Mame opens in anther window
findme29
Hi everyone!
So lately when I launch an arcade game from hyperspin, mame opens in a anther window and I need to "alt-tab" to switch to the game. Any ideas why this is happening?
Don't know. What changes have you made lately? Updated RocketLauncher? Updated MAME? Changed some settings? etc...
Just the standard RL updates
Something probably changed with their module thats giving you the issue. You might go check the update/module section on the RocketLauncher forums.
Their latest update had some massive changes. I had so much trouble that I went back to the previous version until it all gets fixed.
Launches just fine for me and I haven't seen anyone else report this issue here or the RL forums that I recall so it's likely not the module itself. One thing to check is that "Hide Emulator" isn't set to true on the Settings -> Main Settings tab in RLUI for MAME.
Edit: Another thing you may want to try is setting the "Suspend Frontend" option to true on the Settings -> Main Settings tab in RLUI for MAME. I've never had to use it myself but if HyperSpin is stealing the focus that setting may help.
That did it. I set suspend frontend under global settings and it worked! thanks.
