Random5095490 Posted June 6, 2016 Posted June 6, 2016 How to I set Special Art A and Special Art B to not have an animation? I already have the images I want working but there is no way to make it stay still. There is no option in HyperHQ to disable the animation effect and I can't change the "Out" value at all. I want the image to remain still with no fade-in or fade-out if I switch wheels or if I let it sit.
ninja2bceen Posted June 6, 2016 Posted June 6, 2016 The default swf? Try none for fade in/out if you made your own Advance the cause to 100%. http://hyperbase.hyperspin-fe.com/ Planet Geekdom, Subscribe for Tutorials! https://www.youtube.com/channel/UCdcby-s2GwriaOHGmVC2vGA?sub_confirmation=1&app=desktop
Random5095490 Posted June 6, 2016 Author Posted June 6, 2016 The default swf? Try none for fade in/out if you made your own That works! Thank you! However, it now flashes every 6 seconds. If I set the length to 0 it doesn't appear and I can't set it for longer than 6 seconds.
Random5095490 Posted June 7, 2016 Author Posted June 7, 2016 Change fade=none to normal. I don't see this option? I only have: normal, fade, and bounce. It is currently set to normal.
potts43 Posted June 7, 2016 Posted June 7, 2016 Normal is there. You said so above. Or open the ini and type it
potts43 Posted June 7, 2016 Posted June 7, 2016 In you HS settings try [special Art A] default=false active=true x = 512 y = 384 in = .4 out = .4 length = 3 delay = .1 type =normal start =none
potts43 Posted June 7, 2016 Posted June 7, 2016 Same settings for SA B The length time is how long it is visible before displaying the next sequential special art Eg Special Art A1. Wait 3 seconds Special art A2 Wait 3 seconds Special Art A3 Wait 3 seconds If type=normal then it will only display the first of no sequentially numbered files are in that folder- Etc the other numbers are for how long the fade takes
Random5095490 Posted June 7, 2016 Author Posted June 7, 2016 Normal is there. You said so above. Or open the ini and type it I meant the "none" option is not there. I fixed the issue by just setting the length to "200" in the Main Menu.ini but thanks for the help anyways.
