Samorite Posted June 28, 2016 Posted June 28, 2016 I run the H.Hq exe select my wheel try to set path for roms it pop's up the browse box then the program coles down ? I have excluded the full folder from defender Any ideas ?
BATTLEDONKEY Posted June 28, 2016 Posted June 28, 2016 It's a bug with windows 10. Edit the config files manually in the settings folder, select the system, edit, then just type in the path to the ROMs folder manually
Samorite Posted June 28, 2016 Author Posted June 28, 2016 It's a bug with windows 10. Edit the config files manually in the settings folder, select the system, edit, then just type in the path to the ROMs folder manually Cheers that sorted it
