Henderson33 Posted June 8, 2016 Posted June 8, 2016 Hello, is there a way to make the wheel fade out fully or make it more transparent after u stop scrolling games/systems? It stays on top of some of the themes im using and ruins the look. Thank you
thatman84 Posted June 8, 2016 Posted June 8, 2016 the first line of the main menu.ini alpha=.8 this value goes from 0 to 1 the lower the value the more transparent the wheel will be Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
Henderson33 Posted June 8, 2016 Author Posted June 8, 2016 Great stuff thank you So u change main menu.ini but when u go into others like mame.ini ect ect there is also a alpha line, most are set at .15, what does that change if i change that value?
