Enter button won't start roms
Cladwig23
This is my first time setting up Hyperspin and RocketLauncher. I have paid the platnium membership and the EMUmovies membership and have been following Simply Austins videos on youtube. When in Rocketluancher I can start and play my MAME roms but when I start HyperSpin the enter button goes into MAME but won't start a ROM. What am I missing? Thanks for the help in advance!
Thank you both!
Is mame still open in the back ground or is Rocketlauncher still running in the sys tray?
Didn't know about this, but I just tried it and that didn't work. Thank you I'm sure this will  help again.
Make sure that you have the Hyperlaunch_path in the HyperSpin/Settings/Settings.ini pointing to your RocketLauncher.exe and that you're using HyperSpin 1.4.
I am using HyperSpin 1.4 and I have it set to here Hyperlaunch_Path=C:\Users\cladw\Desktop\RocketLauncher.exe as rocket launcher is on my desktop. should it be pointing to the rocketlauncherui.exe instead?
Pointing it to RocketLauncher.exe is what you want to do, but there are a couple things you may want to fix with your setup first. You should really have your HyperSpin and RocketLauncher folders on the root of your drive (C:\HyperSpin, C:\RocketLauncher) preferably a drive other than your OS. Second, RocketLauncher.exe should be inside the RocketLauncher folder, so you either have your path set wrong or you have everything that should be inside the RocketLauncher folder on your Desktop, which is probably really messy.
I would advise following this video to get HS and RL configured properly before you get too far in.
I do have a second drive, I'll start over and try the video you linked. Thanks I'll let you know if the problem persist after a new install.
