cannot run commodore 64 from within hyperspin
nickbuus
I am unable to run the commodore 64 emulator (winvice) from within hyperspin.
This is the error I get when clicking on the commodore 64 icon.
cannot find rom "Commodore 64" In any Rom Paths provided: "C:\hyperspin133\Emulators\Arcade\Commodore 64\roms" with any provided Rom_Extension: "7z|zip|crt|vsf|d64|g64|tap|prg|t64|nib"
From within RocketLauncherUI everything seems to be set up correctly. the Commodore 64 icon is there in the systems list. I am able to get a list of all of the games in my roms folder when I press the "audit all games..." and I am able to launch a game from the roms list within RocketLauncherUI.
Here is the Hyperspin log:
08:59:02 AM |  HyperSpin Started
08:59:02 AM |  Going windowed mode
08:59:03 AM |  Checking for updates
08:59:03 AM |  Update Check Complete
08:59:03 AM |  Startup program unavailable
08:59:03 AM |  Playing intro video
08:59:22 AM |  Error intializing joysticks
08:59:22 AM |  Menu Mode is multi
08:59:22 AM |  Loading Main Menu.xml
08:59:22 AM |  Main Menu.xml successfully loaded
08:59:25 AM |  Main Menu wheel loaded successfully
09:00:24 AM |  Launching Game
09:00:24 AM |  Using HyperLaunch
09:00:24 AM |  Getting Launcher path
09:00:24 AM |  Launcher located at C:\Hyperspin133\rocketlauncher\rocketlauncher.exe
09:00:24 AM |  Running Launcher
09:00:24 AM |  Launcher Command Line is: C:\Hyperspin133\rocketlauncher\rocketlauncher.exe "Commodore 64" "Commodore 64"
09:00:26 AM |  Launching Game
09:00:26 AM |  Using HyperLaunch
09:00:26 AM |  Getting Launcher path
09:00:26 AM |  Launcher located at C:\Hyperspin133\rocketlauncher\rocketlauncher.exe
09:00:26 AM |  Running Launcher
09:00:26 AM |  Launcher Command Line is: C:\Hyperspin133\rocketlauncher\rocketlauncher.exe "Commodore 64" "Commodore 64"
09:00:27 AM |  Launching Game
09:00:27 AM |  Using HyperLaunch
09:00:27 AM |  Getting Launcher path
09:00:27 AM |  Launcher located at C:\Hyperspin133\rocketlauncher\rocketlauncher.exe
09:00:27 AM |  Running Launcher
09:00:27 AM |  Launcher Command Line is: C:\Hyperspin133\rocketlauncher\rocketlauncher.exe "Commodore 64" "Commodore 64"
09:00:28 AM |  Launcher located at C:\Hyperspin133\rocketlauncher\rocketlauncher.exe
09:00:28 AM |  Running Launcher
09:00:28 AM |  Launcher Command Line is: C:\Hyperspin133\rocketlauncher\rocketlauncher.exe "Commodore 64" "Commodore 64"
09:00:28 AM |  Launching Game
09:00:28 AM |  Using HyperLaunch
09:00:28 AM |  Getting Launcher path
09:01:05 AM |  Launching Game
09:01:05 AM |  Using HyperLaunch
09:01:05 AM |  Getting Launcher path
09:01:05 AM |  Launcher located at C:\Hyperspin133\rocketlauncher\rocketlauncher.exe
09:01:05 AM |  Running Launcher
09:01:05 AM |  Launcher Command Line is: C:\Hyperspin133\rocketlauncher\rocketlauncher.exe "Commodore 64" "Commodore 64"
09:01:22 AM |  Launching Game
09:01:22 AM |  Using HyperLaunch
09:01:22 AM |  Getting Launcher path
09:01:22 AM |  Launcher located at C:\Hyperspin133\rocketlauncher\rocketlauncher.exe
09:01:22 AM |  Running Launcher
09:01:22 AM |  Launcher Command Line is: C:\Hyperspin133\rocketlauncher\rocketlauncher.exe "Commodore 64" "Commodore 64"
09:01:38 AM |  Launching Game
09:01:38 AM |  Using HyperLaunch
09:01:38 AM |  Getting Launcher path
09:01:38 AM |  Launcher located at C:\Hyperspin133\rocketlauncher\rocketlauncher.exe
09:01:38 AM |  Running Launcher
09:01:38 AM |  Launcher Command Line is: C:\Hyperspin133\rocketlauncher\rocketlauncher.exe "Commodore 64" "Commodore 64"
Thanks for your response. I just tried setting it to true in rocketlauncherui under settings/7z/enabled=true - but still same error.
You are right that it is a rocketlauncher error as if I go to the rocketlauncherui/log viewer - it shows the error:
10:46:49:320 | RL |    ERROR  | +9281  | Cannot find Rom
"Commodore 64"
In any Rom_Paths provided:
With any provided Rom_Extension:
It seems that it is set up wrong since it is looking for a rom called "commodore 64" in the games folder - does a commodore 64 rom at all exist? shouldn't it just look for the x64.exe in the winvice folder?
I am using HS 1.4 - just copied the 1.4 files into the existing 133 folder.
This is how my rocketlauncher log looks like:
10:46:38:456 | RL |      INFO  | +N/A   | Main - RocketLauncher v1.1.0.7 (www.rlauncher.com)
10:46:38:799 | RL |      INFO  | +344   | Main - System Specs:
RocketLauncher Dir: C:\hyperspin133\RocketLauncher
RocketLauncher is: 32-bit
OS: Microsoft Windows 10 Home
SKU: Windows 8
Total Memory: 4051.47 MB
Free Memory: 1130.80 MB
Used Memory: 2920.672 MB
SystemType: 64-bit
Physical Processors: 1
Logical Processors: 4
GPU 1 Name: NVIDIA GeForce GTX 745
GPU 1 RAM: -2048.00 MB
GPU 1 Driver Version: 10.18.13.5362
Sound 1 Device: NVIDIA High Definition Audio
Sound 1 Status: Enabled
Sound 2 Device: Realtek High Definition Audio
Sound 2 Status: Enabled
Sound 3 Device: USB-lydenhed
Sound 3 Status: Enabled
OS Language: Danish
System Locale: da-DK
Formats Locale: da-DK
Windows UI Language: da-DK
Text Encoding: Windows-1252
OS Admin Status: No
RL Compatibility Flags:
Latest .Net Version: v4.0.30319
Monitor #1 (\\.\DISPLAY1): 1920x1200 (1920x1160 work) [32bit] [59hz] [Landscape]  (Primary)
Current AHK Desktop Width: 1920
Current AHK Desktop Height: 1200
Monitor #1 DPI: 100
AutoHotkey Path:
AHK Version: 1.1.09.04
Unicode: No
10:46:38:799 | RL |      INFO  | +0     | CheckFile - Checking if C:\hyperspin133\RocketLauncher\RocketLauncher.exe exists
10:46:38:799 | RL |      INFO  | +0     | Main - Raw CLI received: "Commodore 64 Commodore 64"
10:46:38:805 | RL |      INFO  | +0     | Main - Loading Front End Plugin: "RocketLauncherUI"
10:46:38:805 | RL |      INFO  | +0     | Process.Process - "Exist" "RocketLauncherUI.exe"
10:46:38:805 | RL |      INFO  | +0     | Main - Detected RocketLauncherUI.exe is currently running
10:46:38:805 | RL |      INFO  | +0     | Main - RocketLauncherUI.exe coordinates are x541 y205 w1150 h960
10:46:38:805 | RL |      INFO  | +0     | Main - RocketLauncher received "Commodore 64" and "Commodore 64"
10:46:38:831 | RL |      INFO  | +31    | Main - Did not find a "C:\hyperspin133\RocketLauncher\Settings\Commodore 64\Game Options.ini" file, skipping any game-specific options.
10:46:38:831 | RL |      INFO  | +0     | Main - Commodore 64 is using the default emulator: WinVICE
10:46:38:831 | RL |      INFO  | +0     | Main - Checking for a [WinVICE] section in C:\hyperspin133\RocketLauncher\Settings\Commodore 64\Emulators.ini
10:46:38:831 | RL |      INFO  | +0     | Main - Checking for a [WinVICE] section in C:\hyperspin133\RocketLauncher\Settings\Global Emulators.ini
10:46:38:832 | RL |      INFO  | +0     | Main - Found [WinVICE] in C:\hyperspin133\RocketLauncher\Settings\Global Emulators.ini
10:46:38:833 | RL |      INFO  | +0     | CheckFile - Checking if C:\hyperspin133\RocketLauncher\Modules\WinVICE\WinVICE.ahk exists
10:46:38:956 | RL |      INFO  | +125   | Main - CRC Check - CRC matches, this is an official unedited module.
10:46:38:956 | RL |      INFO  | +0     | Main - Commodore 64 will use module: C:\hyperspin133\RocketLauncher\Modules\WinVICE\WinVICE.ahk
10:46:38:981 | RL |      INFO  | +15    | Main - Using standard method with "Rom Extension" SkipChecks or without any SkipChecks.
10:46:38:984 | RL |      INFO  | +16    | CheckFile - Checking if C:\hyperspin133\Emulators\WinVICE\x64.exe exists
10:46:39:830 | RL |      INFO  | +844   | Main - INI Keys read
10:46:39:830 | RL |      INFO  | +0     | CheckFile - Checking if C:\hyperspin133\RocketLauncher\Module Extensions\7z.exe exists
10:46:39:912 | RL |      INFO  | +78    | CheckFile - Checking if C:\hyperspin133\RocketLauncher\Module Extensions\7z.dll exists
10:46:40:016 | RL |      INFO  | +109   | Main - "Commodore 64" does not qualify for MultiGame. Only roms with any of these strings in their name are acceptable: \(Disc|\(Disk|\(Cart|\(Tape|\(Cassette|\(Part|\(Side
10:46:40:016 | RL |      INFO  | +0     | CheckPaths - Started
10:46:40:016 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\hyperspin133\Emulators\Arcade\Commodore 64\roms\Commodore 64.7z
10:46:40:044 | RL |      INFO  | +16    | CheckPaths - Looking for rom by name in subfolder: C:\hyperspin133\Emulators\Arcade\Commodore 64\roms\Commodore 64\Commodore 64.7z
10:46:40:044 | RL |      INFO  | +0     | CheckPaths - Rom not found
10:46:40:044 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\hyperspin133\Emulators\Arcade\Commodore 64\roms\Commodore 64.zip
10:46:40:044 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\hyperspin133\Emulators\Arcade\Commodore 64\roms\Commodore 64\Commodore 64.zip
10:46:40:044 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\hyperspin133\Emulators\Arcade\Commodore 64\roms\Commodore 64.crt
10:46:40:044 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\hyperspin133\Emulators\Arcade\Commodore 64\roms\Commodore 64\Commodore 64.crt
10:46:40:044 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\hyperspin133\Emulators\Arcade\Commodore 64\roms\Commodore 64.vsf
10:46:40:044 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\hyperspin133\Emulators\Arcade\Commodore 64\roms\Commodore 64\Commodore 64.vsf
10:46:40:044 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\hyperspin133\Emulators\Arcade\Commodore 64\roms\Commodore 64.d64
10:46:40:044 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\hyperspin133\Emulators\Arcade\Commodore 64\roms\Commodore 64\Commodore 64.d64
10:46:40:044 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\hyperspin133\Emulators\Arcade\Commodore 64\roms\Commodore 64.g64
10:46:40:044 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\hyperspin133\Emulators\Arcade\Commodore 64\roms\Commodore 64\Commodore 64.g64
10:46:40:045 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\hyperspin133\Emulators\Arcade\Commodore 64\roms\Commodore 64.tap
10:46:40:045 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\hyperspin133\Emulators\Arcade\Commodore 64\roms\Commodore 64\Commodore 64.tap
10:46:40:045 | RL |      INFO  | +0     | CheckPaths - Rom not found
10:46:40:045 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\hyperspin133\Emulators\Arcade\Commodore 64\roms\Commodore 64.prg
10:46:40:045 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\hyperspin133\Emulators\Arcade\Commodore 64\roms\Commodore 64\Commodore 64.prg
10:46:40:045 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\hyperspin133\Emulators\Arcade\Commodore 64\roms\Commodore 64.t64
10:46:40:045 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\hyperspin133\Emulators\Arcade\Commodore 64\roms\Commodore 64\Commodore 64.t64
10:46:40:045 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\hyperspin133\Emulators\Arcade\Commodore 64\roms\Commodore 64.nib
10:46:40:045 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\hyperspin133\Emulators\Arcade\Commodore 64\roms\Commodore 64\Commodore 64.nib
"Commodore 64"
10:46:49:320 | RL |      INFO  | +0     | ExitScript - Started
10:46:49:323 | RL |      INFO  | +0     | ExitScript - Checking what application is currently in focus.
10:46:49:323 | RL |      INFO  | +0     | ExitScript - ErrorLayer is currently active. Putting focus back on RocketLauncherUI.exe with PID of 5648
10:46:49:861 | RL |      INFO  | +547   | SystemCursor - Restoring mouse cursor
10:46:49:865 | RL |      INFO  | +0     | ExitScript - Restored cursor
here is the commodore 64.ini - I don't think I changed anything in it at all. But perhaps I should?
[exe info]
path=
exe=
parameters=
pcgame=true
winstate=NORMAL
hyperlaunch=true
I have now set it to false and saved it:
[exe info]
path=
exe=
parameters=
pcgame=false
winstate=NORMAL
hyperlaunch=true
but I still get the same error:
20:25:10:586 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\hyperspin133\Emulators\Arcade\Commodore 64\roms\Commodore 64.t64
20:25:10:586 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\hyperspin133\Emulators\Arcade\Commodore 64\roms\Commodore 64\Commodore 64.t64
20:25:10:586 | RL |      INFO  | +0     | CheckPaths - Rom not found
20:25:10:586 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\hyperspin133\Emulators\Arcade\Commodore 64\roms\Commodore 64.nib
20:25:10:586 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\hyperspin133\Emulators\Arcade\Commodore 64\roms\Commodore 64\Commodore 64.nib
20:25:17:536 | RL |     ERROR  | +6953  | Cannot find Rom
Ok I did just that - and here is the new rocketlauncher.log file after running hyperspin again and seeing the same error:
21:16:58:046 | RL |      INFO  | +N/A   | Main - RocketLauncher v1.1.0.7 (www.rlauncher.com)
21:16:58:330 | RL |      INFO  | +297   | Main - System Specs:
SKU: Windows 8
Free Memory: 1773.49 MB
Used Memory: 2277.984 MB
SystemType: 64-bit
OS Language: Danish
OS Admin Status: No
Monitor #1 DPI: 100
AutoHotkey Path:
Unicode: No
21:16:58:334 | RL |      INFO  | +0     | CheckFile - Checking if C:\hyperspin133\RocketLauncher\RocketLauncher.exe exists
21:16:58:347 | RL |     DEBUG  | +15    | CheckFile - Attributes:
FileDescription         RocketLauncher
FileVersion             1.1.0.7
LegalCopyright           ©2015 RocketLauncher
ProductName             djvj's one swell guy!
ProductVersion           1.1.0.7
CompanyName             Your favorite Front End companion! Visit us @ www.rlauncher.com
File Size: 2162688 bytes
Created: 7/17/2015 - 10:44:44
Modified: 6/26/2016 - 9:29:54
21:16:58:361 | RL |     TRACE  | +16    | File.__New - Creating new file object of: "C:\hyperspin133\RocketLauncher\Module Extensions\RocketLauncher.dll"
21:16:58:376 | RL |      INFO  | +16    | File.CheckFile - Checking if "C:\hyperspin133\RocketLauncher\Module Extensions\RocketLauncher.dll" exists
21:16:58:378 | RL |     TRACE  | +0     | File.Exist - This file exists: C:\hyperspin133\RocketLauncher\Module Extensions\RocketLauncher.dll
21:16:58:381 | RL |     DEBUG  | +0     | File.CheckFile - Attributes:
FileDescription         RocketLauncher Utils
FileVersion             1.0.0.8
InternalName             RocketLauncher.dll
LegalCopyright           Copyright © RocketLauncher 2013-2016
OriginalFilename         RocketLauncher.dll
ProductName             RocketLauncher
ProductVersion           1.0.0.8
File Size: 67072 bytes
Created: 3/16/2015 - 8:12:32
Modified: 6/26/2016 - 9:29:05
21:16:58:415 | RL |      INFO  | +31    | CRC Check - CRC matches, this is an official unedited Extension: C:\hyperspin133\RocketLauncher\Module Extensions\Array.ahk
21:16:58:419 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 4781 bytes
Created: 6/26/2016 - 9:29:55
Modified: 6/26/2016 - 9:29:56
21:16:58:458 | RL |      INFO  | +47    | CRC Check - CRC matches, this is an official unedited Library: C:\hyperspin133\RocketLauncher\Module Extensions\BinHexRW.ahk | v1.0.2
21:16:58:461 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 5077 bytes
Created: 6/4/2014 - 11:48:12
Modified: 6/26/2016 - 9:28:41
21:16:58:464 | RL |      INFO  | +0     | CheckFile - Checking if C:\hyperspin133\RocketLauncher\Module Extensions\BlockInput.exe exists
21:16:58:678 | RL |     DEBUG  | +219   | CheckFile - Attributes:
FileDescription
FileVersion             1.1.09.04
InternalName
OriginalFilename
ProductName
ProductVersion           1.1.09.04
File Size: 657920 bytes
Created: 1/2/2014 - 10:27:34
Modified: 6/26/2016 - 9:25:07
21:16:58:728 | RL |      INFO  | +46    | CRC Check - CRC matches, this is an official unedited Extension: C:\hyperspin133\RocketLauncher\Module Extensions\CLR_L.ahk | vInterop
21:16:58:731 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 5323 bytes
Created: 6/26/2016 - 9:28:39
Modified: 6/26/2016 - 9:28:40
21:16:58:763 | RL |      INFO  | +32    | CRC Check - CRC matches, this is an official unedited Extension: C:\hyperspin133\RocketLauncher\Module Extensions\Control_AniGif.ahk | vAniGif.ahk
21:16:58:771 | RL |     DEBUG  | +15    | CheckFile - Attributes:
File Size: 5716 bytes
Created: 4/29/2013 - 2:56:02
21:16:58:808 | RL |      INFO  | +32    | CRC Check - CRC matches, this is an official unedited Extension: C:\hyperspin133\RocketLauncher\Module Extensions\gdip.ahk
21:16:58:812 | RL |     DEBUG  | +15    | CheckFile - Attributes:
File Size: 88789 bytes
Created: 1/13/2013 - 5:07:30
Modified: 6/26/2016 - 9:25:08
21:16:58:843 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: C:\hyperspin133\RocketLauncher\Module Extensions\gdip_alt.ahk | v1.0.3
21:16:58:846 | RL |     DEBUG  | +15    | CheckFile - Attributes:
File Size: 5891 bytes
Created: 6/26/2015 - 10:28:42
Modified: 6/26/2016 - 9:29:55
21:16:58:852 | RL |      INFO  | +0     | CheckFile - Checking if C:\hyperspin133\RocketLauncher\Module Extensions\gsdll32.dll exists
21:16:58:923 | RL |     DEBUG  | +79    | CheckFile - Attributes:
File Size: 13090816 bytes
Created: 1/6/2015 - 9:20:42
Modified: 6/26/2016 - 9:25:09
21:16:58:926 | RL |      INFO  | +0     | CheckFile - Checking if C:\hyperspin133\RocketLauncher\Module Extensions\itextsharp.dll exists
21:16:59:041 | RL |     DEBUG  | +109   | CheckFile - Attributes:
FileDescription         iTextSharp
FileVersion             5.4.2.0
InternalName             itextsharp.dll
LegalCopyright           Copyright (C) 1999-2013 by Bruno Lowagie and Paulo Soares. All Rights Reserved.
OriginalFilename         itextsharp.dll
ProductName             iTextSharp
ProductVersion           5.4.2.0
CompanyName             1T3XT BVBA
File Size: 3743744 bytes
Created: 6/14/2013 - 3:06:20
21:16:59:076 | RL |      INFO  | +31    | CRC Check - CRC matches, this is an official unedited Library: C:\hyperspin133\RocketLauncher\Module Extensions\Java.ahk | v1.0.0
21:16:59:079 | RL |     DEBUG  | +16    | CheckFile - Attributes:
File Size: 7841 bytes
Created: 12/23/2014 - 11:02:36
21:16:59:108 | RL |      INFO  | +15    | CRC Check - CRC matches, this is an official unedited Extension: C:\hyperspin133\RocketLauncher\Module Extensions\JSON.ahk
21:16:59:112 | RL |     DEBUG  | +16    | CheckFile - Attributes:
File Size: 9227 bytes
Created: 5/5/2013 - 3:22:24
Modified: 6/26/2016 - 9:27:49
21:16:59:146 | RL |      INFO  | +31    | CRC Check - CRC matches, this is an official unedited Library: C:\hyperspin133\RocketLauncher\Module Extensions\Origin.ahk | v1.0.2
21:16:59:153 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 4904 bytes
Created: 3/22/2015 - 3:51:40
Modified: 6/26/2016 - 9:25:10
21:16:59:179 | RL |      INFO  | +32    | CRC Check - CRC matches, this is an official unedited Extension: C:\hyperspin133\RocketLauncher\Module Extensions\RegRW64.ahk
21:16:59:183 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 6915 bytes
Created: 5/8/2014 - 4:06:38
21:16:59:246 | RL |      INFO  | +62    | CRC Check - CRC matches, this is an official unedited Extension: C:\hyperspin133\RocketLauncher\Module Extensions\RIni.ahk | v1.7
21:16:59:254 | RL |     DEBUG  | +16    | CheckFile - Attributes:
File Size: 67561 bytes
Created: 6/5/2013 - 7:56:22
21:16:59:257 | RL |      INFO  | +0     | CheckFile - Checking if C:\hyperspin133\RocketLauncher\Module Extensions\SevenZipSharp.dll exists
21:16:59:308 | RL |     DEBUG  | +47    | CheckFile - Attributes:
FileDescription         SevenZipSharp
FileVersion             0.64.5717.6837
InternalName             SevenZipSharp.dll
LegalCopyright           Copyright (C) Markovtsev Vadim 2009, 2010, licenced under LGPLv3
OriginalFilename         SevenZipSharp.dll
ProductName             SevenZipSharp
ProductVersion           0.64.5717.6837
CompanyName             Markovtsev Vadim
File Size: 167424 bytes
Created: 4/21/2013 - 12:08:10
Modified: 6/26/2016 - 9:29:42
21:16:59:340 | RL |      INFO  | +31    | CRC Check - CRC matches, this is an official unedited Library: C:\hyperspin133\RocketLauncher\Module Extensions\Steam.ahk | v1.0.3
21:16:59:344 | RL |     DEBUG  | +15    | CheckFile - Attributes:
File Size: 5504 bytes
Created: 3/22/2015 - 3:52:24
Modified: 6/26/2016 - 9:27:37
21:16:59:391 | RL |      INFO  | +47    | CRC Check - CRC matches, this is an official unedited Extension: C:\hyperspin133\RocketLauncher\Module Extensions\VA.ahk
21:16:59:394 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 34688 bytes
Created: 3/1/2013 - 9:05:46
21:16:59:427 | RL |      INFO  | +32    | CRC Check - CRC matches, this is an official unedited Library: C:\hyperspin133\RocketLauncher\Module Extensions\VA_Extension.ahk | v1.0.1
21:16:59:431 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 3833 bytes
Created: 1/13/2015 - 8:16:56
21:16:59:454 | RL |      INFO  | +31    | CRC Check - CRC matches, this is an official unedited Library: C:\hyperspin133\RocketLauncher\Lib\7z.ahk | v1.0.8
21:16:59:458 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 31307 bytes
Created: 5/29/2015 - 4:22:34
Modified: 6/26/2016 - 9:29:46
21:16:59:478 | RL |      INFO  | +15    | CRC Check - CRC matches, this is an official unedited Library: C:\hyperspin133\RocketLauncher\Lib\Bezel.ahk | v1.2.3
21:16:59:483 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 117029 bytes
Created: 6/17/2015 - 10:54:26
Modified: 6/26/2016 - 9:28:52
21:16:59:505 | RL |      INFO  | +32    | CRC Check - CRC matches, this is an official unedited Library: C:\hyperspin133\RocketLauncher\Lib\Fade.ahk | v1.1.8
21:16:59:509 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 39529 bytes
Created: 6/17/2015 - 10:56:04
Modified: 6/26/2016 - 9:29:18
21:16:59:528 | RL |      INFO  | +15    | CRC Check - CRC matches, this is an official unedited Library: C:\hyperspin133\RocketLauncher\Lib\Fade Init.ahk | v1.0.3
21:16:59:536 | RL |     DEBUG  | +16    | CheckFile - Attributes:
File Size: 1130 bytes
Created: 12/23/2014 - 11:21:02
Modified: 6/26/2016 - 9:28:46
21:16:59:556 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: C:\hyperspin133\RocketLauncher\Lib\Fade Animations.ahk | v1.2.2
21:16:59:560 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 77906 bytes
Created: 5/14/2015 - 5:00:06
Modified: 6/26/2016 - 9:29:16
21:16:59:581 | RL |      INFO  | +31    | CRC Check - CRC matches, this is an official unedited Library: C:\hyperspin133\RocketLauncher\Lib\Keymapper.ahk | v1.1.5
21:16:59:588 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 33668 bytes
Created: 5/21/2015 - 9:44:52
Modified: 6/26/2016 - 9:28:22
21:16:59:606 | RL |      INFO  | +15    | CRC Check - CRC matches, this is an official unedited Library: C:\hyperspin133\RocketLauncher\Lib\Keymapper Init.ahk | v1.0.6
21:16:59:610 | RL |     DEBUG  | +16    | CheckFile - Attributes:
File Size: 3956 bytes
Created: 5/21/2015 - 9:44:42
Modified: 6/26/2016 - 9:28:42
21:16:59:628 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: C:\hyperspin133\RocketLauncher\Lib\MultiGame.ahk | v1.1.0
21:16:59:636 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 41541 bytes
Created: 7/7/2015 - 9:28:30
Modified: 6/26/2016 - 9:29:35
21:16:59:667 | RL |      INFO  | +31    | CRC Check - CRC matches, this is an official unedited Library: C:\hyperspin133\RocketLauncher\Lib\MultiGame Init.ahk | v1.0.0
21:16:59:675 | RL |     DEBUG  | +16    | CheckFile - Attributes:
File Size: 161 bytes
Created: 4/14/2013 - 2:33:18
Modified: 6/26/2016 - 9:25:01
21:16:59:696 | RL |      INFO  | +15    | CRC Check - CRC matches, this is an official unedited Library: C:\hyperspin133\RocketLauncher\Lib\MultiPlayer.ahk | v1.0.8
21:16:59:704 | RL |     DEBUG  | +16    | CheckFile - Attributes:
File Size: 66776 bytes
Created: 7/7/2015 - 9:35:48
21:16:59:743 | RL |      INFO  | +31    | CRC Check - CRC matches, this is an official unedited Library: C:\hyperspin133\RocketLauncher\Lib\Pause.ahk | v1.2.3
21:16:59:747 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 396844 bytes
Created: 7/7/2015 - 9:25:24
Modified: 6/26/2016 - 9:29:07
21:16:59:769 | RL |      INFO  | +31    | CRC Check - CRC matches, this is an official unedited Library: C:\hyperspin133\RocketLauncher\Lib\Pause Init.ahk | v1.0.3
21:16:59:774 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 553 bytes
Created: 4/9/2015 - 5:13:28
Modified: 6/26/2016 - 9:27:47
21:16:59:794 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: C:\hyperspin133\RocketLauncher\Lib\Password.ahk | v1.0.4
21:16:59:798 | RL |     DEBUG  | +16    | CheckFile - Attributes:
File Size: 10121 bytes
Created: 4/9/2015 - 5:15:54
Modified: 6/26/2016 - 9:27:52
21:16:59:821 | RL |      INFO  | +15    | CRC Check - CRC matches, this is an official unedited Library: C:\hyperspin133\RocketLauncher\Lib\Classes\DLL\RocketLauncher.ahk | v1.7
21:16:59:825 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 25300 bytes
Created: 6/26/2016 - 9:29:43
Modified: 6/26/2016 - 9:29:43
21:16:59:845 | RL |      INFO  | +31    | CRC Check - CRC matches, this is an official unedited Library: C:\hyperspin133\RocketLauncher\Lib\Classes\Log\Logger.ahk | v1.1
21:16:59:853 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 3095 bytes
Created: 6/26/2016 - 9:29:44
Modified: 6/26/2016 - 9:29:45
21:16:59:874 | RL |      INFO  | +32    | CRC Check - CRC matches, this is an official unedited Library: C:\hyperspin133\RocketLauncher\Lib\Classes\Util\MiscUtils.ahk | v1.1
21:16:59:878 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 5720 bytes
Created: 6/26/2016 - 9:27:41
Modified: 6/26/2016 - 9:27:41
21:16:59:898 | RL |      INFO  | +15    | CRC Check - CRC matches, this is an official unedited Library: C:\hyperspin133\RocketLauncher\Lib\Classes\Util\Environment\Registry.ahk | v1.0
21:16:59:906 | RL |     DEBUG  | +16    | CheckFile - Attributes:
File Size: 1547 bytes
Created: 6/26/2016 - 9:27:31
Modified: 6/26/2016 - 9:27:32
21:16:59:927 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: C:\hyperspin133\RocketLauncher\Lib\Classes\Util\Environment\StringUtils.ahk | v1.5
21:16:59:931 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 7789 bytes
Created: 6/26/2016 - 9:27:45
Modified: 6/26/2016 - 9:27:46
21:16:59:953 | RL |      INFO  | +31    | CRC Check - CRC matches, this is an official unedited Library: C:\hyperspin133\RocketLauncher\Lib\Classes\Util\Environment\TimerUtils.ahk | v1.0
21:16:59:957 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 2961 bytes
Created: 6/26/2016 - 9:29:54
21:16:59:977 | RL |      INFO  | +15    | CRC Check - CRC matches, this is an official unedited Library: C:\hyperspin133\RocketLauncher\Lib\Classes\Util\File\File.ahk | v1.5
21:16:59:981 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 9145 bytes
Created: 6/26/2016 - 9:27:51
Modified: 6/26/2016 - 9:27:51
21:16:59:005 | RL |      INFO  | +32    | CRC Check - CRC matches, this is an official unedited Library: C:\hyperspin133\RocketLauncher\Lib\Classes\Util\File\Folder.ahk | v1.0
21:17:00:010 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 646 bytes
Created: 6/26/2016 - 9:29:18
21:17:00:029 | RL |      INFO  | +15    | CRC Check - CRC matches, this is an official unedited Library: C:\hyperspin133\RocketLauncher\Lib\Classes\Util\File\IniFile.ahk | v1.0
21:17:00:037 | RL |     DEBUG  | +16    | CheckFile - Attributes:
File Size: 4410 bytes
Created: 6/26/2016 - 9:29:08
Modified: 6/26/2016 - 9:29:08
21:17:00:056 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: C:\hyperspin133\RocketLauncher\Lib\Classes\Util\File\RIniFile.ahk | v1.0
21:17:00:060 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 3705 bytes
Created: 6/26/2016 - 9:29:15
Modified: 6/26/2016 - 9:29:15
21:17:00:079 | RL |      INFO  | +31    | CRC Check - CRC matches, this is an official unedited Library: C:\hyperspin133\RocketLauncher\Lib\Classes\Util\File\Process.ahk | v1.5
21:17:00:086 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 9583 bytes
Created: 6/26/2016 - 9:28:21
Modified: 6/26/2016 - 9:28:21
21:17:00:107 | RL |      INFO  | +15    | CRC Check - CRC matches, this is an official unedited Library: C:\hyperspin133\RocketLauncher\Lib\Classes\Util\File\Emulator.ahk | v1.1
21:17:00:111 | RL |     DEBUG  | +16    | CheckFile - Attributes:
File Size: 1218 bytes
Modified: 6/26/2016 - 9:27:31
21:17:00:130 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: C:\hyperspin133\RocketLauncher\Lib\Classes\Util\Input\KeyUtils.ahk | v1.0
21:17:00:139 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 5386 bytes
Created: 6/26/2016 - 9:27:59
Modified: 6/26/2016 - 9:27:59
21:17:00:158 | RL |      INFO  | +31    | CRC Check - CRC matches, this is an official unedited Library: C:\hyperspin133\RocketLauncher\Lib\Classes\Util\UI\Control.ahk | v1.2
21:17:00:162 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 4559 bytes
Created: 6/26/2016 - 9:29:27
Modified: 6/26/2016 - 9:29:27
21:17:00:182 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: C:\hyperspin133\RocketLauncher\Lib\Classes\Util\UI\Window.ahk | v1.2
21:17:00:188 | RL |     DEBUG  | +15    | CheckFile - Attributes:
File Size: 22844 bytes
Created: 6/26/2016 - 9:27:54
Modified: 6/26/2016 - 9:27:55
21:17:00:209 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: C:\hyperspin133\RocketLauncher\Lib\Classes\Util\UI\WindowTitle.ahk | v1.0
21:17:00:212 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 1154 bytes
Created: 6/26/2016 - 9:29:42
21:17:00:237 | RL |      INFO  | +31    | CRC Check - CRC matches, this is an official unedited Library: C:\hyperspin133\RocketLauncher\Lib\Rom Mapping Launch Menu.ahk | v1.0.7
21:17:00:241 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 72261 bytes
Created: 7/7/2015 - 9:35:42
Modified: 6/26/2016 - 9:28:15
21:17:00:260 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: C:\hyperspin133\RocketLauncher\Lib\Shader.ahk | v1.0.1
21:17:00:264 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 3943 bytes
Created: 6/26/2016 - 9:29:29
Modified: 6/26/2016 - 9:29:30
21:17:00:281 | RL |      INFO  | +31    | CRC Check - CRC matches, this is an official unedited Library: C:\hyperspin133\RocketLauncher\Lib\Shader Init.ahk | v1.0.0
21:17:00:289 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 397 bytes
Created: 6/26/2016 - 9:28:20
Modified: 6/26/2016 - 9:28:20
21:17:00:340 | RL |      INFO  | +47    | CRC Check - CRC matches, this is an official unedited Library: C:\hyperspin133\RocketLauncher\Lib\Shared.ahk | v1.4.5
21:17:00:344 | RL |     DEBUG  | +15    | CheckFile - Attributes:
File Size: 175581 bytes
Created: 7/19/2015 - 4:16:10
Modified: 6/26/2016 - 9:28:08
21:17:00:363 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: C:\hyperspin133\RocketLauncher\Lib\Statistics.ahk | v1.0.4
21:17:00:371 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 26810 bytes
Created: 4/9/2015 - 5:16:56
Modified: 6/26/2016 - 9:30:07
21:17:00:391 | RL |      INFO  | +31    | CRC Check - CRC matches, this is an official unedited Library: C:\hyperspin133\RocketLauncher\Lib\Statistics Init.ahk | v1.0.1
21:17:00:394 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 33 bytes
Created: 12/23/2014 - 11:23:48
Modified: 6/26/2016 - 9:25:02
21:17:00:414 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: C:\hyperspin133\RocketLauncher\Lib\Virtual Drive.ahk | v1.0.5
21:17:00:422 | RL |     DEBUG  | +16    | CheckFile - Attributes:
File Size: 19148 bytes
Created: 5/29/2015 - 4:22:44
Modified: 6/26/2016 - 9:28:10
21:17:00:441 | RL |      INFO  | +15    | CRC Check - CRC matches, this is an official unedited Library: C:\hyperspin133\RocketLauncher\Lib\XHotkey.ahk | v1.0.4
21:17:00:445 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 26540 bytes
Created: 4/9/2015 - 5:17:24
Modified: 6/26/2016 - 9:27:30
21:17:00:464 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: C:\hyperspin133\RocketLauncher\Lib\XHotkey Init.ahk | v1.0.2
21:17:00:472 | RL |     DEBUG  | +15    | CheckFile - Attributes:
File Size: 1063 bytes
Created: 4/14/2013 - 2:33:16
Modified: 6/26/2016 - 9:29:34
21:17:00:476 | RL |      INFO  | +0     | Main - Raw CLI received: "Commodore 64 Commodore 64"
21:17:00:479 | RL |     DEBUG  | +0     | Main - Received this dbName with no path via CLI: "Commodore 64"
21:17:00:486 | RL |     DEBUG  | +16    | Main - dbName: Commodore 64
21:17:00:489 | RL |      INFO  | +0     | Main - Loading Front End Plugin: "RocketLauncherUI"
21:17:00:493 | RL |     TRACE  | +0     | Process.__New - Creating new process object for: "C:\hyperspin133\RocketLauncher\RocketLauncherUI\RocketLauncherUI.exe"
21:17:00:496 | RL |     TRACE  | +0     | File.__New - Creating new file object of: "C:\hyperspin133\RocketLauncher\RocketLauncherUI\RocketLauncherUI.exe"
21:17:00:513 | RL |      INFO  | +16    | Process.Process - "Exist" "RocketLauncherUI.exe"
21:17:00:520 | RL |     TRACE  | +15    | Process.GetProcessID
21:17:00:527 | RL |      INFO  | +0     | Main - Detected RocketLauncherUI.exe is currently running
21:17:00:531 | RL |     TRACE  | +16    | Window.__New - Created: "ahk_pid 3992"
21:17:00:539 | RL |     TRACE  | +0     | Window.Get - ID is "0x2e04d6" from "ahk_pid 3992"
21:17:00:542 | RL |     TRACE  | +0     | Window.GetPos - Retrieved x:541 y:205 w: 1355 h: 960 from "ahk_id 0x2e04d6"
21:17:00:546 | RL |      INFO  | +0     | Main - RocketLauncherUI.exe coordinates are x541 y205 w1355 h960
21:17:00:553 | RL |      INFO  | +16    | Main - RocketLauncher received "Commodore 64" and "Commodore 64"
21:17:00:564 | RL |      INFO  | +15    | Main - Did not find a "C:\hyperspin133\RocketLauncher\Settings\Commodore 64\Game Options.ini" file, skipping any game-specific options.
21:17:00:571 | RL |      INFO  | +0     | Main - Commodore 64 is using the default emulator: WinVICE
21:17:00:575 | RL |      INFO  | +0     | Main - Checking for a [WinVICE] section in C:\hyperspin133\RocketLauncher\Settings\Commodore 64\Emulators.ini
21:17:00:578 | RL |      INFO  | +16    | Main - Checking for a [WinVICE] section in C:\hyperspin133\RocketLauncher\Settings\Global Emulators.ini
21:17:00:582 | RL |      INFO  | +0     | Main - Found [WinVICE] in C:\hyperspin133\RocketLauncher\Settings\Global Emulators.ini
21:17:00:589 | RL | TRACE_DLL  | +0     | RLDLL.getFullPathFromRelative - Converting "WinVICE.ahk"
21:17:00:609 | RL | TRACE_DLL  | +31    | RLDLL.getFullPathFromRelative - Converted to "C:\hyperspin133\RocketLauncher\Modules\WinVICE\WinVICE.ahk"
21:17:00:624 | RL |      INFO  | +0     | CheckFile - Checking if C:\hyperspin133\RocketLauncher\Modules\WinVICE\WinVICE.ahk exists
21:17:00:640 | RL |     DEBUG  | +31    | CheckFile - Attributes:
File Size: 25161 bytes
Created: 7/7/2015 - 10:20:24
Modified: 6/26/2016 - 9:28:55
21:17:00:647 | RL |      INFO  | +0     | Main - CRC Check - CRC matches, this is an official unedited module.
21:17:00:654 | RL |      INFO  | +0     | Main - Commodore 64 will use module: C:\hyperspin133\RocketLauncher\Modules\WinVICE\WinVICE.ahk
21:17:00:658 | RL | TRACE_DLL  | +16    | RLDLL.getFullPathFromRelative - Converting ".\Profiles"
21:17:00:679 | RL | TRACE_DLL  | +16    | RLDLL.getFullPathFromRelative - Converted to "C:\hyperspin133\RocketLauncher\Profiles"
21:17:00:686 | RL | TRACE_DLL  | +0     | RLDLL.getFullPathFromRelative - Converting ".\Module Extensions\7z.exe"
21:17:00:708 | RL | TRACE_DLL  | +31    | RLDLL.getFullPathFromRelative - Converted to "C:\hyperspin133\RocketLauncher\Module Extensions\7z.exe"
21:17:00:711 | RL | TRACE_DLL  | +0     | RLDLL.getFullPathFromRelative - Converting "C:\hyperspin133\RocketLauncher\Module Extensions\dxwnd\dxwnd.exe"
21:17:00:725 | RL | TRACE_DLL  | +15    | RLDLL.getFullPathFromRelative - Converted to "C:\hyperspin133\RocketLauncher\Module Extensions\dxwnd\dxwnd.exe"
21:17:00:742 | RL | TRACE_DLL  | +16    | RLDLL.getFullPathFromRelative - Converting ".\Module Extensions\HiToText.exe"
21:17:00:763 | RL | TRACE_DLL  | +16    | RLDLL.getFullPathFromRelative - Converted to "C:\hyperspin133\RocketLauncher\Module Extensions\HiToText.exe"
21:17:00:771 | RL | TRACE_DLL  | +15    | RLDLL.getFullPathFromRelative - Converting "..\Utilities\Xpadder\xpadder.exe"
21:17:00:791 | RL | TRACE_DLL  | +16    | RLDLL.getFullPathFromRelative - Converted to "C:\hyperspin133\Utilities\Xpadder\xpadder.exe"
21:17:00:795 | RL | TRACE_DLL  | +0     | RLDLL.getFullPathFromRelative - Converting "..\Utilities\JoyToKey\JoyToKey.exe"
21:17:00:820 | RL | TRACE_DLL  | +31    | RLDLL.getFullPathFromRelative - Converted to "C:\hyperspin133\Utilities\JoyToKey\JoyToKey.exe"
21:17:00:824 | RL | TRACE_DLL  | +0     | RLDLL.getFullPathFromRelative - Converting "..\Utilities\VJoy\VJoy.exe"
21:17:00:845 | RL | TRACE_DLL  | +31    | RLDLL.getFullPathFromRelative - Converted to "C:\hyperspin133\Utilities\VJoy\VJoy.exe"
21:17:00:854 | RL |   WARNING  | +0     | RIniLoadVar - Created missing Global ini key: "Fade_Click_Through " in section: "Fade" in "C:\hyperspin133\RocketLauncher\Settings\Global RocketLauncher.ini"
21:17:00:863 | RL | TRACE_DLL  | +16    | RLDLL.getFullPathFromRelative - Converting "C:\Users\nick\AppData\Local\Temp\HS"
21:17:00:877 | RL | TRACE_DLL  | +16    | RLDLL.getFullPathFromRelative - Converted to "C:\Users\nick\AppData\Local\Temp\HS"
21:17:00:894 | RL |      INFO  | +15    | Main - Using standard method with "Rom Extension" SkipChecks or without any SkipChecks.
21:17:00:898 | RL | TRACE_DLL  | +0     | RLDLL.getFullPathFromRelative - Converting "..\Emulators\Arcade\Commodore 64\roms"
21:17:00:921 | RL | TRACE_DLL  | +32    | RLDLL.getFullPathFromRelative - Converted to "C:\hyperspin133\Emulators\Arcade\Commodore 64\roms"
21:17:00:925 | RL | TRACE_DLL  | +0     | RLDLL.getFullPathFromRelative - Converting "..\Emulators\WinVICE\x64.exe"
21:17:00:944 | RL | TRACE_DLL  | +15    | RLDLL.getFullPathFromRelative - Converted to "C:\hyperspin133\Emulators\WinVICE\x64.exe"
21:17:00:961 | RL |      INFO  | +16    | CheckFile - Checking if C:\hyperspin133\Emulators\WinVICE\x64.exe exists
21:17:01:685 | RL |     DEBUG  | +719   | CheckFile - Attributes:
FileDescription         Vice C64 Emulator
FileVersion             2.3
ProductName             Vice C64 Emulator
ProductVersion           2.3
CompanyName             Vice Team
File Size: 2906112 bytes
Created: 6/26/2016 - 11:43:25
Modified: 6/28/2016 - 9:00:06
21:17:01:689 | RL |      INFO  | +15    | Main - INI Keys read
21:17:01:705 | RL |      INFO  | +16    | CheckFile - Checking if C:\hyperspin133\RocketLauncher\Module Extensions\7z.exe exists
21:17:01:758 | RL |     DEBUG  | +47    | CheckFile - Attributes:
FileDescription         7-Zip Console
FileVersion             15.06 beta
InternalName             7z
LegalCopyright           Copyright (c) 1999-2015 Igor Pavlov
OriginalFilename         7z.exe
ProductName             7-Zip
ProductVersion           15.06 beta
CompanyName             Igor Pavlov
File Size: 262144 bytes
Created: 3/5/2013 - 9:21:50
Modified: 6/26/2016 - 9:27:56
21:17:01:761 | RL |      INFO  | +0     | CheckFile - Checking if C:\hyperspin133\RocketLauncher\Module Extensions\7z.dll exists
21:17:01:847 | RL |     DEBUG  | +93    | CheckFile - Attributes:
FileDescription         7z Plugin
InternalName             7z
OriginalFilename         7z.dll
ProductName             7-Zip
File Size: 1012224 bytes
Created: 3/5/2013 - 9:21:48
Modified: 6/26/2016 - 9:30:05
21:17:01:857 | RL |      INFO  | +0     | Main - "Commodore 64" does not qualify for MultiGame. Only roms with any of these strings in their name are acceptable: \(Disc|\(Disk|\(Cart|\(Tape|\(Cassette|\(Part|\(Side
21:17:01:861 | RL |      INFO  | +16    | CheckPaths - Started
21:17:01:864 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\hyperspin133\Emulators\Arcade\Commodore 64\roms\Commodore 64.7z
21:17:01:869 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\hyperspin133\Emulators\Arcade\Commodore 64\roms\Commodore 64\Commodore 64.7z
21:17:01:872 | RL |      INFO  | +0     | CheckPaths - Rom not found
21:17:01:876 | RL |      INFO  | +16    | CheckPaths - Looking for rom: C:\hyperspin133\Emulators\Arcade\Commodore 64\roms\Commodore 64.zip
21:17:01:879 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\hyperspin133\Emulators\Arcade\Commodore 64\roms\Commodore 64\Commodore 64.zip
21:17:01:882 | RL |      INFO  | +0     | CheckPaths - Rom not found
21:17:01:885 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\hyperspin133\Emulators\Arcade\Commodore 64\roms\Commodore 64.crt
21:17:01:888 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\hyperspin133\Emulators\Arcade\Commodore 64\roms\Commodore 64\Commodore 64.crt
21:17:01:891 | RL |      INFO  | +15    | CheckPaths - Rom not found
21:17:01:893 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\hyperspin133\Emulators\Arcade\Commodore 64\roms\Commodore 64.vsf
21:17:01:896 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\hyperspin133\Emulators\Arcade\Commodore 64\roms\Commodore 64\Commodore 64.vsf
21:17:01:902 | RL |      INFO  | +0     | CheckPaths - Rom not found
21:17:01:905 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\hyperspin133\Emulators\Arcade\Commodore 64\roms\Commodore 64.d64
21:17:01:908 | RL |      INFO  | +16    | CheckPaths - Looking for rom by name in subfolder: C:\hyperspin133\Emulators\Arcade\Commodore 64\roms\Commodore 64\Commodore 64.d64
21:17:01:911 | RL |      INFO  | +0     | CheckPaths - Rom not found
21:17:01:914 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\hyperspin133\Emulators\Arcade\Commodore 64\roms\Commodore 64.g64
21:17:01:917 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\hyperspin133\Emulators\Arcade\Commodore 64\roms\Commodore 64\Commodore 64.g64
21:17:01:920 | RL |      INFO  | +0     | CheckPaths - Rom not found
21:17:01:923 | RL |      INFO  | +16    | CheckPaths - Looking for rom: C:\hyperspin133\Emulators\Arcade\Commodore 64\roms\Commodore 64.tap
21:17:01:926 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\hyperspin133\Emulators\Arcade\Commodore 64\roms\Commodore 64\Commodore 64.tap
21:17:01:929 | RL |      INFO  | +0     | CheckPaths - Rom not found
21:17:01:932 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\hyperspin133\Emulators\Arcade\Commodore 64\roms\Commodore 64.prg
21:17:01:937 | RL |      INFO  | +15    | CheckPaths - Looking for rom by name in subfolder: C:\hyperspin133\Emulators\Arcade\Commodore 64\roms\Commodore 64\Commodore 64.prg
21:17:01:940 | RL |      INFO  | +0     | CheckPaths - Rom not found
21:17:01:943 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\hyperspin133\Emulators\Arcade\Commodore 64\roms\Commodore 64.t64
21:17:01:946 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\hyperspin133\Emulators\Arcade\Commodore 64\roms\Commodore 64\Commodore 64.t64
21:17:01:949 | RL |      INFO  | +0     | CheckPaths - Rom not found
21:17:01:952 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\hyperspin133\Emulators\Arcade\Commodore 64\roms\Commodore 64.nib
21:17:01:955 | RL |      INFO  | +16    | CheckPaths - Looking for rom by name in subfolder: C:\hyperspin133\Emulators\Arcade\Commodore 64\roms\Commodore 64\Commodore 64.nib
21:17:01:958 | RL |      INFO  | +0     | CheckPaths - Rom not found
21:17:01:961 | RL |     DEBUG  | +0     | CheckPaths - Current romName:
21:17:01:964 | RL |     DEBUG  | +0     | CheckPaths - Current romPath:
21:17:01:969 | RL |     DEBUG  | +15    | CheckPaths - Current romExtension:
21:17:02:302 | RL |     DEBUG  | +329   | ScriptError - Playing error sound: error10.mp3
21:17:04:458 | RL |     ERROR  | +2156  | Cannot find Rom
"Commodore 64"
21:17:04:463 | RL |      INFO  | +0     | ExitScript - Started
21:17:04:482 | RL |     TRACE  | +15    | Window.Get - Transparent is "" from "ahk_id 0x2e04d6"
21:17:04:485 | RL |      INFO  | +16    | ExitScript - Checking what application is currently in focus.
21:17:04:488 | RL |     TRACE  | +0     | Window.Active - "ahk_id 0x2e04d6" is not the active window
21:17:04:491 | RL |      INFO  | +0     | ExitScript - ErrorLayer is currently active. Putting focus back on RocketLauncherUI.exe with PID of 3992
21:17:04:494 | RL |     TRACE  | +0     | Window.Activate - Activating window "ahk_id 0x2e04d6"
21:17:04:615 | RL |     TRACE  | +125   | Window.Activate - Activating window "ahk_id 0x2e04d6"
21:17:04:727 | RL |     TRACE  | +109   | Window.Active - "ahk_id 0x2e04d6" is the active window
21:17:04:731 | RL |     DEBUG  | +0     | ExitScript - Took 1 attempts to put RocketLauncherUI.exe back in focus.
21:17:04:734 | RL |     TRACE  | +16    | StringUtils.Contains - "false" does not contain "true|kill"
21:17:04:737 | RL |     TRACE  | +0     | StringUtils.Contains - "false" does not contain "do_not_restore|kill_&_do_not_restore"
21:17:04:905 | RL |      INFO  | +156   | SystemCursor - Restoring mouse cursor
21:17:04:917 | RL |      INFO  | +16    | ExitScript - Restored cursor
I succefully ran the game "10th frame..." through rocketlauncherui using the games/system audit/"manually launch a game..." and this is how the rocketlauncher.log looked afterwards:
21:59:29:272 | RL |      INFO  | +N/A   | Main - RocketLauncher v1.1.0.7 (www.rlauncher.com)
21:59:29:504 | RL |      INFO  | +235   | Main - System Specs:
SKU: Windows 8
Free Memory: 1520.90 MB
Used Memory: 2530.574 MB
SystemType: 64-bit
OS Language: Danish
OS Admin Status: No
Monitor #1 DPI: 100
AutoHotkey Path:
Unicode: No
21:59:29:506 | RL |      INFO  | +0     | CheckFile - Checking if C:\hyperspin133\RocketLauncher\RocketLauncher.exe exists
21:59:29:536 | RL |     DEBUG  | +31    | CheckFile - Attributes:
FileVersion              1.1.0.7
21:59:29:583 | RL |     TRACE  | +47    | File.__New - Creating new file object of: "C:\hyperspin133\RocketLauncher\Module Extensions\RocketLauncher.dll"
21:59:29:602 | RL |      INFO  | +15    | File.CheckFile - Checking if "C:\hyperspin133\RocketLauncher\Module Extensions\RocketLauncher.dll" exists
21:59:29:605 | RL |     TRACE  | +0     | File.Exist - This file exists: C:\hyperspin133\RocketLauncher\Module Extensions\RocketLauncher.dll
21:59:29:608 | RL |     DEBUG  | +0     | File.CheckFile - Attributes:
FileVersion              1.0.0.8
21:59:29:628 | RL |      INFO  | +32    | CRC Check - CRC matches, this is an official unedited Extension: C:\hyperspin133\RocketLauncher\Module Extensions\Array.ahk
21:59:29:631 | RL |     DEBUG  | +0     | CheckFile - Attributes:
21:59:29:646 | RL |      INFO  | +15    | CRC Check - CRC matches, this is an official unedited Library: C:\hyperspin133\RocketLauncher\Module Extensions\BinHexRW.ahk | v1.0.2
21:59:29:649 | RL |     DEBUG  | +0     | CheckFile - Attributes:
21:59:29:652 | RL |      INFO  | +0     | CheckFile - Checking if C:\hyperspin133\RocketLauncher\Module Extensions\BlockInput.exe exists
21:59:29:779 | RL |     DEBUG  | +125   | CheckFile - Attributes:
FileDescription
InternalName
OriginalFilename
ProductName
21:59:29:793 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Extension: C:\hyperspin133\RocketLauncher\Module Extensions\CLR_L.ahk | vInterop
21:59:29:796 | RL |     DEBUG  | +0     | CheckFile - Attributes:
21:59:29:811 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Extension: C:\hyperspin133\RocketLauncher\Module Extensions\Control_AniGif.ahk | vAniGif.ahk
21:59:29:815 | RL |     DEBUG  | +15    | CheckFile - Attributes:
21:59:29:832 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Extension: C:\hyperspin133\RocketLauncher\Module Extensions\gdip.ahk
21:59:29:836 | RL |     DEBUG  | +0     | CheckFile - Attributes:
21:59:29:850 | RL |      INFO  | +15    | CRC Check - CRC matches, this is an official unedited Library: C:\hyperspin133\RocketLauncher\Module Extensions\gdip_alt.ahk | v1.0.3
21:59:29:853 | RL |     DEBUG  | +0     | CheckFile - Attributes:
21:59:29:856 | RL |      INFO  | +0     | CheckFile - Checking if C:\hyperspin133\RocketLauncher\Module Extensions\gsdll32.dll exists
21:59:29:934 | RL |     DEBUG  | +79    | CheckFile - Attributes:
21:59:29:938 | RL |      INFO  | +15    | CheckFile - Checking if C:\hyperspin133\RocketLauncher\Module Extensions\itextsharp.dll exists
21:59:30:041 | RL |     DEBUG  | +94    | CheckFile - Attributes:
FileVersion              5.4.2.0
21:59:30:063 | RL |      INFO  | +31    | CRC Check - CRC matches, this is an official unedited Library: C:\hyperspin133\RocketLauncher\Module Extensions\Java.ahk | v1.0.0
21:59:30:067 | RL |     DEBUG  | +0     | CheckFile - Attributes:
21:59:30:088 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Extension: C:\hyperspin133\RocketLauncher\Module Extensions\JSON.ahk
21:59:30:092 | RL |     DEBUG  | +0     | CheckFile - Attributes:
21:59:30:118 | RL |      INFO  | +31    | CRC Check - CRC matches, this is an official unedited Library: C:\hyperspin133\RocketLauncher\Module Extensions\Origin.ahk | v1.0.2
21:59:30:122 | RL |     DEBUG  | +0     | CheckFile - Attributes:
21:59:30:145 | RL |      INFO  | +31    | CRC Check - CRC matches, this is an official unedited Extension: C:\hyperspin133\RocketLauncher\Module Extensions\RegRW64.ahk
21:59:30:149 | RL |     DEBUG  | +0     | CheckFile - Attributes:
21:59:30:173 | RL |      INFO  | +32    | CRC Check - CRC matches, this is an official unedited Extension: C:\hyperspin133\RocketLauncher\Module Extensions\RIni.ahk | v1.7
21:59:30:176 | RL |     DEBUG  | +0     | CheckFile - Attributes:
21:59:30:179 | RL |      INFO  | +0     | CheckFile - Checking if C:\hyperspin133\RocketLauncher\Module Extensions\SevenZipSharp.dll exists
21:59:30:229 | RL |     DEBUG  | +46    | CheckFile - Attributes:
21:59:30:256 | RL |      INFO  | +32    | CRC Check - CRC matches, this is an official unedited Library: C:\hyperspin133\RocketLauncher\Module Extensions\Steam.ahk | v1.0.3
21:59:30:260 | RL |     DEBUG  | +0     | CheckFile - Attributes:
21:59:30:288 | RL |      INFO  | +31    | CRC Check - CRC matches, this is an official unedited Extension: C:\hyperspin133\RocketLauncher\Module Extensions\VA.ahk
21:59:30:291 | RL |     DEBUG  | +0     | CheckFile - Attributes:
21:59:30:314 | RL |      INFO  | +31    | CRC Check - CRC matches, this is an official unedited Library: C:\hyperspin133\RocketLauncher\Module Extensions\VA_Extension.ahk | v1.0.1
21:59:30:317 | RL |     DEBUG  | +0     | CheckFile - Attributes:
21:59:30:335 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: C:\hyperspin133\RocketLauncher\Lib\7z.ahk | v1.0.8
21:59:30:339 | RL |     DEBUG  | +0     | CheckFile - Attributes:
21:59:30:362 | RL |      INFO  | +31    | CRC Check - CRC matches, this is an official unedited Library: C:\hyperspin133\RocketLauncher\Lib\Bezel.ahk | v1.2.3
21:59:30:366 | RL |     DEBUG  | +0     | CheckFile - Attributes:
21:59:30:387 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: C:\hyperspin133\RocketLauncher\Lib\Fade.ahk | v1.1.8
21:59:30:391 | RL |     DEBUG  | +15    | CheckFile - Attributes:
21:59:30:413 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: C:\hyperspin133\RocketLauncher\Lib\Fade Init.ahk | v1.0.3
21:59:30:417 | RL |     DEBUG  | +0     | CheckFile - Attributes:
21:59:30:435 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: C:\hyperspin133\RocketLauncher\Lib\Fade Animations.ahk | v1.2.2
21:59:30:439 | RL |     DEBUG  | +15    | CheckFile - Attributes:
21:59:30:458 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: C:\hyperspin133\RocketLauncher\Lib\Keymapper.ahk | v1.1.5
21:59:30:461 | RL |     DEBUG  | +0     | CheckFile - Attributes:
21:59:30:479 | RL |      INFO  | +15    | CRC Check - CRC matches, this is an official unedited Library: C:\hyperspin133\RocketLauncher\Lib\Keymapper Init.ahk | v1.0.6
21:59:30:482 | RL |     DEBUG  | +0     | CheckFile - Attributes:
21:59:30:501 | RL |      INFO  | +32    | CRC Check - CRC matches, this is an official unedited Library: C:\hyperspin133\RocketLauncher\Lib\MultiGame.ahk | v1.1.0
21:59:30:505 | RL |     DEBUG  | +0     | CheckFile - Attributes:
21:59:30:523 | RL |      INFO  | +15    | CRC Check - CRC matches, this is an official unedited Library: C:\hyperspin133\RocketLauncher\Lib\MultiGame Init.ahk | v1.0.0
21:59:30:527 | RL |     DEBUG  | +0     | CheckFile - Attributes:
21:59:30:546 | RL |      INFO  | +32    | CRC Check - CRC matches, this is an official unedited Library: C:\hyperspin133\RocketLauncher\Lib\MultiPlayer.ahk | v1.0.8
21:59:30:550 | RL |     DEBUG  | +0     | CheckFile - Attributes:
21:59:30:573 | RL |      INFO  | +15    | CRC Check - CRC matches, this is an official unedited Library: C:\hyperspin133\RocketLauncher\Lib\Pause.ahk | v1.2.3
21:59:30:577 | RL |     DEBUG  | +0     | CheckFile - Attributes:
21:59:30:595 | RL |      INFO  | +31    | CRC Check - CRC matches, this is an official unedited Library: C:\hyperspin133\RocketLauncher\Lib\Pause Init.ahk | v1.0.3
21:59:30:599 | RL |     DEBUG  | +0     | CheckFile - Attributes:
21:59:30:617 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: C:\hyperspin133\RocketLauncher\Lib\Password.ahk | v1.0.4
21:59:30:621 | RL |     DEBUG  | +0     | CheckFile - Attributes:
21:59:30:640 | RL |      INFO  | +31    | CRC Check - CRC matches, this is an official unedited Library: C:\hyperspin133\RocketLauncher\Lib\Classes\DLL\RocketLauncher.ahk | v1.7
21:59:30:644 | RL |     DEBUG  | +0     | CheckFile - Attributes:
21:59:30:663 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: C:\hyperspin133\RocketLauncher\Lib\Classes\Log\Logger.ahk | v1.1
21:59:30:666 | RL |     DEBUG  | +0     | CheckFile - Attributes:
21:59:30:685 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: C:\hyperspin133\RocketLauncher\Lib\Classes\Util\MiscUtils.ahk | v1.1
21:59:30:689 | RL |     DEBUG  | +15    | CheckFile - Attributes:
21:59:30:708 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: C:\hyperspin133\RocketLauncher\Lib\Classes\Util\Environment\Registry.ahk | v1.0
21:59:30:712 | RL |     DEBUG  | +0     | CheckFile - Attributes:
21:59:30:731 | RL |      INFO  | +15    | CRC Check - CRC matches, this is an official unedited Library: C:\hyperspin133\RocketLauncher\Lib\Classes\Util\Environment\StringUtils.ahk | v1.5
21:59:30:735 | RL |     DEBUG  | +16    | CheckFile - Attributes:
21:59:30:755 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: C:\hyperspin133\RocketLauncher\Lib\Classes\Util\Environment\TimerUtils.ahk | v1.0
21:59:30:759 | RL |     DEBUG  | +0     | CheckFile - Attributes:
21:59:30:777 | RL |      INFO  | +15    | CRC Check - CRC matches, this is an official unedited Library: C:\hyperspin133\RocketLauncher\Lib\Classes\Util\File\File.ahk | v1.5
21:59:30:781 | RL |     DEBUG  | +16    | CheckFile - Attributes:
21:59:30:800 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: C:\hyperspin133\RocketLauncher\Lib\Classes\Util\File\Folder.ahk | v1.0
21:59:30:804 | RL |     DEBUG  | +0     | CheckFile - Attributes:
21:59:30:825 | RL |      INFO  | +15    | CRC Check - CRC matches, this is an official unedited Library: C:\hyperspin133\RocketLauncher\Lib\Classes\Util\File\IniFile.ahk | v1.0
21:59:30:828 | RL |     DEBUG  | +16    | CheckFile - Attributes:
21:59:30:849 | RL |      INFO  | +15    | CRC Check - CRC matches, this is an official unedited Library: C:\hyperspin133\RocketLauncher\Lib\Classes\Util\File\RIniFile.ahk | v1.0
21:59:30:853 | RL |     DEBUG  | +0     | CheckFile - Attributes:
21:59:30:870 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: C:\hyperspin133\RocketLauncher\Lib\Classes\Util\File\Process.ahk | v1.5
21:59:30:873 | RL |     DEBUG  | +0     | CheckFile - Attributes:
21:59:30:888 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: C:\hyperspin133\RocketLauncher\Lib\Classes\Util\File\Emulator.ahk | v1.1
21:59:30:892 | RL |     DEBUG  | +15    | CheckFile - Attributes:
21:59:30:906 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: C:\hyperspin133\RocketLauncher\Lib\Classes\Util\Input\KeyUtils.ahk | v1.0
21:59:30:910 | RL |     DEBUG  | +0     | CheckFile - Attributes:
21:59:30:925 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: C:\hyperspin133\RocketLauncher\Lib\Classes\Util\UI\Control.ahk | v1.2
21:59:30:928 | RL |     DEBUG  | +0     | CheckFile - Attributes:
21:59:30:943 | RL |      INFO  | +15    | CRC Check - CRC matches, this is an official unedited Library: C:\hyperspin133\RocketLauncher\Lib\Classes\Util\UI\Window.ahk | v1.2
21:59:30:947 | RL |     DEBUG  | +0     | CheckFile - Attributes:
21:59:30:961 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: C:\hyperspin133\RocketLauncher\Lib\Classes\Util\UI\WindowTitle.ahk | v1.0
21:59:30:965 | RL |     DEBUG  | +0     | CheckFile - Attributes:
21:59:30:980 | RL |      INFO  | +15    | CRC Check - CRC matches, this is an official unedited Library: C:\hyperspin133\RocketLauncher\Lib\Rom Mapping Launch Menu.ahk | v1.0.7
21:59:30:984 | RL |     DEBUG  | +16    | CheckFile - Attributes:
21:59:30:999 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: C:\hyperspin133\RocketLauncher\Lib\Shader.ahk | v1.0.1
21:59:30:003 | RL |     DEBUG  | +0     | CheckFile - Attributes:
21:59:31:017 | RL |      INFO  | +15    | CRC Check - CRC matches, this is an official unedited Library: C:\hyperspin133\RocketLauncher\Lib\Shader Init.ahk | v1.0.0
21:59:31:021 | RL |     DEBUG  | +0     | CheckFile - Attributes:
21:59:31:037 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: C:\hyperspin133\RocketLauncher\Lib\Shared.ahk | v1.4.5
21:59:31:041 | RL |     DEBUG  | +0     | CheckFile - Attributes:
21:59:31:057 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: C:\hyperspin133\RocketLauncher\Lib\Statistics.ahk | v1.0.4
21:59:31:060 | RL |     DEBUG  | +0     | CheckFile - Attributes:
21:59:31:075 | RL |      INFO  | +15    | CRC Check - CRC matches, this is an official unedited Library: C:\hyperspin133\RocketLauncher\Lib\Statistics Init.ahk | v1.0.1
21:59:31:078 | RL |     DEBUG  | +16    | CheckFile - Attributes:
File Size: 33 bytes
21:59:31:093 | RL |      INFO  | +15    | CRC Check - CRC matches, this is an official unedited Library: C:\hyperspin133\RocketLauncher\Lib\Virtual Drive.ahk | v1.0.5
21:59:31:097 | RL |     DEBUG  | +0     | CheckFile - Attributes:
21:59:31:112 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: C:\hyperspin133\RocketLauncher\Lib\XHotkey.ahk | v1.0.4
21:59:31:116 | RL |     DEBUG  | +0     | CheckFile - Attributes:
21:59:31:131 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: C:\hyperspin133\RocketLauncher\Lib\XHotkey Init.ahk | v1.0.2
21:59:31:134 | RL |     DEBUG  | +0     | CheckFile - Attributes:
21:59:31:138 | RL |      INFO  | +0     | Main - Raw CLI received: "-s Commodore 64 -r 10th Frame (1986)(Access Software)[cr TSC] -f C:\hyperspin133\HyperSpin.exe -p HyperSpin -c 1 -o 1"
21:59:31:141 | RL |     DEBUG  | +15    | Main - Received this dbName with no path via CLI: "10th Frame (1986)(Access Software)[cr TSC]"
21:59:31:145 | RL |     DEBUG  | +0     | Main - dbName: 10th Frame (1986)(Access Software)[cr TSC]
21:59:31:200 | RL |      INFO  | +47    | Main - Loading Front End Plugin: "HyperSpin"
21:59:31:203 | RL |     TRACE  | +16    | Process.__New - Creating new process object for: "C:\hyperspin133\HyperSpin.exe"
21:59:31:206 | RL |     TRACE  | +0     | File.__New - Creating new file object of: "C:\hyperspin133\HyperSpin.exe"
21:59:31:228 | RL |      INFO  | +15    | Main - RocketLauncher received "Commodore 64" and "10th Frame (1986)(Access Software)[cr TSC]"
21:59:31:236 | RL |      INFO  | +16    | Main - Did not find a "C:\hyperspin133\RocketLauncher\Settings\Commodore 64\Game Options.ini" file, skipping any game-specific options.
21:59:31:240 | RL |      INFO  | +0     | Main - 10th Frame (1986)(Access Software)[cr TSC] is using the default emulator: WinVICE
21:59:31:243 | RL |      INFO  | +0     | Main - Checking for a [WinVICE] section in C:\hyperspin133\RocketLauncher\Settings\Commodore 64\Emulators.ini
21:59:31:247 | RL |      INFO  | +0     | Main - Checking for a [WinVICE] section in C:\hyperspin133\RocketLauncher\Settings\Global Emulators.ini
21:59:31:251 | RL |      INFO  | +16    | Main - Found [WinVICE] in C:\hyperspin133\RocketLauncher\Settings\Global Emulators.ini
21:59:31:254 | RL | TRACE_DLL  | +0     | RLDLL.getFullPathFromRelative - Converting "WinVICE.ahk"
21:59:31:268 | RL | TRACE_DLL  | +15    | RLDLL.getFullPathFromRelative - Converted to "C:\hyperspin133\RocketLauncher\Modules\WinVICE\WinVICE.ahk"
21:59:31:279 | RL |      INFO  | +0     | CheckFile - Checking if C:\hyperspin133\RocketLauncher\Modules\WinVICE\WinVICE.ahk exists
21:59:31:291 | RL |     DEBUG  | +16    | CheckFile - Attributes:
21:59:31:298 | RL |      INFO  | +16    | Main - CRC Check - CRC matches, this is an official unedited module.
21:59:31:301 | RL |      INFO  | +0     | Main - 10th Frame (1986)(Access Software)[cr TSC] will use module: C:\hyperspin133\RocketLauncher\Modules\WinVICE\WinVICE.ahk
21:59:31:304 | RL | TRACE_DLL  | +0     | RLDLL.getFullPathFromRelative - Converting ".\Profiles"
21:59:31:319 | RL | TRACE_DLL  | +15    | RLDLL.getFullPathFromRelative - Converted to "C:\hyperspin133\RocketLauncher\Profiles"
21:59:31:322 | RL | TRACE_DLL  | +0     | RLDLL.getFullPathFromRelative - Converting ".\Module Extensions\7z.exe"
21:59:31:336 | RL | TRACE_DLL  | +16    | RLDLL.getFullPathFromRelative - Converted to "C:\hyperspin133\RocketLauncher\Module Extensions\7z.exe"
21:59:31:338 | RL | TRACE_DLL  | +0     | RLDLL.getFullPathFromRelative - Converting "C:\hyperspin133\RocketLauncher\Module Extensions\dxwnd\dxwnd.exe"
21:59:31:347 | RL | TRACE_DLL  | +15    | RLDLL.getFullPathFromRelative - Converted to "C:\hyperspin133\RocketLauncher\Module Extensions\dxwnd\dxwnd.exe"
21:59:31:359 | RL | TRACE_DLL  | +16    | RLDLL.getFullPathFromRelative - Converting ".\Module Extensions\HiToText.exe"
21:59:31:373 | RL | TRACE_DLL  | +0     | RLDLL.getFullPathFromRelative - Converted to "C:\hyperspin133\RocketLauncher\Module Extensions\HiToText.exe"
21:59:31:376 | RL | TRACE_DLL  | +16    | RLDLL.getFullPathFromRelative - Converting "..\Utilities\Xpadder\xpadder.exe"
21:59:31:391 | RL | TRACE_DLL  | +15    | RLDLL.getFullPathFromRelative - Converted to "C:\hyperspin133\Utilities\Xpadder\xpadder.exe"
21:59:31:394 | RL | TRACE_DLL  | +0     | RLDLL.getFullPathFromRelative - Converting "..\Utilities\JoyToKey\JoyToKey.exe"
21:59:31:408 | RL | TRACE_DLL  | +16    | RLDLL.getFullPathFromRelative - Converted to "C:\hyperspin133\Utilities\JoyToKey\JoyToKey.exe"
21:59:31:411 | RL | TRACE_DLL  | +0     | RLDLL.getFullPathFromRelative - Converting "..\Utilities\VJoy\VJoy.exe"
21:59:31:425 | RL | TRACE_DLL  | +16    | RLDLL.getFullPathFromRelative - Converted to "C:\hyperspin133\Utilities\VJoy\VJoy.exe"
21:59:31:435 | RL | TRACE_DLL  | +0     | RLDLL.getFullPathFromRelative - Converting "C:\Users\nick\AppData\Local\Temp\HS"
21:59:31:444 | RL | TRACE_DLL  | +15    | RLDLL.getFullPathFromRelative - Converted to "C:\Users\nick\AppData\Local\Temp\HS"
21:59:31:450 | RL |      INFO  | +0     | Main - Using standard method with "Rom Extension" SkipChecks or without any SkipChecks.
21:59:31:453 | RL | TRACE_DLL  | +16    | RLDLL.getFullPathFromRelative - Converting "..\Emulators\Arcade\Commodore 64\roms"
21:59:31:467 | RL | TRACE_DLL  | +0     | RLDLL.getFullPathFromRelative - Converted to "C:\hyperspin133\Emulators\Arcade\Commodore 64\roms"
21:59:31:470 | RL | TRACE_DLL  | +15    | RLDLL.getFullPathFromRelative - Converting "..\Emulators\WinVICE\x64.exe"
21:59:31:485 | RL | TRACE_DLL  | +16    | RLDLL.getFullPathFromRelative - Converted to "C:\hyperspin133\Emulators\WinVICE\x64.exe"
21:59:31:499 | RL |      INFO  | +0     | CheckFile - Checking if C:\hyperspin133\Emulators\WinVICE\x64.exe exists
21:59:32:117 | RL |     DEBUG  | +625   | CheckFile - Attributes:
FileVersion              2.3
ProductVersion           2.3
21:59:32:120 | RL |      INFO  | +0     | Main - INI Keys read
21:59:32:132 | RL |      INFO  | +16    | CheckFile - Checking if C:\hyperspin133\RocketLauncher\Module Extensions\7z.exe exists
21:59:32:188 | RL |     DEBUG  | +62    | CheckFile - Attributes:
InternalName             7z
ProductName              7-Zip
21:59:32:191 | RL |      INFO  | +0     | CheckFile - Checking if C:\hyperspin133\RocketLauncher\Module Extensions\7z.dll exists
21:59:32:278 | RL |     DEBUG  | +78    | CheckFile - Attributes:
InternalName             7z
ProductName              7-Zip
21:59:32:288 | RL |      INFO  | +16    | Main - "10th Frame (1986)(Access Software)[cr TSC]" does not qualify for MultiGame. Only roms with any of these strings in their name are acceptable: \(Disc|\(Disk|\(Cart|\(Tape|\(Cassette|\(Part|\(Side
21:59:32:291 | RL |      INFO  | +0     | CheckPaths - Started
21:59:32:294 | RL |   WARNING  | +0     | CheckPaths - Please make sure your Database Name (Rom Name) does not contain the special characters [ or ] as these are used to denote sections in RocketLauncher's INI Files: 10th Frame (1986)(Access Software)[cr TSC]
21:59:32:297 | RL |      INFO  | +16    | CheckPaths - Looking for rom: C:\hyperspin133\Emulators\Arcade\Commodore 64\roms\10th Frame (1986)(Access Software)[cr TSC].7z
21:59:32:300 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\hyperspin133\Emulators\Arcade\Commodore 64\roms\10th Frame (1986)(Access Software)[cr TSC]\10th Frame (1986)(Access Software)[cr TSC].7z
21:59:32:303 | RL |      INFO  | +0     | CheckPaths - Rom not found
21:59:32:306 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\hyperspin133\Emulators\Arcade\Commodore 64\roms\10th Frame (1986)(Access Software)[cr TSC].zip
21:59:32:308 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\hyperspin133\Emulators\Arcade\Commodore 64\roms\10th Frame (1986)(Access Software)[cr TSC]\10th Frame (1986)(Access Software)[cr TSC].zip
21:59:32:311 | RL |      INFO  | +0     | CheckPaths - Rom not found
21:59:32:314 | RL |      INFO  | +15    | CheckPaths - Looking for rom: C:\hyperspin133\Emulators\Arcade\Commodore 64\roms\10th Frame (1986)(Access Software)[cr TSC].crt
21:59:32:318 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\hyperspin133\Emulators\Arcade\Commodore 64\roms\10th Frame (1986)(Access Software)[cr TSC]\10th Frame (1986)(Access Software)[cr TSC].crt
21:59:32:321 | RL |      INFO  | +0     | CheckPaths - Rom not found
21:59:32:323 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\hyperspin133\Emulators\Arcade\Commodore 64\roms\10th Frame (1986)(Access Software)[cr TSC].vsf
21:59:32:326 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\hyperspin133\Emulators\Arcade\Commodore 64\roms\10th Frame (1986)(Access Software)[cr TSC]\10th Frame (1986)(Access Software)[cr TSC].vsf
21:59:32:329 | RL |      INFO  | +16    | CheckPaths - Rom not found
21:59:32:332 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\hyperspin133\Emulators\Arcade\Commodore 64\roms\10th Frame (1986)(Access Software)[cr TSC].d64
21:59:32:334 | RL |      INFO  | +0     | CheckPaths - Found rom: C:\hyperspin133\Emulators\Arcade\Commodore 64\roms\10th Frame (1986)(Access Software)[cr TSC].d64
21:59:32:337 | RL |     DEBUG  | +0     | CheckPaths - Current romName: 10th Frame (1986)(Access Software)[cr TSC]
21:59:32:340 | RL |     DEBUG  | +0     | CheckPaths - Current romPath: C:\hyperspin133\Emulators\Arcade\Commodore 64\roms
21:59:32:343 | RL |     DEBUG  | +15    | CheckPaths - Current romExtension: .d64
21:59:32:346 | RL |      INFO  | +0     | CheckPaths - Ended
21:59:32:349 | RL |      INFO  | +0     | BuildScript - User Variables:
; INJECTED VARIABLES
#NoTrayIcon
#InstallKeybdHook
MiscUtils.DetectHiddenWindows("On")
SetTitleMatchMode, 2
SendMode, Event
0 = 12
rlPath = C:\hyperspin133\RocketLauncher
pluginPath = C:\hyperspin133\RocketLauncher\Plugins
pluginName = HyperSpin
pluginExt = .plugin
contextOnExit = 1
rlMode =
rlTitle = RocketLauncher
rlVersion = 1.1.0.7
rlAuthor = djvj
rlURL = www.rlauncher.com
langFile = C:\hyperspin133\RocketLauncher\Data\Language\Localization.ini
primMonitor = 1
frontendPID =
frontendPath = C:\hyperspin133
frontendExe = HyperSpin.exe
frontendExt = exe
frontendName = HyperSpin
frontendDrive = C
exitEmulatorKey = ~Esc
restoreFE = false
exitScriptKey = ~q & ~s
toggleCursorKey = ~e & ~t
emuFullPath = C:\hyperspin133\Emulators\WinVICE\x64.exe
emuPath = C:\hyperspin133\Emulators\WinVICE
emuName = WinVICE
emuExt = exe
baseRomPath =
romPath = C:\hyperspin133\Emulators\Arcade\Commodore 64\roms
romPathFromIni = C:\hyperspin133\Emulators\Arcade\Commodore 64\roms
romExtension = .d64
romExtensionOrig = .d64
romExtensions = 7z|zip|crt|vsf|d64|g64|tap|prg|t64|nib
executable = x64.exe
systemDbName = Commodore 64
systemName = Commodore 64
dbPath =
dbName = 10th Frame (1986)(Access Software)[cr TSC]
dbExt =
romName = 10th Frame (1986)(Access Software)[cr TSC]
romMapPath =
romMappingEnabled = false
romMappingHideParent = false
romMappingMenuWidth = 400
romMappingMenuMargin = 65
romMappingTextMargin = 15
romMappingGameNameTextFont = Bebas Neue
romMappingGameNameTextOptions = cFFFFFFFF r4 s40 Regular
romMappingMenuFlagWidth = 55
altArchiveNameOnly =
altRomNameOnly =
altArchiveAndRomName =
altArchiveAndManyRomNames =
altRomNamesOnly =
romMapScenario =
skipchecks = false
romMatchExt = false
blockInputTime = 0
blockInputFile = C:\hyperspin133\RocketLauncher\Module Extensions\BlockInput.exe
errorLevelReporting = false
lockLaunch = false
lockLaunchGame =
screenRotationAngle = 0
screenRotationAngleGame =
setResolution =
logFile =
logLabel := ["    INFO"," WARNING","   ERROR","   DEBUG","   TRACE"]
logLevel = 10
logShowDebugConsole = false
logShowCommandWindow = false
logCommandWindow = false
logIncludeModule = true
logIncludeDLLLogs = false
errorSounds = true
rlDebugConsoleStdout =
sysLang = Danish
sysType = 64-bit
broadcastWindowTitle =
navUpKey = Up
navDownKey = Down
navLeftKey = Left
navRightKey = Right
navSelectKey = Enter
navP2UpKey = Numpad8
navP2DownKey = Numpad2
navP2LeftKey = Numpad4
navP2RightKey = Numpad6
navP2SelectKey = NumpadEnter
originalWidth = 1920
originalHeight = 1200
vdEnabled = false
vdFullPath =
vdUseSCSI = true
vdDriveLetter =
vdDriveLetterScsi =
vdAddDrive = true
servoStikEnabled = false
servoStikExitMode = false
ledblinkyEnabled = false
ledblinkySystemName =
ledblinkyFullPath =
ledblinkyProfilePath = C:\hyperspin133\RocketLauncher\Profiles\LEDBlinky
ledblinkyRLProfile = C:\hyperspin133\RocketLauncher\Profiles\LEDBlinky\RocketLauncher
winIPACFullPath =
ultraMapEnabled = false
ultraMapFullPath =
emuIdleShutdown = 0
hideCursor = false
hideEmu = false
hideFE = false
suspendFE = false
fadeIn = false
fadeInDuration = 500
fadeInDelay = 0
fadeInExitDelay = 0
fadeOutExitDelay = 0
fadeOut = false
fadeOutExtraScreen = false
fadeOutDuration = 500
fadeOutDelay = 0
fadeLyrInterpolation = 7
fadeMuteEmulator = false
fadeUseBackgrounds = false
fadeClickThrough = false
fadeSounds = true
fade7zProgressMode = extraction
fadeWidthBaseRes = 1920
fadeHeightBaseRes = 1080
fadeLyr1Color = FF000000
fadeLyr2X = 0
fadeLyr2Y = 0
fadeLyr2W =
fadeLyr2H =
fadeLyr2Adjust = 1
fadeLyr2PicPad = 0
fadeLyr3Pos = Center
fadeLyr3X = 450
fadeLyr3Y = 450
fadeLyr3W =
fadeLyr3H =
fadeLyr3Adjust = 1
fadeLyr3PicPad = 0
fadeLyr3Speed = 750
fadeLyr3Type = imageandbar
fadeLyr3Repeat = 1
fadeLyr3StaticX = 0
fadeLyr3StaticY = 870|1575
fadeLyr3StaticW =
fadeLyr3StaticH =
fadeLyr3StaticAdjust = 1
fadeLyr3StaticPicPad = 0
fadeLyr4Adjust = 1
fadeLyr4X = 1792|952
fadeLyr4Y = 891|1596
fadeLyr4W = 128
fadeLyr4H =
fadeLyr4Pos = No Alignment
fadeLyr4FPS = 50
fadeLyr4PicPad = 0
fadeTranspGifColor = FFFFFF
fadeBarWindow = Image
fadeBarWindowX =
fadeBarWindowY =
fadeBarWindowW = 900
fadeBarWindowH =
fadeBarWindowR = 30
fadeBarWindowM = 30
fadeBarWindowHatchStyle = 8
fadeBar = 7zOnly
fadeProgressDuration = 0
fadeBarBack = true
fadeBarBackColor = FF555555
fadeBarH = 30
fadeBarR = 10
fadeBarColor = DD00BFFF
fadeBarHatchStyle = 8
fadeBarPercentageText = true
fadeBarInfoText = true
fadeBarXOffset = 0
fadeBarYOffset = 150
fadeRomInfoSystemName = image
fadeRomInfoDeveloper = disabled
fadeRomInfoPublisher = disabled
fadeRomInfoGenre = disabled
fadeRomInfoRating = image
fadeRomInfoTextMargin = 7
fadeRomInfoText7Options = h135 x15 y885|1590 cFFCFCFCA r4 s120 Regular
fadeStatsInfoTextMargin = 7
fadeText1X = 0
fadeText1Y = 0
fadeText1 = Loading Game
fadeText2X = 0
fadeText2Y = 0
fadeText3 = Loading Game
fadeText4 = Loading Complete
fadeFont = Bebas Neue
fadeExtractionTime = disabled
fadeExtractionTimeTextX = 0
fadeExtractionTimeTextY = 0
fadeInterruptKey =
detectFadeErrorEnabled = true
fadeImgPath = C:\hyperspin133\RocketLauncher\Media\Fade
RLDataPath = C:\hyperspin133\RocketLauncher\Data
RLMediaPath = C:\hyperspin133\RocketLauncher\Media
RLErrSoundPath = C:\hyperspin133\RocketLauncher\Media\Sounds\Error
modulesPath = C:\hyperspin133\RocketLauncher\Modules
moduleFullName = C:\hyperspin133\RocketLauncher\Modules\WinVICE\WinVICE.ahk
moduleName = WinVICE
modulePath = C:\hyperspin133\RocketLauncher\Modules\WinVICE
moduleExtension = ahk
moduleExtensionsPath = C:\hyperspin133\RocketLauncher\Module Extensions
libPath = C:\hyperspin133\RocketLauncher\Lib
sevenZEnabled = true
sevenZPath = C:\hyperspin133\RocketLauncher\Module Extensions\7z.exe
sevenZDllPath = C:\hyperspin133\RocketLauncher\Module Extensions\7z.dll
sevenZExtractPath = C:\Users\nick\AppData\Local\Temp\HS
sevenZExtractPathOrig =
sevenZAttachSystemName = false
sevenZDelTemp = true
sevenZFormats = .zip|.rar|.7z|.lzh|.gzip|.tar
sevenZFormatsNoP = zip|rar|7z|lzh|gzip|tar
sevenZFormatsRegEx = \.zip|\.rar|\.7z|\.lzh|\.gzip|\.tar
7zExtractPath = C:\Users\nick\AppData\Local\Temp\HS
mgEnabled = false
mgKey = ~NumpadSub
mgBackgroundColor = FF000000
mgSidePadding = 0.2
mgWidthBaseRes = 1920
mgHeightBaseRes = 1080
mgYOffset = 500|800
mgFont = Arial
mgText2Offset = 100
mgUseSound = true
mgSoundfreq = 300
mgExitEffect = none
mgSelectedEffect = rotate
mgUseGameArt = false
mgCandidate =
mgValidTypes = \(Disc|\(Disk|\(Cart|\(Tape|\(Cassette|\(Part|\(Side
mgOnLaunch = false
pauseEnabled = false
pauseKey = ~NumpadAdd
pauseBackToMenuBarKey = X
pauseZoomInKey = C
pauseZoomOutKey = V
pauseHiToTextPath = C:\hyperspin133\RocketLauncher\Module Extensions\HiToText.exe
pauseSaveStateKeyCodes =
pauseLoadStateKeyCodes =
keyboardEncoder =
keyboardEncoderEnabled = false
keymapperEnabled = false
keymapperAHKMethod = false
keymapper = xpadder
xpadderFullPath = C:\hyperspin133\Utilities\Xpadder\xpadder.exe
joyToKeyFullPath = C:\hyperspin133\Utilities\JoyToKey\JoyToKey.exe
profilePath = C:\hyperspin133\RocketLauncher\Profiles
keymapperProfilePath = C:\hyperspin133\RocketLauncher\Profiles\xpadder
keymapperFrontEndProfileName = RocketLauncherUI
joyIDsEnabled = false
joyIDsPreferredControllersGlobal =
joyIDsPreferredControllersSystem = use_global
joyIDsPreferredControllersOnExit =
CustomJoyNamesEnabled = false
CustomJoyNames =
rotateMethod = false
FEProfile = C:\hyperspin133\RocketLauncher\Profiles\xpadder\RocketLauncherUI
defaultProfile = C:\hyperspin133\RocketLauncher\Profiles\xpadder\_Default
systemProfile = C:\hyperspin133\RocketLauncher\Profiles\xpadder\Commodore 64
xPadderSystemProfile = C:\hyperspin133\RocketLauncher\Profiles\xpadder\Commodore 64\_Default
emuProfile = C:\hyperspin133\RocketLauncher\Profiles\xpadder\Commodore 64\WinVICE
romProfile = C:\hyperspin133\RocketLauncher\Profiles\xpadder\Commodore 64\10th Frame (1986)(Access Software)[cr TSC]
RocketLauncherProfile = C:\hyperspin133\RocketLauncher\Profiles\xpadder\RocketLauncher
blankProfile = C:\hyperspin133\RocketLauncher\Profiles\xpadder\_Default\blank
ahkFEProfile = C:\hyperspin133\RocketLauncher\Profiles\AHK\RocketLauncherUI
ahkDefaultProfile = C:\hyperspin133\RocketLauncher\Profiles\AHK\_Default
ahkSystemProfile = C:\hyperspin133\RocketLauncher\Profiles\AHK\Commodore 64
ahkEmuProfile = C:\hyperspin133\RocketLauncher\Profiles\AHK\Commodore 64\WinVICE
ahkRomProfile = C:\hyperspin133\RocketLauncher\Profiles\AHK\Commodore 64\10th Frame (1986)(Access Software)[cr TSC]
ahkRocketLauncherProfile = C:\hyperspin133\RocketLauncher\Profiles\AHK\RocketLauncher
bezelEnabled = false
bezelICEnabled = false
shaderName = false
shaderColor =
shaderTransparency =
shaderChangeKey =
statisticsEnabled = true
pressDuration = -1
emuVolume = 1
dxwndIni = C:\hyperspin133\RocketLauncher\Module Extensions\dxwnd\dxwnd.ini
dxwndFullPath = C:\hyperspin133\RocketLauncher\Module Extensions\dxwnd\dxwnd.exe
qResFullPath = C:\hyperspin133\RocketLauncher\Module Extensions\QRes.exe
mon1O =
pacDrivedllFile = C:\hyperspin133\RocketLauncher\Module Extensions\PacDrive32.dll
userFadeAnimIniFile = C:\hyperspin133\RocketLauncher\Lib\User Fade Animations.ini
testFile =
testDuration =
21:59:32:353 | RL |      INFO  | +0     | BuildScript - Loaded XHotkey Init.ahk scripts
21:59:32:356 | RL |      INFO  | +0     | BuildScript - Loaded Statistics Init.ahk scripts
21:59:32:359 | RL |   WARNING  | +16    | BuildScript - "C:\hyperspin133\RocketLauncher\Lib\User Functions Init.ahk" not found
21:59:32:362 | RL |     DEBUG  | +0     | BuildScript - Module starts on line: 2
21:59:32:365 | RL |      INFO  | +0     | BuildScript - Validating module
21:59:32:370 | RL |      INFO  | +0     | BuildScript - Validation complete
21:59:32:374 | RL |      INFO  | +16    | BuildScript - Module:
MEmu = WinVICE
MEmuV = v2.4
MURL = http://vice-emu.sourceforge.net/
MAuthor = djvj,wahoobrian,brolly
MVersion = 2.1.4
MCRC = E0C56FF6
iCRC = 5D564EA8
MID = 635038268966170754
MSystem = "Commodore 64","Commodore 16 & Plus4","Commodore VIC-20","Commodore 128","Commodore MAX Machine","Commodore 64 Games System", "Commodore PET"
; Notes:
; Roms must be unzipped.
; You can turn off the exit confirmation box by unchecking Settings->Confirm on exit
; Turn on saving settings by checking Settings->Save settings on exit, this will create the vice.ini file this module needs.
; Default Joyport setting for C64 requires that you configure "Keyset A" as the default for JoyPort 1 and "Keyset B" as the
; default for JoyPort 2.  This allows the module to use the ini settings and set the default joystick to Player 1 at startup
; This can be disabled by setting the disableAutoControllerSwapping to true.  That is helpful for users who do not wish to use
; "KeySet A" and "KeySet B" as the controller configurations.
; If you want to use the StartTape and StopTape hotkeys make sure you edit the files C64\win_shortcuts.vsc or VIC20\win_shortcuts.vsc
; (paths relative to the emulator install folder) and assign Alt+F7 as the StartTape shortcut and Alt+F8 as the StopTape shortcut, like this:
; ALT 0x76 IDM_DATASETTE_CONTROL_START   F7
; ALT 0x77 IDM_DATASETTE_CONTROL_STOP   F8
; WinVICE SDL:
; This module will also work with the SDL version of WinVICE even though it's not recommended to use it with it. If you do bare in mind that
; some of the features might not work. For hotkeys to work you need to manually set them all in SDL VICE and make sure you save the settings.
; To map the hotkeys navigate to any menu item (F12 shows the menu) press 'm' and then the key or key combo you want to use for the hotkey for that item.
; Don't forget to save your hotkeys before exiting the emulator before you exi or they will be lost. This is done in Settings management->Save hotkeys.
; You can find more info on the Readme-SDL.txt file that comes with this version of the emulator.
; The module will detect that you are using the SDL version by checking if the sdl-vice.ini file exists in your emulator folder, so make sure you
; run the emulator once in order to create this file.
; WinVICE uses different executables for each machine so make sure you setup your emulators properly:
; x64.exe - Commodore 64
; xplus4.exe - Commodore 16 & Plus/4
; xvic.exe - Commodore VIC-20
; x128.exe - Commodore 128
; xpet.exe - Commodore PET
StartModule()
BezelGUI()
FadeInStart()
primaryExe := new Emulator(emuPath . "\" . executable) ; instantiate emulator executable object
mType := Object("Commodore 64","C64","Commodore 16 & Plus4","PLUS4","Commodore VIC-20","VIC20","Commodore 128","C128","Commodore MAX Machine","C64","Commodore 64 Games System","C64", "Commodore PET", "PET") ;ident should be the section names used in VICE.ini
ident := mType[systemName] ; search object for the systemName identifier
Fullscreen := moduleIni.Read("Settings", "Fullscreen","true","",1) ; If true, the module governs If the emulator launches fullscreen or not. Set to false when troubleshooting a module for launching problems.
WarpKey := moduleIni.Read("Settings", "WarpKey","F9","",1) ; toggle warp speed
JoySwapKey := moduleIni.Read("Settings", "JoySwapKey","F10","",1) ; swap joystick port
StartTapeKey := moduleIni.Read("Settings", "StartTapeKey","F7","",1) ; starts tape
StopTapeKey := moduleIni.Read("Settings", "StopTapeKey","F8","",1) ; stops tape
bezelTopOffset := moduleIni.Read("Settings", "bezelTopOffset",16,"",1)
bezelBottomOffset := moduleIni.Read("Settings", "bezelBottomOffset",46,"",1)
bezelLeftOffset := moduleIni.Read("Settings", "bezelLeftOffset",7,"",1)
bezelRightOffset := moduleIni.Read("Settings", "bezelRightOffset",7,"",1)
disableAutoControllerSwapping := moduleIni.Read("Settings", "DisableAutoControllerSwapping","false","",1)
UsePaddles := moduleIni.Read(romName, "UsePaddles", "false","",1)
AutostartPrgMode := moduleIni.Read(romName, "AutostartPrgMode", "2","",1)
RequiresReset := moduleIni.Read(romName, "RequiresReset", "false","",1)
RequiresHardReset := moduleIni.Read(romName, "RequiresHardReset", "false","",1)
TrueDriveEmulation := moduleIni.Read(romName . "|Settings", "TrueDriveEmulation", "false","",1)
LoadFile := moduleIni.Read(romName, "LoadFile","","",1)
DefaultJoyPort := moduleIni.Read(romName, "DefaultJoyPort", "1","",1)
ColumnMode := moduleIni.Read(romName, "ColumnMode", "80","",1)
; DiskSwapKey := "F11" ; swaps disk or tape - Do not need this key anymore with multigame support
7z(romPath, romName, romExtension, SevenZExtractPath)
;Detect if SDL VICE is being used
SdlViceINI := new IniFile(emuPath . "\sdl-vice.ini")
If SdlViceINI.Exist()
SdlVice := "true"
Else
SdlVice := "false"
RLLog.Info("Module - SDL mode is set to " . SdlVice)
If (SdlVice = "true") {
emuPrimaryWindow := new Window(new WindowTitle("VICE","SDL_app")) ; instantiate primary emulator window object
viceINI := SdlViceINI
} Else {
emuPrimaryWindow := new Window(new WindowTitle("","VICE")) ; instantiate primary emulator window object
viceINI := new IniFile(emuPath . "\vice.ini")
viceINI.CheckFile()
emuOpenROMWindow := new Window(new WindowTitle("Select cartridge file","#32770"))
hideEmuObj := Object(emuOpenROMWindow,0,emuPrimaryWindow,1)
viceINIFullscreenKey := "FullscreenEnabled"
If (ident = "C64")
viceINIFullscreenKey := "VICIIFullscreen"
If (ident = "PLUS4")
viceINIFullscreenKey := "TEDFullscreen"
If (ident = "VIC20")
viceINIFullscreenKey := "VICFullscreen"
If (ident = "C128")
currentFullScreen := viceINI.Read(ident, viceINIFullscreenKey)
currentAutostartPrgMode := viceINI.Read(ident, AutostartPrgMode)
currentDriveTrueEmulation := viceINI.Read(ident, DriveTrueEmulation)
currentJoyDevice1 := viceINI.Read(ident, JoyDevice1)
currentJoyDevice2 := viceINI.Read(ident, JoyDevice2)
BezelStart()
; Setting Fullscreen setting in ini If it doesn't match what user wants above
If (Fullscreen != "true" And currentFullScreen = 1)
viceINI.Write(0, ident, viceINIFullscreenKey)
Else If (Fullscreen = "true" And currentFullScreen = 0)
viceINI.Write(1, ident, viceINIFullscreenKey)
If (currentAutostartPrgMode != AutostartPrgMode)
viceINI.Write(AutostartPrgMode, ident, "AutostartPrgMode")
WarpKey := xHotKeyVarEdit(WarpKey,"WarpKey","~","Add")
JoySwapKey := xHotKeyVarEdit(JoySwapKey,"JoySwapKey","~","Add")
StartTapeKey := xHotKeyVarEdit(StartTapeKey,"StartTapeKey","~","Add")
StopTapeKey := xHotKeyVarEdit(StopTapeKey,"StopTapeKey","~","Add")
xHotKeywrapper(WarpKey,"Warp")
xHotKeywrapper(JoySwapKey,"JoySwap")
xHotKeywrapper(StartTapeKey,"StartTape")
xHotKeywrapper(StopTapeKey,"StopTape")
If StringUtils.Contains(romName,"\(USA\)|\(Canada\)")
DefaultVideoMode := "NTSC"
Else
DefaultVideoMode := "PAL"
VideoMode := moduleIni.Read(romName, "VideoMode", DefaultVideoMode,"",1)
params := (If SdlVice = "true" ? " " : " +confirmexit")
; Setting video mode depending on rom, default NTSC
If (VideoMode = "NTSC") {
params .= " -ntsc"
;viceINI.Write(-2, ident, "MachineVideoStandard")  ;NTSC
} Else {
params .= " -pal"
;viceINI.Write(-1, ident, "MachineVideoStandard")  ;PAL
;Enable/Disable paddles as needed, leave these checks in-place because mouse CLI and Ini options aren't supported in VICE 1.22 and this way it will also work with it.
currentUsePaddles := viceINI.Read(ident, "Mouse")
If (UsePaddles = "true" And currentUsePaddles != 1)
params .= " -mouse -mousetype 3"
If (UsePaddles = "false" And currentUsePaddles = 1)
params .= " +mouse"
If (ident = "C64") {
If !StringUtils.Contains(romExtension,"\.d64|\.d71|\.d80|\.d81|\.d82|\.g64|\.g41|\.x64|\.t64|\.tap|\.crt|\.prg|\.vsf")
ScriptError("Your rom has an extension of " . romExtension . ", only these extensions are supported:`nd64,d71,d80,d81,d82,g64,g41,x64,t64,tap,crt")
If (romExtension = ".crt") {
viceINI.Write(romPath . "\" . romName . romExtension, "C64", "CartridgeFile")
viceINI.Write(0, "C64", "CartridgeType")
} Else {
viceINI.Write("", "C64", "CartridgeFile")
viceINI.Write(-1, "C64", "CartridgeType")
; Setting TrueDriveEmulation setting in ini If it doesn't match what user wants above
If (TrueDriveEmulation != "true" And currentDriveTrueEmulation != 0) {
viceINI.Write(0, ident, "DriveTrueEmulation")
viceINI.Write(0, ident, "Drive8Type")
Else If (TrueDriveEmulation = "true" And currentDriveTrueEmulation != 1) {
viceINI.Write(1, ident, "DriveTrueEmulation")
viceINI.Write(1541, ident, "Drive8Type")
If (disableAutoControllerSwapping = "false") {
; Setting Default JoyPort to Player 1 If needed
If (DefaultJoyPort = "1" And currentJoyDevice1 != 2) {
viceINI.Write(2, ident, "JoyDevice1")
viceINI.Write(3, ident, "JoyDevice2")
Else If (DefaultJoyPort = "2" And currentJoyDevice1 != 3) {
viceINI.Write(3, ident, "JoyDevice1")
viceINI.Write(2, ident, "JoyDevice2")
SendCommandDelay := moduleIni.Read("Settings", "SendCommandDelay", "1500","",1)
Command := moduleIni.Read(romName, "Command","","",1)
Command := StringUtils.Lower(Command) ; Command MUST be in lower case so let's force it
HideAppStart(hideEmuObj,hideEmu)
If StringUtils.Contains(romExtension,"\.d64|\.d71|\.d80|\.d81|\.d82|\.g64|\.g41|\.x64|\.prg|\.vsf")
primaryExe.Run(params . " -autostart """ . romPath . "\" . romName . romExtension . ":" . LoadFile . """")
Else If StringUtils.Contains(romExtension,"\.t64|\.tap")
primaryExe.Run(params . " """ . romPath . "\" . romName . romExtension . """")
Else If (romExtension = ".crt")
primaryExe.Run(params . " -cartcrt """ . romPath . "\" . romName . romExtension . """")
If (RequiresReset = "true")
emuPrimaryWindow.WaitActive()
TimerUtils.Sleep(1000) ; increase if command is not appearing in the emu window or some just some letters
KeyUtils.Send("!r")
If Command {
KeyUtils.SetKeyDelay(50)
SendCommand(Command . "{Enter}", SendCommandDelay)
Else If (ident = "PLUS4") {
If !StringUtils.Contains(romExtension,"\.prg|\.d64|\.t64|\.tap|\.crt|\.g64")
ScriptError("Your rom has an extension of " . romExtension . ", only these extensions are supported:`nprg,d64,t64,tap,crt,g64")
Model := moduleIni.Read(romName, "Model", "Commodore Plus/4","",1)
; Setting model
If (Model = "Commodore Plus/4") { ;Commodore Plus/4
viceINI.Write("3plus1lo", ident, "FunctionLowName")
viceINI.Write("3plus1hi", ident, "FunctionHighName")
viceINI.Write(64, ident, "RamSize")
viceINI.Write(1, ident, "Acia1Enable")
} Else { ; Commodore 16
viceINI.Write("", ident, "FunctionLowName")
viceINI.Write("", ident, "FunctionHighName")
viceINI.Write(16, ident, "RamSize")
viceINI.Write(0, ident, "Acia1Enable")
; TrueDriveEmulation must be set to false
If (currentDriveTrueEmulation != 0) {
If StringUtils.Contains(romExtension,"\.d64|\.g64|\.prg")
Else If romExtension in .t64,.tap
Else If (romExtension = .crt)
Else
;CLI does not seem to work for carts for Plus4, use GUI instead
; primaryExe.Run(params . " -cartcrt """ . romPath . "\" . romName . romExtension . """")
primaryExe.Run()
emuPrimaryWindow.Wait()
;Following keystrokes open up dialog for smart-attach cartridge image
TimerUtils.Sleep(500)
emuPrimaryWindow.MenuSelectItem("File", "Attach cartridge image", "1&")
OpenROM(emuOpenROMWindow.WinTitle.GetWindowTitle(),romPath . "\" . romName . romExtension)
TimerUtils.Sleep(1000) ; increase If command is not appearing in the emu window or some just some letters
KeyUtils.Send("!r")
If (RequiresHardReset = "true")
KeyUtils.Send("^!r")
If Command
;TimerUtils.Sleep(SendCommandDelay) ; increase If command is not appearing in the emu window or some just some letters
;Tape loading time will vary greatly so we can't type this automatically, user must do it using a hotkey
RunTapeKey := moduleIni.Read(romname, "RunTapeKey","Ctrl&F12","",1) ; run tape key
RunTapeKey := xHotKeyVarEdit(RunTapeKey,"RunTapeKey","~","Add")
xHotKeywrapper(RunTapeKey,"RunTape")
} Else
Else If (ident = "VIC20") {
If !StringUtils.Contains(romExtension, "\.prg|\.d64|\.t64|\.tap|\.crt|\.vsf")
ScriptError("Your rom has an extension of " . romExtension . ", only these extensions are supported: prg,d64,t64,tap,crt")
CartAddress := moduleIni.Read(romName, "CartLoadingAddress", "X000","",1)
MemoryExpansion := moduleIni.Read(romName, "MemoryExpansion", "none","",1)
;TimerUtils.Sleep(100) ;Without this romtable comes empty (thread related?)
RomTableCheck() ; make sure romTable is created already so the next line can calculate correctly
;MultiPart carts can only be run If the MultiGame feature is enabled
If StringUtils.Contains(romName, "\(Part ")
If (mgEnabled = "false")
ScriptError("You cannot run multipart games with MultiGame disabled")
romCount := romtable.MaxIndex()
If (romCount > 1) {
;multipart carts - need to build custom CLI parameters to invoke multipart cartridges.  Multipart cartridges are loaded in more than one
;                  memory address, so we interrogate each part, and determine its loading address, and build the CLI parameters.
;    Once all the cartridge parts have been processed, the emulator with the custom CLI parameters are invoked.
;                  Using Lunaar Leeper as an example, it has two parts, one loaded in $2000, and one in $A000
;                "xvic.exe -cart2 "D:\Games\Commodore VIC-20\Lunar Leeper (USA) (Part 1).crt" -cartA "D:\Games\Commodore VIC-20\Lunar Leeper (USA) (Part 2).crt"
multipartCLI := params
for index, element in romtable {
currentCart := romtable[A_Index,1]
StringUtils.SplitPath(currentCart,"","","",OutFileName)
currentCartAddress := moduleIni.Read(OutFileName, "CartLoadingAddress", "X000","",1)
If (currentCartAddress = "A000")
cartSlot := " -cartA"
Else If (currentCartAddress = "B000")
cartSlot := " -cartB"
Else If (currentCartAddress = "2000")
cartSlot := " -cart2"
Else If (currentCartAddress = "4000")
cartSlot := " -cart4"
Else If (currentCartAddress = "6000")
cartSlot := " -cart6"
Else
ScriptError("Invalid Cart Address Specified: " . CartAddress)
multipartCLI := multipartCLI . " " . cartSlot . " """ . currentCart . """"
primaryExe.Run(multipartCLI)
Else {
;singlepart carts - unlike multipart carts, we can directly run the emulator with a single CLI parameter
If (CartAddress = "A000")
Else If (CartAddress = "B000")
Else If (CartAddress = "2000")
Else If (CartAddress = "4000")
Else If (CartAddress = "6000")
Else
primaryExe.Run(params . cartSlot . " """ . romPath . "\" . romName . romExtension . """")
} Else {
;for non cartridges, update the vice.ini with the proper memory expansion values (If needed) prior to calling the emulator.
varBlock0 := 0
varBlock1 := 0
varBlock2 := 0
varBlock3 := 0
varBlock5 := 0
If (MemoryExpansion = "3k") {
varBlock0 := 1
} Else If (MemoryExpansion = "8k") {
varBlock1 := 1
} Else If (MemoryExpansion = "16k") {
varBlock1 := 1
varBlock2 := 1
} Else If (MemoryExpansion = "24k") {
varBlock1 := 1
varBlock2 := 1
varBlock3 := 1
} Else If (MemoryExpansion = "all") {
varBlock0 := 1
varBlock1 := 1
varBlock2 := 1
varBlock3 := 1
varBlock5 := 1
} Else If (MemoryExpansion = "3,5") {
varBlock3 := 1
varBlock5 := 1
} Else If (MemoryExpansion = "5") {
varBlock5 := 1
} Else If (MemoryExpansion = "1,5") {
varBlock1 := 1
varBlock5 := 1
} Else If (MemoryExpansion = "1,2,5") {
varBlock1 := 1
varBlock2 := 1
varBlock5 := 1
viceINI.Write(varBlock0, "VIC20", "RAMBlock0")
viceINI.Write(varBlock1, "VIC20", "RAMBlock1")
viceINI.Write(varBlock2, "VIC20", "RAMBlock2")
viceINI.Write(varBlock3, "VIC20", "RAMBlock3")
viceINI.Write(varBlock5, "VIC20", "RAMBlock5")
KeyUtils.Send("!r")
If Command
Else If (ident = "C128") {
If !StringUtils.Contains(romExtension,"\.prg|\.d64|\.d81")
ScriptError("Your rom has an extension of " . romExtension . ", only these extensions are supported:`nprg,d64,d81")
viceINI.Write(1570, ident, "Drive8Type")
Commodore64Mode := moduleIni.Read(romName, "Commodore64Mode", "false","",1)
;set 80/40 col param
If (ColumnMode = 40) {
params .= " -40col"
Else {
params .= " -80col"
; Force either C64 mode (-go64) or C128 mode (+go64)
If (Commodore64Mode = "true") {
params .= " -go64"
Else {
params .= " +go64"
params .= " +reu +autostart-warp"
TimerUtils.Sleep(1000) ; wait just a little more for 2 instances of the emu to open
emuPrimaryWindow.Get("List") ; Retrieves the unique ID numbers of all existing windows
MaxWidth := 0
MinWidth := 10000
Loop % emuPrimaryWindow.List[0] {
emuWindow%A_Index% := new Window(new WindowTitle("","","",emuPrimaryWindow.List[A_Index])) ; instantiate each emulator window object with the ahk_id
emuWindow%A_Index%.Activate()
emuWindow%A_Index%.GetClass() ; store the class of this window in the object
emuWindow%A_Index%.GetTitle() ; store the title of this window in the object
emuWindow%A_Index%.GetPos(emuX, emuY, emuWidth, emuHeight)
If (emuWidth > MaxWidth) {
emu80ColWindow := emuWindow%A_Index%
MaxWidth := emuWidth
If (emuWidth < MinWidth) {
emu40ColWindow := emuWindow%A_Index%
MinWidth := emuWidth
emu80ColWindow.Hide()
} Else {
emu40ColWindow.Hide()
;Activate the desired window since you might have hidden the active one above
emuPrimaryWindow.Activate()
WinSet, Redraw, , A ;Without this line bezel will always draw below the emulator window!
If Command {
Else If (ident = "PET") {
If !StringUtils.Contains(romExtension,"\.prg|\.d64|\.d81|\.tap")
ScriptError("Your rom has an extension of " . romExtension . ", only these extensions are supported:`nprg,d64,d81,tap")
PETModel := moduleIni.Read(romName, "PETModel", "PET4032","",1)
If (PETModel = "PET3032")
viceINI.Write("kernal2", ident, "KernalName")
viceINI.Write("edit2g", ident, "EditorName")
viceINI.Write("basic2", ident, "BasicName")
viceINI.Write(0, ident, "Crtc")
viceINI.Write(40, ident, "VideoSize")
viceINI.Write(2, ident, "KeymapIndex")
Else If (PETModel = "PET8032")
viceINI.Write("kernal4", ident, "KernalName")
viceINI.Write("edit4b80", ident, "EditorName")
viceINI.Write("basic4", ident, "BasicName")
viceINI.Write(1, ident, "Crtc")
viceINI.Write(80, ident, "VideoSize")
viceINI.Write(0, ident, "KeymapIndex")
Else
;Assume Model 4032
viceINI.Write("edit4g40", ident, "EditorName")
If Command {
SendCommand(Command, SendCommandDelay)
BezelDraw()
HideAppEnd(hideEmuObj,hideEmu)
FadeInExit()
primaryExe.Process("WaitClose")
7zCleanUp()
FadeOutExit()
ExitModule()
JoySwap:
KeyUtils.Send("!j")
Return
Warp:
KeyUtils.Send("!w")
Return
StartTape:
KeyUtils.Send("!{F7}")
Return
StopTape:
KeyUtils.Send("!{F8}")
Return
RunTape:
Loop, parse, Command
KeyUtils.Send("{" . A_LoopField . " down}{" . A_LoopField . " up}")
KeyUtils.Send("{Enter down}{Enter up}")
Return
HaltEmu:
If WarpKey
XHotKeywrapper(WarpKey,"Warp","OFF")
If JoySwapKey
XHotKeywrapper(JoySwapKey,"JoySwap","OFF")
If StartTapeKey
XHotKeywrapper(StartTapeKey,"StartTape","OFF")
If StopTapeKey
XHotKeywrapper(StopTapeKey,"StopTape","OFF")
If (Fullscreen = "true")
KeyUtils.Send("!{Enter}")
Return
MultiGame:
RLLog.Info("MultiGame label triggered")
If romExtension in .d64,.d71,.d80,.d81,.d82,.g64,.g41,.x64,.prg
{ KeyUtils.Send("!8") ; swaps a Disk
wvTitle := "Attach disk image ahk_class #32770"
} Else If romExtension in .t64,.tap
{ KeyUtils.Send("!t") ; swaps a Tape
wvTitle := "Attach tape image ahk_class #32770"
} Else
ScriptError(romExtension . " is an invalid multi-game extension")
OpenROM(wvTitle, selectedRom)
emuPrimaryWindow.WaitActive(5)
Return
RestoreEmu:
If WarpKey
XHotKeywrapper(WarpKey,"Warp","ON")
If JoySwapKey
XHotKeywrapper(JoySwapKey,"JoySwap","ON")
If StartTapeKey
XHotKeywrapper(StartTapeKey,"StartTape","ON")
If StopTapeKey
XHotKeywrapper(StopTapeKey,"StopTape","ON")
Return
CloseProcess:
FadeOutStart()
BezelExit()
emuPrimaryWindow.Close()
Return
21:59:32:423 | RL |      INFO  | +47    | BuildScript - Loaded Multi-Player scripts
21:59:32:439 | RL |      INFO  | +15    | BuildScript - Loaded Statistics.ahk script
21:59:32:455 | RL |   WARNING  | +16    | BuildScript - "C:\hyperspin133\RocketLauncher\Lib\User Functions.ahk" not found
21:59:32:470 | RL |      INFO  | +15    | BuildScript - Finished injecting functions into module
21:59:32:487 | RL |      INFO  | +16    | Main - Module is built
21:59:32:503 | RL |      INFO  | +16    | CheckFile - Checking if C:\hyperspin133\RocketLauncher\AutoHotkey.dll exists
21:59:32:627 | RL |     DEBUG  | +125   | CheckFile - Attributes:
FileDescription          AutoHotkey_H ANSI 32-bit
FileVersion              1.1.09.04
InternalName             AutoHotkey_H
LegalCopyright           Copyright (C) 2012
OriginalFilename         AutoHotkey.exe
ProductName              AutoHotkey_H
ProductVersion           1.1.09.04
File Size: 785408 bytes
Created: 4/19/2013 - 7:16:32
Modified: 6/26/2016 - 9:24:58
21:59:32:669 | RL |      INFO  | +31    | Main - Starting timer to watch if Front End gets displaced and restore it if it does.
21:59:32:685 | RL |      INFO  | +16    | Main - Running module
21:59:32:898 | MD |      INFO  | +N/A   | Module initialized
21:59:32:926 | MD |     TRACE  | +32    | XHotkeyTableCreation - Started
21:59:32:958 | MD |     TRACE  | +31    | XHotkeyTableCreation - KeyGroup ~Esc not in TableKeyGroups
21:59:32:989 | MD |     TRACE  | +31    | XHotkeyTableCreation - Post loop 1 check
21:59:32:024 | MD |     TRACE  | +31    | XHotkeyTableCreation - Post loop 2 check
21:59:33:027 | MD |     TRACE  | +0     | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~Esc" to call label: "CloseProcess"
21:59:33:030 | MD |     TRACE  | +0     | XHotkeyTableCreation - Ended
21:59:33:053 | MD |      INFO  | +32    | StartModule - Started
21:59:33:056 | MD |      INFO  | +0     | StartModule - MEmu: WinVICE
MEmuV: v2.4
MURL: http://vice-emu.sourceforge.net/
MAuthor: djvj,wahoobrian,brolly
MVersion: 2.1.4
MCRC: E0C56FF6
iCRC: 5D564EA8
MID:
MSystem: "Commodore 64","Commodore 16 & Plus4","Commodore VIC-20","Commodore 128","Commodore MAX Machine","Commodore 64 Games System", "Commodore PET"
21:59:33:059 | MD |      INFO  | +0     | StartModule - You have a supported System Name for this module: "Commodore 64"
21:59:33:082 | MD |      INFO  | +31    | PluginInit - Started
21:59:33:085 | MD |     DEBUG  | +0     | BuildDatabaseTable - Started - Building Table for: Name|Cloneof|Publisher|Year|Genre|Rating
21:59:33:088 | MD |      INFO  | +0     | CheckFile - Checking if C:\hyperspin133\Databases\Commodore 64\Commodore 64.xml exists
21:59:33:092 | MD |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 160975 bytes
Created: 6/28/2016 - 8:52:58
Modified: 6/26/2016 - 10:01:23
21:59:33:109 | MD |     DEBUG  | +31    | BuildDatabaseTable - Searching for a "Game Name" in the database
21:59:33:112 | MD |     DEBUG  | +0     | BuildDatabaseTable - Found "Game Name" in the database!
21:59:33:115 | MD |     DEBUG  | +0     | BuildDatabaseTable - Searching database for: Name
21:59:33:119 | MD |     DEBUG  | +0     | BuildDatabaseTable - Found "Name" with a value: "10th Frame (1986)(Access Software)[cr TSC]"
21:59:33:122 | MD |     DEBUG  | +0     | BuildDatabaseTable - Searching database for: Cloneof
21:59:33:145 | MD |     DEBUG  | +31    | BuildDatabaseTable - Could not find: Cloneof
21:59:33:175 | MD |     DEBUG  | +32    | BuildDatabaseTable - Searching database for: Publisher
21:59:33:178 | MD |     DEBUG  | +0     | BuildDatabaseTable - Could not find: Publisher
21:59:33:181 | MD |     DEBUG  | +0     | BuildDatabaseTable - Searching database for: Year
21:59:33:184 | MD |     DEBUG  | +0     | BuildDatabaseTable - Could not find: Year
21:59:33:207 | MD |     DEBUG  | +31    | BuildDatabaseTable - Searching database for: Genre
21:59:33:210 | MD |     DEBUG  | +0     | BuildDatabaseTable - Could not find: Genre
21:59:33:213 | MD |     DEBUG  | +0     | BuildDatabaseTable - Searching database for: Rating
21:59:33:216 | MD |     DEBUG  | +0     | BuildDatabaseTable - Could not find: Rating
21:59:33:239 | MD |     TRACE  | +31    | PluginInit - GameInfo:
GameInfo Label: Name | GameInfo Value: 10th Frame (1986)(Access Software)[cr TSC]
21:59:33:242 | MD |     DEBUG  | +0     | BuildDatabaseTable - Ended
21:59:33:245 | MD |      INFO  | +0     | BuildAssetsTable - Started - Building Table for: Game Logo|System Logo
21:59:33:248 | MD |     DEBUG  | +0     | BuildAssetsTable - Searching for a Game Logo: C:\hyperspin133\Media\Commodore 64\Images\Wheel\10th Frame (1986)(Access Software)[cr TSC].png
21:59:33:269 | MD |     DEBUG  | +31    | BuildAssetsTable - Searching for a System Logo: C:\hyperspin133\Media\Main Menu\Images\Wheel\Commodore 64.png
21:59:33:273 | MD |     DEBUG  | +0     | BuildAssetsTable - Media assets found:
Asset Label: System Logo | Asset Path1:  C:\hyperspin133\Media\Main Menu\Images\Wheel\Commodore 64.png | Asset Extension1:  png | Asset Type1:  system
21:59:33:276 | MD |      INFO  | +0     | BuildAssetsTable - Ended
21:59:33:279 | MD |      INFO  | +0     | BuildAssetsTable - Started - Building Table for: Artwork1|Box Art|Cartridge|Flyers|Letters|Other
21:59:33:302 | MD |     DEBUG  | +32    | BuildAssetsTable - Searching for a Artwork1: C:\hyperspin133\Media\Commodore 64\Images\Artwork1\10th Frame (1986)(Access Software)[cr TSC].png
21:59:33:305 | MD |     DEBUG  | +0     | BuildAssetsTable - Searching for a Box Art: C:\hyperspin133\Media\Commodore 64\Images\Artwork2\10th Frame (1986)(Access Software)[cr TSC].png
21:59:33:308 | MD |     DEBUG  | +0     | BuildAssetsTable - Searching for a Cartridge: C:\hyperspin133\Media\Commodore 64\Images\Artwork3\10th Frame (1986)(Access Software)[cr TSC].png
21:59:33:311 | MD |     DEBUG  | +0     | BuildAssetsTable - Searching for a Flyers: C:\hyperspin133\Media\Commodore 64\Images\Artwork4\10th Frame (1986)(Access Software)[cr TSC].png
21:59:33:332 | MD |     DEBUG  | +31    | BuildAssetsTable - Searching for a Letters: C:\hyperspin133\Media\Commodore 64\Images\Letters
21:59:33:335 | MD |     DEBUG  | +0     | BuildAssetsTable - Searching for a Other: C:\hyperspin133\Media\Commodore 64\Images\Other
21:59:33:338 | MD |      INFO  | +0     | BuildAssetsTable - Ended
21:59:33:341 | MD |      INFO  | +0     | BuildAssetsTable - Started - Building Table for: Game Video|System Video
21:59:33:363 | MD |     DEBUG  | +31    | BuildAssetsTable - Searching for a Game Video: C:\hyperspin133\Media\Commodore 64\Video\10th Frame (1986)(Access Software)[cr TSC].*
21:59:33:366 | MD |     DEBUG  | +0     | BuildAssetsTable - Searching for a System Video: C:\hyperspin133\Media\Main Menu\Video\Commodore 64.*
21:59:33:369 | MD |     DEBUG  | +0     | BuildAssetsTable - Media assets found:
Asset Label: System Video | Asset Path1:  C:\hyperspin133\Media\Main Menu\Video\Commodore 64.mp4 | Asset Extension1:  mp4 | Asset Type1:  system
21:59:33:372 | MD |      INFO  | +0     | BuildAssetsTable - Ended
21:59:33:395 | MD |      INFO  | +31    | PluginInit - Ended
21:59:33:398 | MD |     DEBUG  | +0     | StartModule - Setting romName to the dbName sent to RocketLauncher: 10th Frame (1986)(Access Software)[cr TSC]
21:59:33:401 | MD |     TRACE  | +0     | XHotkeyTableCreation - Started
21:59:33:403 | MD |     TRACE  | +0     | XHotkeyTableCreation - KeyGroup ~e&~t not in TableKeyGroups ~Esc,
21:59:33:426 | MD |     TRACE  | +32    | XHotkeyTableCreation - Post loop 1 check
21:59:33:429 | MD |     TRACE  | +0     | XHotkeyTableCreation - Post loop 2 check
21:59:33:432 | MD |     TRACE  | +0     | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~e & ~t" to call label: "ToggleCursor"
21:59:33:435 | MD |     TRACE  | +0     | XHotkeyTableCreation - Ended
21:59:33:458 | MD |     TRACE  | +31    | Process.__New - Creating new process object for: "C:\hyperspin133\HyperSpin.exe"
21:59:33:460 | MD |     TRACE  | +0     | File.__New - Creating new file object of: "C:\hyperspin133\HyperSpin.exe"
21:59:33:488 | MD |     TRACE  | +31    | File.__New - Creating new file object of: "C:\hyperspin133\RocketLauncher\Modules\WinVICE\Commodore 64\10th Frame (1986)(Access Software)[cr TSC].ini"
21:59:33:519 | MD |     TRACE  | +31    | File.__New - Creating new file object of: "C:\hyperspin133\RocketLauncher\Modules\WinVICE\Commodore 64.ini"
21:59:33:551 | MD |     TRACE  | +32    | File.__New - Creating new file object of: "C:\hyperspin133\RocketLauncher\Modules\WinVICE\WinVICE.ini"
21:59:33:586 | MD |      INFO  | +31    | StartModule - Ended
21:59:33:589 | MD |     TRACE  | +0     | Emulator.__New - Creating new emulator object for: "C:\hyperspin133\Emulators\WinVICE\x64.exe"
21:59:33:591 | MD |     TRACE  | +0     | Process.__New - Creating new process object for: "C:\hyperspin133\Emulators\WinVICE\x64.exe"
21:59:33:615 | MD |     TRACE  | +31    | File.__New - Creating new file object of: "C:\hyperspin133\Emulators\WinVICE\x64.exe"
21:59:33:645 | MD |      INFO  | +31    | RIniFile.Read - Module - Fullscreen: true (DEFAULT)
21:59:33:648 | MD |      INFO  | +0     | RIniFile.Read - Module - WarpKey: F9 (DEFAULT)
21:59:33:651 | MD |      INFO  | +0     | RIniFile.Read - Module - JoySwapKey: F10 (DEFAULT)
21:59:33:654 | MD |      INFO  | +0     | RIniFile.Read - Module - StartTapeKey: F7 (DEFAULT)
21:59:33:677 | MD |      INFO  | +32    | RIniFile.Read - Module - StopTapeKey: F8 (DEFAULT)
21:59:33:680 | MD |      INFO  | +0     | RIniFile.Read - Module - bezelTopOffset: 16 (DEFAULT)
21:59:33:683 | MD |      INFO  | +0     | RIniFile.Read - Module - bezelBottomOffset: 46 (DEFAULT)
21:59:33:686 | MD |      INFO  | +0     | RIniFile.Read - Module - bezelLeftOffset: 7 (DEFAULT)
21:59:33:708 | MD |      INFO  | +31    | RIniFile.Read - Module - bezelRightOffset: 7 (DEFAULT)
21:59:33:711 | MD |      INFO  | +0     | RIniFile.Read - Module - DisableAutoControllerSwapping: false (DEFAULT)
21:59:33:714 | MD |      INFO  | +0     | RIniFile.Read - Module - UsePaddles: false (DEFAULT)
21:59:33:717 | MD |      INFO  | +0     | RIniFile.Read - Module - AutostartPrgMode: 2 (DEFAULT)
21:59:33:740 | MD |      INFO  | +31    | RIniFile.Read - Module - RequiresReset: false (DEFAULT)
21:59:33:743 | MD |      INFO  | +0     | RIniFile.Read - Module - RequiresHardReset: false (DEFAULT)
21:59:33:746 | MD |      INFO  | +0     | RIniFile.Read - Module - TrueDriveEmulation: false (DEFAULT)
21:59:33:749 | MD |      INFO  | +0     | RIniFile.Read - Module - LoadFile: (NO VALUE)
21:59:33:770 | MD |      INFO  | +31    | RIniFile.Read - Module - DefaultJoyPort: 1 (DEFAULT)
21:59:33:773 | MD |      INFO  | +0     | RIniFile.Read - Module - ColumnMode: 80 (DEFAULT)
21:59:33:776 | MD |      INFO  | +0     | 7z - Started, received C:\hyperspin133\Emulators\Arcade\Commodore 64\roms\10th Frame (1986)(Access Software)[cr TSC].d64. If rom is an archive, it will extract to C:\Users\nick\AppData\Local\Temp\HS
21:59:33:779 | MD |   WARNING  | +0     | 7z - Unhandled scenario, please report this and post your troubleshooting log
21:59:33:801 | MD |      INFO  | +32    | 7z - This rom type does not need 7z: ".d64"
21:59:33:804 | MD |      INFO  | +0     | 7z - Starting non-7z FadeIn animation.
21:59:33:807 | MD |   WARNING  | +0     | 7z - romPath changed from "C:\hyperspin133\Emulators\Arcade\Commodore 64\roms" to "C:\hyperspin133\Emulators\Arcade\Commodore 64\roms"
21:59:33:810 | MD |   WARNING  | +0     | 7z - romName changed from "10th Frame (1986)(Access Software)[cr TSC]" to "10th Frame (1986)(Access Software)[cr TSC]"
21:59:33:832 | MD |   WARNING  | +31    | 7z - romExtension changed from ".d64" to ".d64"
21:59:33:835 | MD |      INFO  | +0     | 7z - Ended
21:59:33:838 | MD |     TRACE  | +0     | File.__New - Creating new file object of: "C:\hyperspin133\Emulators\WinVICE\sdl-vice.ini"
21:59:33:860 | MD |     TRACE  | +31    | IniFile.__New - Created new ini object of: "C:\hyperspin133\Emulators\WinVICE\sdl-vice.ini"
21:59:33:863 | MD |      INFO  | +0     | Module - SDL mode is set to false
21:59:33:866 | MD |     TRACE  | +0     | Window.__New - Created: "ahk_class VICE"
21:59:33:869 | MD |     TRACE  | +0     | File.__New - Creating new file object of: "C:\hyperspin133\Emulators\WinVICE\vice.ini"
21:59:33:891 | MD |     TRACE  | +31    | IniFile.__New - Created new ini object of: "C:\hyperspin133\Emulators\WinVICE\vice.ini"
21:59:33:895 | MD |      INFO  | +0     | File.CheckFile - Checking if "C:\hyperspin133\Emulators\WinVICE\vice.ini" exists
21:59:33:928 | MD |     TRACE  | +32    | File.Exist - This file exists: C:\hyperspin133\Emulators\WinVICE\vice.ini
21:59:33:958 | MD |     DEBUG  | +31    | File.CheckFile - Attributes:
File Size: 7583 bytes
Created: 6/26/2016 - 11:43:24
Modified: 6/28/2016 - 2:16:55
21:59:33:961 | MD |     TRACE  | +0     | Window.__New - Created: "Select cartridge file ahk_class #32770"
21:59:33:964 | MD |     DEBUG  | +0     | IniFile.Read - SECTION: [C64] - KEY: FullscreenEnabled - VALUE:  - FILE: C:\hyperspin133\Emulators\WinVICE\vice.ini
21:59:33:967 | MD |     DEBUG  | +0     | IniFile.Read - SECTION: [C64] - KEY: 2 - VALUE:  - FILE: C:\hyperspin133\Emulators\WinVICE\vice.ini
21:59:33:989 | MD |     DEBUG  | +31    | IniFile.Read - SECTION: [C64] - KEY:  - VALUE:  - FILE: C:\hyperspin133\Emulators\WinVICE\vice.ini
21:59:33:035 | MD |     DEBUG  | +47    | IniFile.Read - SECTION: [C64] - KEY:  - VALUE:  - FILE: C:\hyperspin133\Emulators\WinVICE\vice.ini
21:59:34:038 | MD |     DEBUG  | +0     | IniFile.Read - SECTION: [C64] - KEY:  - VALUE:  - FILE: C:\hyperspin133\Emulators\WinVICE\vice.ini
21:59:34:066 | MD |      INFO  | +31    | IniFile.Write - SECTION: [C64] - KEY: AutostartPrgMode - VALUE: 2 - FILE: C:\hyperspin133\Emulators\WinVICE\vice.ini
21:59:34:069 | MD |     TRACE  | +0     | XHotkeyTableCreation - Started
21:59:34:073 | MD |     TRACE  | +0     | XHotkeyTableCreation - KeyGroup ~F9 not in TableKeyGroups ~Esc,~e&~t,
21:59:34:076 | MD |     TRACE  | +0     | XHotkeyTableCreation - Post loop 1 check
21:59:34:099 | MD |     TRACE  | +31    | XHotkeyTableCreation - Post loop 2 check
21:59:34:102 | MD |     TRACE  | +0     | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~F9" to call label: "Warp"
21:59:34:105 | MD |     TRACE  | +0     | XHotkeyTableCreation - Ended
21:59:34:128 | MD |     TRACE  | +32    | XHotkeyTableCreation - Started
21:59:34:131 | MD |     TRACE  | +0     | XHotkeyTableCreation - KeyGroup ~F10 not in TableKeyGroups ~Esc,~e&~t,~F9,
21:59:34:134 | MD |     TRACE  | +0     | XHotkeyTableCreation - Post loop 1 check
21:59:34:137 | MD |     TRACE  | +0     | XHotkeyTableCreation - Post loop 2 check
21:59:34:160 | MD |     TRACE  | +31    | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~F10" to call label: "JoySwap"
21:59:34:163 | MD |     TRACE  | +0     | XHotkeyTableCreation - Ended
21:59:34:166 | MD |     TRACE  | +0     | XHotkeyTableCreation - Started
21:59:34:169 | MD |     TRACE  | +0     | XHotkeyTableCreation - KeyGroup ~F7 not in TableKeyGroups ~Esc,~e&~t,~F9,~F10,
21:59:34:192 | MD |     TRACE  | +31    | XHotkeyTableCreation - Post loop 1 check
21:59:34:195 | MD |     TRACE  | +0     | XHotkeyTableCreation - Post loop 2 check
21:59:34:198 | MD |     TRACE  | +0     | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~F7" to call label: "StartTape"
21:59:34:201 | MD |     TRACE  | +0     | XHotkeyTableCreation - Ended
21:59:34:223 | MD |     TRACE  | +31    | XHotkeyTableCreation - Started
21:59:34:226 | MD |     TRACE  | +0     | XHotkeyTableCreation - KeyGroup ~F8 not in TableKeyGroups ~Esc,~e&~t,~F9,~F10,~F7,
21:59:34:229 | MD |     TRACE  | +0     | XHotkeyTableCreation - Post loop 1 check
21:59:34:232 | MD |     TRACE  | +0     | XHotkeyTableCreation - Post loop 2 check
21:59:34:255 | MD |     TRACE  | +32    | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~F8" to call label: "StopTape"
21:59:34:258 | MD |     TRACE  | +0     | XHotkeyTableCreation - Ended
21:59:34:261 | MD |     TRACE  | +0     | StringUtils.Contains - "10th Frame (1986)(Access Software)[cr TSC]" does not contain "\(USA\)|\(Canada\)"
21:59:34:264 | MD |      INFO  | +0     | RIniFile.Read - Module - VideoMode: PAL (DEFAULT)
21:59:34:285 | MD |     DEBUG  | +31    | IniFile.Read - SECTION: [C64] - KEY: Mouse - VALUE:  - FILE: C:\hyperspin133\Emulators\WinVICE\vice.ini
21:59:34:288 | MD |     TRACE  | +0     | StringUtils.Contains - ".d64" contains "\.d64|\.d71|\.d80|\.d81|\.d82|\.g64|\.g41|\.x64|\.t64|\.tap|\.crt|\.prg|\.vsf" at position 1
21:59:34:293 | MD |      INFO  | +0     | IniFile.Write - SECTION: [C64] - KEY: CartridgeFile - VALUE:  - FILE: C:\hyperspin133\Emulators\WinVICE\vice.ini
21:59:34:316 | MD |      INFO  | +31    | IniFile.Write - SECTION: [C64] - KEY: CartridgeType - VALUE: -1 - FILE: C:\hyperspin133\Emulators\WinVICE\vice.ini
21:59:34:320 | MD |      INFO  | +0     | IniFile.Write - SECTION: [C64] - KEY: DriveTrueEmulation - VALUE: 0 - FILE: C:\hyperspin133\Emulators\WinVICE\vice.ini
21:59:34:324 | MD |      INFO  | +0     | IniFile.Write - SECTION: [C64] - KEY: Drive8Type - VALUE: 0 - FILE: C:\hyperspin133\Emulators\WinVICE\vice.ini
21:59:34:327 | MD |      INFO  | +0     | IniFile.Write - SECTION: [C64] - KEY: JoyDevice1 - VALUE: 2 - FILE: C:\hyperspin133\Emulators\WinVICE\vice.ini
21:59:34:350 | MD |      INFO  | +31    | IniFile.Write - SECTION: [C64] - KEY: JoyDevice2 - VALUE: 3 - FILE: C:\hyperspin133\Emulators\WinVICE\vice.ini
21:59:34:353 | MD |      INFO  | +0     | RIniFile.Read - Module - SendCommandDelay: 1500 (DEFAULT)
21:59:34:356 | MD |      INFO  | +0     | RIniFile.Read - Module - Command: (NO VALUE)
21:59:34:379 | MD |     TRACE  | +32    | StringUtils.Contains - ".d64" contains "\.d64|\.d71|\.d80|\.d81|\.d82|\.g64|\.g41|\.x64|\.prg|\.vsf" at position 1
21:59:34:381 | MD |     TRACE  | +0     | CustomFunction.PreLaunch - Starting
21:59:34:384 | MD |     TRACE  | +0     | CustomFunction.PreLaunch - Ending
21:59:34:387 | MD |      INFO  | +0     | Process.Run - Running: C:\hyperspin133\Emulators\WinVICE\x64.exe +confirmexit -pal -autostart "C:\hyperspin133\Emulators\Arcade\Commodore 64\roms\10th Frame (1986)(Access Software)[cr TSC].d64:"
21:59:34:520 | MD |     DEBUG  | +140   | Process.Run - "x64.exe +confirmexit -pal -autostart "C:\hyperspin133\Emulators\Arcade\Commodore 64\roms\10th Frame (1986)(Access Software)[cr TSC].d64:"" Process ID: 2736
21:59:34:524 | MD |     TRACE  | +0     | CustomFunction.PostLaunch - Starting
21:59:34:527 | MD |     TRACE  | +0     | CustomFunction.PostLaunch - Ending
21:59:34:530 | MD |     TRACE  | +0     | Window.__New - Created: "ahk_id 721572"
21:59:34:553 | MD |     TRACE  | +32    | MiscUtils.DetectHiddenWindows - Mode changed to "Off"
21:59:34:556 | MD |     TRACE  | +0     | Window.GetPos - Retrieved x:541 y:205 w: 1355 h: 960 from "ahk_id 721572"
21:59:34:560 | MD |     TRACE  | +0     | MiscUtils.DetectHiddenWindows - Mode changed to "On"
21:59:34:583 | MD |     DEBUG  | +31    | MiscUtils.GetActiveWindowStatus - Title: RocketLauncherUI v1.0.1.4 [ FE = HyperSpin | Plugin = HyperSpin ] | Class: HwndWrapper[RocketLauncherUI.exe;;c1443040-2dd0-4fef-a3a9-7430d5d7c905] | State: 0 | X: 541 | Y: 205 | Width: 1355 | Height: 960 | Window HWND: 0xb02a4 | Process ID: 12480 | Process Path: C:\hyperspin133\RocketLauncher\RocketLauncherUI\RocketLauncherUI.exe
21:59:34:586 | MD |      INFO  | +0     | Window.Wait - Waiting for window "ahk_class VICE"
21:59:35:454 | MD |     TRACE  | +875   | Window.__New - Created: "ahk_id 1705476"
21:59:35:924 | MD |     TRACE  | +469   | MiscUtils.DetectHiddenWindows - Mode changed to "Off"
21:59:36:019 | MD |     TRACE  | +93    | Window.GetPos - Retrieved x:0 y:0 w: 1280 h: 1024 from "ahk_id 1705476"
21:59:36:022 | MD |     TRACE  | +0     | MiscUtils.DetectHiddenWindows - Mode changed to "On"
21:59:36:026 | MD |     DEBUG  | +0     | MiscUtils.GetActiveWindowStatus - Title: VICE: C64 emulator | Class: VICE | State: 0 | X: 0 | Y: 0 | Width: 1280 | Height: 1024 | Window HWND: 0x1a0604 | Process ID: 2736 | Process Path: C:\hyperspin133\Emulators\WinVICE\x64.exe
21:59:36:029 | MD |     TRACE  | +0     | Window.__New - Created: "ahk_id 1705476"
21:59:36:048 | MD |     TRACE  | +32    | MiscUtils.DetectHiddenWindows - Mode changed to "Off"
21:59:36:053 | MD |     TRACE  | +0     | Window.GetPos - Retrieved x:0 y:0 w: 1280 h: 1024 from "ahk_id 1705476"
21:59:36:057 | MD |     TRACE  | +0     | MiscUtils.DetectHiddenWindows - Mode changed to "On"
21:59:36:061 | MD |     DEBUG  | +0     | MiscUtils.GetActiveWindowStatus - Title: VICE: C64 emulator | Class: VICE | State: 0 | X: 0 | Y: 0 | Width: 1280 | Height: 1024 | Window HWND: 0x1a0604 | Process ID: 2736 | Process Path: C:\hyperspin133\Emulators\WinVICE\x64.exe
21:59:36:081 | MD |      INFO  | +31    | Window.WaitActive - Waiting for "ahk_class VICE"
21:59:36:188 | MD |     TRACE  | +109   | Window.__New - Created: "ahk_id 1705476"
21:59:36:192 | MD |     TRACE  | +0     | MiscUtils.DetectHiddenWindows - Mode changed to "Off"
21:59:36:197 | MD |     TRACE  | +0     | Window.GetPos - Retrieved x:0 y:0 w: 1280 h: 1024 from "ahk_id 1705476"
21:59:36:201 | MD |     TRACE  | +0     | MiscUtils.DetectHiddenWindows - Mode changed to "On"
21:59:36:220 | MD |     DEBUG  | +31    | MiscUtils.GetActiveWindowStatus - Title: VICE: C64 emulator | Class: VICE | State: 0 | X: 0 | Y: 0 | Width: 1280 | Height: 1024 | Window HWND: 0x1a0604 | Process ID: 2736 | Process Path: C:\hyperspin133\Emulators\WinVICE\x64.exe
21:59:36:275 | MD |     TRACE  | +47    | CustomFunction.PostLoad - Starting
21:59:36:304 | MD |     TRACE  | +32    | CustomFunction.PostLoad - Ending
21:59:36:308 | MD |      INFO  | +0     | Process.Process - "WaitClose" "x64.exe"
21:59:36:311 | MD |     TRACE  | +0     | Process.GetProcessID
21:59:43:344 | MD |      INFO  | +7046  | CloseProcess - Started, user requested to end launched application
21:59:43:382 | MD |     TRACE  | +32    | Window.Close - Closing: "ahk_class VICE"
21:59:43:977 | MD |      INFO  | +593   | CloseProcess - Ended
21:59:43:983 | MD |     DEBUG  | +0     | Process.Process - "x64.exe" returned 0 and is now closed. Continuing thread.
21:59:43:004 | MD |      INFO  | +32    | 7zCleanUp - Started
21:59:44:008 | MD |      INFO  | +0     | 7zCleanUp - Deleted
21:59:44:012 | MD |      INFO  | +0     | 7zCleanUp - Ended
21:59:44:031 | MD |      INFO  | +31    | ExitModule - Started
21:59:44:034 | MD |      INFO  | +0     | Starting Updating Statistics:
21:59:44:037 | MD |     TRACE  | +0     | Total Elapsed Time in Pause in seconds: 0
21:59:44:040 | MD |     TRACE  | +0     | gameSectionStartTime:225705281
21:59:44:044 | MD |     TRACE  | +0     | ElapsedTime:10
21:59:44:064 | MD |     TRACE  | +31    | Statistics cleared game name: 10th Frame
21:59:44:159 | MD |     TRACE  | +94    | Loaded game statistics from ini files:
Number_of_Times_Played: 0
Last_Time_Played: 0
Average_Time_Played: 0
Total_Time_Played: 0
System_Total_Played_Time: 108
Total_Global_Played_Time: 108
21:59:44:163 | MD |     TRACE  | +0     | Updated Statistics: Number_of_Times_Played: 1
Last_Time_Played: fredag juli 1, 2016 09:59:33
Average_Time_Played: 10
Total_Time_Played: 10
System_Total_Played_Time: 118
Total_Global_Played_Time: 118
21:59:44:226 | MD |      INFO  | +62    | Game section statistics updated.
21:59:44:229 | MD |     TRACE  | +0     | CustomFunction.PostExit - Starting
21:59:44:232 | MD |     TRACE  | +0     | CustomFunction.PostExit - Ending
21:59:44:256 | MD |      INFO  | +32    | ExitModule - Ended
End of Module Logs
21:59:44:345 | RL |      INFO  | +11671 | Main - Module ended, exiting RocketLauncher normally
21:59:44:348 | RL |      INFO  | +0     | ExitScript - Started
21:59:44:356 | RL |     TRACE  | +0     | StringUtils.Contains - "false" does not contain "true|kill"
21:59:44:359 | RL |      INFO  | +16    | ExitScript - Restoring taskbar
21:59:44:362 | RL |     TRACE  | +0     | Window.__New - Created: "ahk_class Shell_TrayWnd"
21:59:44:365 | RL |     TRACE  | +0     | Window.__New - Created: "Start ahk_class Button"
21:59:44:369 | RL |     TRACE  | +0     | Window.Show - Unhiding window "ahk_class Shell_TrayWnd"
21:59:44:492 | RL |     TRACE  | +125   | Window.Show - Unhiding window "Start ahk_class Button"
21:59:44:663 | RL |      INFO  | +172   | SystemCursor - Restoring mouse cursor
21:59:44:675 | RL |      INFO  | +16    | ExitScript - Restored cursor
the rocketlauncherui.log looks like this:
INFO  2016-07-01 09:58:44 [1] RocketLauncher.UI.Util.FileUtils RocketLauncher.UI.Util.FileUtils.findDllFolder(:0) – 7z.dll found in C:\hyperspin133\RocketLauncher\RocketLauncherUI\lib
DEBUG 2016-07-01 09:58:44 [1] RocketLauncher.UI.Ini.RocketLauncherUIIni RocketLauncher.UI.Ini.RocketLauncherUIIni..ctor(:0) – RocketLauncherUI ini file path is C:\hyperspin133\RocketLauncher\RocketLauncherUI\Settings\RocketLauncherUI.ini
DEBUG 2016-07-01 09:58:44 [1] RocketLauncher.UI.Ini.IniFile RocketLauncher.UI.Ini.IniFile..ctor(:0) – Loading INI File C:\hyperspin133\RocketLauncher\RocketLauncherUI\Settings\RocketLauncherUI.ini
DEBUG 2016-07-01 09:58:44 [1] RocketLauncher.UI.Ini.RocketLauncherUIIni RocketLauncher.UI.Ini.RocketLauncherUIIni.readIniValues(:0) – Window coordinates are : 1355|960|541|205
DEBUG 2016-07-01 09:58:44 [1] RocketLauncher.UI.Util.AdsUtil RocketLauncher.UI.Util.AdsUtil.checkIfFileIsBlocked(:0) – Security zone for 'C:\hyperspin133\RocketLauncher\Module Extensions\RocketLauncher.dll' is MyComputer
DEBUG 2016-07-01 09:58:44 [1] RocketLauncher.UI.Database.DatabasePluginManager RocketLauncher.UI.Database.DatabasePluginManager.BuildAssembly(:0) – LinqXML is at C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\System.Xml.Linq\v4.0_4.0.0.0__b77a5c561934e089\System.Xml.Linq.dll
DEBUG 2016-07-01 09:58:44 [1] RocketLauncher.UI.Ini.FrontendIni RocketLauncher.UI.Ini.FrontendIni..ctor(:0) – Frontends ini file path is C:\hyperspin133\RocketLauncher\RocketLauncherUI\Settings\Frontends.ini
DEBUG 2016-07-01 09:58:44 [1] RocketLauncher.UI.Ini.IniFile RocketLauncher.UI.Ini.IniFile..ctor(:0) – Loading INI File C:\hyperspin133\RocketLauncher\RocketLauncherUI\Settings\Frontends.ini
DEBUG 2016-07-01 09:58:45 [1] RocketLauncher.UI.Ini.RocketLauncherUIIni RocketLauncher.UI.Ini.RocketLauncherUIIni..ctor(:0) – RocketLauncherUI ini file path is C:\hyperspin133\RocketLauncher\RocketLauncherUI\Settings\RocketLauncherUI.ini
DEBUG 2016-07-01 09:58:45 [1] RocketLauncher.UI.Ini.IniFile RocketLauncher.UI.Ini.IniFile..ctor(:0) – Loading INI File C:\hyperspin133\RocketLauncher\RocketLauncherUI\Settings\RocketLauncherUI.ini
DEBUG 2016-07-01 09:58:45 [1] RocketLauncher.UI.Ini.RocketLauncherUIIni RocketLauncher.UI.Ini.RocketLauncherUIIni.readIniValues(:0) – Window coordinates are : 1355|960|541|205
DEBUG 2016-07-01 09:58:45 [1] RocketLauncher.UI.Ini.FrontendIni RocketLauncher.UI.Ini.FrontendIni..ctor(:0) – Frontends ini file path is C:\hyperspin133\RocketLauncher\RocketLauncherUI\Settings\Frontends.ini
DEBUG 2016-07-01 09:58:45 [1] RocketLauncher.UI.Ini.IniFile RocketLauncher.UI.Ini.IniFile..ctor(:0) – Loading INI File C:\hyperspin133\RocketLauncher\RocketLauncherUI\Settings\Frontends.ini
DEBUG 2016-07-01 09:58:45 [1] RocketLauncher.UI.Forms.BaseWindow RocketLauncher.UI.Forms.BaseWindow..ctor(:0) – Main Folder is C:\hyperspin133\RocketLauncher
DEBUG 2016-07-01 09:58:45 [1] RocketLauncher.UI.Forms.BaseWindow RocketLauncher.UI.Forms.BaseWindow..ctor(:0) – Initializing Emulator Settings...
DEBUG 2016-07-01 09:58:45 [1] RocketLauncher.UI.Forms.BaseWindow RocketLauncher.UI.Forms.BaseWindow..ctor(:0) – Initializing Game Settings...
DEBUG 2016-07-01 09:58:45 [1] RocketLauncher.UI.Forms.BaseWindow RocketLauncher.UI.Forms.BaseWindow..ctor(:0) – Initializing Global RocketLauncher Settings...
DEBUG 2016-07-01 09:58:45 [1] RocketLauncher.UI.Ini.IniFile RocketLauncher.UI.Ini.IniFile..ctor(:0) – Loading INI File C:\hyperspin133\RocketLauncher\Settings\RocketLauncher.ini
DEBUG 2016-07-01 09:58:45 [1] RocketLauncher.UI.Forms.BaseWindow RocketLauncher.UI.Forms.BaseWindow..ctor(:0) – Initializing RocketLauncher Settings...
DEBUG 2016-07-01 09:58:45 [1] RocketLauncher.UI.Forms.BaseWindow RocketLauncher.UI.Forms.BaseWindow..ctor(:0) – Initializing Pause Settings...
DEBUG 2016-07-01 09:58:45 [1] RocketLauncher.UI.Forms.BaseWindow RocketLauncher.UI.Forms.BaseWindow..ctor(:0) – Initializing Bezel Settings...
DEBUG 2016-07-01 09:58:45 [1] RocketLauncher.UI.Forms.BaseWindow RocketLauncher.UI.Forms.BaseWindow..ctor(:0) – Initializing Plugins Settings...
DEBUG 2016-07-01 09:58:45 [1] RocketLauncher.UI.Forms.BaseWindow RocketLauncher.UI.Forms.BaseWindow..ctor(:0) – Frontend folder is C:\hyperspin133
DEBUG 2016-07-01 09:58:45 [1] RocketLauncher.UI.Forms.BaseWindow RocketLauncher.UI.Forms.BaseWindow..ctor(:0) – Reading RLUI version
DEBUG 2016-07-01 09:58:45 [1] RocketLauncher.UI.Forms.BaseWindow RocketLauncher.UI.Forms.BaseWindow..ctor(:0) – AssemblyVersion is 1.0.1.4, FileVersion is 1.0.1.4
DEBUG 2016-07-01 09:58:45 [1] RocketLauncher.UI.Forms.BaseWindow RocketLauncher.UI.Forms.BaseWindow.loadSystems(:0) – Loading systems...
DEBUG 2016-07-01 09:58:45 [1] RocketLauncher.UI.Forms.BaseWindow RocketLauncher.UI.Forms.BaseWindow.loadSystems(:0) – RLUI Media folder is set to : .\Media
DEBUG 2016-07-01 09:58:45 [1] RocketLauncher.UI.Forms.BaseWindow RocketLauncher.UI.Forms.BaseWindow.loadSystems(:0) – Searching for icons in : C:\hyperspin133\RocketLauncher\RocketLauncherUI\Media\Icons\GLOBAL.png
DEBUG 2016-07-01 09:58:45 [1] RocketLauncher.UI.Forms.BaseWindow RocketLauncher.UI.Forms.BaseWindow.loadSystems(:0) – Searching for logos in : C:\hyperspin133\RocketLauncher\RocketLauncherUI\Media\Icons\GLOBAL.png
DEBUG 2016-07-01 09:58:45 [1] RocketLauncher.UI.Forms.BaseWindow RocketLauncher.UI.Forms.BaseWindow.refreshSystemsList(:0) – Database being read from Main Menu.xml according to plugin
DEBUG 2016-07-01 09:58:45 [1] RocketLauncher.UI.Forms.BaseWindow RocketLauncher.UI.Forms.BaseWindow.refreshSystemsList(:0) – Loading systems complete. 21 systems found
DEBUG 2016-07-01 09:58:45 [1] RocketLauncher.UI.Forms.BaseWindow RocketLauncher.UI.Forms.BaseWindow..ctor(:0) – Initializing Components
DEBUG 2016-07-01 09:58:48 [1] RocketLauncher.UI.Controls.RocketLauncherUIPanel RocketLauncher.UI.Controls.RocketLauncherUIPanel..ctor(:0) – Initializing RocketLauncherUIPanel
DEBUG 2016-07-01 09:58:48 [1] RocketLauncher.UI.Controls.RocketLauncherUIPanel RocketLauncher.UI.Controls.RocketLauncherUIPanel..ctor(:0) – RocketLauncherUIPanel Initialization complete
DEBUG 2016-07-01 09:58:48 [1] RocketLauncher.UI.Forms.BaseWindow RocketLauncher.UI.Forms.BaseWindow..ctor(:0) – Initializing Systray
DEBUG 2016-07-01 09:58:48 [1] RocketLauncher.UI.Forms.BaseWindow RocketLauncher.UI.Forms.BaseWindow..ctor(:0) – Reading version info
DEBUG 2016-07-01 09:58:48 [1] RocketLauncher.UI.Controls.RocketLauncherUIPanel RocketLauncher.UI.Controls.RocketLauncherUIPanel.CheckWinMgmtService(:0) – Detecting if WMI Service is running...
INFO  2016-07-01 09:58:48 [1] RocketLauncher.UI.Controls.RocketLauncherUIPanel RocketLauncher.UI.Controls.RocketLauncherUIPanel.CheckWinMgmtService(:0) – WMI Service is running
DEBUG 2016-07-01 09:58:48 [1] RocketLauncher.UI.Forms.BaseWindow RocketLauncher.UI.Forms.BaseWindow.updateWindowTitle(:0) – Updating Main Window title...
DEBUG 2016-07-01 09:58:48 [1] RocketLauncher.UI.Forms.BaseWindow RocketLauncher.UI.Forms.BaseWindow.updateWindowTitle(:0) – Active plugin is HyperSpin on version v1.0.0
DEBUG 2016-07-01 09:58:48 [1] RocketLauncher.UI.Forms.BaseWindow RocketLauncher.UI.Forms.BaseWindow.updateWindowTitle(:0) – Main Window title Updated to RocketLauncherUI v1.0.1.4 [ FE = HyperSpin | Plugin = HyperSpin ]
DEBUG 2016-07-01 09:58:48 [1] RocketLauncher.UI.Forms.BaseWindow RocketLauncher.UI.Forms.BaseWindow..ctor(:0) – Loading Joysticks from Constructor
DEBUG 2016-07-01 09:58:48 [1] RocketLauncher.UI.Forms.BaseWindow RocketLauncher.UI.Forms.BaseWindow.LoadConnectedJoysticks(:0) – getConnectedJoystickOEMNames from LoadConnectedJoysticks : True
DEBUG 2016-07-01 09:58:48 [1] RocketLauncher.UI.Util.JoystickUtil RocketLauncher.UI.Util.JoystickUtil.queryJoysticks(:0) – Forcing JoyConfigChanged...
DEBUG 2016-07-01 09:58:48 [1] RocketLauncher.UI.Util.JoystickUtil RocketLauncher.UI.Util.JoystickUtil.queryJoysticks(:0) – JoyConfigChanged Complete
DEBUG 2016-07-01 09:58:48 [1] RocketLauncher.UI.Util.JoystickUtil RocketLauncher.UI.Util.JoystickUtil.getNumberOfJoysticksForDriver(:0) – Reading Joystick Driver Info
DEBUG 2016-07-01 09:58:48 [1] RocketLauncher.UI.Util.JoystickUtil RocketLauncher.UI.Util.JoystickUtil.getNumberOfJoysticksForDriver(:0) – Driver Info Returned 16
DEBUG 2016-07-01 09:58:48 [1] RocketLauncher.UI.Util.JoystickUtil RocketLauncher.UI.Util.JoystickUtil.getJoystickInfoEx(:0) – Reading Joystick Extended Info for ID 0
DEBUG 2016-07-01 09:58:48 [1] RocketLauncher.UI.Util.JoystickUtil RocketLauncher.UI.Util.JoystickUtil.getJoystickInfoEx(:0) – Extended Info is 165
DEBUG 2016-07-01 09:58:48 [1] RocketLauncher.UI.Util.JoystickUtil RocketLauncher.UI.Util.JoystickUtil.getJoystickInfoEx(:0) – Reading Joystick Extended Info for ID 1
DEBUG 2016-07-01 09:58:48 [1] RocketLauncher.UI.Util.JoystickUtil RocketLauncher.UI.Util.JoystickUtil.getJoystickInfoEx(:0) – Reading Joystick Extended Info for ID 2
DEBUG 2016-07-01 09:58:48 [1] RocketLauncher.UI.Util.JoystickUtil RocketLauncher.UI.Util.JoystickUtil.getJoystickInfoEx(:0) – Reading Joystick Extended Info for ID 3
DEBUG 2016-07-01 09:58:48 [1] RocketLauncher.UI.Util.JoystickUtil RocketLauncher.UI.Util.JoystickUtil.getJoystickInfoEx(:0) – Reading Joystick Extended Info for ID 4
DEBUG 2016-07-01 09:58:48 [1] RocketLauncher.UI.Util.JoystickUtil RocketLauncher.UI.Util.JoystickUtil.getJoystickInfoEx(:0) – Reading Joystick Extended Info for ID 5
DEBUG 2016-07-01 09:58:48 [1] RocketLauncher.UI.Util.JoystickUtil RocketLauncher.UI.Util.JoystickUtil.getJoystickInfoEx(:0) – Reading Joystick Extended Info for ID 6
DEBUG 2016-07-01 09:58:48 [1] RocketLauncher.UI.Util.JoystickUtil RocketLauncher.UI.Util.JoystickUtil.getJoystickInfoEx(:0) – Reading Joystick Extended Info for ID 7
DEBUG 2016-07-01 09:58:48 [1] RocketLauncher.UI.Util.JoystickUtil RocketLauncher.UI.Util.JoystickUtil.getJoystickInfoEx(:0) – Reading Joystick Extended Info for ID 8
DEBUG 2016-07-01 09:58:48 [1] RocketLauncher.UI.Util.JoystickUtil RocketLauncher.UI.Util.JoystickUtil.getJoystickInfoEx(:0) – Reading Joystick Extended Info for ID 9
DEBUG 2016-07-01 09:58:48 [1] RocketLauncher.UI.Util.JoystickUtil RocketLauncher.UI.Util.JoystickUtil.getJoystickInfoEx(:0) – Reading Joystick Extended Info for ID 10
DEBUG 2016-07-01 09:58:48 [1] RocketLauncher.UI.Util.JoystickUtil RocketLauncher.UI.Util.JoystickUtil.getJoystickInfoEx(:0) – Reading Joystick Extended Info for ID 11
DEBUG 2016-07-01 09:58:48 [1] RocketLauncher.UI.Util.JoystickUtil RocketLauncher.UI.Util.JoystickUtil.getJoystickInfoEx(:0) – Reading Joystick Extended Info for ID 12
DEBUG 2016-07-01 09:58:48 [1] RocketLauncher.UI.Util.JoystickUtil RocketLauncher.UI.Util.JoystickUtil.getJoystickInfoEx(:0) – Reading Joystick Extended Info for ID 13
DEBUG 2016-07-01 09:58:48 [1] RocketLauncher.UI.Util.JoystickUtil RocketLauncher.UI.Util.JoystickUtil.getJoystickInfoEx(:0) – Reading Joystick Extended Info for ID 14
DEBUG 2016-07-01 09:58:48 [1] RocketLauncher.UI.Util.JoystickUtil RocketLauncher.UI.Util.JoystickUtil.getJoystickInfoEx(:0) – Reading Joystick Extended Info for ID 15
DEBUG 2016-07-01 09:58:48 [1] RocketLauncher.UI.Ini.IniFile RocketLauncher.UI.Ini.IniFile..ctor(:0) – Loading INI File C:\hyperspin133\RocketLauncher\Settings\Global Emulators.ini
DEBUG 2016-07-01 09:58:48 [1] RocketLauncher.UI.Ini.IniFile RocketLauncher.UI.Ini.IniFile..ctor(:0) – Loading INI File C:\hyperspin133\RocketLauncher\Settings\Global RocketLauncher.ini
DEBUG 2016-07-01 09:58:49 [1] RocketLauncher.UI.Ini.IniFile RocketLauncher.UI.Ini.IniFile..ctor(:0) – Loading INI File C:\hyperspin133\RocketLauncher\Settings\Global Pause.ini
DEBUG 2016-07-01 09:58:49 [1] RocketLauncher.UI.Ini.IniFile RocketLauncher.UI.Ini.IniFile..ctor(:0) – Loading INI File C:\hyperspin133\RocketLauncher\Settings\Global Bezel.ini
DEBUG 2016-07-01 09:58:49 [1] RocketLauncher.UI.Ini.IniFile RocketLauncher.UI.Ini.IniFile..ctor(:0) – Loading INI File C:\hyperspin133\RocketLauncher\Settings\Global Plugins.ini
DEBUG 2016-07-01 09:58:49 [1] RocketLauncher.UI.Forms.BaseWindow RocketLauncher.UI.Forms.BaseWindow..ctor(:0) – Loading Modules
DEBUG 2016-07-01 09:58:49 [1] RocketLauncher.UI.Controls.ModulePanel RocketLauncher.UI.Controls.ModulePanel.GenerateModuleList(:0) – Loading modules from C:\hyperspin133\RocketLauncher\Modules
DEBUG 2016-07-01 09:58:52 [1] RocketLauncher.UI.Forms.BaseWindow RocketLauncher.UI.Forms.BaseWindow..ctor(:0) – Loading Keymapper Profiles
DEBUG 2016-07-01 09:58:52 [1] RocketLauncher.UI.Util.KeymapperLoader RocketLauncher.UI.Util.KeymapperLoader.getSystemNames(:0) – Loading System Names...
DEBUG 2016-07-01 09:58:52 [1] RocketLauncher.UI.Util.KeymapperLoader RocketLauncher.UI.Util.KeymapperLoader.getGlobalEmuNames(:0) – Loading Global Emulator Names...
DEBUG 2016-07-01 09:58:52 [1] RocketLauncher.UI.Util.KeymapperLoader RocketLauncher.UI.Util.KeymapperLoader.getSystemEmuNames(:0) – Loading System Emulator Names...
DEBUG 2016-07-01 09:58:52 [1] RocketLauncher.UI.Util.KeymapperLoader RocketLauncher.UI.Util.KeymapperLoader.getJoystickNames(:0) – Loading Joystick Names...
DEBUG 2016-07-01 09:58:52 [1] RocketLauncher.UI.Util.JoystickUtil RocketLauncher.UI.Util.JoystickUtil.getLocalOEMIds(:0) – Reading OEM Ids...
DEBUG 2016-07-01 09:58:52 [1] RocketLauncher.UI.Util.JoystickUtil RocketLauncher.UI.Util.JoystickUtil.getLocalOEMIds(:0) – Found 30 entries
DEBUG 2016-07-01 09:58:52 [1] RocketLauncher.UI.Util.JoystickUtil RocketLauncher.UI.Util.JoystickUtil.getUserOEMIds(:0) – Reading User OEM Ids...
DEBUG 2016-07-01 09:58:52 [1] RocketLauncher.UI.Util.JoystickUtil RocketLauncher.UI.Util.JoystickUtil.getUserOEMIds(:0) – Found 3 entries
DEBUG 2016-07-01 09:58:52 [1] RocketLauncher.UI.Util.JoystickUtil RocketLauncher.UI.Util.JoystickUtil.getOEMName(:0) – Reading User OEM Name for VID_044F&PID_A012
DEBUG 2016-07-01 09:58:52 [1] RocketLauncher.UI.Util.JoystickUtil RocketLauncher.UI.Util.JoystickUtil.getOEMName(:0) – Name is null
DEBUG 2016-07-01 09:58:52 [1] RocketLauncher.UI.Util.JoystickUtil RocketLauncher.UI.Util.JoystickUtil.getOEMName(:0) – Reading User OEM Name for VID_044F&PID_B202
DEBUG 2016-07-01 09:58:52 [1] RocketLauncher.UI.Util.JoystickUtil RocketLauncher.UI.Util.JoystickUtil.getOEMName(:0) – Reading User OEM Name for VID_045E&PID_000E
DEBUG 2016-07-01 09:58:52 [1] RocketLauncher.UI.Util.JoystickUtil RocketLauncher.UI.Util.JoystickUtil.getOEMName(:0) – Reading User OEM Name for VID_045E&PID_001A
DEBUG 2016-07-01 09:58:52 [1] RocketLauncher.UI.Util.JoystickUtil RocketLauncher.UI.Util.JoystickUtil.getOEMName(:0) – Reading User OEM Name for VID_045E&PID_001B
DEBUG 2016-07-01 09:58:52 [1] RocketLauncher.UI.Util.JoystickUtil RocketLauncher.UI.Util.JoystickUtil.getOEMName(:0) – Reading User OEM Name for VID_045E&PID_0026
DEBUG 2016-07-01 09:58:52 [1] RocketLauncher.UI.Util.JoystickUtil RocketLauncher.UI.Util.JoystickUtil.getOEMName(:0) – Reading User OEM Name for VID_045E&PID_0034
DEBUG 2016-07-01 09:58:52 [1] RocketLauncher.UI.Util.JoystickUtil RocketLauncher.UI.Util.JoystickUtil.getOEMName(:0) – Reading User OEM Name for VID_045E&PID_0038
DEBUG 2016-07-01 09:58:52 [1] RocketLauncher.UI.Util.JoystickUtil RocketLauncher.UI.Util.JoystickUtil.getOEMName(:0) – Reading User OEM Name for VID_045E&PID_003B
DEBUG 2016-07-01 09:58:52 [1] RocketLauncher.UI.Util.JoystickUtil RocketLauncher.UI.Util.JoystickUtil.getOEMName(:0) – Reading User OEM Name for VID_046D&PID_C029
DEBUG 2016-07-01 09:58:52 [1] RocketLauncher.UI.Util.JoystickUtil RocketLauncher.UI.Util.JoystickUtil.getOEMName(:0) – Reading User OEM Name for VID_046D&PID_C202
DEBUG 2016-07-01 09:58:52 [1] RocketLauncher.UI.Util.JoystickUtil RocketLauncher.UI.Util.JoystickUtil.getOEMName(:0) – Reading User OEM Name for VID_046D&PID_C208
DEBUG 2016-07-01 09:58:52 [1] RocketLauncher.UI.Util.JoystickUtil RocketLauncher.UI.Util.JoystickUtil.getOEMName(:0) – Reading User OEM Name for VID_046D&PID_C209
DEBUG 2016-07-01 09:58:52 [1] RocketLauncher.UI.Util.JoystickUtil RocketLauncher.UI.Util.JoystickUtil.getOEMName(:0) – Reading User OEM Name for VID_046D&PID_C20A
DEBUG 2016-07-01 09:58:52 [1] RocketLauncher.UI.Util.JoystickUtil RocketLauncher.UI.Util.JoystickUtil.getOEMName(:0) – Reading User OEM Name for VID_046D&PID_C291
DEBUG 2016-07-01 09:58:52 [1] RocketLauncher.UI.Util.JoystickUtil RocketLauncher.UI.Util.JoystickUtil.getOEMName(:0) – Reading User OEM Name for VID_046D&PID_C293
DEBUG 2016-07-01 09:58:52 [1] RocketLauncher.UI.Util.JoystickUtil RocketLauncher.UI.Util.JoystickUtil.getOEMName(:0) – Reading User OEM Name for VID_047D&PID_3001
DEBUG 2016-07-01 09:58:52 [1] RocketLauncher.UI.Util.JoystickUtil RocketLauncher.UI.Util.JoystickUtil.getOEMName(:0) – Reading User OEM Name for VID_047D&PID_3004
DEBUG 2016-07-01 09:58:52 [1] RocketLauncher.UI.Util.JoystickUtil RocketLauncher.UI.Util.JoystickUtil.getOEMName(:0) – Reading User OEM Name for VID_047D&PID_3005
DEBUG 2016-07-01 09:58:52 [1] RocketLauncher.UI.Util.JoystickUtil RocketLauncher.UI.Util.JoystickUtil.getOEMName(:0) – Reading User OEM Name for VID_047D&PID_4003
DEBUG 2016-07-01 09:58:52 [1] RocketLauncher.UI.Util.JoystickUtil RocketLauncher.UI.Util.JoystickUtil.getOEMName(:0) – Reading User OEM Name for VID_047D&PID_4005
DEBUG 2016-07-01 09:58:52 [1] RocketLauncher.UI.Util.JoystickUtil RocketLauncher.UI.Util.JoystickUtil.getOEMName(:0) – Reading User OEM Name for VID_047D&PID_4008
DEBUG 2016-07-01 09:58:52 [1] RocketLauncher.UI.Util.JoystickUtil RocketLauncher.UI.Util.JoystickUtil.getOEMName(:0) – Reading User OEM Name for VID_05FD&PID_0253
DEBUG 2016-07-01 09:58:52 [1] RocketLauncher.UI.Util.JoystickUtil RocketLauncher.UI.Util.JoystickUtil.getOEMName(:0) – Reading User OEM Name for VID_05FD&PID_3002
DEBUG 2016-07-01 09:58:52 [1] RocketLauncher.UI.Util.JoystickUtil RocketLauncher.UI.Util.JoystickUtil.getOEMName(:0) – Reading User OEM Name for VID_06A3&PID_0101
DEBUG 2016-07-01 09:58:52 [1] RocketLauncher.UI.Util.JoystickUtil RocketLauncher.UI.Util.JoystickUtil.getOEMName(:0) – Reading User OEM Name for VID_06A3&PID_0102
DEBUG 2016-07-01 09:58:52 [1] RocketLauncher.UI.Util.JoystickUtil RocketLauncher.UI.Util.JoystickUtil.getOEMName(:0) – Reading User OEM Name for VID_06A3&PID_0104
DEBUG 2016-07-01 09:58:52 [1] RocketLauncher.UI.Util.JoystickUtil RocketLauncher.UI.Util.JoystickUtil.getOEMName(:0) – Reading User OEM Name for VID_06F8&PID_0004
DEBUG 2016-07-01 09:58:52 [1] RocketLauncher.UI.Util.JoystickUtil RocketLauncher.UI.Util.JoystickUtil.getOEMName(:0) – Reading User OEM Name for VID_06F8&PID_A300
DEBUG 2016-07-01 09:58:52 [1] RocketLauncher.UI.Util.JoystickUtil RocketLauncher.UI.Util.JoystickUtil.getOEMName(:0) – Reading User OEM Name for VID_06F8&PID_A303
DEBUG 2016-07-01 09:58:52 [1] RocketLauncher.UI.Util.JoystickUtil RocketLauncher.UI.Util.JoystickUtil.getOEMName(:0) – Reading User OEM Name for VID_0314&PID_0326
DEBUG 2016-07-01 09:58:52 [1] RocketLauncher.UI.Util.JoystickUtil RocketLauncher.UI.Util.JoystickUtil.getOEMName(:0) – Name is JUYAO Dual Arcade
DEBUG 2016-07-01 09:58:52 [1] RocketLauncher.UI.Util.JoystickUtil RocketLauncher.UI.Util.JoystickUtil.getOEMName(:0) – Reading User OEM Name for VID_043D&PID_0185
DEBUG 2016-07-01 09:58:52 [1] RocketLauncher.UI.Util.JoystickUtil RocketLauncher.UI.Util.JoystickUtil.getOEMName(:0) – Reading User OEM Name for VID_04F3&PID_0103
DEBUG 2016-07-01 09:58:52 [1] RocketLauncher.UI.Util.KeymapperLoader RocketLauncher.UI.Util.KeymapperLoader.listKeymapperProfiles(:0) – Loading AHK Profiles...
DEBUG 2016-07-01 09:58:52 [1] RocketLauncher.UI.Util.KeymapperLoader RocketLauncher.UI.Util.KeymapperLoader.listKeymapperProfiles(:0) – Loading JoyToKey Profiles...
DEBUG 2016-07-01 09:58:52 [1] RocketLauncher.UI.Util.KeymapperLoader RocketLauncher.UI.Util.KeymapperLoader.listKeymapperProfiles(:0) – Loading xPadder Profiles...
DEBUG 2016-07-01 09:58:52 [1] RocketLauncher.UI.Util.KeymapperLoader RocketLauncher.UI.Util.KeymapperLoader.listKeymapperProfiles(:0) – Loading VJoy Profiles...
DEBUG 2016-07-01 09:58:52 [1] RocketLauncher.UI.Util.KeymapperLoader RocketLauncher.UI.Util.KeymapperLoader.listKeymapperProfiles(:0) – Profiles loading complete
DEBUG 2016-07-01 09:58:52 [1] RocketLauncher.UI.Util.KeymapperLoader RocketLauncher.UI.Util.KeymapperLoader.listStandardKeymapperProfiles(:0) – Loading WinIPAC Profiles...
DEBUG 2016-07-01 09:58:52 [1] RocketLauncher.UI.Util.KeymapperLoader RocketLauncher.UI.Util.KeymapperLoader.listStandardKeymapperProfiles(:0) – Profiles loading complete
DEBUG 2016-07-01 09:58:52 [1] RocketLauncher.UI.Util.KeymapperLoader RocketLauncher.UI.Util.KeymapperLoader.listStandardKeymapperProfiles(:0) – Loading Ultramap Profiles...
DEBUG 2016-07-01 09:58:54 [1] RocketLauncher.UI.Updater.AutoUpdater RocketLauncher.UI.Updater.AutoUpdater.getMD5Hash(:0) – Calculating hash for file
DEBUG 2016-07-01 09:58:54 [1] RocketLauncher.UI.Updater.AutoUpdater RocketLauncher.UI.Updater.AutoUpdater.getCRC32(:0) – Calculating crc for file
DEBUG 2016-07-01 09:58:54 [1] RocketLauncher.UI.Updater.SimpleAES RocketLauncher.UI.Updater.SimpleAES.releaseObjects(:0) – Releasing encryptor objects
DEBUG 2016-07-01 09:59:22 [1] RocketLauncher.UI.Ini.IniFile RocketLauncher.UI.Ini.IniFile..ctor(:0) – Loading INI File C:\hyperspin133\RocketLauncher\Settings\Commodore 64\Emulators.ini
DEBUG 2016-07-01 09:59:22 [1] RocketLauncher.UI.Ini.IniFile RocketLauncher.UI.Ini.IniFile..ctor(:0) – Loading INI File C:\hyperspin133\RocketLauncher\Settings\Global Emulators.ini
DEBUG 2016-07-01 09:59:22 [1] RocketLauncher.UI.Ini.IniFile RocketLauncher.UI.Ini.IniFile..ctor(:0) – Loading INI File C:\hyperspin133\RocketLauncher\Settings\Commodore 64\Games.ini
DEBUG 2016-07-01 09:59:22 [1] RocketLauncher.UI.Ini.IniFile RocketLauncher.UI.Ini.IniFile..ctor(:0) – Loading INI File C:\hyperspin133\RocketLauncher\Settings\Commodore 64\RocketLauncher.ini
DEBUG 2016-07-01 09:59:22 [1] RocketLauncher.UI.Ini.IniFile RocketLauncher.UI.Ini.IniFile..ctor(:0) – Loading INI File C:\hyperspin133\RocketLauncher\Settings\Commodore 64\Pause.ini
DEBUG 2016-07-01 09:59:22 [1] RocketLauncher.UI.Ini.IniFile RocketLauncher.UI.Ini.IniFile..ctor(:0) – Loading INI File C:\hyperspin133\RocketLauncher\Settings\Commodore 64\Bezel.ini
DEBUG 2016-07-01 09:59:22 [1] RocketLauncher.UI.Ini.IniFile RocketLauncher.UI.Ini.IniFile..ctor(:0) – Loading INI File C:\hyperspin133\RocketLauncher\Settings\Commodore 64\Plugins.ini
DEBUG 2016-07-01 09:59:23 [5] RocketLauncher.UI.Ini.IniFile RocketLauncher.UI.Ini.IniFile..ctor(:0) – Loading INI File C:\hyperspin133\RocketLauncher\Settings\Global Emulators.ini
DEBUG 2016-07-01 09:59:24 [5] RocketLauncher.UI.Ini.IniFile RocketLauncher.UI.Ini.IniFile..ctor(:0) – Loading INI File C:\hyperspin133\RocketLauncher\Settings\Commodore 64\Emulators.ini
DEBUG 2016-07-01 09:59:24 [5] RocketLauncher.UI.Ini.IniFile RocketLauncher.UI.Ini.IniFile..ctor(:0) – Loading INI File C:\hyperspin133\RocketLauncher\Settings\Commodore 64\Games.ini
DEBUG 2016-07-01 09:59:45 [1] RocketLauncher.UI.Forms.BaseWindow RocketLauncher.UI.Forms.BaseWindow.TimerEventProcessor(:0) – RocketLauncher was closed, trying to reactivate RLUI window
