Mess working fine with Atari 2600 but controls not working with creativision
Bruiserh89
Hi all
I have Atari 2600 and VTech Creativision consoles on my Mess emulator with hyperspin. Atari 2600 works perfectly and I've mapped the joystick buttons for general controls for all systems. However this doesnt work for creativision. Firstly games come up in a windows mouse operating menu at the top mode which I cant remove. Also the buttons mapped dont work. I also tried the this system only section. And strangely when I try some menu options from the top menu bar in a game, it kicks me back out to hyperspin game wheel!
Any help would be great.
Cheers
Bruiser
As to the controls, when you set up the Atari 2600, did you use Input (General) or Input (This system).  If the ladder, it may be as simple as doing a input setup using the general selection.  That sets up a default for all systems using MESS.
I have ran into the menu bar at the top as well and honestly I cannot remember what I did to fix that.
EDIT:
I am not sure that my solution is the best way to go but what I did was add the parameter '-nomenu' to the Global settings for MESS in the individual systems that were affected.
What I think might be a better solution is to use MAME as they are merged now.
EDIT:
Cheers mate. I'll have a go with mame which i use for arcade and have controls working.
EDIT:
I have tried to switch over to Mame but games wont launch. I get the message 'could not find game within archive with any defined rom extensions. The games are zip and I have that defined as an extension in the emulator settings for mame. My arcade games are zip too and work fine. Any ideas? Thanks!
  On 4/20/2016 at 10:11 PM, agent47 said:
If you're getting that message with MAME (arcade) roms, that means you have 7z enabled which should not be enabled for MAME. If you're getting that message with other roms (like Atari 2600) it means the name of the file inside the zip/7z doesn't match the database name or the extension isn't listed for MAME in RLUI.
Hey 47. Thanks again. I didnt have 7z enabled in the settings. I checked my vtech creativision roms and unzipped them to their rom format and also added rom to the extensions for mame in RLUI. I now get a long pause when I try to launch a game and then the message: There was an error waiting for the window Ahk class mame. I dont know if this helps but I am using the mame version MAMEUIFX 0.153 as suggested in the Austin guide. Oh and my roms were named correctly for the database in their rom form just as for zip.
By the way my arcade games work fine with mame. No probs there.
  On 4/21/2016 at 12:18 PM, agent47 said:
Ah, this is your problem. The MAME/MESS merge happened in version .162 so using an older version will not work for non arcade games. Also, UIFX is typically an arcades only build.
Bugger. ok I will go back to attempting through MESS. Thanks mate.
  On 4/21/2016 at 12:57 PM, adamg said:
You could try this download
http://www.hyperspin-fe.com/files/file/11466-mame-172-64bit-nonag-hi-score-forced-directinput/
But I guess it is preference as I prefer the least amount of stuff to run everything that I h
Thanks mate. I went with this and now i have vtech working but the controls for all systems settings wont apply and i cant even enter into the menu when in a game to make this system only settings. Grrrr!
