Titi87audi Posted April 24, 2016 Posted April 24, 2016 Hi I am new member on the super forum, I wanted to know how to install Hyperspin on my new Nvidia Shield Tv Thank you
thatman84 Posted April 25, 2016 Posted April 25, 2016 These threads will help you Do you have hyperspin on PC? http://www.hyperspin-fe.com/topic/8304-setup-hyperspin-for-android/#entry143327 http://www.hyperspin-fe.com/topic/9226-how-to-set-up-hyperspin-on-the-nvidia-shield-beginners-guide/page-1# Basically you need to:- 1. Install the emulators you need on the shield 2. Organise you roms mainly as unzipped to be accessible on the Shield 3. Check the roms load in the emulators 4. adjust the hyperspin ini files to be android compatable (there is a download to pre configured ones) You need to adjust the rom path to suit your rom folder location, change/check the exe= line is set to open the correct emulator, change/check the parameter= line is correct for the emulator 5. Install hyperspin app from play store 6. Put your setup hyperspin folder in the correct place on your shield Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
