Creezz67 Posted May 9, 2016 Posted May 9, 2016 I have tried to get for example Nintendo Gamecube to show background images , but so far no luck. I have a folder called backgrounds in my Images folder and inside that I have put a .png image (1024x768) and named it the same as the rom. Should this not show up behind the game when i use the wheel in Hyperspin ? Am I missing something ? Do I need to set anything else in HyperHQ/RocketLauncher etc to enable it ? I am using Hyperspin 1.4 with RocketLauncher. Thanks for any info.
Creezz67 Posted May 9, 2016 Author Posted May 9, 2016 Found solution, you just have to delete the background in the default theme then all images will show against each game
KristianD Posted May 15, 2016 Posted May 15, 2016 could you be more specific with your solution? (like explain with examples...files paths and such) Thanx in advance!
