sjlewis78 Posted April 21, 2016 Posted April 21, 2016 I am not sure if anyone has run across this issue, but I wanted to use a horizontal layout for my racing cabinet. It just seemed more logical to go side to side when navigating games with steering wheel. than up and down. Anyway, the spinner works just fine in the normal wheel style layout, but when I change it to pin or horizontal it doesn't. Not sure if this is a bug or if I am missing something.
jfp Posted February 20, 2017 Posted February 20, 2017 Found the issue--- [up] and [down] doesn't work in horizontal style. You'll have to set [skip up] and [skip down] in hyperHQ
processedmeat Posted June 28, 2017 Posted June 28, 2017 On 2/20/2017 at 11:18 AM, jfp said: Found the issue--- [up] and [down] doesn't work in horizontal style. You'll have to set [skip up] and [skip down] in hyperHQ Expand Hi jfp, I'm having the same issue. Where did you set the [skip up] and [skip down] in HyperHQ i.e. joystick or keyboard setup or somewhere else and what did you set them to? Thanks.
jfp Posted June 28, 2017 Posted June 28, 2017 I did not have left/right set New Bitmap Image.bmp New_Bitmap_Image.bmp
processedmeat Posted June 29, 2017 Posted June 29, 2017 I appreciate the help but for some reason I still can't keep it from skipping games when in pin or horizontal with your keyboard settings. In the meantime, I'll just go with the vertical orientation. Thanks for replying.
