UncutCreator Posted June 8, 2016 Posted June 8, 2016 HI all i bought a pre-configured hyperspin cd off of ebay as i had trouble installing it myself. Copied it to my c drive and it worked great. Took the same CD to an older pc but still running windows 7 HP like my normal pc. installed, 7zip, direct x, c++, framework etc... hyperspin loads up fine but i get to the select emulator wheel, try to select snes for example and it just goes back to the select emulator wheel. Also the keys are a bit different too. ESC seems to pause the menu rather than escape?? The only thing that i did differently was at the start of installation of windows 7 where i didn't select uk keyboard. surely this doesn't matter?
UncutCreator Posted June 11, 2016 Author Posted June 11, 2016 UPDATE: Took the hard drive and put it in my faster PC then copied all the files to the C:drive and works perfectly. Put that hard drive back in the slow PC and get that problem again. so it must be something to do with the Specs of the old PC? Any idea? Thanks in advance
gigapig Posted June 11, 2016 Posted June 11, 2016 As you have bought HyperSpin from someone who shouldn't be selling it you should really contact them. You may not get many replies as well. However as your getting kicked back to the main menu it will be a setting in HyperHQ. Either the Rom/emulator path, extension or wheel filters. There are lots of threads about this problem so also try searching.
