (3.31MHz, DIV=1) ROM KEY 'G:\Hyperspin\Emulators\WinUAE\Roms\rom.key' 750 bytes loaded Enumerating display devices.. Sorting devices and modes.. Desktop: W=1680 H=1050 B=32. CXVS=2960 CYVS=1050 AMD Radeon HD 7900 Series '\\.\DISPLAY1' [PCI\VEN_1002&DEV_679A&SUBSYS_254C1458&REV_00] -: SyncMaster 2232BW/2232GW/2232GW Plus,SyncMaster Magic CX2232GW(Digital) (1680*1050) * [\Registry\Machine\System\CurrentControlSet\Control\Class\{4d36e96e-e325-11ce-bfc1-08002be10318}\0001] 0: 640x480, 16-bit (59,60,67,72,75) 1: 640x480, 32-bit (59,60,67,72,75) 2: 720x480, 16-bit (56,!59,60,72,75) 3: 720x480, 32-bit (56,!59,60,72,75) 4: 720x576, 16-bit (!50,56,60,72,75) 5: 720x576, 32-bit (!50,56,60,72,75) 6: 800x600, 16-bit (56,60,72,75) 7: 800x600, 32-bit (56,60,72,75) 8: 1024x768, 16-bit (60,70,75) 9: 1024x768, 32-bit (60,70,75) 10: 1152x864, 16-bit (60,75) 11: 1152x864, 32-bit (60,75) 12: 1280x720, 16-bit (!50,59,60) 13: 1280x720, 32-bit (!50,59,60) 14: 1280x768, 16-bit (60) 15: 1280x768, 32-bit (60) 16: 1280x800, 16-bit (60) 17: 1280x800, 32-bit (60) 18: 1280x960, 16-bit (60) 19: 1280x960, 32-bit (60) 20: 1280x1024, 16-bit (60,75) 21: 1280x1024, 32-bit (60,75) 22: 1360x768, 16-bit (60) 23: 1360x768, 32-bit (60) 24: 1360x1024, 16-bit (60) 25: 1360x1024, 32-bit (60) 26: 1366x768, 16-bit (60) 27: 1366x768, 32-bit (60) 28: 1440x900, 16-bit (60) 29: 1440x900, 32-bit (60) 30: 1680x1050, 16-bit (60) 31: 1680x1050, 32-bit (60) 32: !1920x1080, 16-bit (!25i,!29i,!30i,!50,!59,!60) 33: !1920x1080, 32-bit (!25i,!29i,!30i,!50,!59,!60) 34 display modes. AMD Radeon HD 7900 Series '\\.\DISPLAY2' [PCI\VEN_1002&DEV_679A&SUBSYS_254C1458&REV_00] -: ACER AL1916 (1280*1024) [1680*0] [\Registry\Machine\System\CurrentControlSet\Control\Class\{4d36e96e-e325-11ce-bfc1-08002be10318}\0004] 0: 640x480, 16-bit (60,67,72,75) 1: 640x480, 32-bit (60,67,72,75) 2: 720x480, 16-bit (56,!59,60,72,75) 3: 720x480, 32-bit (56,!59,60,72,75) 4: 720x576, 16-bit (!50,56,60,72,75) 5: 720x576, 32-bit (!50,56,60,72,75) 6: 800x600, 16-bit (56,60,72,75) 7: 800x600, 32-bit (56,60,72,75) 8: 1024x768, 16-bit (60,70,75) 9: 1024x768, 32-bit (60,70,75) 10: 1280x720, 16-bit (!50,59,60,75) 11: 1280x720, 32-bit (!50,59,60,75) 12: 1280x768, 16-bit (60,75) 13: 1280x768, 32-bit (60,75) 14: 1280x800, 16-bit (60,75) 15: 1280x800, 32-bit (60,75) 16: 1280x960, 16-bit (60,75) 17: 1280x960, 32-bit (60,75) 18: 1280x1024, 16-bit (60,75) 19: 1280x1024, 32-bit (60,75) 20: !1920x1080i, 16-bit (!25i,!29i,!30i) 21: !1920x1080i, 32-bit (!25i,!29i,!30i) 22 display modes. Display buffer mode = 1 Enumerating DirectSound devices.. Enumerating WASAPI devices... Enumeration end 0:DS: Primary Sound Driver 1:DS: Multichannel (M-Audio Delta Audiophile) 2:DS: Speakers (Realtek High Definition Audio) 3:DS: S/PDIF (M-Audio Delta Audiophile) 4:DS: Line 1/2 (M-Audio Delta Audiophile) 5:DS: Realtek Digital Output (Realtek High Definition Audio) 6:WA: Default Audio Device 7:WA: Multichannel (M-Audio Delta Audiophile) 8:WA: Speakers (Realtek High Definition Audio) 9:WA: S/PDIF (M-Audio Delta Audiophile) 10:WA: Line 1/2 (M-Audio Delta Audiophile) 11:WA: Realtek Digital Output (Realtek High Definition Audio) 12:WX: Default Audio Device 13:WX: Multichannel (M-Audio Delta Audiophile) 14:WX: Speakers (Realtek High Definition Audio) 15:WX: S/PDIF (M-Audio Delta Audiophile) 16:WX: Line 1/2 (M-Audio Delta Audiophile) 17:WX: Realtek Digital Output (Realtek High Definition Audio) Enumerating recording devices: 0:DS: Primary Sound Capture Driver 1:DS: Microphone (2- USB Audio Device) 2:DS: Realtek Digital Input (Realtek High Definition Audio) done Filesystem charset (ACP=1252,FSCP=28605): 00: 0000 01: 0001 02: 0002 03: 0003 04: 0004 05: 0005 06: 0006 07: 0007 08: 0008 09: 0009 0A: 000A 0B: 000B 0C: 000C 0D: 000D 0E: 000E 0F: 000F 10: 0010 11: 0011 12: 0012 13: 0013 14: 0014 15: 0015 16: 0016 17: 0017 18: 0018 19: 0019 1A: 001A 1B: 001B 1C: 001C 1D: 001D 1E: 001E 1F: 001F 20: 0020 21: 0021 22: 0022 23: 0023 24: 0024 25: 0025 26: 0026 27: 0027 28: 0028 29: 0029 2A: 002A 2B: 002B 2C: 002C 2D: 002D 2E: 002E 2F: 002F 30: 0030 31: 0031 32: 0032 33: 0033 34: 0034 35: 0035 36: 0036 37: 0037 38: 0038 39: 0039 3A: 003A 3B: 003B 3C: 003C 3D: 003D 3E: 003E 3F: 003F 40: 0040 41: 0041 42: 0042 43: 0043 44: 0044 45: 0045 46: 0046 47: 0047 48: 0048 49: 0049 4A: 004A 4B: 004B 4C: 004C 4D: 004D 4E: 004E 4F: 004F 50: 0050 51: 0051 52: 0052 53: 0053 54: 0054 55: 0055 56: 0056 57: 0057 58: 0058 59: 0059 5A: 005A 5B: 005B 5C: 005C 5D: 005D 5E: 005E 5F: 005F 60: 0060 61: 0061 62: 0062 63: 0063 64: 0064 65: 0065 66: 0066 67: 0067 68: 0068 69: 0069 6A: 006A 6B: 006B 6C: 006C 6D: 006D 6E: 006E 6F: 006F 70: 0070 71: 0071 72: 0072 73: 0073 74: 0074 75: 0075 76: 0076 77: 0077 78: 0078 79: 0079 7A: 007A 7B: 007B 7C: 007C 7D: 007D 7E: 007E 7F: 007F 80: 20AC (0080) 81: 0081 82: 201A (0082) 83: 0192 (0083) 84: 201E (0084) 85: 2026 (0085) 86: 2020 (0086) 87: 2021 (0087) 88: 02C6 (0088) 89: 2030 (0089) 8A: 0160 (008A) 8B: 2039 (008B) 8C: 0152 (008C) 8D: 008D 8E: 017D (008E) 8F: 008F 90: 0090 91: 2018 (0091) 92: 2019 (0092) 93: 201C (0093) 94: 201D (0094) 95: 2022 (0095) 96: 2013 (0096) 97: 2014 (0097) 98: 02DC (0098) 99: 2122 (0099) 9A: 0161 (009A) 9B: 203A (009B) 9C: 0153 (009C) 9D: 009D 9E: 017E (009E) 9F: 0178 (009F) A0: 00A0 A1: 00A1 A2: 00A2 A3: 00A3 A4: 00A4 (20AC) A5: 00A5 A6: 00A6 (0160) A7: 00A7 A8: 00A8 (0161) A9: 00A9 AA: 00AA AB: 00AB AC: 00AC AD: 00AD AE: 00AE AF: 00AF B0: 00B0 B1: 00B1 B2: 00B2 B3: 00B3 B4: 00B4 (017D) B5: 00B5 B6: 00B6 B7: 00B7 B8: 00B8 (017E) B9: 00B9 BA: 00BA BB: 00BB BC: 00BC (0152) BD: 00BD (0153) BE: 00BE (0178) BF: 00BF C0: 00C0 C1: 00C1 C2: 00C2 C3: 00C3 C4: 00C4 C5: 00C5 C6: 00C6 C7: 00C7 C8: 00C8 C9: 00C9 CA: 00CA CB: 00CB CC: 00CC CD: 00CD CE: 00CE CF: 00CF D0: 00D0 D1: 00D1 D2: 00D2 D3: 00D3 D4: 00D4 D5: 00D5 D6: 00D6 D7: 00D7 D8: 00D8 D9: 00D9 DA: 00DA DB: 00DB DC: 00DC DD: 00DD DE: 00DE DF: 00DF E0: 00E0 E1: 00E1 E2: 00E2 E3: 00E3 E4: 00E4 E5: 00E5 E6: 00E6 E7: 00E7 E8: 00E8 E9: 00E9 EA: 00EA EB: 00EB EC: 00EC ED: 00ED EE: 00EE EF: 00EF F0: 00F0 F1: 00F1 F2: 00F2 F3: 00F3 F4: 00F4 F5: 00F5 F6: 00F6 F7: 00F7 F8: 00F8 F9: 00F9 FA: 00FA FB: 00FB FC: 00FC FD: 00FD FE: 00FE FF: 00FF End CW: No Catweasel detected PARAPORT: no ParaPort.dll, direct parallel port emulation disabled IPC: Named Pipe '\\.\pipe\WinUAE' open IPC: Named Pipe '\\.\pipe\WinUAE_COM' open Serial port enumeration.. SERPORT: 'Communications Port (COM1)' = 'COM1' = '\\?\acpi#pnp0501#1#{86e0d1e0-8089-11d0-9ce4-08003e301f73}' Parallel port enumeration.. PARPORT: 'Printer Port (LPT1)' = 'LPT1' = '\\?\acpi#pnp0400#4&34575efb&0#{97f76ef0-f883-11d0-af1f-0000f800845c}' Port enumeration end MIDI port enumeration.. MIDI OUT: -1:'Microsoft MIDI Mapper' (1/1) MIDI OUT: 0:'Microsoft GS Wavetable Synth' (1/27) MIDI OUT: 1:'Delta AP MIDI' (239/65535) MIDI IN: 0:'Delta AP MIDI' (239/65535) MIDI port enumeration end RawInput enumeration.. RAWINPUT: found 11 devices 00010047 hid: '\\?\HID#VID_045E&PID_02A1&IG_00#8&2975e72e&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}' 00010043 keyboard: '\\?\HID#Vid_1038&Pid_1000&Rev_0100&MI_00#3&30f5259a&0&0000#{884b96c3-56ef-11d1-bc8c-00a0c91405dd}' type=81 sub=0 mode=1 fkeys=12 indicators=3 tkeys=154 000B0041 keyboard: '\\?\HID#VID_04F2&PID_0402&MI_00#7&209880cd&0&0000#{884b96c3-56ef-11d1-bc8c-00a0c91405dd}' type=81 sub=0 mode=1 fkeys=12 indicators=3 tkeys=264 0001003D mouse: '\\?\HID#VID_1038&PID_1364&MI_01#7&e8a936f&0&0000#{378de44c-56ef-11d1-bc8c-00a0c91405dd}' id=256 buttons=5 hw=0 rate=0 000B003B mouse: '\\?\HID#Vid_1038&Pid_1000&Rev_0100&MI_02#3&24e1741d&0&0000#{378de44c-56ef-11d1-bc8c-00a0c91405dd}' id=256 buttons=5 hw=0 rate=0 'HID-compliant mouse' ('\\?\HID#Vid_1038&Pid_1000&Rev_0100&MI_02#3&24e1741d&0&0000#{378de44c-56ef-11d1-bc8c-00a0c91405dd}') 'HID-compliant mouse' ('\\?\HID#VID_1038&PID_1364&MI_01#7&e8a936f&0&0000#{378de44c-56ef-11d1-bc8c-00a0c91405dd}') 'HID Keyboard Device' ('\\?\HID#VID_04F2&PID_0402&MI_00#7&209880cd&0&0000#{884b96c3-56ef-11d1-bc8c-00a0c91405dd}') 'HID Keyboard Device' ('\\?\HID#Vid_1038&Pid_1000&Rev_0100&MI_00#3&30f5259a&0&0000#{884b96c3-56ef-11d1-bc8c-00a0c91405dd}') HID-compliant mouse: (1038/1364) 00 000 'X Axis' (0, [0 - 0, 0 - 0, 0 0 0]) 01 001 'Y Axis' (1, [0 - 0, 0 - 0, 0 0 0]) 02 002 'Wheel' (2, [0 - 0, 0 - 0, 0 0 0]) 03 003 'HWheel' (3, [0 - 0, 0 - 0, 0 0 0]) 00 000 'Button 1' (0) 01 001 'Button 2' (1) 02 002 'Button 3' (2) 03 003 'Button 4' (3) 04 004 'Button 5' (4) 02 002 'Wheel [-]' (1004) 02 002 'Wheel [+]' (1005) 03 003 'HWheel [-]' (1006) 03 003 'HWheel [+]' (1007) HID-compliant mouse: (1038/1000) 00 000 'X Axis' (0, [0 - 0, 0 - 0, 0 0 0]) 01 001 'Y Axis' (1, [0 - 0, 0 - 0, 0 0 0]) 02 002 'Wheel' (2, [0 - 0, 0 - 0, 0 0 0]) 03 003 'HWheel' (3, [0 - 0, 0 - 0, 0 0 0]) 00 000 'Button 1' (0) 01 001 'Button 2' (1) 02 002 'Button 3' (2) 03 003 'Button 4' (3) 04 004 'Button 5' (4) 02 002 'Wheel [-]' (1004) 02 002 'Wheel [+]' (1005) 03 003 'HWheel [-]' (1006) 03 003 'HWheel [+]' (1007) RAWINPUT test ok, usage=2 RAWINPUT test ok, usage=6 DirectInput enumeration.. Game controllers.. I={6AB74C20-11E4-11E3-8001-444553540000} P={02A1045E-0000-0000-0000-504944564944} 'Controller (Xbox 360 Wireless Receiver for Windows)' 'Controller (Xbox 360 Wireless Receiver for Windows)' 00010215 [Game controller] Windowsmouse initialization.. Catweasel joymouse initialization.. wintab tablet initialization.. Tablet: no wintab32.dll end Controller (Xbox 360 Wireless Receiver for Windows): (0000/0000) PGUID={02A1045E-0000-0000-0000-504944564944} 00 000 'X Axis' (-99, [0 - 0, 0 - 0, 0 0 0]) 04 004 'Y Axis' (-98, [0 - 0, 0 - 0, 0 0 0]) 08 008 'Z Axis' (-97, [0 - 0, 0 - 0, 0 0 0]) 0C 012 'X Rotation' (-89, [0 - 0, 0 - 0, 0 0 0]) 10 016 'Y Rotation' (-88, [0 - 0, 0 - 0, 0 0 0]) 20 032 'Hat Switch (X)' (-69, [0 - 0, 0 - 0, 0 0 0]) 20 032 'Hat Switch (Y)' (-69, [0 - 0, 0 - 0, 0 0 0]) 30 048 'Button 0' (48) 31 049 'Button 1' (49) 32 050 'Button 2' (50) 33 051 'Button 3' (51) 34 052 'Button 4' (52) 35 053 'Button 5' (53) 36 054 'Button 6' (54) 37 055 'Button 7' (55) 38 056 'Button 8' (56) 39 057 'Button 9' (57) 00 000 'X Axis [-]' (1000) 00 000 'X Axis [+]' (1001) 04 004 'Y Axis [-]' (1008) 04 004 'Y Axis [+]' (1009) 08 008 'Z Axis [-]' (1016) 08 008 'Z Axis [+]' (1017) 0C 012 'X Rotation [-]' (1024) 0C 012 'X Rotation [+]' (1025) 10 016 'Y Rotation [-]' (1032) 10 016 'Y Rotation [+]' (1033) 20 032 'Hat Switch (X) [-]' (1066) 20 032 'Hat Switch (X) [+]' (1067) 20 032 'Hat Switch (Y) [-]' (1068) 20 032 'Hat Switch (Y) [+]' (1069) load config '.\Configurations\default.uae':0 load failed failed to load config '.\Configurations\default.uae' LCD: Logitech LCD system not detected GUIBase 803x590 (6x13) '.\Configurations\configuration.cache' loaded successfully Entering GUI idle loop Requested GUI size = 800x600 (720x568) Got GUI size = 800x598 '.\Configurations\configuration.cache' flushed '.\Configurations\configuration.cache' load failed '.\Configurations\configuration.cache' flushed '.\Configurations\configuration.cache' created Something tells me it's still looking for a default config file? Even though we did specify this in the cmd prompt!?
rfancella Posted May 13, 2014 Author Posted May 13, 2014 The command line launches winuae, but again just sits at cd32 boot screen awaiting cd Something tells me it's still looking for a default config file? Even though we did specify this in the cmd prompt!? Tim, That load config - load failed - failed to load config is normal. The config is passed through the command line as cd32host.uae. So it doesn't need a default config. I think there is an issue with your os or boot roms. Just reaching here, but my log shows very similar to yours: WinUAE 2.6.1 (2013.06.19) (6.0 Service Pack 2 [2]) 64-bit 9.6.F0B 2 16:21 (c) 1995-2001 Bernd Schmidt - Core UAE concept and implementation. (c) 1998-2013 Toni Wilen - Win32 port, core code updates. (c) 1996-2001 Brian King - Win32 port, Picasso96 RTG, and GUI. (c) 1996-1999 Mathias Ortmann - Win32 port and bsdsocket support. (c) 2000-2001 Bernd Meyer - JIT engine. (c) 2000-2005 Bernd Roesch - MIDI input, many fixes. Press F12 to show the Settings Dialog (GUI), Alt-F4 to quit. End+F1 changes floppy 0, End+F2 changes floppy 1, etc. 'H:\HyperSpin\Emulators\WinUAE\winuae.exe' EXE: 'H:\HyperSpin\Emulators\WinUAE\', DATA: 'H:\HyperSpin\Emulators\WinUAE\', PLUGIN: 'H:\HyperSpin\Emulators\WinUAE\' WARNING: Unsupported 'H:\HyperSpin\Emulators\WinUAE\winuae.ini' enabled Total physical RAM 4093M, all RAM 7829M. Attempting to reserve: 2049M. Reserved: 0x87EB0000-0xFFFB0000 (78100000 1921M) CLOCKFREQ: QPF 25.00MHz (6.25MHz, DIV=4) ROM KEY 'C:\Program Files (x86)\Cloanto\Amiga Forever\Player\amigaforever.dll' 1544 bytes loaded Enumerating display devices.. Sorting devices and modes.. Desktop: W=1680 H=1050 B=32. CXVS=3360 CYVS=1050 NVIDIA GeForce GTX 260 '\\.\DISPLAY1' [PCI\VEN_10DE&DEV_05E2&SUBSYS_00000000&REV_A1] -: Generic PnP Monitor (1680*1050) [1680*0] [\Registry\Machine\System\CurrentControlSet\Control\Class\{4d36e96e-e325-11ce-bfc1-08002be10318}\0006] 0: 640x480, 16-bit (60,72,75) 1: 640x480, 32-bit (60,72,75) 2: 720x480, 16-bit (56,!59,60,72,75) 3: 720x480, 32-bit (56,!59,60,72,75) 4: 720x576, 16-bit (!50,56,60,72,75) 5: 720x576, 32-bit (!50,56,60,72,75) 6: 800x600, 16-bit (56,60,72,75) 7: 800x600, 32-bit (56,60,72,75) 8: 1024x768, 16-bit (60,70,75) 9: 1024x768, 32-bit (60,70,75) 10: 1152x864, 16-bit (75) 11: 1152x864, 32-bit (75) 12: 1280x720, 16-bit (!50,59,60) 13: 1280x720, 32-bit (!50,59,60) 14: 1280x768, 16-bit (60) 15: 1280x768, 32-bit (60) 16: 1280x800, 16-bit (60) 17: 1280x800, 32-bit (60) 18: 1280x960, 16-bit (60) 19: 1280x960, 32-bit (60) 20: 1280x1024, 16-bit (60,75) 21: 1280x1024, 32-bit (60,75) 22: 1360x765, 16-bit (59,60) 23: 1360x765, 32-bit (59,60) 24: 1360x768, 16-bit (59,60) 25: 1360x768, 32-bit (59,60) 26: 1440x900, 16-bit (59,60) 27: 1440x900, 32-bit (59,60) 28: 1600x900, 16-bit (59,60) 29: 1600x900, 32-bit (59,60) 30: 1600x1024, 16-bit (59,60) 31: 1600x1024, 32-bit (59,60) 32: 1680x1050, 16-bit (59,60) 33: 1680x1050, 32-bit (59,60) 34: !1920x1080i, 16-bit (!25i,!29i,!30i) 35: !1920x1080i, 32-bit (!25i,!29i,!30i) 36 display modes. NVIDIA GeForce GTX 260 '\\.\DISPLAY2' [PCI\VEN_10DE&DEV_05E2&SUBSYS_00000000&REV_A1] -: Generic PnP Monitor (1680*1050) * [\Registry\Machine\System\CurrentControlSet\Control\Class\{4d36e96e-e325-11ce-bfc1-08002be10318}\0005] 0: 640x480, 16-bit (60,72,75) 1: 640x480, 32-bit (60,72,75) 2: 720x480, 16-bit (56,60,72,75) 3: 720x480, 32-bit (56,60,72,75) 4: 720x576, 16-bit (56,60,72,75) 5: 720x576, 32-bit (56,60,72,75) 6: 800x600, 16-bit (56,60,72,75) 7: 800x600, 32-bit (56,60,72,75) 8: 1024x768, 16-bit (60,70,75) 9: 1024x768, 32-bit (60,70,75) 10: 1152x864, 16-bit (75) 11: 1152x864, 32-bit (75) 12: 1280x720, 16-bit (60) 13: 1280x720, 32-bit (60) 14: 1280x768, 16-bit (60) 15: 1280x768, 32-bit (60) 16: 1280x800, 16-bit (60) 17: 1280x800, 32-bit (60) 18: 1280x960, 16-bit (60) 19: 1280x960, 32-bit (60) 20: 1280x1024, 16-bit (60,75) 21: 1280x1024, 32-bit (60,75) 22: 1360x765, 16-bit (60) 23: 1360x765, 32-bit (60) 24: 1360x768, 16-bit (60,75) 25: 1360x768, 32-bit (60,75) 26: 1440x900, 16-bit (60,75) 27: 1440x900, 32-bit (60,75) 28: 1600x900, 16-bit (59,60) 29: 1600x900, 32-bit (59,60) 30: 1600x1024, 16-bit (59,60) 31: 1600x1024, 32-bit (59,60) 32: 1680x1050, 16-bit (59,60) 33: 1680x1050, 32-bit (59,60) 34 display modes. Display buffer mode = 1 Enumerating DirectSound devices.. Enumerating WASAPI devices... Enumeration end 0:DS: Primary Sound Driver 1:DS: Speakers (SoundMAX Integrated Digital HD Audio) 2:DS: SPDIF Interface (SoundMAX Integrated Digital HD Audio) 3:WA: Default Audio Device 4:WA: SPDIF Interface (SoundMAX Integrated Digital HD Audio) 5:WA: Speakers (SoundMAX Integrated Digital HD Audio) 6:WX: Default Audio Device 7:WX: SPDIF Interface (SoundMAX Integrated Digital HD Audio) 8:WX: Speakers (SoundMAX Integrated Digital HD Audio) Enumerating recording devices: 0:DS: Primary Sound Capture Driver 1:DS: Microphone (SoundMAX Integrated Digital HD Audio) 2:DS: Line In (SoundMAX Integrated Digital HD Audio) done Filesystem charset (ACP=1252,FSCP=28605): 00: 0000 01: 0001 02: 0002 03: 0003 04: 0004 05: 0005 06: 0006 07: 0007 08: 0008 09: 0009 0A: 000A 0B: 000B 0C: 000C 0D: 000D 0E: 000E 0F: 000F 10: 0010 11: 0011 12: 0012 13: 0013 14: 0014 15: 0015 16: 0016 17: 0017 18: 0018 19: 0019 1A: 001A 1B: 001B 1C: 001C 1D: 001D 1E: 001E 1F: 001F 20: 0020 21: 0021 22: 0022 23: 0023 24: 0024 25: 0025 26: 0026 27: 0027 28: 0028 29: 0029 2A: 002A 2B: 002B 2C: 002C 2D: 002D 2E: 002E 2F: 002F 30: 0030 31: 0031 32: 0032 33: 0033 34: 0034 35: 0035 36: 0036 37: 0037 38: 0038 39: 0039 3A: 003A 3B: 003B 3C: 003C 3D: 003D 3E: 003E 3F: 003F 40: 0040 41: 0041 42: 0042 43: 0043 44: 0044 45: 0045 46: 0046 47: 0047 48: 0048 49: 0049 4A: 004A 4B: 004B 4C: 004C 4D: 004D 4E: 004E 4F: 004F 50: 0050 51: 0051 52: 0052 53: 0053 54: 0054 55: 0055 56: 0056 57: 0057 58: 0058 59: 0059 5A: 005A 5B: 005B 5C: 005C 5D: 005D 5E: 005E 5F: 005F 60: 0060 61: 0061 62: 0062 63: 0063 64: 0064 65: 0065 66: 0066 67: 0067 68: 0068 69: 0069 6A: 006A 6B: 006B 6C: 006C 6D: 006D 6E: 006E 6F: 006F 70: 0070 71: 0071 72: 0072 73: 0073 74: 0074 75: 0075 76: 0076 77: 0077 78: 0078 79: 0079 7A: 007A 7B: 007B 7C: 007C 7D: 007D 7E: 007E 7F: 007F 80: 20AC (0080) 81: 0081 82: 201A (0082) 83: 0192 (0083) 84: 201E (0084) 85: 2026 (0085) 86: 2020 (0086) 87: 2021 (0087) 88: 02C6 (0088) 89: 2030 (0089) 8A: 0160 (008A) 8B: 2039 (008B) 8C: 0152 (008C) 8D: 008D 8E: 017D (008E) 8F: 008F 90: 0090 91: 2018 (0091) 92: 2019 (0092) 93: 201C (0093) 94: 201D (0094) 95: 2022 (0095) 96: 2013 (0096) 97: 2014 (0097) 98: 02DC (0098) 99: 2122 (0099) 9A: 0161 (009A) 9B: 203A (009B) 9C: 0153 (009C) 9D: 009D 9E: 017E (009E) 9F: 0178 (009F) A0: 00A0 A1: 00A1 A2: 00A2 A3: 00A3 A4: 00A4 (20AC) A5: 00A5 A6: 00A6 (0160) A7: 00A7 A8: 00A8 (0161) A9: 00A9 AA: 00AA AB: 00AB AC: 00AC AD: 00AD AE: 00AE AF: 00AF B0: 00B0 B1: 00B1 B2: 00B2 B3: 00B3 B4: 00B4 (017D) B5: 00B5 B6: 00B6 B7: 00B7 B8: 00B8 (017E) B9: 00B9 BA: 00BA BB: 00BB BC: 00BC (0152) BD: 00BD (0153) BE: 00BE (0178) BF: 00BF C0: 00C0 C1: 00C1 C2: 00C2 C3: 00C3 C4: 00C4 C5: 00C5 C6: 00C6 C7: 00C7 C8: 00C8 C9: 00C9 CA: 00CA CB: 00CB CC: 00CC CD: 00CD CE: 00CE CF: 00CF D0: 00D0 D1: 00D1 D2: 00D2 D3: 00D3 D4: 00D4 D5: 00D5 D6: 00D6 D7: 00D7 D8: 00D8 D9: 00D9 DA: 00DA DB: 00DB DC: 00DC DD: 00DD DE: 00DE DF: 00DF E0: 00E0 E1: 00E1 E2: 00E2 E3: 00E3 E4: 00E4 E5: 00E5 E6: 00E6 E7: 00E7 E8: 00E8 E9: 00E9 EA: 00EA EB: 00EB EC: 00EC ED: 00ED EE: 00EE EF: 00EF F0: 00F0 F1: 00F1 F2: 00F2 F3: 00F3 F4: 00F4 F5: 00F5 F6: 00F6 F7: 00F7 F8: 00F8 F9: 00F9 FA: 00FA FB: 00FB FC: 00FC FD: 00FD FE: 00FE FF: 00FF End CW: No Catweasel detected PARAPORT: no ParaPort.dll, direct parallel port emulation disabled IPC: Named Pipe '\\.\pipe\WinUAE' open IPC: Named Pipe '\\.\pipe\WinUAE_COM' open Serial port enumeration.. SERPORT: 'LSI PCI-SV92PP Soft Modem' = '\\?\pci#ven_11c1&dev_0620&subsys_062011c1&rev_00#4&276fbec1&0&3078#{86e0d1e0-8089-11d0-9ce4-08003e301f73}' = '\\?\pci#ven_11c1&dev_0620&subsys_062011c1&rev_00#4&276fbec1&0&3078#{86e0d1e0-8089-11d0-9ce4-08003e301f73}' SERPORT: 1:'COM3' = '\.\\COM3' (\Device\AgereModem5) Parallel port enumeration.. Port enumeration end MIDI port enumeration.. MIDI OUT: -1:'Microsoft MIDI Mapper' (1/1) MIDI OUT: 0:'Microsoft GS Wavetable Synth' (1/27) MIDI port enumeration end RawInput enumeration.. RAWINPUT: found 14 devices 1A640C49 hid: '\\?\HID#VID_046D&PID_C216#6&239d3685&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}' 0001006B keyboard: '\\?\HID#VID_045E&PID_00DB&MI_00#7&1875a9&0&0000#{884b96c3-56ef-11d1-bc8c-00a0c91405dd}' type=81 sub=0 mode=1 fkeys=12 indicators=3 tkeys=154 00010069 keyboard: '\\?\HID#IrDevice&Col07#2&98aaa8&0&0006#{884b96c3-56ef-11d1-bc8c-00a0c91405dd}' type=7 sub=2 mode=1 fkeys=12 indicators=3 tkeys=161 00010067 keyboard: '\\?\HID#IrDevice&Col06#2&98aaa8&0&0005#{884b96c3-56ef-11d1-bc8c-00a0c91405dd}' type=81 sub=0 mode=1 fkeys=12 indicators=3 tkeys=154 00010065 keyboard: '\\?\HID#IrDevice&Col05#2&98aaa8&0&0004#{884b96c3-56ef-11d1-bc8c-00a0c91405dd}' type=81 sub=0 mode=1 fkeys=12 indicators=3 tkeys=153 0001004D mouse: '\\?\HID#VID_045E&PID_076C&Col02#6&d817960&0&0001#{378de44c-56ef-11d1-bc8c-00a0c91405dd}' id=256 buttons=5 hw=0 rate=0 0001004B mouse: '\\?\HID#IrDevice&Col08#2&98aaa8&0&0007#{378de44c-56ef-11d1-bc8c-00a0c91405dd}' id=128 buttons=2 hw=0 rate=0 'HID-compliant mouse' ('\\?\HID#IrDevice&Col08#2&98aaa8&0&0007#{378de44c-56ef-11d1-bc8c-00a0c91405dd}') 'Microsoft Comfort Mouse 4500 (IntelliPoint)' ('\\?\HID#VID_045E&PID_076C&Col02#6&d817960&0&0001#{378de44c-56ef-11d1-bc8c-00a0c91405dd}') 'Microsoft eHome Remote Control Keyboard keys' ('\\?\HID#IrDevice&Col05#2&98aaa8&0&0004#{884b96c3-56ef-11d1-bc8c-00a0c91405dd}') 'Microsoft eHome MCIR Keyboard' ('\\?\HID#IrDevice&Col06#2&98aaa8&0&0005#{884b96c3-56ef-11d1-bc8c-00a0c91405dd}') 'Microsoft eHome MCIR 109 Keyboard' ('\\?\HID#IrDevice&Col07#2&98aaa8&0&0006#{884b96c3-56ef-11d1-bc8c-00a0c91405dd}') 'Microsoft USB Natural Ergonomic Keyboard 4000 (IntelliType Pro)' ('\\?\HID#VID_045E&PID_00DB&MI_00#7&1875a9&0&0000#{884b96c3-56ef-11d1-bc8c-00a0c91405dd}') Microsoft Comfort Mouse 4500 (IntelliPoint): (045E/076C) 00 000 'X Axis' (0, [0 - 0, 0 - 0, 0 0 0]) 01 001 'Y Axis' (1, [0 - 0, 0 - 0, 0 0 0]) 02 002 'Wheel' (2, [0 - 0, 0 - 0, 0 0 0]) 03 003 'HWheel' (3, [0 - 0, 0 - 0, 0 0 0]) 00 000 'Button 1' (0) 01 001 'Button 2' (1) 02 002 'Button 3' (2) 03 003 'Button 4' (3) 04 004 'Button 5' (4) 02 002 'Wheel [-]' (1004) 02 002 'Wheel [+]' (1005) 03 003 'HWheel [-]' (1006) 03 003 'HWheel [+]' (1007) HID-compliant mouse: (FFFFFFFF/FFFFFFFF) 00 000 'X Axis' (0, [0 - 0, 0 - 0, 0 0 0]) 01 001 'Y Axis' (1, [0 - 0, 0 - 0, 0 0 0]) 02 002 'Wheel' (2, [0 - 0, 0 - 0, 0 0 0]) 03 003 'HWheel' (3, [0 - 0, 0 - 0, 0 0 0]) 00 000 'Button 1' (0) 01 001 'Button 2' (1) 02 002 'Wheel [-]' (1004) 02 002 'Wheel [+]' (1005) 03 003 'HWheel [-]' (1006) 03 003 'HWheel [+]' (1007) RAWINPUT test ok, usage=2 RAWINPUT test ok, usage=6 DirectInput enumeration.. Game controllers.. I={081EE2A0-2617-11E0-8001-444553540000} P={C216046D-0000-0000-0000-504944564944} 'Logitech Dual Action' 'Logitech Dual Action' 00010214 [Game controller] Windowsmouse initialization.. Catweasel joymouse initialization.. wintab tablet initialization.. Tablet: WTInfo() returned failure end Logitech Dual Action: (0000/0000) PGUID={C216046D-0000-0000-0000-504944564944} 00 000 'X Axis' (-99, [0 - 0, 0 - 0, 0 0 0]) 04 004 'Y Axis' (-98, [0 - 0, 0 - 0, 0 0 0]) 08 008 'Z Axis' (-97, [0 - 0, 0 - 0, 0 0 0]) 14 020 'Z Rotation' (-87, [0 - 0, 0 - 0, 0 0 0]) 20 032 'Hat Switch (X)' (-69, [0 - 0, 0 - 0, 0 0 0]) 20 032 'Hat Switch (Y)' (-69, [0 - 0, 0 - 0, 0 0 0]) 30 048 'Button 0' (48) 31 049 'Button 1' (49) 32 050 'Button 2' (50) 33 051 'Button 3' (51) 34 052 'Button 4' (52) 35 053 'Button 5' (53) 36 054 'Button 6' (54) 37 055 'Button 7' (55) 38 056 'Button 8' (56) 39 057 'Button 9' (57) 3A 058 'Button 10' (58) 3B 059 'Button 11' (59) 00 000 'X Axis [-]' (1000) 00 000 'X Axis [+]' (1001) 04 004 'Y Axis [-]' (1008) 04 004 'Y Axis [+]' (1009) 08 008 'Z Axis [-]' (1016) 08 008 'Z Axis [+]' (1017) 14 020 'Z Rotation [-]' (1040) 14 020 'Z Rotation [+]' (1041) 20 032 'Hat Switch (X) [-]' (1066) 20 032 'Hat Switch (X) [+]' (1067) 20 032 'Hat Switch (Y) [-]' (1068) 20 032 'Hat Switch (Y) [+]' (1069) load config '.\Configurations\default.uae':0 load failed failed to load config '.\Configurations\default.uae' LCD: Logitech LCD system not detected GUIBase 803x588 (6x13) '.\Configurations\configuration.cache' loaded successfully Entering GUI idle loop Requested GUI size = 800x600 (720x568) One of the following system ROMs is required: - Arcadia OnePlay 2.11 - Arcadia TenPlay 2.11 - Arcadia OnePlay 3.00 Check the System ROM path in the Paths panel and click Rescan ROMs. Got GUI size = 800x600 ROM scan directory 'H:\HyperSpin\Emulators\WinUAE\rom\' *: H:\HyperSpin\Emulators\WinUAE\rom\amiga-boot-a1000.rom:8192 = A1000 bootstrap ROM (64k) [252179-01/252180-01] CRC32=62F11C04 SHA1=C87F9FADA4EE4E69F3CCA0C36193BE822B9F5FE6 *: H:\HyperSpin\Emulators\WinUAE\rom\amiga-boot-a4091.rom:32768 = A4091 SCSI boot ROM (32k) [391592-02] CRC32=54CB9E85 SHA1=3CE66919F6FD67974923A12D91B730F1FFB4A7BA *: H:\HyperSpin\Emulators\WinUAE\rom\amiga-boot-a590.rom:16384 = A590/A2091 SCSI boot ROM (16k) [390722-03/390721-03] CRC32=714A97A2 SHA1=E50F01BAF28998928554786372A82C333C91276E *: H:\HyperSpin\Emulators\WinUAE\rom\amiga-crt-310-cd32-fmv.rom:262144 = CD32 MPEG Cartridge ROM rev 40.30 (256k) CRC32=C35C37BF SHA1=03CA81C7A7B259CF64BC9582863ECA0F6529F435 !: Name='H:\HyperSpin\Emulators\WinUAE\rom\amiga-os-070.rom':262144 CRC32=10CC650F SHA1=4E2EE86C5675312EC4319BC694BDCABC81897E46 *: H:\HyperSpin\Emulators\WinUAE\rom\amiga-os-100.rom:262144 = KS ROM v1.0 (A1000)(NTSC) (256k) CRC32=299790FF SHA1=00C15406BEB4B8AB1A16AA66C05860E1A7C1AD79 *: H:\HyperSpin\Emulators\WinUAE\rom\amiga-os-110.rom:262144 = KS ROM v1.1 (A1000)(PAL) rev 31.34 (256k) CRC32=EC86DAE2 SHA1=16DF8B5FD524C5A1C7584B2457AC15AFF9E3AD6D *: H:\HyperSpin\Emulators\WinUAE\rom\amiga-os-120.rom:262144 = KS ROM v1.2 (A500,A1000,A2000) rev 33.180 (256k) [315093-01] CRC32=A6CE1636 SHA1=11F9E62CF299F72184835B7B2A70A16333FC0D88 *: H:\HyperSpin\Emulators\WinUAE\rom\amiga-os-130-cdtv-ext.rom:262144 = CDTV extended ROM v1.00 (256k) [252606-01/252607-01] CRC32=42BAA124 SHA1=7BA40FFA17E500ED9FED041F3424BD81D9C907BE *: H:\HyperSpin\Emulators\WinUAE\rom\amiga-os-130.rom:262144 = KS ROM v1.3 (A3000)(SK) rev 34.5 (256k) CRC32=E0F37258 SHA1=C39BD9094D4E5F4E28C1411F3086950406062E87 *: H:\HyperSpin\Emulators\WinUAE\rom\amiga-os-140-a3000.rom:524288 = KS ROM v1.4 (A3000) rev 36.16 (512k) [390629-02/390630-02] CRC32=BC0EC13F SHA1=F76316BF36DFF14B20FA349ED02E4B11DD932B07 *: H:\HyperSpin\Emulators\WinUAE\rom\amiga-os-204.rom:524288 = KS ROM v2.04 (A500+) rev 37.175 (512k) [390979-01] CRC32=C3BDB240 SHA1=C5839F5CB98A7A8947065C3ED2F14F5F42E334A1 *: H:\HyperSpin\Emulators\WinUAE\rom\amiga-os-205.rom:524288 = KS ROM v2.05 (A600HD) rev 37.350 (512k) [391304-02] CRC32=43B0DF7B SHA1=02843C4253BBD29ABA535B0AA3BD9A85034ECDE4 *: H:\HyperSpin\Emulators\WinUAE\rom\amiga-os-300.rom:524288 = KS ROM v3.0 (A4000) rev 39.106 (512k) [391513-02/391514-02] CRC32=9E6AC152 SHA1=F0B4E9E29E12218C2D5BD7020E4E785297D91FD7 *: H:\HyperSpin\Emulators\WinUAE\rom\amiga-os-310-a1200.rom:524288 = KS ROM v3.1 (A1200) rev 40.68 (512k) [391773-01/391774-01] CRC32=1483A091 SHA1=E21545723FE8374E91342617604F1B3D703094F1 *: H:\HyperSpin\Emulators\WinUAE\rom\amiga-os-310-a3000.rom:524288 = KS ROM v3.1 (A3000) rev 40.68 (512k) CRC32=EFB239CC SHA1=F8E210D72B4C4853E0C9B85D223BA20E3D1B36EE *: H:\HyperSpin\Emulators\WinUAE\rom\amiga-os-310-a4000.rom:524288 = KS ROM v3.1 (A4000)(Cloanto) rev 40.68 (512k) CRC32=43B6DD22 SHA1=C3C481160866E60D085E436A24DB3617FF60B5F9 *: H:\HyperSpin\Emulators\WinUAE\rom\amiga-os-310-a500.rom:524288 = KS ROM v3.1 (A500,A600,A2000) rev 40.63 (512k) CRC32=FC24AE0D SHA1=3B7F1493B27E212830F989F26CA76C02049F09CA *: H:\HyperSpin\Emulators\WinUAE\rom\amiga-os-310-cd32-ext.rom:524288 = CD32 extended ROM rev 40.60 (512k) CRC32=87746BE2 SHA1=5BEF3D628CE59CC02A66E6E4AE0DA48F60E78F7F *: H:\HyperSpin\Emulators\WinUAE\rom\amiga-os-310-cd32.rom:524288 = CD32 KS ROM v3.1 rev 40.60 (512k) CRC32=1E62D4A5 SHA1=3525BE8887F79B5929E017B42380A79EDFEE542D !: Name='H:\HyperSpin\Emulators\WinUAE\rom\amiga-os-320-walker.rom':524288 CRC32=571662C0 SHA1=E898F4264E0865BB89B389F2A611C34AE9EB461A *: H:\HyperSpin\Emulators\WinUAE\rom\amiga-os-3x0-a4000.rom:524288 = KS ROM v3.X (A4000)(Cloanto) rev 45.57 (512k) CRC32=3AC99EDC SHA1=3CBFC9E1FE396360157BD161DE74FC901ABEE7EC !: Name='H:\HyperSpin\Emulators\WinUAE\rom\aros-20130502-ext.rom':524288 CRC32=03BFA98A SHA1=C3DC1E11D9CF65CC823B93946CDE147371C7E0A9 !: Name='H:\HyperSpin\Emulators\WinUAE\rom\aros-20130502.rom':524288 CRC32=B3048BE6 SHA1=65B686C57CEB32130501EDD19F71E0F8E3BBC838 *: H:\HyperSpin\Emulators\WinUAE\rom\logica-dialoga-200.rom:524288 = The Diagnostic 2.0 (Logica) (512k) CRC32=8484F426 SHA1=BA10D16166B2E2D6177C979C99EDF8462B21651E *: H:\HyperSpin\Emulators\WinUAE\rom\rom.key:1544 = Cloanto Amiga Forever 2010 ROM key (2k) CRC32=8C4DD05C SHA1=05034F620B5BB7B286954EA9164FDB90FB2897A4 Scan of ROMs finished A500 Boot ROM 1.2: available A500 Boot ROM 1.3: available A500+: available A600: available A1000: available A1200: available A3000: available A4000: available CD32: available CDTV: available Arcadia Multi Select: unavailable High end WinUAE: available A590/A2091 SCSI Boot ROM: available load config 'H:\HyperSpin\Emulators\WinUAE\Configurations\Host\amigahost.uae':0 ROM scan directory 'H:\HyperSpin\Emulators\WinUAE\rom\' *: H:\HyperSpin\Emulators\WinUAE\rom\amiga-boot-a1000.rom:8192 = A1000 bootstrap ROM (64k) [252179-01/252180-01] CRC32=62F11C04 SHA1=C87F9FADA4EE4E69F3CCA0C36193BE822B9F5FE6 *: H:\HyperSpin\Emulators\WinUAE\rom\amiga-boot-a4091.rom:32768 = A4091 SCSI boot ROM (32k) [391592-02] CRC32=54CB9E85 SHA1=3CE66919F6FD67974923A12D91B730F1FFB4A7BA *: H:\HyperSpin\Emulators\WinUAE\rom\amiga-boot-a590.rom:16384 = A590/A2091 SCSI boot ROM (16k) [390722-03/390721-03] CRC32=714A97A2 SHA1=E50F01BAF28998928554786372A82C333C91276E *: H:\HyperSpin\Emulators\WinUAE\rom\amiga-crt-310-cd32-fmv.rom:262144 = CD32 MPEG Cartridge ROM rev 40.30 (256k) CRC32=C35C37BF SHA1=03CA81C7A7B259CF64BC9582863ECA0F6529F435 !: Name='H:\HyperSpin\Emulators\WinUAE\rom\amiga-os-070.rom':262144 CRC32=10CC650F SHA1=4E2EE86C5675312EC4319BC694BDCABC81897E46 *: H:\HyperSpin\Emulators\WinUAE\rom\amiga-os-100.rom:262144 = KS ROM v1.0 (A1000)(NTSC) (256k) CRC32=299790FF SHA1=00C15406BEB4B8AB1A16AA66C05860E1A7C1AD79 *: H:\HyperSpin\Emulators\WinUAE\rom\amiga-os-110.rom:262144 = KS ROM v1.1 (A1000)(PAL) rev 31.34 (256k) CRC32=EC86DAE2 SHA1=16DF8B5FD524C5A1C7584B2457AC15AFF9E3AD6D *: H:\HyperSpin\Emulators\WinUAE\rom\amiga-os-120.rom:262144 = KS ROM v1.2 (A500,A1000,A2000) rev 33.180 (256k) [315093-01] CRC32=A6CE1636 SHA1=11F9E62CF299F72184835B7B2A70A16333FC0D88 *: H:\HyperSpin\Emulators\WinUAE\rom\amiga-os-130-cdtv-ext.rom:262144 = CDTV extended ROM v1.00 (256k) [252606-01/252607-01] CRC32=42BAA124 SHA1=7BA40FFA17E500ED9FED041F3424BD81D9C907BE *: H:\HyperSpin\Emulators\WinUAE\rom\amiga-os-130.rom:262144 = KS ROM v1.3 (A3000)(SK) rev 34.5 (256k) CRC32=E0F37258 SHA1=C39BD9094D4E5F4E28C1411F3086950406062E87 *: H:\HyperSpin\Emulators\WinUAE\rom\amiga-os-140-a3000.rom:524288 = KS ROM v1.4 (A3000) rev 36.16 (512k) [390629-02/390630-02] CRC32=BC0EC13F SHA1=F76316BF36DFF14B20FA349ED02E4B11DD932B07 *: H:\HyperSpin\Emulators\WinUAE\rom\amiga-os-204.rom:524288 = KS ROM v2.04 (A500+) rev 37.175 (512k) [390979-01] CRC32=C3BDB240 SHA1=C5839F5CB98A7A8947065C3ED2F14F5F42E334A1 *: H:\HyperSpin\Emulators\WinUAE\rom\amiga-os-205.rom:524288 = KS ROM v2.05 (A600HD) rev 37.350 (512k) [391304-02] CRC32=43B0DF7B SHA1=02843C4253BBD29ABA535B0AA3BD9A85034ECDE4 *: H:\HyperSpin\Emulators\WinUAE\rom\amiga-os-300.rom:524288 = KS ROM v3.0 (A4000) rev 39.106 (512k) [391513-02/391514-02] CRC32=9E6AC152 SHA1=F0B4E9E29E12218C2D5BD7020E4E785297D91FD7 *: H:\HyperSpin\Emulators\WinUAE\rom\amiga-os-310-a1200.rom:524288 = KS ROM v3.1 (A1200) rev 40.68 (512k) [391773-01/391774-01] CRC32=1483A091 SHA1=E21545723FE8374E91342617604F1B3D703094F1 *: H:\HyperSpin\Emulators\WinUAE\rom\amiga-os-310-a3000.rom:524288 = KS ROM v3.1 (A3000) rev 40.68 (512k) CRC32=EFB239CC SHA1=F8E210D72B4C4853E0C9B85D223BA20E3D1B36EE *: H:\HyperSpin\Emulators\WinUAE\rom\amiga-os-310-a4000.rom:524288 = KS ROM v3.1 (A4000)(Cloanto) rev 40.68 (512k) CRC32=43B6DD22 SHA1=C3C481160866E60D085E436A24DB3617FF60B5F9 *: H:\HyperSpin\Emulators\WinUAE\rom\amiga-os-310-a500.rom:524288 = KS ROM v3.1 (A500,A600,A2000) rev 40.63 (512k) CRC32=FC24AE0D SHA1=3B7F1493B27E212830F989F26CA76C02049F09CA *: H:\HyperSpin\Emulators\WinUAE\rom\amiga-os-310-cd32-ext.rom:524288 = CD32 extended ROM rev 40.60 (512k) CRC32=87746BE2 SHA1=5BEF3D628CE59CC02A66E6E4AE0DA48F60E78F7F *: H:\HyperSpin\Emulators\WinUAE\rom\amiga-os-310-cd32.rom:524288 = CD32 KS ROM v3.1 rev 40.60 (512k) CRC32=1E62D4A5 SHA1=3525BE8887F79B5929E017B42380A79EDFEE542D !: Name='H:\HyperSpin\Emulators\WinUAE\rom\amiga-os-320-walker.rom':524288 CRC32=571662C0 SHA1=E898F4264E0865BB89B389F2A611C34AE9EB461A *: H:\HyperSpin\Emulators\WinUAE\rom\amiga-os-3x0-a4000.rom:524288 = KS ROM v3.X (A4000)(Cloanto) rev 45.57 (512k) CRC32=3AC99EDC SHA1=3CBFC9E1FE396360157BD161DE74FC901ABEE7EC !: Name='H:\HyperSpin\Emulators\WinUAE\rom\aros-20130502-ext.rom':524288 CRC32=03BFA98A SHA1=C3DC1E11D9CF65CC823B93946CDE147371C7E0A9 !: Name='H:\HyperSpin\Emulators\WinUAE\rom\aros-20130502.rom':524288 CRC32=B3048BE6 SHA1=65B686C57CEB32130501EDD19F71E0F8E3BBC838 *: H:\HyperSpin\Emulators\WinUAE\rom\logica-dialoga-200.rom:524288 = The Diagnostic 2.0 (Logica) (512k) CRC32=8484F426 SHA1=BA10D16166B2E2D6177C979C99EDF8462B21651E *: H:\HyperSpin\Emulators\WinUAE\rom\rom.key:1544 = Cloanto Amiga Forever 2010 ROM key (2k) CRC32=8C4DD05C SHA1=05034F620B5BB7B286954EA9164FDB90FB2897A4 Scan of ROMs finished A500 Boot ROM 1.2: available A500 Boot ROM 1.3: available A500+: available A600: available A1000: available A1200: available A3000: available A4000: available CD32: available CDTV: available Arcadia Multi Select: unavailable High end WinUAE: available A590/A2091 SCSI Boot ROM: available '.\Configurations\configuration.cache' loaded successfully '.\Configurations\configuration.cache' flushed '.\Configurations\configuration.cache' load failed '.\Configurations\configuration.cache' flushed '.\Configurations\configuration.cache' created Only you are missing the entire section on roms... What might tell me more is your winuaelog.txt that you will have to enable in WinUAE. Edit your ...\WinUAE\Configurations\Host\cd32host.uae in notepad. Somewhere around line 10 you should find: ; host-specific Add this line below it: win32.logfile=true This will allow WinUAE to create another log file (winuaelog.txt). Please run the command line again and post this new log. Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
clownstyle Posted May 13, 2014 Posted May 13, 2014 Only you are missing the entire section on roms... What might tell me more is your winuaelog.txt that you will have to enable in WinUAE. Edit your ...\WinUAE\Configurations\Host\cd32host.uae in notepad. Somewhere around line 10 you should find: ; host-specific Add this line below it: win32.logfile=true This will allow WinUAE to create another log file (winuaelog.txt). Please run the command line again and post this new log. Thanks' date=' Ron[/quote'] Thanks again Ron, here is the log file. One thing to note is that if I mount the image myself in daemon tools, then select that specific drive in winuae it works without issue 2014-05-13 22:44:57 57-689 [0 000=000]: WinUAE 2.6.1 (2013.06.19) (6.1 Service Pack 1 [2]) 64-bit 9.6.3C03 4 10:31 (c) 1995-2001 Bernd Schmidt - Core UAE concept and implementation. (c) 1998-2013 Toni Wilen - Win32 port, core code updates. (c) 1996-2001 Brian King - Win32 port, Picasso96 RTG, and GUI. (c) 1996-1999 Mathias Ortmann - Win32 port and bsdsocket support. (c) 2000-2001 Bernd Meyer - JIT engine. (c) 2000-2005 Bernd Roesch - MIDI input, many fixes. Press F12 to show the Settings Dialog (GUI), Alt-F4 to quit. End+F1 changes floppy 0, End+F2 changes floppy 1, etc. 57-689 [0 000=000]: 'G:\Hyperspin\Emulators\WinUAE\winuae.exe' 57-689 [0 000=000]: EXE: 'G:\Hyperspin\Emulators\WinUAE\', DATA: 'G:\Hyperspin\Emulators\WinUAE\', PLUGIN: 'G:\Hyperspin\Emulators\WinUAE\' 57-689 [0 000=000]: WARNING: Unsupported 'G:\Hyperspin\Emulators\WinUAE\winuae.ini' enabled 57-689 [0 000=000]: NATMEM: Our special area: 0x87EB0000-0x97EB0000 (10000000 256M) 57-694 [0 000=000]: RTAREA located at 00F00000 57-694 [0 000=000]: shmget of size 65536 (64k) for rtarea 57-694 [0 000=000]: VA 00F00000 - 00F10000 10000 (64k) ok (88DB0000) 57-694 [0 000=000]: uaegfx.card magic code: 00F03000-00F0313E ABI=00000000 57-694 [0 000=000]: shmget of size 65536 (64k) for filesys 57-694 [0 000=000]: shmget of size 524288 (512k) for kick 57-694 [0 000=000]: VA 00F80000 - 01000020 80020 (512k) ok (88E30000) 57-694 [0 000=000]: Entered action_replay_load () 57-694 [0 000=000]: shmget of size 4194304 (4096k) for chip 57-694 [0 000=000]: VA 00000000 - 00400020 400020 (4096k) ok (87EB0000) 57-694 [0 000=000]: ROM loader.. (<none>) 57-699 [0 000=000]: shmget of size 524288 (512k) for rom_e0 57-699 [0 000=000]: VA 00E00000 - 00E80000 80000 (512k) ok (88CB0000) 57-705 [0 000=000]: Known ROM 'CD32 KS ROM v3.1' loaded 57-705 [0 000=000]: ROM loader end 57-706 [0 000=000]: memory init end 57-709 [0 000=000]: No disk in drive 0. 57-709 [0 000=000]: CPU cycleunit: 128 (0.250) 57-709 [0 000=000]: Building CPU table for configuration: 68020 ~cycle-exact 24-bit 57-720 [0 000=000]: 1883 CPU functions 57-720 [0 000=000]: Building CPU, 45954 opcodes (2 -1 1) 57-720 [0 000=000]: CPU=68020, FPU=0, MMU=0, JIT=0. 57-720 [0 000=000]: CPUID level=13, Family=6, Model=12, Mask=3, Vendor=GenuineIntel [0] 57-720 [0 000=000]: JIT: Setting signal handler 57-720 [0 000=000]: JIT: Building Compiler function table 57-720 [0 000=000]: JIT: Supposedly 42346 compileable opcodes! 57-721 [0 000=000]: JIT: cache=0. b=1 w=1 l=1 fpu=1 nf=1 const=1 hard=0 57-732 [0 000=000]: Max hardware surface size: 16384x16384 57-733 [0 000=000]: SetCursorPos 400x300 57-735 [0 000=000]: winuae_active(0) 57-738 [0 000=000]: Allocated draw temp buffer (1600*1280*16) = 08CC0020 57-754 [0 000=000]: Direct3D: Pixel shader 2.0+ support detected, shader filters enabled. 57-762 [0 000=000]: Device name: 'AMD Radeon HD 7900 Series' 80011000a04df.0 58-287 [0 000=000]: D3D9Ex: 00000056 ALPHA DYNAMIC SCANLINE 58-287 [0 000=000]: D3D9Ex: PS=3.0 VS=3.0 800*600*0p FS VS=0 B=2WE 16-bit 0 58-298 [0 000=000]: D3D9Ex: pixelshader filter 'G:\Hyperspin\Emulators\WinUAE\_winuae.fx':-1 enabled 58-300 [0 000=000]: Buffer size (752*576) Native 58-301 [0 000=000]: D3D9Ex: 752*576 main texture, depth 16 58-306 [0 000=000]: CPU cycleunit: 128 (0.250) 58-306 [0 000=000]: clipboard: reset (00000000) 58-330 [0 000=000]: memory init end 58-330 [0 000=000]: Reset at 00000000. Chipset mask = 00000007 58-330 [0 000=000]: 00000000 4096K/1 = 4096K Chip memory 58-330 [0 000=000]: 00400000 6656K/0 = 6656K <none> 58-331 [0 000=000]: 00A80000 512K/1 = 512K Kickstart ROM (1E62D4A5) 58-331 [0 000=000]: =CD32 KS ROM v3.1 rev 40.60 (512k) 58-332 [0 000=000]: 00B00000 512K/1 = 512K Extended Kickstart ROM (87746BE2) 58-332 [0 000=000]: =CD32 extended ROM rev 40.60 (512k) 58-332 [0 000=000]: 00B80000 64K/0 = 64K Akiko 58-332 [0 000=000]: 00B90000 384K/0 = 384K <none> 58-332 [0 000=000]: 00BF0000 64K/0 = 64K CIA 58-332 [0 000=000]: 00C00000 1792K/0 = 1792K <none> 58-332 [0 000=000]: 00DC0000 64K/0 = 64K Battery backed up clock (none) 58-332 [0 000=000]: 00DD0000 128K/0 = 128K Gayle (high) 58-332 [0 000=000]: 00DF0000 64K/0 = 64K Custom chipset 58-333 [0 000=000]: 00E00000 512K/1 = 512K Extended Kickstart ROM (87746BE2) 58-333 [0 000=000]: =CD32 extended ROM rev 40.60 (512k) 58-333 [0 000=000]: 00E80000 64K/0 = 64K Autoconfig 58-333 [0 000=000]: 00E90000 448K/0 = 448K <none> 58-333 [0 000=000]: 00F00000 64K/1 = 64K UAE Boot ROM 58-333 [0 000=000]: 00F10000 448K/0 = 448K <none> 58-334 [0 000=000]: 00F80000 512K/1 = 512K Kickstart ROM (1E62D4A5) 58-334 [0 000=000]: =CD32 KS ROM v3.1 rev 40.60 (512k) 58-336 [0 000-000]: IOCTL driver open, 4 devices. 58-336 [0 000-000]: IOCTL driver installed, ok=4 58-336 [0 000-000]: Image driver open. 58-336 [0 000-000]: IMAGE driver installed, ok=1 58-336 [0 000-000]: CUE TOC: 'G:\Hyperspin\Emulators\Commodore Amiga CD32\roms\Alien Breed '92 Special Edition & Qwak (Europe)\Alien Breed '92 Special Edition & Qwak (Europe).cue' 58-336 [0 000-000]: 1: 0 00:02:00 DATA 4 0 0 [FILE ERROR] 58-336 [0 000-000]: - Alien Breed Special Edition & Qwak (1994)(Team 17)[!][compilation].iso 58-336 [0 000-000]: 0 00:02:00 58-346 [0 000-000]: using drive IMG:G:\Hyperspin\Emulators\Commodore Amiga CD32\roms\Alien Breed '92 Special Edition & Qwak (Europe)\Alien Breed '92 Special Edition & Qwak (Europe).cue (unit 0, media 1) 58-346 [0 000-000]: CD32: media changed = 1 58-352 [0 000-000]: PAL mode V=49.9201Hz H=15625.0881Hz (227x312+1) IDX=10 (PAL) D=0 RTG=0/0 58-352 [0 000-000]: P96FREQ: 312*49.9201 = 15575.0799 / 49.9 = 312 58-352 [0 000-000]: POS (0 0 800 600) - (0 0 672 526)[672,526] (56 20) 58-433 [0 000-000]: hardreset, memory cleared 58-450 [0 000-000]: DS: 00140004 1:00000000 2:00000000 4:00000033 4:00000603 4:00000107 6:0000003F 6:0000060F 58-450 [0 000-000]: DS: 00000000,CH=2,FREQ=44100 'Primary Sound Driver' buffer 16384, dist 4096 58-480 [0 227-045]: DS: 1323 = (1356 - 33) 58-480 [0 227-045]: DS: bs=128 w=10240 max=16384 tof=21845 tuf=29127 58-925 [23 211-002]: SERIAL: period=372, baud=9600, hsyncs=16, bits=8, PC=f8018a 58-925 [23 199-006]: 6888x no FPU: f201 00009000 PC=00f80cac 58-925 [23 199-006]: B-Trap f201 at f80cac (88E30CAC) 59-354 [44 035-175]: Filesystem: mapped memory @$e90000. 59-354 [44 035-175]: Card 1 (ZorroII) done. 59-354 [44 035-175]: Memory map after autoconfig: 59-354 [44 035-175]: 00000000 4096K/1 = 4096K Chip memory 59-354 [44 035-175]: 00400000 6656K/0 = 6656K <none> 59-355 [44 035-175]: 00A80000 512K/1 = 512K Kickstart ROM (1E62D4A5) 59-355 [44 035-175]: =CD32 KS ROM v3.1 rev 40.60 (512k) 59-356 [44 035-175]: 00B00000 512K/1 = 512K Extended Kickstart ROM (87746BE2) 59-356 [44 035-175]: =CD32 extended ROM rev 40.60 (512k) 59-356 [44 035-175]: 00B80000 64K/0 = 64K Akiko 59-356 [44 035-175]: 00B90000 384K/0 = 384K <none> 59-356 [44 035-175]: 00BF0000 64K/0 = 64K CIA 59-356 [44 035-175]: 00C00000 1792K/0 = 1792K <none> 59-356 [44 035-175]: 00DC0000 64K/0 = 64K Battery backed up clock (none) 59-356 [44 035-175]: 00DD0000 128K/0 = 128K Gayle (high) 59-356 [44 035-175]: 00DF0000 64K/0 = 64K Custom chipset 59-357 [44 035-175]: 00E00000 512K/1 = 512K Extended Kickstart ROM (87746BE2) 59-357 [44 035-175]: =CD32 extended ROM rev 40.60 (512k) 59-357 [44 035-175]: 00E80000 64K/0 = 64K <none> 59-357 [44 035-175]: 00E90000 64K/0 = 64K Filesystem Autoconfig Area 59-357 [44 035-175]: 00EA0000 384K/0 = 384K <none> 59-357 [44 035-175]: 00F00000 64K/1 = 64K UAE Boot ROM 59-357 [44 035-175]: 00F10000 448K/0 = 448K <none> 59-358 [44 035-175]: 00F80000 512K/1 = 512K Kickstart ROM (1E62D4A5) 59-358 [44 035-175]: =CD32 KS ROM v3.1 rev 40.60 (512k) 59-792 [66 191-044]: filesystem: diagentry called: 498 2014-05-13 22:45:02 02-513 [201 000=000]: PAL mode lace V=49.9201Hz H=15625.0881Hz (227x312+0) IDX=10 (PAL) D=0 RTG=0/0 15-455 [848 000=000]: CPU tracer enabled 15-796 [849 000-000]: GUIBase 803x590 (6x13) 15-796 [849 000-000]: '.\Configurations\configuration.cache' loaded successfully 15-796 [849 000-000]: Entering GUI idle loop 15-796 [849 000-000]: Requested GUI size = 800x600 (800x600) 15-798 [849 000-000]: winuae_inactive(0) 15-809 [849 000-000]: Got GUI size = 800x598 17-227 [849 000-000]: winuae_active(0) 17-390 [849 000-000]: CPU tracer disabled 17-915 [849 001=000]: winuae_inactive(0) 18-140 [849 001=000]: DS: DirectSound driver freed
clownstyle Posted May 13, 2014 Posted May 13, 2014 CUE TOC: 'G:\Hyperspin\Emulators\Commodore Amiga CD32\roms\Alien Breed '92 Special Edition & Qwak (Europe)\Alien Breed '92 Special Edition & Qwak (Europe).cue' 58-336 [0 000-000]: 1: 0 00:02:00 DATA 4 0 0 [FILE ERROR] 58-336 [0 000-000]: - Alien Breed Special Edition & Qwak (1994)(Team 17)[!][compilation].iso 58-336 [0 000-000]: 0 00:02:00 58-346 [0 000-000]: using drive IMG:G:\Hyperspin\Emulators\Commodore Amiga CD32\roms\Alien Breed '92 Special Edition & Qwak (Europe)\Alien Breed '92 Special Edition & Qwak (Europe).cue (unit 0, media 1) I found the culprit, the name held within the cue file did not match the iso, nor did any of the other games I tested. DOH! Schoolboy error on this one I'm afraid. Thanks for the help though
rfancella Posted May 14, 2014 Author Posted May 14, 2014 I found the culprit, the name held within the cue file did not match the iso, nor did any of the other games I tested. DOH! Schoolboy error on this one I'm afraid. Thanks for the help though Whew... That one had me noodle baked. Glad it's all sorted now! Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
Cybersnuff Posted June 27, 2014 Posted June 27, 2014 For me Amiga and CD32 was that hard but thanks to your guides I have both working.. Thanks for this awesome guides.... C64, Atari 800XL, Amiga, Atari ST that were the great Home Computers of the 80s... The Sinclair was only in the UK popular as far as I now.. Over here I never saw one. Commodore were the leading gaming systems in the 80s over here. Atari the second ones... But I like both systems .
rfancella Posted June 27, 2014 Author Posted June 27, 2014 For me Amiga and CD32 was that hard but thanks to your guides I have both working.. Thanks for this awesome guides.... C64, Atari 800XL, Amiga, Atari ST that were the great Home Computers of the 80s... WooT!! And don't forget the Sinclair!!! Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
muppets4 Posted August 14, 2014 Posted August 14, 2014 In my installation there is no ahk module for WinUAE, just for the auto loader. Can anyone provide me with the correct files? I tried and copy them from Google code, but it gives me crc errors.
rfancella Posted August 14, 2014 Author Posted August 14, 2014 In my installation there is no ahk module for WinUAE, just for the auto loader. Can anyone provide me with the correct files? I tried and copy them from Google code, but it gives me crc errors. Muppets4, Hello! If you do not have the module, that means your HyperLaunch is not current. This is a post on how to update your HyperLaunch: http://www.hyperspin-fe.com/forum/showthread.php?31472-Complete-Guide-for-Commodore-Amiga-in-HS-and-RL-Using-WinUAE-Only&p=304130&viewfull=1#post304130 Once you have updated, this will update all your modules and support files, you need to add WinUAE to your Global Emulators. Here is a post on how to do that: http://www.hyperspin-fe.com/forum/showthread.php?31472-Complete-Guide-for-Commodore-Amiga-in-HS-and-RL-Using-WinUAE-Only&p=305212&viewfull=1#post305212 Let me know how it goes and if you have any more questions. Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
muppets4 Posted August 14, 2014 Posted August 14, 2014 Hi Ron, thanks. I've taken the module from Git. Then I took the database from Hyperlist. Both installed got me playing right away! Thanks.
rfancella Posted August 14, 2014 Author Posted August 14, 2014 Hi Ron, thanks. I've taken the module from Git. Then I took the database from Hyperlist. Both installed got me playing right away! Thanks. Very cool! Glad it's all sorted now! Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
